Average Energy Bill UK Explained: 2025 Prices and Saving Tips
If you’ve noticed your gas or electricity costs creeping up, you’re not alone. Energy prices in the UK have shifted a lot in recent years, and understanding where your bill sits compared to the average can help you take control. In this guide, you’ll find the latest figures for the average energy bill UK in 2025, the key factors that influence what you pay, and practical ways to keep your household costs down without sacrificing comfort.
What Is the Average Energy Bill in the UK in 2025?
If you’re on a standard variable tariff and pay by Direct Debit, the average energy bill in the UK for a typical dual-fuel household is around £1,720 a year (about £143 a month) from 1 July–30 September 2025 under the quarterly Ofgem Energy Price Cap. That’s down roughly 7% from the April–June quarter.
It’s worth remembering that the price cap doesn’t limit your total bill—it sets maximum unit rates and standing charges. Your actual costs depend entirely on how much energy you use.
What counts as “average” use?
To work out the price cap, Ofgem uses Typical Domestic Consumption Values (TDCVs). These are benchmarks for annual gas and electricity average consumption, based on the size of your home and how many people live there.
Energy use
Example home
Annual gas
Annual electricity
Annual electricity (multi-rate like Economy 7)
Low
Flat or 1-bed; 1–2 people
7,500 kWh
1,800 kWh
2,200 kWh
Medium
2–3 bed; 2–3 people
11,500 kWh
2,700 kWh
3,900 kWh
High
4+ bed; 4–5 people
17,000 kWh
4,100 kWh
6,700 kWh
2025 so far: average bills by usage level
Using Ofgem’s published unit rates and standing charges for each quarter, here’s what a low, medium, or high usage household would typically pay on a dual-fuel Direct Debit tariff this year:
Period (2025)
Low
Medium (typical)
High
Quarter-on-quarter change
Jan–Mar
£1,261 (~£105/month)
£1,738 (~£145/month)
£2,435 (~£203/month)
Apr–Jun
£1,326 (~£111/month)
£1,849 (~£154/month)
£2,612 (~£218/month)
↑ 6%
Jul–Sep (current)
£1,234 (~£103/month)
£1,719 (~£143/month)
£2,427 (~£202/month)
↓ 7%
Figures are rounded and based on the TDCVs above, using Ofgem’s average UK energy cost per kWh for each quarter.
Current price cap rates (1 July–30 September 2025)
Fuel
Unit rate (p/kWh)
Standing charge (p/day)
Electricity
25.73p
51.37p
Gas
6.33p
29.82p
These are average gas and electricity cost per kilowatt hour in the UK. Rates vary slightly by region and tariff type. The cap applies in England, Scotland, and Wales. Northern Ireland has its own regulator.
You see, at the current 25.73p electricity cost per kWh UK, the average electricity bill in the UK now ranges from £54 to £104 per month if you pay by Direct Debit. Gas bills typically add another £50 to £100, depending on insulation quality, home efficiency, and weather conditions.
Factors That Affect Your Energy Bill
Your energy bill isn’t just based on one thing; it’s shaped by a mix of how much energy you use, how your home is built, your appliances, and the type of tariff you’re on.
How much energy you use (kWh)
Your bill is driven first by consumption. The more gas or electricity you use, the more you pay. Compare your last 12 months’ kWh with Ofgem’s “typical use” to see how you stack up against the average energy bill benchmark.
Heating and hot water systems
The type of heating and hot-water system matters a lot. An efficient condensing boiler, a well-installed heat pump or a modern electric boiler will use less fuel for the same warmth than an older, inefficient boiler. Likewise, homes that rely heavily on electric heating will see higher electricity bills compared with gas-heated homes.
Your home’s energy efficiency
How your home is built makes a big difference. Poor insulation, single glazing, gaps around doors and windows, and uninsulated lofts cause heat to escape and force the heating on for longer. That’s why two homes of the same size can have very different bills.
The age and efficiency of your appliances, especially power-hungry ones like fridges, washing machines, tumble dryers, and electric ovens, are important here. Newer, A-rated, or other energy-efficient models often use significantly less power.
Property size and occupancy
Larger homes with more rooms naturally require more energy for heating and lighting. Similarly, the more people living in a household, the higher the usage from laundry, dishwashing, showers, and electronics. Even a small flat with high occupancy can have higher energy demands than a larger but more efficient house.
Your everyday usage habits
The way you use energy has a direct impact on your bill. Heating rooms for long periods, running appliances during peak hours, and leaving devices on standby all increase consumption. Households that work from home full-time or cook frequently will naturally use more electricity than those who are away during the day.
Tariff and payment method
The tariff and payment method you’re on also matter. Power cost per kWh and standing charges can vary quite a bit depending on whether you’re on a standard variable tariff, a fixed deal, or a time-of-use tariff like Economy 7. People on prepayment meters or paying by standard credit might also face different charges or fees. That’s why comparing tariffs and switching where possible can make a big difference.
Meter type and billing accuracy
Smart meters track your energy use in real time, so suppliers can calculate electricity bill based on your actual consumption, not rough estimates. With traditional meters, readings have to be taken manually, and if they’re not submitted regularly, suppliers often rely on estimated usage, which can result in overcharges or undercharges.
How to Reduce Your Energy Bill in the UK
If your bills feel higher than they should be, there are plenty of energy saving tips to help you lower them and take control. From quick, low-cost changes to bigger home upgrades, small actions can add up to meaningful savings over time.
Quick wins you can do today
  • Nudge the heat lower. If it’s safe and comfortable, turn your room thermostat down by just 1°C and heat the rooms you use most. Close doors to keep warmth where you need it and don’t cover radiators with furniture or clothes.
  • Shrink hot water waste. Take shorter showers, fix dripping taps, and use a shower timer if it helps. With a hot-water cylinder, keep the stored water at 60°C to prevent legionella (you can still mix down at the tap).
  • Kill standby. Switch devices off at the wall or use a master power strip for TVs, games consoles and set-top boxes. Many gadgets sip power 24/7.
  • Cook smarter. Lids on pans, batch cooking, and using the microwave or air fryer for small portions all reduce oven time. Defrost food in the fridge overnight.
  • Laundry tweaks. Wash at lower temperatures when possible, run full loads, and use a higher spin so clothes dry faster. Air-dry instead of tumble-drying where you can.
  • Light right. Turn lights off when you leave a room and rely on task lighting rather than lighting the whole space.
Low-cost tweaks that pay back fast
  • LED bulbs in high-use rooms. Swap the bulbs you use most first (kitchen, living room, hall/landing). They’re cheap and the savings stack up.
  • Draught-proofing. Fit stick-on strips around leaky windows and doors, add a letterbox brush and keyhole cover, and use a chimney balloon if a fireplace is unused. Close curtains at dusk—thermal liners help.
  • Hot-water insulation. If you have a cylinder, add or upgrade a jacket and insulate the first metre of hot pipes. It’s inexpensive and cuts standing losses.
  • Smart plugs and timers. Automate schedules for lamps, routers, or towel rails so they’re not running when you don’t need them.
Pick the right tariff and keep billing accurate
  • Pay for what you actually use. If you don’t have a smart meter, submit meter readings regularly—especially before price changes—so you’re not billed on estimates.
  • Consider a smart meter to monitor home electricity usage. It automates readings and gives you an in-home display, making it easier to spot waste in real time.
  • Match tariff to lifestyle. If you have storage heaters or can shift usage overnight (e.g., EV charging, dishwasher), a time-of-use or Economy 7/10 deal may suit you. If not, a flat-rate tariff is usually better.
Bigger changes for long-term savings
  • Insulation first. Top up loft insulation (many UK homes still fall short), draught-proof loft hatches, and insulate suspended timber floors. If you have cavity walls, get them filled; for solid walls, consider internal or external insulation with a qualified installer.
  • Heat pumps (where suitable). Best in well-insulated homes with larger radiators or underfloor heating. They offer stable running costs and low carbon emissions—insulation and good controls are critical to performance.
  • Appliance upgrades. When something needs replacing, choose modern A- or B-rated high-efficient models (fridges, freezers, washing machines, dryers). Consider an induction hob when the time comes.
  • Look into solar and storage. Think of solar + battery as two parts of the same job: the solar panels capture energy when the sun’s out, and a battery stores the surplus so you can use it during the evening peak or when prices are highest. That combination cuts the electricity you import from the grid and gives you control. You can prioritise solar first, top up from cheap overnight electricity, and use stored power when tariffs spike.
If you want a beginner-friendly solar setup that does all that without a big installation project, the EcoFlow STREAM Ultra X is worth a look. It’s an all-in-one unit with integrated storage and a built-in microinverter, so you don’t need a separate inverter cabinet.
It features a 3.84 kWh LFP battery with a capacity expandable to 23 kWh, which can meet the evening peak electricity demand of many households. Its four MPPT trackers can accept up to 2,000W of solar input, so when paired with high-efficiency EcoFlow solar panels, you can capture more energy throughout the day even in mixed light conditions.
What stands out in everyday use is the flexibility. You can run appliances from the Ultra X’s 1,200W AC outlet, export up to 800W grid-tied to your home circuits, and handle short heavier loads up to around 2,300W.
The EcoFlow app adds practical smarts: tariff-aware charging schedules and solar forecasts mean the system will charge when electricity is cheapest and discharge during peak price windows automatically.
The EcoFlow STREAM Ultra X is an all-in-one unit featuring a 3.84 kWh LFP battery and four MPPTs that support up to 2,000W solar input. It integrates a built-in microinverter, a 1,200W AC outlet, and can supply up to 800W of grid-tied power to home circuits. In parallel or bypass mode, it handles heavier loads up to 2,300W, with capacity expandable to 23kWh.
Understanding the average energy bill in the UK in 2025 gives you a clear benchmark for your own household costs. By knowing what’s typical, recognising the factors that push your bill up, and taking practical steps to use less energy, you can keep more money in your pocket without sacrificing comfort. Whether it’s small daily changes, home upgrades, or switching to a better tariff, every action makes a difference. The sooner you start, the sooner you’ll see the savings add up.
What is the average energy bill per month in the UK?
From 1 July to 30 September 2025, Ofgem’s price cap means a typical dual-fuel household paying by Direct Debit would spend around £1,720 a year, or roughly £143 a month. This is based on medium annual usage of about 2,700 kWh of electricity and 11,500 kWh of gas in England, Scotland, and Wales.
Your own bill might be higher or lower depending on where you live, your standing charges, your meter type (for example, Economy 7), and how much energy you actually use. Ofgem updates the cap every quarter, so these figures can change.
What is the average gas bill for a 3 bedroom house in the UK?
A three-bedroom home often matches Ofgem’s “medium” gas usage level, which is around 11,500 kWh a year. Under the current July–September 2025 rates, that works out to about £70 a month (or roughly £837 a year).
The actual cost can vary depending on your insulation, boiler efficiency, thermostat settings, and even your region, as both standing charges and unit rates differ across the UK. If your property is well-insulated or you heat less, your bills may be lower; larger households or colder homes could see higher bills. Always compare your usage in kWh with the latest capped rates to check you’re paying the right amount.
How much is the average energy bill for a 4 bedroom house in the UK?
Four-bedroom homes typically sit between Ofgem’s medium and high usage levels. At today’s cap, a medium-use household pays around £1,719 a year (about £143/month), while a high-use home is closer to £2,427 a year (around £202/month).
Your place on this scale will depend on factors such as the number of occupants, the efficiency of your heating system, your insulation (loft, cavity walls, windows), and how you use energy day to day. Regional differences in standing charges and unit rates also play a role. In practice, many four-bedroom homes fall in the £170–£190 per month range unless they’re particularly energy efficient.
What is the average electric bill for a 2-person flat in the UK?
For a two-person flat using electricity only, annual usage usually falls between Ofgem’s low and medium categories (around 1,800–2,700 kWh). Under the July–September 2025 cap, that means a monthly bill of roughly £55–£75, including the standing charge.
Costs can rise if you have electric heating or cook with electricity, and drop if you use off-peak tariffs (like Economy 7) or have great insulation and efficient appliances. Because unit rates and standing charges vary depending on where you live, the best way to check if your bill is reasonable is to compare your kWh usage and rates to the latest Ofgem cap.
Saving Bills
