Best Electric Blankets: What to Compare Before You Buy
A good electric blanket can make a cold bedroom bearable without turning up the thermostat for the whole house. But the best electric blankets for you depend on what you need. Couples may want two controls. Light sleepers may want a long timer, while others want a short auto-off. And every buyer should look for a safety listing, because federal regulators recalled or warned about several heated blankets in 2025 and 2026. This guide covers the features worth paying for, the safety checks that matter, and how to keep a blanket usable when winter storms knock out power.
Six Features to Compare on Any Electric Blanket
Most electric blankets look alike in photos, so the differences hide in the controller and care label. To find the best heated blanket for your bed, compare six features, then confirm figures in the manual.
  • Heat settings: from 4 on some throws to 10 on some bed blankets
  • Timer or auto shut-off: from 4 hours up to 12
  • Single or dual controls: dual zones let each side set its own heat
  • Overheat protection: count it only when the maker lists it
  • Safety listing: a UL, ETL, or CSA mark
  • Warranty: if none is listed, treat it as unknown
Three Listings Compared
Good heating blankets share these basics, but details differ. Here are three listings as examples, not a ranking.
Model (maker page, checked Oct 28, 2026)
Size listed
Heat levels
Timer / auto-off
Controls
Listing on page
Warranty on page
Westinghouse Electric Heated Flannel Blanket
Queen 84" x 90"
10
1 to 12 hours
Dual zone, wireless
ETL, FCC
5 years
Westinghouse Electric Heated Sherpa Plaid Blanket
84" x 90"
6
2 to 10 hours
Single
Not stated
5 years
Brookstone Cozy Heated Plush Throw
50" x 60"
4
4-hour auto shut off
Single
ETL
Not listed
None of these pages lists wattage, so check the label. A quick look at electric blanket power use and cost helps you compare a few dozen watts against a space heater's draw.
Features decide comfort. A safety listing and a clean recall history decide whether the blanket belongs on your bed at all.
Safety Marks, Recalls, and Who Should Skip Heated Bedding
A low price means little if the wiring overheats. In 2025 and 2026, the US Consumer Product Safety Commission (CPSC) announced recalls and a warning for heated blankets sold online, so checking recalls is part of shopping.
What the Listing Marks Mean
UL 964 is the standard for "Electrically Heated Bedding" used on 110 to 120V household circuits. UL, Intertek (the ETL mark), and CSA Group all appear on OSHA's list of Nationally Recognized Testing Laboratories, so any of those marks means a recognized lab certified the product. No one mark is safer than another. The Maine fire marshal's blanket tips put it simply: "Only use electric blankets that have been approved by nationally recognized testing agencies."
Recent Recalls Worth Knowing
A top rated electric blanket online isn't proof of safety. The largest recent case covered about 195,000 units, and the full JKMAX recall notice lists the affected products.
Date
Product
Units
Hazard (CPSC wording, paraphrased)
Remedy
Sept 17, 2026 (Recall 26-778)
JKMAX heated blankets and heating pads, sold on Amazon Sept 2022 to July 2026
About 195,000
Internal heating wires can overheat; 577 reports of smoking, melting, or burning, 53 burn injuries
Stop using; refund
July 30, 2026 (Recall 26-652)
OCTROT heated Sherpa throws and blankets, sold on Amazon Aug 2021 to Dec 2025
About 178,000
Cord can detach and ignite; 555 reports, 27 fires, 15 burn or shock injuries
Stop using; refund
July 16, 2026 (Warning 26-616)
Melinora electric heated blankets, sold on Amazon Feb to Oct 2025
About 700
Heating wires can overheat and melt through fabric; 5 reports, 1 burn injury
CPSC warns consumers to stop using
June 18, 2025 (Recall 25-351)
MaxKare electric blankets (made by Yumo), sold on Walmart.com June 2021 to Nov 2024
About 8,560
Can overheat and ignite; 34 overheating reports, 3 burn injuries
Stop using; refund after disposal
Before buying or reusing a blanket, search the CPSC recalls and warnings page by product category. A brand missing here hasn't necessarily been cleared.
Who Should Skip or Limit Use
UL says electric blankets are "not recommended for infants, young children or anyone who is paralyzed," or anyone who can't use the controls safely, and advises keeping pets away. The Maine fire marshal says people with diabetes shouldn't sleep with one on but can preheat the bed, then switch it off and unplug it. People who are incontinent shouldn't use one, since wet wiring can malfunction.
Checking cords and outlets is part of preventing cold-weather electrical fires. Next comes a bigger question: what happens when a winter storm cuts the power?
Planning Backup Power for an Electric Blanket in a Winter Outage
An electric blanket stops when the power drops, exactly when a cold bedroom matters most. Since it draws far less than a space heater, a power station can run one for a useful stretch.
Staying Comfortable Through Cold NightsStaying Comfortable Through Cold Nights
Layers First, Then Label Wattage
Start with layers that need no power. The CDC's power outage guidance lists "extra blankets, sleeping bags, and warm winter coats," so treat a powered blanket as an add-on. It also says never to run a generator inside your home, basement, or garage, or within 20 feet of a window, door, or vent, while a battery unit can sit indoors.
A Utah state appliance wattage chart citing EPA lists about 60 watts for a single blanket and 100 for a double, versus 750 to 1,500 for a portable heater. Treat 100W as a planning figure and swap in your label rating. By our estimate, a 1,024Wh station runs a 1,500W heater for 1,024Wh × 0.85 ÷ 1,500W ≈ 0.58 hours, about 35 minutes, so a blanket is the realistic load.
Runtime Estimates
We assume usable energy is capacity × 0.85 for conversion losses, with the blanket's label wattage as the load. These are estimates, not promises.
Setup
Calculation
Estimate
EcoFlow DELTA 3 Classic, one 100W double blanket
1,024Wh × 0.85 = 870Wh; 870 ÷ 100W
About 8.7 hours of continuous draw at the full label rating
Same, used for 30-minute preheats
100W × 0.5 hr = 50Wh per preheat; 870 ÷ 50
About 17 preheat sessions
EcoFlow DELTA 3 Max, two 100W double blankets
2,048Wh × 0.85 = 1,741Wh; 1,741 ÷ 200W
Same, both blankets on 30-minute preheats
200W × 0.5 hr = 100Wh per round; 1,741 ÷ 100
About 17 preheat rounds
A phone, lamp, or router cuts these numbers, so add its wattage to the load. Continuous draw is a ceiling, not a sleep plan; UL suggests warming the bed for about half an hour, then switching off before sleep.
Two EcoFlow Options for Blanket Backup
In a cold-snap outage, a quiet battery unit by the bed can keep a listed blanket and a phone going for a planned stretch. EcoFlow builds portable power stations that charge from a wall outlet or solar panels, so they're ready before the next storm. Here are two sizes that suit blanket backup.
For one blanket and a phone on one side of the bed, the smaller unit keeps things simple. EcoFlow calls the EcoFlow DELTA 3 Classic lightweight and easy to carry, which helps if the bedroom is upstairs.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
For two sleepers, or a lamp or router too, a larger battery leaves room for a second blanket. That's the job the EcoFlow DELTA 3 Max is sized for.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
With either unit, check the blanket's label wattage, your planned use time, and the station's output limit, and follow the blanket manual for cords. Matching capacity to label wattage is the heart of choosing a battery for electric blankets. Backup is also easier to size when the blanket fits the bed properly.
Matching Blanket Size and Controls to Your Bed
Blanket sizes aren't standardized, so read the dimensions, not just the label. Controls matter too when two sleepers disagree on temperature.
Reading Blanket Dimensions
Westinghouse lists its Sherpa Plaid in sizes from 50" x 60" up to 100" x 90", and its Flannel page calls 84" x 90" a Queen. Compare them with your mattress and preferred drape. If you want the best heated throw blanket for the couch, the 50" x 60" Brookstone with its 4-hour shut off fits that role, while a bed blanket suits sleeping.
Dual Controls and Safe Cord Placement
For couples, a good heated blanket with dual zones, like the Westinghouse Flannel, lets each partner set their own heat. UL and the Maine fire marshal say never to run cords under rugs or staple them, and UL rules out sofa beds, pullouts, and adjustable beds. Before checkout, confirm:
  • Mattress size and depth
  • Preferred drape
  • One control or two
  • Timer length
  • Cord length to the nearest outlet
Full coverage is the first step in using electric blankets more efficiently. After that, safety comes down to washing, storage, and replacement.
Washing, Storing, and Knowing When to Replace It
Most electric blankets are washable once the controller is disconnected. Storage matters too, since folding can damage the wires.
Keeping Electric Blankets in Good ConditionKeeping Electric Blankets in Good Condition
Care and Storage Tips
Westinghouse says to "pull out the controller plug" before machine washing its Flannel blanket and calls its Sherpa Plaid "dryer safe," while Brookstone lists its throw as "Machine wash and dryer safe." UL says to store a blanket "by rolling, not folding, it." The Maine fire marshal adds: no blankets on top, no heating pad with it, and unplug it when idle.
When to Replace Your Blanket
Even the best heating blanket wears out, so check for "worn areas, loose plugs or other damage" and replace an old or damaged one. UL warns against buying secondhand, noting bedding made since the late 1980s gives off much less heat. Replacing an old blanket fits with other budget ways to stay warm without heating every room.
The best heated blankets balance heat levels, a usable timer, the right size, easy washing, and a recognized safety listing, plus a CPSC recall check. Read the label wattage first, then preheat and switch off rather than sleeping with it on high. If winter outages are common where you live, compare the EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max on the EcoFlow US site to keep a listed blanket usable for a planned stretch.
What should I look for in a good electric blanket?
Look for a UL, ETL, or CSA mark, an auto-off timer, enough heat settings, and dimensions that fit your mattress. Couples often prefer dual controls, and a detachable controller eases washing.
Are cheap electric blankets sold online safe?
Price alone won't tell you. Several blankets recalled or flagged by CPSC in 2025 and 2026 were sold on Amazon and Walmart.com, so look for a listing mark and search CPSC's recalls first.
Should I leave an electric blanket on all night?
Safety groups advise against it. UL suggests warming the bed, then switching the blanket off before you fall asleep, and your manual has the final word.
How many watts does an electric blanket use?
It varies by model, so check the label or controller. As a rough guide, a Utah state chart citing EPA lists about 60 watts for a single and 100 watts for a double.
Can a portable power station run an electric blanket during an outage?
Yes, within its limits and for a planned stretch. A 1,024Wh unit like the EcoFlow DELTA 3 Classic suits one listed blanket, and runtime depends on its label wattage and anything else plugged in.
Tips
