How Much Is the Average Electric Bill in the US & How to Save?
- What Is the Average Electric Bill in the United States?
- Regional Breakdown: How Much Are Electric Bills on Average by State?
- Key Drivers Behind High Monthly Electricity Bills
- Practical Strategies to Lower Your Monthly Electric Bill
- How EcoFlow Home Battery Storage Slashes Your Monthly Electric Bill
- Conclusion
- FAQs
Utility rates have been creeping up across the country for years, and most households notice it the same way: the bill arrives, the number looks a little higher than last month, and nothing about daily habits has really changed. Between seasonal spikes in summer cooling and winter heating, plus regional swings in how power gets priced, it's fair to wonder how your own bill stacks up. This guide breaks down how much the average electric bill in the US actually is, what pushes it higher in some states than others, and what you can do about it.
National Benchmark Overview Based on EIA utility data, the average American household spends roughly $140 to $150 a month on electricity, tied to typical usage of about 880 to 900 kWh per month. That number moves around a lot depending on home size, climate, and how many people live under one roof, but it's a useful baseline for comparing your own bill against.
How Monthly Bills Are Calculated A power bill isn't just usage times a flat rate. It's built from several layers: the per-kWh electricity rate itself, a base utility connection fee that shows up whether you use much power or not, delivery and transmission surcharges, and local municipal taxes. Two households using the exact same amount of electricity can still end up with different totals once these extra line items are factored in.
Understanding Regional Cost Disparities Rates vary this much across states for a few concrete reasons: how the local grid generates power (natural gas, hydro, and nuclear all carry different costs), how extreme the regional climate is, and how much a utility has recently invested in infrastructure upgrades. A state leaning on cheap hydropower will look very different on paper than one rebuilding wildfire-hardened transmission lines.
Knowing what goes into a bill nationally is only half the picture. The more useful question for most readers is how their own state or region compares, since the swings from one part of the country to another can be dramatic.
High-Cost States (California, Hawaii, the Northeast) These states combine steep per-kWh rates, often $0.25 to $0.40 or more, with aging infrastructure and, in California's case, wildfire-mitigation costs baked into delivery charges. Even modest usage can produce a bill that dwarfs the national average.
High-Consumption States (Texas, Florida, the Southeast) Here, the story flips. Rates per kWh are often closer to the national middle, but months of continuous air conditioning during long, humid summers push total consumption, and therefore the total bill, well above average.
Low-Cost States (Utah, Idaho, Washington) States with access to abundant hydroelectric power and milder year-round climates tend to post some of the lowest average bills in the country, since neither the rate nor the consumption side of the equation is working against residents.
If you want a closer look at how your own state compares, EcoFlow's state-by-state electricity cost breakdown walks through current averages region by region.
Where you live sets the baseline, but it doesn't explain everything about why a bill spikes month to month. That comes down to a handful of specific cost drivers inside the home itself.
.png)
.png)
Time-of-Use (TOU) Rates & Peak Hours: Many utilities now charge more for electricity used during high-demand windows, typically late afternoon into evening, when everyone gets home and turns on the AC, the oven, and the EV charger at once. Running the same appliances an hour or two earlier or later can measurably change what that usage costs. EcoFlow's guide to peak electricity hours by state breaks down when those windows fall across different utility territories.
HVAC and High-Wattage Household Appliances: Central air conditioning, electric heat pumps, water heaters, clothes dryers, and EV chargers are consistently the biggest line items on a power bill. Space conditioning alone accounts for a large share of most households' total usage, especially in climates with long cooling or heating seasons.
Inconsistent Insulation and Phantom Loads: Poor thermal sealing forces HVAC systems to work harder than they should, and standby power draw from devices that are technically "off" but still plugged in adds up quietly in the background. Neither shows up as a single dramatic line item, but together they can inflate a bill by a meaningful percentage every month. EcoFlow's explainer on phantom power covers which devices are the worst offenders.
Once you know what's driving the number up, the next step is doing something about it, starting with the changes that cost the least and working up from there.
Peak Shaving and Time-of-Use Management: Shifting heavy appliance use away from peak utility hours is one of the simplest ways to cut costs without changing how much electricity you actually use. Running the dishwasher or the dryer overnight instead of at 6 p.m. can make a real difference on a TOU rate plan.
Upgrading to High-Efficiency Home Systems: Smart thermostats, LED lighting, and ENERGY STAR-rated appliances reduce baseline consumption steadily over time. None of these changes are dramatic on their own, but they compound month after month.
Transitioning to Solar Energy Storage: Generating and storing your own solar power reduces how much you rely on the grid in the first place, and it sidesteps expensive peak-rate charges entirely for the hours you're running on stored power instead. EcoFlow's broader energy optimization guide covers how to combine these strategies into a single plan.
Efficiency habits and rate-timing tricks help at the margins, but the biggest structural change most households can make is adding home battery storage that actively manages when and how power gets pulled from the grid.
Traditional energy conservation, like adjusting the thermostat a couple of degrees, helps reduce total kWh usage. But utility rate structures like Time-of-Use pricing and peak demand charges can keep a bill unnecessarily high even when consumption drops. EcoFlow home battery systems work differently: they store power when grid rates are lowest, or generate free power through solar panels, and discharge that stored energy during expensive peak hours instead. Shifting your power source away from peak-rate windows lowers your household energy costs while also giving you complete blackout backup if the grid goes down.
EcoFlow DELTA Pro Ultra X
For households in the ≥ 4 kWh whole-home backup tier, the EcoFlow DELTA Pro Ultra X is built for comprehensive load coverage rather than just keeping a few essentials running, automating Time-of-Use peak shaving on its own instead of requiring you to manually track rate windows.
EcoFlow DELTA Pro 3
Also sized for the ≥ 4 kWh whole-home tier, the EcoFlow DELTA Pro 3 offers a bit more flexibility for households that want room to grow.
EcoFlow DELTA 3 Ultra (3072Wh)
Not every household needs full whole-home coverage, and that's where the EcoFlow DELTA 3 Ultra fits in.
Whichever tier fits your household best, the underlying math is the same: less reliance on peak-rate grid power means a lower bill every month, not just during outages. Actual monthly savings will vary based on local utility rates, TOU plan structure, and individual household energy consumption patterns.
Understanding what the average electric bill is gives you a real benchmark for judging whether your own household is paying more than it should, and why. Protect your household from rising utility rates by combining smarter usage habits with a home battery system that generates and stores clean, localized power. Compare your monthly bill against the benchmarks above, then take a look at which EcoFlow whole-home battery fits your household's size and backup needs. Explore the DELTA Pro Ultra X and DELTA Pro 3 product pages to find the right fit for your home.
How much is the average electric bill per month in the US?
Most US households pay between $140 and $150 a month, based on average usage of roughly 880 to 900 kWh, though this varies significantly by state and season.
Why is my electricity bill so high compared to the average?
Common causes include Time-of-Use peak pricing, an inefficient HVAC system, poor insulation, and phantom loads from devices left plugged in around the clock.
Which appliances contribute the most to an average electric bill?
Central air conditioning, water heaters, electric heat pumps, clothes dryers, and EV chargers are typically the largest contributors to a household's monthly usage.
How can a home battery storage system reduce my monthly electric bill?
A system like the EcoFlow DELTA Pro Ultra X stores low-cost, off-peak or solar power and discharges it during expensive peak hours, cutting your reliance on the grid's highest-priced electricity.
What is Time-of-Use (TOU) pricing and how does it affect my bill?
TOU pricing charges more for electricity used during high-demand hours, usually late afternoon into evening. Shifting heavy appliance use outside that window can noticeably lower your total cost.
