Fort McMurray Fire: What Happened and How to Prepare
The 2016 Fort McMurray fire, known as the Horse River wildfire, led to a citywide evacuation on May 3. If you live in Wood Buffalo, its history offers a clear reason to prepare your household before an alert arrives.
You need separate plans for leaving safely and handling an outage at home. This article covers the fire's timeline, recovery, current official information, and practical preparation. For present conditions, use the alert sources below rather than a historical report.
What Happened During the 2016 Fort McMurray Fire?
The Horse River wildfire spread into Fort McMurray two days after its reported start. By May 3, 2016, the entire city was under a mandatory evacuation order.
The Alberta wildfire review summary dates the fire's start to May 1. These three dates separate its beginning from the evacuation and return:
Date | What Happened |
May 1, 2016 | The Horse River wildfire started outside Fort McMurray. |
May 3, 2016 | A mandatory evacuation covered the entire city. |
June 1, 2016 | Residents began returning in phases, subject to re-entry conditions. |
The Canadian Disaster Database records the evacuation and June return. Returning to the area didn't mean every home was ready to occupy.
The Fort McMurray forest fire forced more than 80,000 people to evacuate. It burned approximately 579,767 hectares and destroyed about 2,400 homes and businesses, according to the federal event summary.
The Fort McMurray fire in Canada also damaged key infrastructure and transportation routes. The often-cited 2,400 figure covers homes and businesses together, so it isn't a house-only total.
Hot, dry weather and high winds helped the fire spread. Those conditions explain its behaviour, but they don't identify the source that first ignited it.
For your own planning, separate the date people could return from the condition of each property. Access restrictions, damaged buildings and local instructions can still affect what you can safely do after an evacuation.
Where Can You Check Current Wildfire and Evacuation Alerts?
Check provincial fire information alongside local emergency instructions. Alberta wildfire updates for the Fort McMurray area describe forest conditions, while evacuation notices tell you what action to take.
Use each official tool for the question it answers:
Official Tool | Use It For | Important Limit |
Forest-area wildfire information and danger updates. | A danger rating isn't an evacuation order. | |
Public emergency alerts and required actions. | Check the affected area and time of issue. | |
Local notices and community instructions. | Follow the notice for your location. |
An evacuation alert means you should be ready to leave on short notice. An evacuation order means leave immediately because it isn't safe to stay, under RMWB evacuation guidance.
Follow the designated route and current road instructions. Don't rely on a route from a past fire, and return only when officials permit it. Read any re-entry conditions before heading home.
A low incident count, a working outlet or a charged battery doesn't override an evacuation order. Check the latest official notice rather than assuming yesterday's conditions still apply.
What Should Your Wildfire Plan Include?
Build a plan that lets everyone leave promptly, whether you own or rent. Home backup belongs in a separate plan for a property you're permitted to occupy.
Prepare Your Household to Leave
Agree on who contacts each household member and how you'll travel if you're apart. Arrange help ahead of time for anyone who needs transport or assistance, including your pets.
Save the official alert sources and check where departure instructions will appear. Keep your vehicle ready if you drive, and discuss an alternative if your usual transport isn't available.
Keep important supplies where you can reach them without a long search. The Canadian emergency kit checklist recommends being prepared for at least 72 hours, with supplies suited to your household.
Before wildfire season, check these departure basics:
Household contacts, transport arrangements, fuel and current departure instructions.
Accessible documents, keys, essential supplies and pet arrangements.
Charged phones, charging cables and a small power bank for travel.
Keep your wildfire go-bag easy to reach, with its contents checked in advance. Don't delay an ordered departure to collect more gear.
Plan Home Backup Separately
For selected 120 V household essentials during a power outage, the EcoFlow TITAN 5000 Classic offers 5 kWh of nominal storage and 4 kW of rated output. Check each device's running and starting requirements, and use the system only in a location that is safe to occupy and permitted by the manufacturer's instructions.
Compatible plug-in devices can use its standalone outlets. Selected-circuit backup instead requires the compatible 120 V Smart Home Panel 10 and a qualified electrician, following local requirements.
Classic can expand to 30 kWh with compatible batteries and connection cables. Extra storage doesn't increase its 4 kW output, and the roughly 46.5 kg main unit isn't an evacuation-bag item.
How Has Fort McMurray Rebuilt Since 2016?
Fort McMurray has rebuilt much of what the fire damaged, but recovery isn't one single milestone. A repaired building, a reopened business and a household feeling settled measure different things.
The Canadian Red Cross tenth-anniversary update describes support for families, small businesses and community organizations. Its work spans evacuation, re-entry and longer-term recovery, rather than construction alone.
For your household, rebuilding also means reducing future risk where you can. RMWB FireSmart guidance identifies an immediate zone extending 0 to 1.5 metres from your home and deck.
Inspect that area for dry leaves, needles, and other combustible debris. Maintain a non-combustible surface, such as suitable gravel or concrete, and don't let items collect against the building or beneath the deck.
If you rent, raise property concerns with your landlord or building manager. You can still keep departure supplies ready and make clear transport arrangements without controlling the landscaping.
Schedule property work before an emergency, when it's safe to complete. FireSmart measures reduce risk, but they don't make a home fireproof or replace an evacuation plan.
How Much Backup Power Do Your Essential Loads Need?
Check voltage and simultaneous power first, then estimate energy use over time. Watts describe power at one moment, while watt-hours describe energy used or stored.
Estimate Energy Use and Check Starting Demand
Multiply a load's average power by the hours you need it. In a hypothetical example, a combined average load of 300 W running for eight hours uses:
300 W × 8 h = 2,400 Wh, or 2.4 kWh
That estimate excludes conversion losses, a battery reserve, and changing operating conditions. It's a planning example, not measured appliance consumption or a promised product runtime.
Use labels, measured consumption, and manufacturer instructions to check your own equipment. A fridge cycles on and off, while a motor can briefly need more power to start. An energy total alone doesn't prove that the battery or a particular outlet can start it.
Match Output and Voltage to Your Loads
Choose EcoFlow TITAN 5000 when verified higher simultaneous demand or a genuine 120 V/240 V need justifies it. Its 7.2 kW rated output supports a different load plan from Classic's 120 V-only output.
Compare output separately from stored energy:
Model | Rated Output and Voltage | Nominal Base Storage |
EcoFlow TITAN 5000 Classic | 4 kW, 120 V only. | 5 kWh, expandable to 30 kWh. |
EcoFlow TITAN 5000 | 7.2 kW, 120 V/240 V. | 5 kWh, expandable to 30 kWh. |
Higher output doesn't create longer runtime from equal usable energy. Adding compatible batteries increases stored energy, not the main unit's rated output.
For selected-circuit TITAN backup, use the compatible 120 V/240 V Smart Home Panel 10 and qualified installation. Confirm appliance, outlet, and circuit limits rather than assuming every connected load can run together.
Keep either model dry and ventilated, within its manual's limits. Backup electricity doesn't make a restricted, damaged, or smoke-affected home safe to occupy.
Prepare for the Next Alert Before You Need to Leave
Review your household contacts and departure arrangements before choosing equipment. Then list the essential loads you'd support during an outage at a home you can safely occupy.
The Fort McMurray fire shows why those plans need different priorities. Leave promptly when ordered, and don't return to retrieve or charge a battery. Once your evacuation plan is ready, compare EcoFlow TITAN home backup options against the essential loads you need to support.
What started Fort McMurray's fire?
Investigators suspected human activity in 2016, while the May 2021 investigation update didn't establish whether it was criminal. That doesn't prove arson or a specific ignition source, and hot, dry weather explains spread rather than ignition.
What was the biggest fire in Alberta history?
Fort McMurray wasn't the largest by burned area. The Canadian Disaster Database records about 1.4 million hectares for the 1950 Whisp/Chinchaga fires across Alberta and B.C., a larger historical event, though rankings depend on the metric and geographic boundary.
Did Fort McMurray rebuild after the 2016 wildfire?
Yes, substantial rebuilding took place, but physical reconstruction doesn't show whether every household fully recovered. If you're assessing a property, separate its current condition and occupancy approval from general accounts of the community's recovery.
How many homes were lost in Fort McMurray?
The commonly cited figure is approximately 2,400 homes and businesses destroyed, not 2,400 houses alone. Keep that combined scope when comparing reports, since structures, individual dwellings, and damaged properties aren't interchangeable counts.
