Smart Washing Machine Guide: Features, Advantages And Buying Tips
Whether you're tired of spending hours on laundry or looking for a way to make your home smarter, a smart washing machine could be the game-changer you need. Modern technology has transformed the way we wash clothes, offering convenience, energy savings, and even remote control at your fingertips. When paired with solar batteries, these machines can make the most of stored solar energy, further reducing electricity consumption and lowering your energy bills.
In this guide, we'll explore the key features, benefits, and buying tips that can help you choose the perfect washing machine for your home.
What is a smart washing machine?
A smart washing machine is a type of appliance that connects to the internet and can be controlled remotely via a smartphone app or voice commands. It has advanced sensors and things like AI to adjust how much water, detergent, and the cycle of washing for better cleaning. These appliance systems frequently include aspects such as remote observation, energy-saving modes, and notifications when laundry is completed.
Smart washing machines vs traditional washing machines
The decision on whether to go with a smart washing machine or a more traditional one boils down to how much you embrace automation, efficiency, and convenience. Older machines require manual adjustments, whereas smart models optimize cycles, conserve energy, and may even be controlled over the Internet. The table below shows the main differences:
Feature
Traditional Washing Machine
Automation
Adjusts wash cycles, water levels, and detergent automatically using sensors and AI.
Requires manual selection of wash programs, water levels, and detergent amounts.
Energy efficiency
Optimises energy and water usage with eco-modes and load detection, reducing bills.
Uses fixed energy and water consumption; less efficient for small or uneven loads.
Convenience
Can be controlled remotely via smartphone or voice assistants; sends notifications when laundry is done.
No remote control; requires manual supervision and timing.
Advanced features
Offers stain removal programs, delayed start, self-cleaning, and smart diagnostics.
Limited features; mostly basic wash and rinse cycles.
Key features of smart washing machines
Smart technology has changed how we do laundry, making it easier, faster, and more efficient. A smart tech washing machine uses automation, connectivity, and smart features to give you more control. Here are the main features that make a washing machine smart for modern homes.
Remote control and scheduling
Smart washing machines let you control your laundry using a smartphone or tablet. You can start, pause, or schedule washing cycles from anywhere, even when you're not at home. This makes it easy to fit laundry into your routine, saving time and giving you more flexibility.
Automatic adjustments and energy-efficient programs
A smart washing machine uses sensors and AI to automatically adjust water, detergent, and cycle settings for the best cleaning. It also has energy-saving programs that use less electricity and water. This keeps your clothes clean and helps lower your utility bills.
Smart washing machine adjustment systems
Maintenance alerts and diagnostics
One smart tech washing machine can detect problems and send maintenance requests straight to your phone. It delivers diagnostic insight to avoid breakdowns and can extend the machine's life. This helps reduce repair costs and ensures your laundry routine is hassle-free.
Benefits of using a smart washing machine
Getting a modern washing machine does more than add convenience. It changes how you handle laundry every day. A smart machine is efficient, cleans better, and is easy to control, making it a great choice for any home. Here are the main benefits:
Improved energy efficiency
A smart washing machine uses just the right amount of water and electricity for each load and fabric type. By adjusting cycles on its own, it cuts down on wasted energy and helps lower your bills. Over time, this also supports a more eco-friendly lifestyle.
Time-saving convenience
You can make your washing machine smart with remote control and scheduling features. This allows you to start, pause, or monitor laundry from anywhere using a smartphone. It saves time by eliminating the need to supervise every wash cycle.
Better washing performance
A smart washing machine uses sensors to detect fabric type and how dirty your clothes are. It adjusts the wash cycle for the best cleaning and protects delicate items. This gives you great results every time without needing to change settings yourself.
Reduced water and electricity usage
Even a cheap smart washing machine can help cut down on resource waste. It automatically calculates the right amount of water and energy needed for each load. This not only lowers utility costs but also promotes more sustainable laundry practices.
Power management for smart appliances
Efficient energy management is important for smart appliances to work well and keep electricity bills low. Reliable home energy solutions help your devices, like smart washing machines, run smoothly and save money. EcoFlow's advanced solar storage systems are a great option for stable and efficient power.
Recommended smart energy solutions
EcoFlow STREAM systems offer a full energy management solution for homes with smart appliances. They store solar energy during the day and use it when needed, so high-demand devices keep running without interruption. Intelligent monitoring helps these systems use energy efficiently, cutting waste and lowering bills.
450W Rigid Solar Panel + STREAM Ultra X
The 450W Rigid Solar Panel + STREAM Ultra X provides a robust and efficient solar energy solution for UK homes with high-demand appliances like smart washing machines. The system delivers up to 2,300 W AC output, easily powering devices such as refrigerators, ovens, and smart washing machines. Its expandable battery capacity from 3.84 kWh to 23 kWh ensures consistent energy coverage throughout the day and night, giving homeowners flexibility and peace of mind.
With support for up to 2,000 W of solar input, 4 MPPT channels, and Low-Light Cells, the STREAM Ultra X captures maximum solar energy even in cloudy conditions or early mornings and evenings. Built to last, it features a 15-year operational lifespan, combining high safety standards with long-term reliability.
The system also integrates seamlessly with smart home setups, being compatible with third-party devices that use Tiber, Matter, and Shelly protocols. Together, these features make the 450W Rigid Solar Panel + STREAM Ultra X a practical, energy-efficient, and cost-saving choice for modern UK households.
- Save up to £1,734 annually on your electricity bills. - Enjoy 1200W AC output, easily powering high-demand appliances. - Expandable capacity from 3.84 to 23kWh provides energy coverage throughout the day and night. - With a 2000W solar input, 4 MPPTs, and Low-Light Cells, this system captures more solar energy. - Features a 15-year lifespan, ensuring high safety and long-term reliability. - Set up is effortless and requires no electricity. - Compatible with third-party devices that use Tiber, Matter, and Shelly protocols.
STREAM Ultra
EcoFlow STREAM Ultra is a compact, all-in-one solar storage solution designed to power smart home appliances efficiently. Each unit delivers a 1,200 W AC output, providing reliable power for everyday high-demand devices like smart washing machines, refrigerators, and ovens. With a dual-mode 2,800 W solar input, it captures and stores solar energy for use day and night, helping reduce electricity bills. The system's modular design allows homeowners to expand storage capacity as energy needs grow.
The system integrates seamlessly with EcoFlow's OASIS Home Energy Management System, enabling AI-driven optimisation, real-time monitoring via the mobile app, and improved energy self-consumption for greater savings and enhanced energy resilience. Additionally, it is compatible with other EcoFlow products and third-party devices, making it a smart, flexible, and energy-efficient solution for modern homes.
- Slash up to £963 off your electricity bills - Fully compatible with EcoFlow STREAM Pro and AC Pro - AI‑driven monitoring and control via the EcoFlow app - Seamlessly integrates with over 99% of solar panels on the market
Popular smart washing machines compared
To pick the right smart washing machine, compare features, energy ratings, and prices to match your home and budget. Today's smart washers have AI load sensing, app control, and energy-saving technology for better efficiency. Here's a look at popular models and what they offer:
Model
Features
Energy rating
Approx price (UK)
Samsung Series 5 AI Energy WW10FG5U34AEEU (10 kg)
Wi‑Fi control, AI wash, Ecobubble tech
A rated
~£399 (discounted)
Samsung Series 5 AI Energy WW80CGC04DAEEU (8 kg)
SmartThings app, 1400 rpm spin
A rated
~£309 – £349
Samsung Series 7 AI Energy WW11DB7B94GBU1 (11 kg)
Larger capacity, app control
A rated
~£589
Bosch WGG24400GB (9 kg)
LED display, smart programs
A rated
~£499
Beko BW1O3821W (8 kg)
Wi-Fi-enabled smart washing
A rated
~£239
How to choose the best smart washing machine
Choosing the best smart washing machine is about more than picking a well-known brand. Think about your laundry needs, energy efficiency, smart features, and total cost. Knowing these factors helps you find a model that saves time, money, and energy while cleaning well.
Capacity and load size
The capacity of a washing machine will tell you how much laundry you can comfortably wash in one cycle. High capacities suit families with kids or heavy laundry needs, while smaller capacities are efficient for singles or couples. Ensure that you select the right size for your needs so as not to waste energy and water, as well as money on utility bills.
Energy rating and efficiency
High energy ratings in a smart washing machine mean lower electricity and water consumption, helping reduce household bills effectively. Energy-efficient machines reduce bills and environmental impact significantly over their lifespan. Look for models with A+ ratings or above for maximum savings and consistent performance every wash.
Smart features and compatibility
Modern smart washing machines offer app control, remote monitoring, and AI wash cycles for ultimate convenience. Compatibility with other smart home devices adds seamless functionality to your routine. Features like scheduling, notifications, and automated adjustments make laundry management easier and stress-free.
Budget and long-term cost
The upfront price of a smart washing machine is important, but consider running costs, maintenance, repairs, and potential part replacements too. Energy-efficient models save money over time, balancing initial investment with ongoing savings effectively. Evaluate durability, warranty, reliability, and features to ensure the best long-term value and practical everyday usage.
How to use smart washing machines efficiently
Using the right settings and habits can help your smart washing machine use less energy and work better. Small changes in how and when you run it can lower your bills and help them last longer. Here are some practical tips to get the most from your smart tech washing machine:
Running full loads
Always aim to run your smart washing machine with full loads instead of multiple small washes. This maximises water and energy use per cycle, reducing overall consumption. It also helps shorten the number of washing cycles needed, saving both time and resources.
Using eco modes
Eco modes on smart washing machines lower water temperature and energy usage without compromising wash quality. These settings are ideal for lightly soiled clothes, helping you cut costs and environmental impact. Modern machines optimize cycle length and power, giving a smart, efficient wash every time.
Scheduling during off-peak hours
Many smart washing machines allow you to schedule cycles during off-peak electricity hours. Running your washer at these times reduces energy costs and eases demand on the grid. This feature also pairs well with solar or smart home energy systems for maximum savings.
Smart washing machines: safety and security
Safety and security are important for smart washing machines to keep users and homes safe. New models have child locks, automatic shut-off, and leak detection to help prevent accidents. Wi-Fi-enabled machines use secure encryption to protect your data and stop unauthorized access. Many also send alerts through apps if there's a problem, so you can act quickly. Regular maintenance and following the manufacturer's advice make the operation even safer and more reliable.
Smart washing machines have changed home laundry, making it more convenient, efficient, and suited to modern life. They help you save time, energy, and water while still cleaning well. By using these machines, you can make your routine smarter and lower your impact on the environment. Buying a smart washer is not just about convenience; it's also a step toward a smarter and more sustainable home.
Using smart appliances with reliable energy solutions like EcoFlow's STREAM Ultra and 450W Rigid Solar Panels makes your home even more efficient. These systems provide steady power and help lower your electricity bills while running devices like washing machines. If you want to combine smart laundry with better energy management, EcoFlow products offer a practical, money-saving, and eco-friendly choice.
  1. What does a smart washing machine do?
A smart washing machine connects to the internet and can be controlled via an app or voice commands from anywhere. It adjusts water, detergent, and cycles automatically for optimal cleaning every time. It also offers features like scheduling, notifications, and energy-saving modes for convenience.
  1. How long do smart washing machines last?
Most smart washing machines have a lifespan of 8–12 years with proper care and regular usage. Regular maintenance and following manufacturer guidelines can extend durability and prevent early breakdowns. Quality models with reliable components may even last significantly longer than expected.
  1. What are common problems with smart washers?
Common issues include connectivity errors, sensor malfunctions, or software glitches that affect performance. Minor problems can often be fixed through app updates, resets, or simple troubleshooting steps. Regular cleaning and maintenance help prevent most issues and ensure consistent operation.
Home Solutions
