Seattle Power Outage: How to Check the Map, Report It, and Prepare
Fall and winter windstorms in the Pacific Northwest can knock trees into power lines. When that happens, Seattle neighborhoods can lose electricity for hours or longer. The first questions are usually the same: How widespread is the outage? When will power return? And how do you report it? Seattle City Light, the city's publicly owned electric utility, provides an outage map and reporting line. This guide explains how to check outages, report power failures, stay safe around downed lines, and keep essential devices running during a Seattle power outage.
Seattle Power Outage: Check the Map and Report It
Seattle City Light serves Seattle and nearby communities in King County. Its online map shows reported outages and available restoration estimates. If your outage is not shown after about five minutes, call the utility to report it.
Power outage mapPower outage map
How to Check the Seattle City Light Outage Map
Checking your local status takes only a minute on your phone. Keep these essential map details in mind during a storm:
  • Live status updates: The Seattle City Light outage map at scl.datacapable.com/map refreshes every 5 minutes.
  • Coverage details: The tool shows estimated restoration times, affected customer counts, and crew status.
  • Underground network exception: The official outage page says the map excludes underground network distribution areas in downtown Seattle, First Hill, and the University District.
  • Outage alerts: Review the current alert eligibility and account settings. City Light is piloting text and email alerts for smaller outages; major outages and the downtown, First Hill, and University District underground networks are not yet covered.
If you live in a surrounding suburb, check your electricity bill to confirm your utility provider. Puget Sound Energy serves many communities in Western Washington. If PSE supplies your electricity, use the Puget Sound Energy outage map; otherwise, use your own electric utility's outage information.
How to Report an Outage
Do not assume your neighbors called it in. Reporting helps City Light identify an outage. Its restoration priorities put immediate life-safety hazards first, emergency services next, and then repairs that restore the largest number of customers.
  1. Visit the official Seattle City Light outages page.
  2. Call (206) 684-3000, labeled "Report an Outage" on its outage page.
  3. Have your City Light account number or the phone number associated with your account ready, and follow the reporting prompts.
  4. Note down your confirmation number if one is provided.
Managing routine home energy needs also helps you budget better year-round. Outage prep fits alongside knowing the average electric bill in Seattle before stormy weather hits.
Restoration times change quickly as line crews assess storm damage. Having your own backup system for essentials takes the pressure off your family.
Backup Power for Seattle Outages: Essentials First
Wind and falling trees or branches can damage Seattle power lines. Major storms can cause extended outages, so plan for phones, Wi-Fi routers, lights, and food storage. Set up your backup gear well before a storm arrives.
Seattle windstorms tend to arrive in fall and winter. The right time to set up backup power is before the next storm warning. EcoFlow portable power stations run indoors with zero emissions and recharge from standard wall outlets. Choose one unit based on what you need to keep running, rather than buying both by default.
A 1kWh-class unit can cover a modest combination of phones, a Wi-Fi router, and LED lamps, but the required capacity depends on total power use and outage duration. Use the illustrative runtime calculation below to plan, and place the unit on a dry, stable surface that supports its weight with room for ventilation.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
If you also want backup for a kitchen refrigerator or chest freezer, plan for a larger unit in advance. The EcoFlow DELTA 3800 Gen4 has 3,763Wh of capacity; check the appliance's 120V supply, running watts, and starting surge before connecting it. For expansion, use compatible extra batteries and the EcoFlow Smart Extra Battery Expansion Adapter. In ordinary operation, connected loads must stay within the unit's limits. Fridge Runtime Boost is different: use it with only one AC compressor-based cooling appliance and no other AC appliances.
•Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. •Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴ . •Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3-4kWh capacity and 3,600W output. •4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. • UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs.
Choosing the Right Unit for Your Home
Dividing your home electrical loads prevents overloading your power supply during an emergency:
  • EcoFlow DELTA 3 Classic: Best for running table lamps, charging family smartphones, and powering your home router.
  • EcoFlow DELTA 3800 Gen4: Consider it for a compatible 120V kitchen refrigerator or longer backup with compatible extra batteries. Check the appliance's running and starting requirements before use.
Check delivery timing before buying emergency equipment. As checked on November 11, 2026, the EcoFlow US listings show the EcoFlow DELTA 3000 Gen4 shipping in early December and the EcoFlow DELTA 3800 Gen4 in late November. These are shipping estimates, not guaranteed arrival dates; confirm the current schedule for your address. Do not rely on a new Gen4 order for an outage happening now.
Remember important operating limits during an emergency. Live grid restoration times always come directly from Seattle City Light. Battery backup supplies power to your router, but neighborhood internet lines may still lose signal. Calculate device starting and running watts carefully. Portable units cannot run every major appliance simultaneously. Always keep power stations dry and clear of wet weather.
Runtime Estimates
These are hypothetical sizing calculations, not measured runtimes or a guarantee for a particular appliance. Assume a full battery, no recharging, a constant average combined load of 40W or 78W, and an illustrative 85% usable-energy factor: 1,024Wh × 0.85 ≈ 870Wh and 3,763Wh × 0.85 ≈ 3,199Wh. Divide those assumed watt-hours by the assumed load to estimate hours. The 38W refrigerator average in the second example is an assumption, not an ENERGY STAR rating or a measured result for a named model. Actual runtime depends on inverter overhead, battery condition, temperature, refrigerator cycling, and usage; verify startup surge separately. These multi-device examples do not use Fridge Runtime Boost mode.
Household Load Scenario (Example)
Running Watts Used
EcoFlow DELTA 3 Classic (870Wh Usable Est.)
EcoFlow DELTA 3800 Gen4 (3,199Wh Usable Est.)
Wi-Fi Router + LED Lamps + Smartphone Charging
~40W
~22 Hours
~80 Hours
Hypothetical Fridge (assumed 38W average) + Router + Lamps (assumed 40W combined)
~78W
~11 Hours
~41 Hours
Renters in Seattle can look at apartment-friendly battery backup for quiet, indoor emergency power. Safety comes before comfort whenever severe weather downs electrical wires.
Downed Lines and Outage Safety
Pacific Northwest windstorms tear down mature Douglas fir branches and utility wires together. Never touch a fallen wire or anything touching it. Treat every downed electrical wire as fully energized and lethal.
Downed linesDowned lines
Critical Downed Line Rules
Follow these precautions if you see damaged lines in your street or alleyway:
  • Keep your distance: Seattle City Light advises everyone to stay at least 30 feet away and call 911 immediately.
  • Watch your surroundings: Look up for damaged tree branches dangling above overhead lines.
  • Stay in your vehicle: If a wire falls on your car, stay inside until emergency crews arrive.
  • Keep pets clear: Keep dogs on short leashes away from puddles, fences, and metal railings near lines.
Safe Generator and Food Storage Rules
Carbon monoxide poisoning causes severe illness and death during winter power failures. Combustion generators and grills bring the hidden dangers of carbon monoxide indoors if used improperly.
  • Outdoor use only: The CDC says never to run a fuel generator inside your home, basement, or garage, even with doors or windows open.
  • Exhaust clearance: Operate fuel generators outdoors, more than 20 feet from any windows, doors, and vents, with exhaust directed away from buildings. Use battery-operated or battery-backup CO detectors in the home.
  • Food safety windows: FoodSafety.gov says a closed refrigerator keeps food safe for up to 4 hours without power. Discard refrigerated perishables after that unless they have been kept at 40°F (4°C) or below; never taste food to test its safety.
  • Freezer limits: With the door closed, a full freezer holds a safe temperature for approximately 48 hours, or 24 hours if half full. Check for ice crystals or a food temperature of 40°F (4°C) or below before refreezing.
A little advance prep before storm season arrives makes unexpected blackouts much easier to manage.
How to Prepare for a Seattle Power Outage
Preparation begins weeks before winter storm watches hit Puget Sound. Charge your portable electronics, verify emergency lighting, and check utility contact numbers.
Outage preparationOutage preparation
Step-by-Step Outage Preparation
  1. Check utility alert settings: Keep the mobile number and email in your City Light account current and review pilot coverage and notification preferences. Do not rely on pilot alerts for major storms or the excluded underground networks.
  2. Monitor local forecasts: Check the National Weather Service Seattle page for upcoming wind advisories and high wind warnings.
  3. Assemble lighting supplies: Place bright LED flashlights and spare alkaline batteries in every bedroom and the main hallway.
  4. Stock emergency water and food: Store a three-day supply of drinking water and shelf-stable foods that need no cooking.
  5. Protect home electronics: Plug sensitive computers and entertainment systems into certified surge protectors.
  6. Plan for critical medical gear: If someone relies on an oxygen concentrator, CPAP machine, or other powered medical device, arrange backup with the healthcare provider and device manufacturer. Review City Light's Life Support Equipment guidance. A portable power station recommendation is not a substitute for a device-specific plan.
Seattle homes can follow the basics of preparing for a winter power outage to stay warm, connected, and safe.
When a Seattle power outage strikes, check the Seattle City Light outage map, which updates every five minutes. If your outage is missing after about five minutes, call (206) 684-3000 with your account number or associated phone number ready. Stay at least 30 feet from downed power lines and call 911. Check current alert eligibility, keep emergency supplies ready, and leave the refrigerator closed to help protect perishable food.
For reliable home backup without toxic gas fumes, consider an EcoFlow portable power station. The compact EcoFlow DELTA 3 Classic easily handles lights, phones, and your router during quick neighborhood outages. For extended winter blackouts, the EcoFlow DELTA 3800 Gen4 delivers 3.7kWh of expandable power to keep your refrigerator running smoothly. Order your unit ahead of storm season so your household stays comfortable when high winds arrive.
How do I check a Seattle power outage?
Visit the Seattle City Light outage page and map for reported outages, affected customer counts, available restoration estimates, and event status. Information updates every five minutes, but may be delayed during major events. The map excludes underground network distribution areas in downtown Seattle, First Hill, and the University District.
How do I report a power outage in Seattle?
Call Seattle City Light at (206) 684-3000 to report an outage. Have your City Light account number or the phone number associated with your account ready. Checking your service address in your online account does not itself submit an outage report.
What should I do about a downed power line?
Always treat downed lines as live, energized, and extremely dangerous. Stay at least 30 feet away immediately, keep pets and others clear of the area, and dial 911 right away for emergency dispatch.
Why isn't my downtown outage on the map?
The official outage page excludes underground network distribution areas in downtown Seattle, First Hill, and the University District from the map. This exception does not apply to every underground line in the service area. Call (206) 684-3000 to report an outage that is not shown.
How long can food stay safe in an outage?
According to FoodSafety.gov, food stays safe inside a closed refrigerator for up to four hours. A full, unopened freezer maintains safe temperatures for approximately 48 hours, or 24 hours if half full.
Power Outages
