Cost of Oil Radiators to Run: 2026 UK Energy Guide
One of the most searched questions in the UK is what’s the cost of oil radiators to run, and for a good reason. Energy bills are still a major concern for millions of households. That’s why many people want to understand how much it costs them per hour, day, month, or year to run oil-filled radiators, so that they can plan their budgets effectively. These radiators are known for their quiet operation, gentle warmth, and portability, that’s why it's a favorite among households.
This guide discusses the true cost of running oil radiator units by wattage using current energy rates. It further explains the key factors that influence your spend and provides modern technology solutions alternatives you can implement to reduce your heating bills.
What Is the Cost of Running an Oil Radiator?
There are two main variables that determine the cost of running an oil filled radiator:
  • The unit’s wattage
  • Your electricity tariff
The current standard unit rate in the UK is 24.67p per kWh (kilowatt-hour). To get the running cost per hour, use this formula:
Running cost per hour = (Wattage ÷ 1,000) × unit rate (pence)
Note: Always check Ofgem’s website for the up-to-date energy rate in the UK
The principle of oil-filled radiators is that the diathermic oil enclosed within the unit is heated and then emits heat into the room. They do not lose heat as quickly as fan heaters after the element is switched off. And, this is what makes them more efficient for longer periods. A factor that you must consider when assessing the cost of oil filled radiators against alternatives.
Oil Radiator Wattage and Running Costs Explained
The majority of domestic oil-filled radiators range between 500W to 2,500W. The table below shows the running costs of these radiators using the current Ofgem standard rate of 24.67p per kWh:
Wattage
Cost Per Hour
Cost Per Day (8 hrs)
Cost Per Month (30 Days)
500W
12.34p
£0.99
£29.60
1,500W
37.01p
£2.96
£88.81
2,000W
49.34p
£3.95
£118.42
2,500W
61.68p
£4.93
£148.02
Note: We have calculated the figures in this table using the current Ofgem price of 24.67p per kWh. This figure is subject to change, always visit Ofgem’s website for the up-to-date figure, then use the formula below to get the updated value:
Daily Costs= kW x Hours x Rate
Monthly Costs= Daily Rate x 30
All calculations have been done with the assumption that the radiators are running for 8 hours a day
Cost of Running 500W Oil Filled Radiator
From our table calculation above, the cost of running 500w oil filled radiator units per hour is 12.34p. This unit requires roughly £0.99 for an 8 hour period per day, and for 30 days the cost is £29.60. This makes the radiator best for small rooms or supplementary heating.
Cost of Running 1.5 kw Oil Filled Radiator
The cost of running 1.5 kw oil filled radiator is 37.01p per hour, £2.96 per day, and about £88.81 per month. The units are ideal for medium-sized living spaces.
Cost of Running a 2,000W Oil Filled Radiator
The cost of running a 2000w oil filled radiator is 49.34p per hour, £3.95 per day, and £118.42 per month. The cost of running 2kw oil filled radiator is slightly significant and must be factored into your budget.
Cost of Running a 2,500W Oil Filled Radiator
The cost of running 2500w oil filled radiator models is 61.68p per hour, £4.93 per day, and £148.02 per month. These units are recommended for large, open-plan spaces and rooms with poor insulation.
Note: The calculations provided in this section are based on Ofgem price of 24.67p per kWh, and the assumption the units are running for 8 hours a day for 30 days.
Factors That Affect the Cost of Oil Filled Radiators
  1. Thermostat Settings
Modern oil-filled radiators have a built-in thermostat. The thermostat turns the heating element on and off, to ensure the room gains your desired temperature. This means that the radiator does not consume the fully rated wattage throughout the hour of use. For example, if you run a 2,000W radiator in a well-heated room, the element may only run for 20 to 30 minutes. In the end, the cost of oil filled radiator to run will be lower compared to the theoretical maximum figure.
  1. Room Size and Insulation
The physical properties of your room directly affect the duration that your radiator should be turned on. Uninsulated rooms, single-glazed window furnishings, uninsulated walls, and door and skirting boards allow heat out easily and therefore leave the unit to work harder and longer to keep the room at a comfortable temperature. Easy fixes, such as draught-proof, thermal coverings, and loft insulation can significantly decrease the number of hours the radiator has to operate, and, consequently, your total heating costs.
  1. Ambient Temperature
If the outdoor temperature is colder than the indoor temperature, then the radiator must work to compensate for heat loss. In mild autumn evenings, the radiator can draw little power because it may cycle infrequently. However, during the winter season, the same radiator will run more frequently, increasing its power consumption and your electricity bills cost.
  1. Electricity Tariff
Your electricity tariff also affects the cost of running an oil filled radiator UK. If you are running on a standard variable tariff, you are subject to Ofgem energy price cap rate. Currently, this is at 24.65p per kWh. However, if you are on Economy 7 or any other time-of-use tariffs, you benefit from cheaper off-peak rates. This can reduce your cost of oil radiators to run, especially if you are using a timer to align heating with those lower-rate periods.
  1. Usage Patterns
Usage patterns refers to how you are using the radiator. A first case scenario is a sustained low-heat operation for keeping your room at a steady, moderate temperature over several hours. This way is more efficient and you can expect the radiator to draw less energy. A second case scenario is allowing the room to cool completely and then turn on the radiator at full capacity to reheat it. In this case, the radiator will draw the rated electricity, which will be higher than the first case scenario.
Are Oil Filled Radiators Cost-Effective in the UK?
The cost of running oil radiator units is slightly lower compared to other portable options. For example, if you compare them against fan heaters of equivalent wattage, oil radiators provide more sustained warmth due to their thermal mass. The sealed oil retains heat and continues radiating after the element is switched off.
However, these radiators don’t come cheap. Gas central heating costs less per unit of heat delivered and requires installation and maintenance expenses. If your household lacks central heating, or you are looking for a way to get room-by-room supplementary warmth, the cost of running a oil filled radiator at lower wattages can still represent solid value.
The key to get the most from your unit is disciplined usage. Also, combine with a timer, set the thermostat, and implement better insulation habits. These tips will help keep the cost of oil radiators to run as low as possible across a heating season.
Reducing Your Heating Costs with Smarter Energy Solutions
Integrating a home storage system you can charge with solar energy or during off-peak hours can help you manage the cost of running a 1500w oil filled radiator or higher-wattage units. Below are our top two product recommendations that can help keep the cost of oil radiators to run low:
EcoFlow STREAM Ultra X Home Solar Battery
The EcoFlow STREAM Ultra X is an energy solution that can help you reduce grid dependence. It is built with LiFePO4 to ensure it lasts longer, and incorporates MPPT solar charging efficiency for maximum panel output. The battery stores energy generated during daylight hours. It then deploys it when grid prices are highest, including evenings when you are using your oil-filled radiators.
Through providing reliable energy to power your heating you effectively decouple the cost of oil filled radiators from fluctuating tariff rates. In the long run, this can produce meaningful savings without changing your comfort levels.
Large 3.84kWh capacity that can store enough energy to keep you online for days 6000 life cycles that ensure dependable power for fifteen years 2000W solar input for quickly recharging the battery Four MPPT trackers for harvesting energy efficiently even in shade IP65 rating that guarantees the unit can withstand harsh weather Silent 30dB operation guaranteeing no noise disturbance at home 10-year warranty giving you long term protection
EcoFlow STREAM Ultra Pro Solar Plant
If your household has greater energy demands, or you are building a more comprehensive renewable setup, the EcoFlow STREAM Ultra Pro offers expanded storage capacity and output capability. Similar to STREAM Ultra X, this system runs on LiFePO4 chemistry and integrates with EcoFlow’s smart energy ecosystem. It allows intelligent load management across your home’s appliances, including the oil-filled radiator.
The STREAM Ultra Pro can help offset grid consumption. And this means that the cost of running an oil filled radiator UK households pay can reduce significantly over time.
All-in-one hybrid system with energy storage and a built-in microinverter High solar input of up to 2,800W for capturing more solar energy 2,300W AC output sufficient to run two appliances at the same Scalable capacity from 1.92kWh up to 11.52kWh to match your increasing energy needs LFP battery that lasts up to 6,000 cycles, giving you around 15 years of use Low-light solar capture for generating power even on cloudy days AI-powered time-of-use (TOU) capabilities that automatically charges and discharges based on cheap and peak electricity pricing Runs at under 30 dB which is quieter than a library whisper
In the UK, the total cost of oil radiators to run depends on wattage, usage duration, insulation quality, and your electricity tariff. Based on the current Ofgem standard rate which is at 24.67p, the average costs start at 12.34p per hour for the 500W unit. However, you can control how much energy the oil radiator consumes by using a thermostat, setting timers, and matching wattage to room size. With these strategies, you can keep the cost of running oil filled radiator units manageable. If you have solar panels, or your household has time-of-use tariffs, pairing your radiator with stored energy offers a further, sustained reduction in overall heating spend.
EcoFlow provides a range of solar and home battery solutions that can help you take control of your home energy costs. These systems are designed to work with your existing heating setup. Explore our full catalog today and get products that actually perform.
Cost of Oil Radiators to Run Frequently Asked Questions
  1. What is the cost of oil filled radiator per hour in the UK?
Wattage and your traffic determine the cost of oil filled radiator per hour. The current Ofgem rate is 24.67p per kWh. Using this rate, the cost per hour to run the 500W unit is 12.34p per hour, 1000W unit 37.01p per hour, 1500W unit 49.34p per hour, and 2000W unit 61.68p per hour. That is the current cost of oil radiators to run in the UK.
Note: These figures are an estimate based on the current Ofgem rate. Visit the Ofgem website to get the up-to-date rate
  1. Is it cheaper to run an oil filled radiator or use central heating?
If you are looking for a heating solution for your whole home, the gas central heating is recommended because it has a lower cost per unit. However, the cost of running a oil filled radiator in a single occupied room can be more economical than heating the entire house, especially if multiple rooms are unoccupied.
  1. Does a 2kW oil filled radiator use a lot of electricity?
The cost of running 2kw oil filled radiator units over eight hours consumes 16 kWh. Using the current Ofgem rate of 24.67p per kWh, the total amount you pay is 61.68p per hour and £4.93 for 8 hours use. This translates to approximately £148.02 per month if you are using the radiator for 8 hours a day.
Home Solutions
