4 Best Off-Grid Power Stations for Remote Living
There are so many unique joys associated with living remotely. From quiet mornings to escape from the daily hustle and bustle, it’s no wonder that more people are choosing to live off-grid.
If you dream of joining the remote-living population, you are in luck. Technological advancements have made this lifestyle easier and helped ensure you don’t have to forgo any of your day-to-day needs.
While there are plenty of off-grid power stations on the market, we’ve helped to narrow your search with a simple breakdown of the best options for your specific needs. Let’s dive in.
EcoFlow’s Best Small Generators
  1. Best for Basic Home Backup: EcoFlow DELTA 2 Max
  2. Best Expandable Option: EcoFlow DELTA 3
  3. Best Affordable, Whole Home Backup: EcoFlow DELTA 3 Plus
  4. Best for Comprehensive Essential Backup: EcoFlow DELTA Pro 3
Whether your home is off the beaten path or in the center of a city, it’s important to have a backup plan ready in case the power goes out.
If you are looking for the perfect, multi-purpose backup power solution for the basic items throughout your home, look no further than the EcoFlow DELTA 2 Max. This compact yet mighty unit is strong enough to power most appliances and gadgets without all the common shortcomings associated with loud, noisy, and sometimes dangerous gas-powered generators.
With multiple charging options available, this unit is excellent for supplying power to your refrigerator, Wi-Fi router, phone, computer, or even smaller heaters and fans in a pinch.
No matter your reasons, this device is an excellent backup power solution for your home. It will help give you peace of mind and prevent you from relying on the grid directly for your power needs.
EcoFlow DELTA 2 Max Specifications
  • Storage Capacity (Minimum): 2048 Wh
  • Storage Capacity (Maximum): 6kWh
  • AC Output (Maximum): 2.4kW continuous output (3.4kW surge)
  • Solar Charge Capacity (Maximum): 11-60V 15A, single port 500W; dual port 1kW
  • Weight: 50.7 lbs  (23 kg)
  • Dimensions: 19.6 × 9.5 × 12 in (49.7 × 24.2 × 30.5 cm)
  • Operating Noise Level: ~50 decibels
  • Charging Options:  Solar/AC/Car Charger
  • Multicharge Options?  Yes
  • Battery Chemistry: Lithium Iron Phosphate (LFP/LiFePO4)
  • Cycle Life: 3000 Cycles to +/-80% Capacity
  • Depth of Discharge: 100%
  • Warranty: Five years (no cycle life restrictions)
  • App Monitoring and Control?: Yes
Pros
  • Easy to use and compatible with a large variety of devices.
  • Runs at a low decibel, making it a great option to use in or around your home.
  • Charges incredibly fast and reaches its max charging capacity in under an hour.
Cons
  • Presents a larger investment than smaller backup power systems.
  • Connecting solar charging solutions without any previous experience can be challenging. However, a quick search for a video tutorial can help.
Maybe you don't need a backup power unit for your home, but would rather have something with more diverse capabilities to bring along with you on your next remote adventure. If this aligns with your needs, the EcoFlow DELTA 3 is an ideal portable power station.
No matter where you plan to travel, there are plenty of expandable battery packs to add to the base power unit. The compact size and expandability options make this an amazing power unit to bring on the go and use in even the most remote destinations.
If you are an avid camper or RV traveler, you will quickly see the benefits of having this powerful power station at your disposal. With a faster solar-charging speed and numerous output options, you can quickly and efficiently access this reliable power source throughout your entire trip.
EcoFlow DELTA 3 Specifications
  • Storage Capacity (Minimum): 1024Wh
  • Storage Capacity (Maximum): 5kWh
  • AC Output (Minimum): 1800W total (X-Boost: 2200W, Surge 3600W)
  • Solar Charge Capacity (Maximum): 2 ports, DC Charge Input, 11V-60V 500W Max
  • Weight: 27.6 lbs (12.5 kg)
  • Dimensions: 15.7 x 8 x 11.2 in (39.8 x .20.2 x 283.6 cm)
  • Operating Noise Level: 600W<30db;1200W<40db
  • Charging Options: Solar/AC/Car/Smart Generator 3000 (Dual Fuel)
  • Multi-Charge Options? Yes
  • Cycle Life: 4000 Cycles to +/-80% Capacity
  • Depth of Discharge: 100%% %
  • App Monitoring and Control? Yes
Pros
  • Great for heavy-duty appliances with a heightened surge capacity.
  • Offers multiple charging options that can be used on the go.
  • Light and easy to transport from place to place.
Cons
  • Requires other connections in order to charge with solar capabilities.
  • While it’s a lightweight model, it may be difficult to carry for long periods of time.
Power stations can usually supply power to smaller devices, but what about a system strong enough to power an entire home? The EcoFlow DELTA 3 Plus is up to the challenge and is relatively affordable.
High performance, expandability, and user-friendly features are just some of the benefits of investing in this robust device. Designed to power an entire home, the EcoFlow DELTA 3 Plus is great for emergency preparedness and everyday use.
So, if you’re on a budget and have been searching for something that suits your needs and doesn’t break the bank, this is likely the best option.
EcoFlow DELTA 3 Plus Specifications
  • Weight: 27.6 lbs (13 kg)
  • Dimensions: 398×200×284 mm
Pros
  • This system runs very quietly, making it a great option to use indoors at your home.
  • Offering AC, solar, car, and generator charging methods, this unit is multipurpose and easy to use in various settings.
  • With the app integration, you can access and customize your device settings right from your phone.
Cons
  • While some portable generators offer built-in lighting, these units are not equipped with this feature.
Remote settings call for a robust system that can power up essential devices and maintain this supply of power for a seamless and functional living situation. Equipped with a large storage capacity and powerful energy output, the EcoFlow DELTA Pro 3 is an excellent option for off-the-grid living and can also easily function as a backup power system in your home.
This substantial power source is both versatile and an excellent investment for those looking for a device that can suit any future backup power needs. Whether you’re looking for something to power up your essential devices in a blackout or need a consistent stream of power in your off-the-grid living setup, this device is up for the challenge.
Investing in this powerful backup power system will give you autonomy and reduce reliance on the traditional grid for your power needs. You can take your life on the go wherever you please, and know that you have a reliable and consistent supply of power thanks to the EcoFlow DELTA Pro 3.
EcoFlow DELTA Pro 3 Specifications
  • Storage Capacity (Minimum): 4kWh per Battery. Up to 3 Batteries per DP3 (12kWh)
  • Storage Capacity (Maximum): 36kWh (Battery Storage) + 12kWh with a full Smart Generator 4000 (Dual Fuel) = 48kWh
  • AC Output (Minimum): 4kW (6kW X-Boost/8kW Surge) (120/240V)
  • AC Output (Maximum): Expandable to 8kW or 12kW by chaining 2 or 3 x DELTA Pro 3
  • Solar Charge Capacity (Maximum): 2600W Dual-PV Charging (150V) per DP3
  • Weight: 115 lbs (52kg)
  • Dimensions: 27.5 × 13.5 × 16 in (69.5 × 34 × 41 cm)
  • Operating Noise Level: 35 decibels
  • Charging Options: Smart Home Panel 2 (7200W) / AC (3600W) / Dual Solar Input (2600W) / EV Charging (4000W) / Gas Generator (3200W) / Alternator Charging / Car Adapter Charging
  • Multi-Charge Options? Yes - 18 Options
  • Cycle Life: 4000 Cycles to +/-80% Capacity (11+ years of regular use)
Pros
  • This device offers a massive power capacity and is great for extended trips off the grid.
  • Large appliances can easily be powered up with the high-energy output supplied by this device.
  • The rugged design is great for outdoor or indoor use and allows this device to be installed in a more permanent setting.
Cons
  • As a larger power system, it’s very heavy and can be difficult to move on your own. If you plan to invest in the EcoFlow DELTA Pro 3, it’s recommended that you have it semi-installed in your home or RV.
How To Choose an Off-Grid Power Station for Remote Living
If the idea of living remotely interests you, here are some important things to consider as you work on choosing the right off-grid power station for your specific needs.
Know Your Battery Capacity Needs
Backup power systems come in a variety of models, which is an important point to consider before making your purchase. If you only want a small backup power option for quick weekend trips, you won’t need to invest as much as if you’re looking for something to power your entire home.
The price of these items tends to vary based on battery capacity and a few other features, so be sure to know what you need before you buy.
Consider the Best Charging Options and Speed
Do you need your gadgets ready at the drop of a hat? Or, are you just looking for something to slowly but surely charge up your devices when you have some downtime?
Your answers to these questions will be very helpful in pointing you in the right direction. Also, ensure that your chosen device aligns with your charging needs. Solar, AC, EV, and car charging are included on some portable charging stations, but they’re not guaranteed to be on all of them. So, ensure you get exactly what you need from your chosen device.
Focus on Important Features
User-friendly features are important and can make or break your experience with portable chargers. Do plenty of research and find a device that offers features you will actually use to avoid paying for unnecessary extras.
What Is the Best Power Source for Off-Grid Living?
If you plan to live off the grid, you must have access to a reliable and consistent power source. For remote living, it’s strongly recommended to have a compact yet powerful unit, like the EcoFlow DELTA 3, for your lifestyle and needs.
How Big of a Power Station Do You Need for Remote Living?
Size and features are important to consider when choosing which power station is suitable for your remote lifestyle. It’s best to find a unit that is easy to transport but can still supply a strong and consistent power flow to the devices you need. When doing your research, make sure to take your output requirements and towing capabilities into account.
Going off-grid requires some forethought, especially when it comes to power. There are so many great portable power stations available for purchase, but some are better than others for your specific needs. If you’re keen on off-grid living, EcoFlow has a range of power solutions tailored to your lifestyle.
Don’t wait—EcoFlow’s DELTA Pro 3 is the best device for your essential backup needs. Visit the EcoFlow store today to get yours for any upcoming adventures off-grid, whether long-term or short.
Off-Grid Power
