In floor Heating Systems: How They Work, Key Benefits, and Power Outage Solutions
People who install in-floor heating rarely go back. The warmth rises from the ground up, the whole room heats evenly with no cold spots, and the system runs quietly without blowing dust around. It's comfort you notice the first time you step out of bed or the shower.
This guide explains how in the floor heating systems work, compares the two main types, and covers a question most guides skip: what happens when the power goes out? We'll also look at the best In floor heating system Canada, installation tips, and how to plan backup power for the zones that matter most. If you want a broader plan for the season, start with this winter storm prep checklist.
What Are In floor Heating Systems?
In floor, or radiant, heating uses heating elements or tubing installed beneath the floor. The floor surface warms up and radiates heat evenly into the room, so you feel comfortable at a lower air temperature. Forced-air systems work differently. They push warm air through vents, which can leave cold spots and stir up dust.
There are two main types: electric and hydronic. Each suits a different kind of project.
Electric In floor Heating
Electric systems use heating cables or pre-built mats embedded in a membrane under the flooring. Output is typically around 12 watts per square foot at full power, and zone-based thermostats usually control about 150 sq ft per zone at 120V. Installation is easier and costs less than hydronic, which makes electric a natural fit for bathrooms and single rooms.
Hydronic In floor Heating
Hydronic systems use a boiler to heat water, which circulates through tubing under the floor. They suit whole-home heating and are efficient to run, but they cost more to install. They also still depend on electricity for the boiler, circulator pumps, and thermostats, so a power outage affects them too.
Modern-in-floor-heating-system-installed-beneath-wooden-flooring-in-a-cozy-living-room Modern-in-floor-heating-system-installed-beneath-wooden-flooring-in-a-cozy-living-room
How to Keep Your Heated Floors Running During an Outage
Backup power can keep selected heating zones and essential devices running when the grid goes down. The key is sizing it realistically. At roughly 12 watts per square foot, a 150 sq ft electric zone draws about 1,800W. That adds up quickly across several rooms, so prioritize key zones rather than assuming whole-home floor-heating coverage.
Before an outage hits, list your essential circuits: the zones you'd heat first, plus lighting, communications, and any medical or safety equipment. For more outage planning, see how to prepare for a winter power outage.
Backing Up Multiple Heating Zones and Essential Home Circuits
For extended outages, the EcoFlow DELTA Pro Ultra is the top option here. It starts with 6,144Wh of base capacity and 7,200W of AC output at 120V/240V, and capacity can expand up to 30kWh. It also offers high solar input, operates down to -20°C, and provides online UPS for sensitive electronics.
In practice, that means it can run selected floor-heating zones alongside essential household circuits during a prolonged outage, depending on your power requirements. It won't necessarily heat every floor in the house, and runtime depends on what you connect. Any integration with your home's circuits must follow local codes and be done by a qualified electrician.
• 7.2 kW–21.6 kW High Output: Delivers robust power capable of running entire households, including high-load appliances like central air conditioners. •6 kWh–90 kWh Scalable Capacity: Expandable energy storage that provides continuous whole-home backup power for weeks during extended outages. • Smart Home Panel 2 Integration: Features automatic switchover, prolonged outage support, and intelligent scheduling to lower utility bills. •5 Versatile Charging Options: Offers multi-source recharging flexibility to ensure power redundancy under any condition. •Automatic Low-Temp Self-Heating: Built-in heating activates automatically below 0°C (32°F) to ensure uninterrupted battery performance in freezing climates.
Keeping Warm in a Single Heating Zone with Portable Backup Power
If you’re only looking to keep one big area comfortable, then the EcoFlow DELTA 3 Ultra Plus is a more focused option. It provides 3,072Wh of capacity and 3,600W of rated output, which can cover a single bathroom or entryway zone plus lights and communications, depending on requirements. Capacity is expandable, and it supports multiple charging methods.
It isn't meant to heat an entire home, and runtime varies with the load. Check compatibility for your specific zone before you rely on it.
• Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. •3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Minutes: Ready in Just 48 Minutes (0-80%) with Solar + Generator Dual Charging • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
Benefits of In-Floor Heating
The main advantages are easy to feel and easy to see:
  • Even heat with no cold spots.
  • Quiet operation.
  • Potential energy savings, since rooms feel comfortable at a lower thermostat setting and zoned heating avoids warming unused space.
  • No radiators or vents taking up wall and floor space.
  • Less forced-air circulation: Radiant floor heating does not rely on forced-air vents to distribute heat, although it does not eliminate indoor allergens.
Best Rooms for In-Floor Heating
Bathrooms are the most popular choice. The area is small, the cost is manageable, and warm tile makes a real difference. Basements, entryways, and mudrooms also work well, since warm floors dry boots faster. Laundry rooms are another good fit.
Avoid laying heating elements under vanities, toilets, or bathtubs.
Hydronic-in-floor-heating-system-with-red-radiant-heating-pipes-installed-beneath-wooden-flooring Hydronic-in-floor-heating-system-with-red-radiant-heating-pipes-installed-beneath-wooden-flooring
In-floor Heating Installation Tips
Professional guidance is consistent on a few points. Hire a licensed electrician for all wiring and obtain any required permits. Use a professional tiler so cables aren't nicked during installation. Choose a smart programmable thermostat, ideally with GFCI protection, and follow both the manufacturer's instructions and local codes.
If you live where winter storms are common, plan your backup power at the same time. These tips for preparing your home for severe snowstorms can help, as can this guide to staying safe, warm, and connected in an outage.
In floor heating delivers even, quiet, comfortable warmth, whether you choose electric for a single room or hydronic for the whole home. Most guides ignore the risk that both types need electricity, so a power outage can leave your floors cold. Planning backup power for your key zones is a practical way to stay comfortable. Explore the DELTA Pro Ultra and DELTA 3 Ultra Plus to find EcoFlow backup power suited to your home's actual heating and electricity needs.
What are in the floor heating systems?
They are radiant systems with heating cables, mats, or water tubing beneath the floor. The floor warms up and radiates heat evenly into the room.
What is the difference between electric and hydronic in-floor heating?
Electric uses cables or mats and is cheaper and easier to install, ideal for single rooms. Hydronic circulates heated water through tubing, suits whole homes, and costs more to install.
How much does in-floor heating cost to run?
It depends on your electricity or fuel rates, room size, insulation, and thermostat settings. Zoned control and lower thermostat settings can help limit costs.
What is the best in-floor heating system in Canada?
There's no single best in-floor heating system in Canada. Electric usually fits bathrooms and retrofits, while hydronic is often chosen for whole-home or new-build projects. A licensed professional can help you decide.
Can in-floor heating heat a whole house?
Yes, hydronic systems are commonly used for whole-home heating. Electric systems are usually better suited to individual rooms.
Does in-floor heating work during a power outage?
Not on its own. Electric systems need power directly, and hydronic systems need it for the boiler, pumps, and thermostats.
How can I power in-floor heating during an outage?
Use backup power sized to your essential zones and circuits. At about 12 watts per square foot, a 150 sq ft zone draws roughly 1,800W, so have an electrician confirm compatibility and code-compliant connections.
Home Backup
