Tankless Water Heater Cost in Canada: Installation & Savings Guide
The heater itself is only one part of what Canadian homeowners may pay. Tankless water heater cost can also include electrical upgrades, gas-line work, venting, plumbing, and labor, sometimes pushing the installation well above the unit's purchase price. This guide looks at equipment, installation, monthly running expenses, and potential long-term savings compared with traditional tank water heaters.
For efficiency guidance, homeowners can also check Natural Resources Canada. EcoFlow products are covered separately for backup power needs, including the DELTA Pro Ultra, to explain whether battery systems can support a tankless water heater during an outage.
Support Compatible Water Heaters with EcoFlow DELTA Pro Ultra
• Provides 7,200 W of continuous AC output.- Supports 120/240V AC output for compatible household equipment. •May support some lower-demand electric tankless water heaters, depending on their specifications. • Typical 10–30+ kW whole-home electric tankless heaters exceed its continuous output. • Gas tankless heaters generally need far less electricity for ignition, controls, and venting. • Heater rated wattage, voltage, startup demand, and circuit requirements should be checked before connection. • Best treated as a backup option only when the specific heater’s electrical requirements fall within the system’s limits.
How Much Does a Tankless Water Heater Cost?
Before comparing the figures, it helps to separate the unit price from the tankless water heater installation cost. The estimates below are in Canadian dollars, based on 2026 quotes from Canadian installers:
Type
Unit
Installation
Possible Upgrades
Total Installed
Point-of-Use Electric
$130 to $400
$150 to $400
Dedicated 240V circuit
$300 to $600
Whole-Home Electric
$700 to $1,800
$800 to $2,500
Panel or service upgrade
$2,500 to $4,500
Non-Condensing Gas
$1,200 to $2,200
$1,500 to $3,000
Gas line, venting
$3,000 to $5,000
Condensing Gas
$2,000 to $3,500
$1,500 to $3,000
Venting, condensate drain
$4,500 to $6,500
Tankless to Tankless
Varies by model
Around $1,000
Usually minimal
$2,500 to $4,500
Tank to Tankless
Varies by model
$1,500 to $3,000
Gas, electrical, venting
$3,500 to $8,500
Where you live moves those numbers considerably. Ontario quotes run roughly $2,800 to $5,500, while the GTA and Metro Vancouver run closer to $3,500 to $6,500. Calgary commonly lands between $4,980 and $8,500, and complex jobs anywhere can reach $10,000.
Gas vs Electric Tankless Water Heater Cost
The cost of tankless water heater systems varies by fuel type, energy rates, and installation requirements.
Factor
Electric
Gas
Equipment Price
Generally lower
Higher, especially condensing
Installation Complexity
Simpler, no venting
More involved
Electrical Requirements
Substantial for whole-home units
Modest, for controls and ignition
Gas-line Requirements
None
Often needs resizing
Venting
Not required
Required
Operating Cost
Follows local electricity rates
Usually lower where gas is cheap
Hot-Water Capacity
Limited by electrical service
Higher flow rates available
Maintenance
Descaling
Descaling plus burner and vent checks
Best Fit
Condos and homes without gas
Larger households on a gas line
The challenge with electric is often capacity, not the unit price. A whole-home electric model can require substantial electrical service, so panel upgrades may offset its lower purchase price. EcoFlow’s home electrification guide covers those electrical considerations in more detail.
Whole-Home vs Point-of-Use Tankless Water Heater Cost
Your cost of a tankless water heater varies by system size and coverage, as the table below shows:
Factor
Point-of-Use
Whole-Home
Coverage
One fixture or a small area
Multiple fixtures at once
Equipment Cost
Low
Substantially higher
Flow Requirement
Small
Sized for simultaneous demand
Typical Use
A sink far from the main heater
The household's primary supply
Installing several point-of-use units is not automatically cheaper. Each unit requires its own electrical supply and plumbing connection, so installing 3 or 4 can cost more than one correctly sized whole-home system. For broader pricing comparisons, see SolarReviews’ tankless water heater cost guide.
What Hidden Costs Should You Budget For?
Your tankless water heater installation cost may also include these less obvious expenses, depending on your home:
  • Electrical service or panel upgrades for high-demand electric units.
  • A larger gas line where the existing supply was sized for a tank.
  • New exhaust or intake venting.
  • Water treatment in hard-water areas, which shortens unit life.
  • Condensate drainage for condensing models.
  • Permit fees, sometimes billed separately from the quote.
  • Descaling and professional servicing, typically $150 to $200 a year.
How Does Tankless Water Heater Size Affect Cost?
The cost of tankless water heater systems also depends on capacity, so proper sizing starts with five inputs:
  • Required flow rate in liters or gallons per minute.
  • How many fixtures run at the same time.
  • Incoming groundwater temperature.
  • Your desired hot-water temperature.
  • Household size and daily usage patterns.
Canadian winters make this harder than in milder climates. Groundwater in southern Ontario drops to roughly 2 to 4°C, so the heater must raise it around 45 degrees. Colder inlet water means less hot water per minute from any given unit, which is why sizing up matters here. The table below shows how household demand affects the recommended system size and overall cost:
Household Demand
Typical Sizing Direction
Single Fixture, Point-of-Use
Small dedicated unit near the tap
1 Bathroom, Low Simultaneous Use
Modest whole-home capacity
2 Bathrooms, Moderate Use
Mid-range capacity with winter headroom
Multiple Bathrooms, Higher Use
High-capacity model, often the largest available
Do not size by headcount alone. 2 people showering at the same time can create more demand than 4 people using hot water at different times. For additional pricing context, see SolarReviews’ tankless water heater cost guide.
How Much Does a Tankless Water Heater Cost to Run?
Monthly tankless water heater cost varies by household, with these seven factors having the greatest impact:
  • Fuel type, gas or electricity.
  • Your local energy price.
  • How much hot water the household actually uses.
  • The heater's efficiency rating.
  • Incoming water temperature through the year.
  • The temperature you set.
  • How often the unit runs.
The basic calculation is straightforward: multiply energy consumed by the applicable electricity or gas rate to get operating cost.
For an electric model, multiply its rated power in kilowatts by the actual time it operates at that power, then multiply the resulting kWh by your electricity rate. For example, a 27-kW unit operating at full power for 30 minutes per day would use about 13.5 kWh per day, or roughly 405 kWh over a 30-day month. EcoFlow’s guide to calculating appliance wattage explains the same calculation in more detail.
Avoid relying on one universal monthly estimate because electricity and natural gas rates vary by province, utility, and rate plan. EcoFlow’s guide on why your hydro bill is high provides more context on what affects electricity costs.
Does a Tankless Water Heater Actually Save Money?
Whether the cost of tankless water heater ownership pays off depends on balancing long-term savings against added expenses:
Potential Savings
Added Costs
No Energy Spent Keeping a Full Tank Hot
Higher purchase price
Lower Standby Losses
More complicated conversion from a tank
Efficient Models Cut Water-Heating Energy Use
Possible electrical or gas upgrades
Longer Service Life Improves Lifecycle Economics
Periodic descaling and servicing
Frees the Floor Space a Tank Occupied
Repairs can cost more on some systems
The number that matters is total ownership cost, not just the monthly bill. Natural Resources Canada notes that efficient tankless models can reduce energy use. See its tankless water heater efficiency guidance. However, costly panel or gas-line upgrades can reduce those long-term savings.
Tankless vs Traditional Water Heater: Which Costs Less Overall?
The table below compares how the cost of tankless water heater ownership differs from a traditional storage tank:
Factor
Tankless
Storage Tank
Purchase Cost
Higher
Lower
Installation
$2,500 to $8,500 installed
$1,000 to $2,500 installed
Operating Cost
Generally lower per unit of hot water
Higher, due to standby heating
Standby Losses
None
Continuous
Space
Wall-mounted, compact
Occupies floor space
Maintenance
Annual descaling
Periodic flushing and anode checks
Service Life
Around 15 to 20 years
Around 10 to 15 years
High-Demand Performance
Limited by flow rate
Limited by tank volume
Replacement Complexity
Simple if replacing tankless
Straightforward like-for-like
Overall value depends on how long you stay, since tankless systems need time to offset their higher upfront costs.
How Can You Reduce Water Heating Costs?
To lower expenses after asking how much does a tankless hot water heater cost, focus on these practical savings steps:
  • Size the heater correctly rather than buying larger than needed.
  • Fix leaking hot-water taps, which waste heated water continuously.
  • Fit efficient showerheads and aerators.
  • Cut unnecessary hot-water use, particularly long showers.
  • Maintain the unit on the manufacturer's schedule.
  • Compare local gas and electricity rates before choosing a fuel.
Water heating is one line in a larger bill. When the whole bill runs high, the measures in our guide to make your home more energy efficient usually pay off more. Replacing a working heater purely to save energy rarely pays for itself.
Tankless Water Heater vs Heat Pump Water Heater: Which Is Better for Savings?
The cost of tankless water heater systems differs from heat pumps in several key areas, as shown below:
Factor
Tankless
Upfront Equipment Cost
Moderate to high
High
Installation
Venting or electrical work
$3,000 to $7,500 installed
Energy Source
Gas or electricity
Electricity plus ambient heat
Space
Compact, wall-mounted
Needs a tank and air volume
Efficiency
High at the point of use
2 to 3 times as efficient as an electric tank
Hot-Water Delivery
Continuous within its flow rate
Stored, with recovery time
Climate
Cold inlet water reduces flow
Needs a warm enough space
Operating Cost
Depends on fuel and rates
Typically lowest of the electric options
Heat pump water heater rebates can differ from tankless programs, so check eligibility before choosing a system. Canadian incentives may target heat pump models specifically, while conventional tankless units may not qualify. Programs can change, so verify current federal, provincial, municipal, and utility requirements. EcoFlow’s home power solutions guide for heat pump water heaters provides additional information.
 ecoflow home power solution ecoflow home power solution
Can Backup Power Run a Tankless Water Heater?
The tankless water heater cost of ownership can also include backup-power requirements, but compatibility depends heavily on the heater’s electrical demand:
  • Whole-home electric units can draw 10–30+ kW, which exceeds the continuous output of many battery systems.
  • Gas units still need electricity for ignition, controls, and venting.
  • Gas models generally have much lower electrical demand than electric tankless heaters.
  • Startup and continuous power requirements should both be checked before connecting backup power.
The EcoFlow DELTA Pro Ultra provides 7,200W of continuous AC output at 120/240V, so it may support some lower-demand electric tankless models, but not typical 10–30 kW whole-home units. For a specific heater, compare its rated wattage, voltage, and circuit requirements with the battery system before assuming compatibility.
 ecoflow delta pro ultra ecoflow delta pro ultra
Is a Tankless Water Heater Worth the Cost?
The tankless water heater installation cost varies by home, as the table below breaks down the main factors that can affect the overall value.
Worth It If
Less Compelling If
You will stay long enough to recover the cost
Major electrical or gas upgrades are needed
Space is limited
Upfront budget is the main constraint
Demand matches a properly sized model
A working tank already meets your needs
Existing gas or electrical service is adequate
Expected savings will not cover conversion
Lower standby energy use matters to you
Energy savings are not a priority
You are replacing an existing tankless unit
Converting from a working tank adds substantial costs
Collect at least three itemized quotes before committing. The spread between contractors on identical work often exceeds the difference between two heater models.
The cost of tankless water heater ownership in Canada depends on fuel, capacity, existing infrastructure, labor, and required upgrades. Compare installed costs with realistic savings, size for actual demand, and account for cold inlet water. Confirm local requirements before buying, and consider EcoFlow backup solutions if reliable power matters.
  1. How long does a tankless water heater usually last?
Around fifteen to twenty years with proper maintenance, against roughly ten to fifteen for a storage tank. On-schedule descaling matters most in hard-water areas, where mineral buildup shortens life considerably. That longer service life helps offset the higher purchase price.
  1. Does a tankless water heater increase home value?
It can help, though it is rarely decisive for buyers. Canadian estimates suggest a high-efficiency unit may add a few thousand, recovering part rather than all of the installation cost. Treat resale value as a secondary benefit, not a reason to convert.
  1. Can one tankless water heater supply two showers at the same time?
Yes, provided the unit is sized for that combined flow at Canadian winter inlet temperatures. Two showers drawing together need meaningful capacity, and a unit sized for warmer climates will run lukewarm. Correct sizing prevents this.
  1. How often does a tankless water heater need maintenance?
The general recommendation is once a year, more often in hard-water areas. Servicing usually means descaling the heat exchanger and cleaning the inlet filter, and gas models also need burner and venting checks. Budget roughly $150 to $200 annually for professional servicing.
  1. Is it cheaper to rent or buy a tankless water heater?
Buying costs less across the life of the unit, while renting removes the upfront outlay and usually covers repairs. Rental contracts run for years and can complicate a house sale, so read the exit terms carefully. Renting suits tight budgets; buying suits long-term owners.
Save Bills
