UK Washing Machine Running Costs in 2026: How Much Does It Cost Per Wash?
The rise in energy prices and washing machines running costs will have a significant impact on how much the average household spends on electricity to use washing machines over the course of 2026. The amount of electricity consumed by washing machines during a month can also contribute significantly to your electricity usage.
Families can save money on their monthly electricity bill and increase their energy efficiency by understanding the costs of running a washing machine.
As Americans look for ways to lower their electric bill, energy storage systems are becoming more popular with homeowners because they allow owners to be able to store and manage their energy usage for daily purposes with common appliances such as washing machines.
1. Introduction: UK Washing Machine Running Costs in 2026
In 2026, UK homeowners are continuing to be concerned with the costs of electricity. Large energy rates, peak period rates and increased appliance usage are all contributing factors to increasing monthly utility expenses. Although washing machines are essential appliances, when used several times per week, they can become quite costly on a monthly basis.
Why electricity prices are increasing
Electricity costs are escalating for several reasons in the UK:
  • Increasing wholesale energy prices
  • Electrical grid improvements and infrastructure expenditures
  • Increased demand for electricity during the winter months
  • Utility costs rising due to inflation
  • Increasing reliance on the use of electrical appliances by the average household
Because of the increasing cost of electricity, a growing number of families in the UK are now monitoring how much it costs them to operate their washing machines more than they ever have before.
Understanding the real cost of running a washing machine
There is no one answer to what the true cost of running a washing machine is. The true average cost of running a washing machine will be different for each person and will depend on several things including:
  • Energy rating of the appliance
  • Temperature of the wash
  • Size of the load
  • How often do you do laundry
  • Rate that you pay for electricity
A washing machine that is operated several times per week on hot water with an older model washing machine will incur much higher annual energy charges than a newer energy efficient model.
2. How Much Does It Cost to Run a Washing Machine Per Wash?
Knowing precisely how much it costs to run a washing machine per load in the UK will help people to budget more accurately for the washing machine.
Average UK electricity usage
Most modern washing machines have a range of between 0.5 kWh and 1.5 kWh per cycle, depending upon:
  • Water temperature
  • Spin speed
  • Time of cycle
  • Efficiency of machine
With the average cost of electricity in the UK in 2026, being between £0.24 to £0.34 per kWh, normal washing costs.
Wash Type
Estimated cost per Load
Eco wash
£0.12 - £0.20
Standard wash
£0.20 - £0.35
Hot wash
£0.35 - £0.55
Note: Hot wash costs are estimated using current UK electricity unit rates set under the Ofgem energy price cap, where higher-temperature cycles consume more energy for water heating. Electricity rates may vary by region and tariff type
How much does it cost to run a washing machine
There is an estimated broad variation in costs according to washing habits and electricity tariffs. Extimated running 4–6 loads a week on average:
  • Cost Per Week: £1.20 - £3.00
  • Cost Per Month: £5 - £12
  • Cost Per Year: £60 - £145
The average UK electricity cost estimation is based on 24p-34p per kWh and assuming total energy consumption of 0.5-1.5 kWh per washing machine cycle. Actual washing costs depend on how efficient your appliance is, how warm the water is, how big the drum is and what local rates you pay for your electricity.
Note: The washing machine running cost estimates above are based on average UK household electricity rates in 2026, which are approximately 24p–34p per kWh depending on the region and tariff type. Electricity prices may change over time, so always check the latest updates on the official UK energy regulator website.
A household that uses a lot of hot washes or has older appliances will likely see higher energy usage and thus higher costs than a household using cold or moderate wash settings or newer washing machines.
Cost of running a washing machine per load UK
Due to energy inflation, the average cost of running a washing machine per load in the UK is higher than it was previously. The most affordable way to save electricity is by using eco modes and lower temperature washe
3. Washing Machine Running Cost Calculator: Estimate Your Laundry Expenses
You can use a straightforward calculation to estimate how much energy your clothes washing will use.
Cost (amount of electricity you will pay for using your washing machine) - Formula for simple cost.
Simple cost formula explained
The following formula will allow you to calculate your costs using the calculator cost of running a washing machine per load:
Appliance's Kwh × Price Per Kwh = Cost To Wash
For example -
The washing machine uses 1.0 Kwh
Price of electricity per Kwh at the moment: 28 pence
1×0.28=0.28
Thus, you are looking at paying £0.28 per wash.
Washing machine running cost calculator
Estimating monthly expenses is as follows:
  1. Determine the kilowatt-hour (kWh) usage of your washing machine.
  2. Multiply that figure by the cost of electricity.
  3. Then multiply that price by how often you use it each week.
Example:
5 loads a week x £0.28 (for each load) = Total Annual Cost
(5x0.28x52) = £72.80
Total Cost over the Course of a Year = £72.80
Cost of running the washing machine
How much does it costs to run a washing machine can greatly depend on how and how often you use the machine. Although one load of laundry may seem cheap today, the many loads over the course of an entire year can have a huge impact on your yearly electric bill.
The biggest impact on cost is due to hot washes because of the amount of energy required to heat large volumes of water. Hot, warm, and cold wash cycles vary significantly in their energy consumption; with hot cycles requiring many more kilowatt hours than do cold or 30°C eco cycles.
The following are other examples of inefficient usage patterns contributing to excessive energy consumption and increased cost:
Running multiple small loads rather than one full load (even though a washing machine uses relatively the same amount of energy no matter how full it is).
Using old and/or poorly rated energy-efficient washers (typically rated less than A).
These, and other, inefficient usage patterns can result in your average annual cost to run your washing machine being up to 30% -60% higher compared to optimized usage.
By making an effort to do the following, your household can work to lower your overall annual electricity costs associated with using your washing machine:
  • Utilize your machine's eco or 30°C cycle options as often as possible
  • Always wash a full load whenever possible
  • Consider upgrading to a more energy-efficient washing machine.
4. What Increases the Cost of Running a Washing Machine?
You may not realize this, but there are several factors that can significantly increase your long-term laundry costs. So aware of these factors, you can manage your cost per wash and eventually reduce your total electricity usage over time.
Hot washes vs eco cycles
Water heating uses a large portion of the energy required to complete a wash cycle. Therefore, as the temperature increases, the amount of electricity consumed by your washing machine also increases.
Examples of energy usage when performing various types of washes.
  • Eco Wash (20 - 30 degrees Celsius) - The least amount of energy is consumed while allowing you to do laundry on a daily basis.
  • Washing Machine Between 40 Degrees Celsius and 60 Degrees Celsius - This temperature is good for mixed wash loads and provides adequate cleaning.
  • 60 Degrees + Wash - This washing temperature has high energy consumption and is used for cleaning heavily soiled items or for hygiene reasons.
Although eco cycles may take slightly longer to complete than traditional hot washes, an eco cycle's total energy consumption is generally reduced by 30 - 40 percent compared to a traditional hot wash; therefore, eco cycles are the most economical of the three.
Load size and spin speed
The way you load the washing machine greatly impacts how efficient it will be at washing and drying your clothes.
  1. Half loads waste energy because the washing machine will run an entire wash cycle regardless of how full the drum is.
  2. Full loads of washing maximize efficiency and minimize the number of times per week that the washing machine needs to be cycled.
The spin speed also affects the efficiency of washing clothes:
  • Higher spin speeds extract more water from clothes, which will reduce the amount of time needed to dry clothes.
  • However, if the spin speed used is excessively high, it may slightly increase the amount of energy required to run the washing machine during the wash cycle.
  • By identifying a spin speed that provides a balanced end result, you can optimize your washing and drying costs.
Old vs energy-efficient models
The energy rating and the age of your washing machine impact your overall electric bill.
Older models include:
  • A higher cost of consumption per load
  • Limitations to smart usage and load detection
  • Higher water usage and longer running times
Newer or smart models include:
  • Automated adjustments in both water usage and energy consumption
  • Efficient inverter motors
  • Eco Load Sensors
  • Significant overall reductions to electricity consumption
If you upgrade an older unit, you may reduce your cost of running a washing machine considerably over time.
Washing machine costs are affected by user habits as well as the machine's features.
When you:
  • Wash heavy items frequently (jeans, towels, and bedding)
  • Use multiple rinse cycles
  • Use lengthy cycles
  • Don't keep up with maintenance (dirty filters), the machine operates less efficiently
These little things all add up over weeks and months, increasing the cost of running a washing machine per load in the UK.
5. Best Ways to Reduce Washing Machine Electricity Costs in the UK
You can save money doing your laundry without making big changes to the way you live.
Energy-saving laundry tips
These are the best energy-saving tips for your laundry:
  1. Wash your clothes at 30C, if possible.
  2. Use eco settings whenever possible.
  3. Don't overload your washing machine.
  4. Only run full loads of washing.
  5. Clean your washer filter regularly.
Off-peak electricity usage
The electricity suppliers in the UK provide lower tariffs for using the washing machine during the off-peak times, which are typically nighttime or early morning hours when there is less demand for electricity. Therefore, if you use your washing machine at those times, the amount of money you will spend on electricity to wash clothes will be significantly reduced. And not changing your existing usage practices.
Off-peak tariffs can often be 20%-50% lower than peak times, having the benefit of allowing you to manage your electricity accounts to a more satisfactory level. Utilizing the delay start option allows you to use your washing machine at times that are most expensive. This is best suited for your needs resulting in the effective use of both your washing machine running costs to maintain systems and washtime management wiring.
Smart home energy management
Newer battery storage systems allow homeowners to charge up their batteries when electricity is cheaper and use battery power for various appliances afterwards. For energy savvy customers, this is generally where the EcoFlow STREAM Series product can be very beneficial.
Best EcoFlow STREAM Series Solutions for Reducing UK Energy Costs
Smart home energy storage will continue to be of great importance because of the rising cost of electric power in the United Kingdom.
EcoFlow STREAM Ultra X Home Solar Battery
The EcoFlow STREAM Ultra X Home Solar Battery allows households to store solar energy and lessen reliance on costly grid-based electricity. It is made to maximize the effectiveness of household energy use and provides support for appliances such as washers during times of peak electrical pricing.
Save up to £1,729 annually on electricity bills Up to 2300W AC output for high-demand appliances Expandable storage from 3.84kWh to 23kWh 2000W solar input with 4 MPPTs for higher efficiency Long-lasting 15-year lifespan design Easy plug-and-play installation (no electrician required) Smart compatibility with Matter, Tiber & Shelly systems
Key Benefits:
  • Smart storage of electric power
  • Electricity optimisation through artificial intelligence
  • Reduced reliance on the grid
  • Back-up power supply for critical appliances
EcoFLow STREAM All-in-One Home Storage Kit
The EcoFlow STREAM Home Storage All in One Kit brings solar energy and smart energy management into one simple solution. This bundle includes:
  • 1 × STREAM Ultra X (3.84kWh), which is the primary inverter and battery unit
  • 2 × STREAM Pro, which are additional storage expansion batteries
  • 2 × FREE Parallel Cables, which provide seamless parallel connection
EcoFlow STREAM All-in-One Home Storage Kit
Integrated solar + battery + inverter system for complete home energy control Smart energy storage with automatic solar prioritization Supports high solar input (up to 2000W class system performance) Modular design for scalable home energy expansion Works with EcoFlow STREAM ecosystem for smart energy balancing Designed for whole-home backup and self-consumption optimization App-controlled energy monitoring and scheduling
Key benefits:
  • Energy-conscious homes in the UK
  • Reducing the cost of electricity when using appliances
  • Controlling peak hour energy use
  • Helping with smart home systems
How the STREAM Series helps power home appliances efficiently
The STREAM Series can store energy for later use, depending on how much it is charged. For example, if solar energy is plentiful, you can use it to run major home appliances like:
  • Washer and dryer
  • Refrigerator
  • Television
  • Computer/office equipment
By using alternative energy methods, you are reducing your overall electricity costs.
Smart solar storage and AI energy management features
You can also reduce your monthly utility bill significantly as long as energy prices continue to increase in the UK.
  1. As part of home energy storage systems, smart batteries can be used to monitor the balance of electricity supplied to the home by the grid with any surplus generated by the home itself.
  2. This data provides a real-time picture of your household's daily electricity consumption for all of your individual appliances.
  3. Smart battery systems also help highlight which appliances can operate efficiently at certain times of the day.
  4. Optimising the data from smart battery systems can greatly enhance the efficiency of solar power production and use.
  5. The enhanced co-ordination between solar panels and household appliances results in a considerable decrease in wasted energy.
With the time being, as energy prices increase in the UK, smart battery systems will make substantial savings on monthly utility bills.
Conclusion: How to Keep Your Washing Machine Running Costs Low in 2026
The average cost of washing machines in the UK varies according to how energy-efficient your appliance is, what you pay for electricity and how you typically use the washing machine. Although one cycle's cost per wash may seem like a low amount of money, the total throughout 12 months can really add up.
Using eco cycles, washing at lower temperatures and choosing to wash at off-peak times can considerably reduce your overall electricity use when running your washing machines.
Choosing to invest in a smarter home energy solutions such as EcoFlow STREAM Series may help families manage increasing electricity costs more effectively in 2026 and beyond.
Frequently Asked Questions (FAQs)
How much does a washing machine cost to run
In the UK, the average electricity cost to run a washing machine varies significantly by the electrical cost, the temperature setting of the wash, and how efficient the appliance is. UK homes generally use between £60-£145 worth of electricity per year to power the washing machine.
What is the average cost of running a washing machine
Washing machines, on average, cost of running a washing machine per load uk, between £0.12 - £0.55 depending on the setting you choose to wash on. Washing on eco settings, and using lower temperature washes rather than hotter ones, will generally be the lowest cost.
Is it cheaper to use a washing machine at night in the UK?
In the UK, a large number of energy companies provide discounted electricity rates for off-peak usage. If you run your washing machine at nighttime, you can save a considerable amount of money on your electricity bill over time.
What is the cheapest washing machine setting to use?
Using eco mode on your washing machine, at a 30° wash, is typically the most economical and energy efficient. Eco mode reduces the amount of electricity used by machines by reducing the amount of water that needs to be heated and by maximizing the overall cycle performance.
Home Solutions
