Hydro One Outage: How to Prepare for a Planned Power Outage
A planned Hydro One outage usually means a crew is out repairing equipment, replacing a pole or clearing trees near the lines, and you get a notice first. That notice gives you a head start, but the rest is on you. This guide covers how to check whether your address is affected, what to do the day before, and how to match backup power to what needs to keep running.
How to Check a Planned Hydro One Power Outage
Start by checking whether the Hydro One outage notice applies to your address. For a Hydro One power outage, confirm the planned start and end times on the official map, then check again closer to the work because schedules can change.
Access the Official Hydro One Outage Map
The Hydro One power outage map shows current and future planned interruptions, affected areas and available restoration information. Hydro One states that its outage tools provide updates every 10 minutes, although estimates can change as crews assess conditions.
Check the Planned Outage Schedule
Hydro One customers can select Future Planned Outages in the map legend and sign up for outage alerts through myAccount, the mobile app or text registration. Use the contact preferences and timing shown in the official notice rather than assuming every project follows the same schedule.
Confirm Whether Your Property Is Affected
Grid boundaries are not always obvious from the street. Search the Hydro One outage map with the service address or postal code and confirm whether the property falls within the planned interruption area.
How to Prepare Your Home Before a Planned Power Outage
For a planned outage, complete the main preparation the night before: charge needed devices, review food storage and plan for any heating equipment that requires electricity. Recheck the official schedule before the work begins.
Keep Refrigerated and Frozen Food Safe
Keep refrigerator and freezer doors closed. Health Canada states that an unopened refrigerator keeps food cold for about four hours, a full freezer for about 48 hours and a half-full freezer for about 24 hours. Use appliance thermometers and current food-safety guidance. For temperature-sensitive medication, follow the label and a pharmacist’s or manufacturer’s storage advice.
Charge Phones, Laptops and Other Essential Devices
Top up the phones, laptops, work lights and power banks the evening before and leave them plugged in. If you work from home, test your phone’s hotspot while the router is still up; 9 a.m. with no hydro is a bad time to find out you’re short on data.
Prepare for Heating Interruptions in Winter
A winter outage can interrupt electrically powered heating equipment. Monitor indoor temperature, reduce drafts, use safe layers and blankets, and follow local instructions if the home becomes unsafe.
  • Keep interior doors closed so the heat stays in the rooms you're using.
  • Roll up a couple of towels and lay them along the bottom of the exterior doors to block the drafts.
  • Put the wool blankets, long johns and thick socks where you can grab them in the dark.
  • If you have a certified wood stove or fireplace, check the wood supply ahead of time.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
How to Choose Backup Power for a Planned Outage
Backup planning starts with the devices that need to run and their required duration. List each load before choosing a portable power station, then compare running wattage, startup surge, stored energy and connection requirements.
Identify Essential Household Electricity Needs
Separate priority loads from optional ones. Phones, a router, safe lighting and refrigeration may be priorities for many households. Anyone who relies on powered medical equipment should follow a personal emergency plan developed with the equipment provider and health-care team.
Appliance / Device
Typical Wattage
Priority Level
Smartphones & Tablets
10W – 30W
High
Wi-Fi Router / Modem
15W – 30W
High
LED Lamps & Work Lights
10W – 40W
Medium
Full-Size Refrigerator
150W – 400W (running)
High
Furnace Fan / Sump Pump
600W – 1,200W
High (Winter/Spring)
Microwave / Coffee Maker
1,000W – 1,500W
Medium
Use a Portable Power Station for Essential Devices
For a short list like that (the work setup, phones, a lamp, maybe a small appliance), a portable station built around an LFP battery is the easiest thing to live with. There’s no fuel to store, no exhaust to worry about, and it’s quiet enough to keep in the room with you.
The EcoFlow DELTA 3 Max Plus Portable Power Station delivers a 2,048Wh capacity and a robust 3,000W AC output. During a Hydro One planned outage, it seamlessly powers daily essentials like smartphones, internet routers, LED desk lights, and other compatible compact appliances. To minimize disruption to your home office and communication, plug the unit into a wall outlet as soon as you receive Hydro One’s maintenance alert—this ensures your battery is topped up and ready to deploy the moment the line cuts.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Consider Home Backup Power for Larger Electrical Loads
If the work runs long and your list includes heating circuits, a chest freezer in the garage, a well pump or anything else with a motor, you’re looking at a system wired into the house rather than a unit you carry out of a closet.
The EcoFlow DELTA Pro Ultra is an expandable whole-home backup platform built for that scale. Storage runs from 6kWh to 90kWh and AC output from 7.2kW to 21.6kW, so the system can be sized to your household’s specific load profile. Actual backup duration and appliance compatibility will vary based on your configured battery units, electrical transfer connections and the peak starting wattage of your high-draw equipment.
EcoFlow DELTA Pro Ultra Whole-Home Backup Power
6kWh-90kWh capacity, whole house backup for weeks with comfort. One hour of solar for one day of power. Powers through the most challenging situations. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items.
How to Stay Safe During a Planned Power Outage
The same safety rules apply across power outages in Ontario: use safe lighting, operate fuel-burning generators outdoors at the required distance and keep away from damaged electrical equipment. Have a flashlight or lantern ready before service stops.
Use Flashlights for Safe Emergency Lighting
Skip the candles; an open flame in a dark house, with a dog underfoot and kids moving around, is a fire risk you don’t need. Put bright LED flashlights, headlamps or battery lanterns on the kitchen counter and the nightstands before the power cuts out, so nobody’s hunting for one in the dark.
Never Run Generators Indoors
If you’re running a conventional gas or diesel generator, it belongs outside, at least 6 metres (20 feet) from windows, doors and air intakes. Carbon monoxide is invisible, odourless and toxic, and it gives you no warning if it reaches the house. Don’t run a gas or diesel generator in a basement, breezeway, carport or garage, even with the doors wide open.
Keep Away from Damaged Power Lines
Planned work does not remove other electrical hazards. Treat every downed line as energized, keep well away, warn others and contact Hydro One or emergency services as directed. Do not approach equipment or attempt to move a wire or branch.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
What to Do When Hydro One Restores Power
After service returns, check food temperatures, clocks and sensitive electronics before resuming normal use. If a power station was used, inspect it and recharge or store it according to its manual.
Check Appliances and Electrical Equipment
Power can surge when the line comes back on, so wait a few minutes before plugging sensitive electronics back in. Then check the digital clocks, and make sure the thermostat and the water softener are back on their regular schedules.
Inspect Refrigerated Food Before Consumption
Check the appliance thermometer right away, before the fridge pulls the temperature back down. If raw poultry, meat, dairy, cooked leftovers or anything else perishable has been sitting above 4°C (40°F) for more than two hours, toss it. When in doubt, throw it out. No meal in the fridge is worth a bout of food poisoning.
Review Your Preparedness Plan for Future Outages
While it’s still fresh, go back over how the day went. Did your flashlight batteries run out? Did you wish you’d had backup power for the chest freezer? Jot down what worked and what fell short, then restock or upgrade your gear well before the next storm season starts.
Lines need work sooner or later, and a scheduled outage beats one you didn’t see coming. What you control is how much it disrupts your day. Confirm the schedule, set the fridge to its coldest, charge your devices, and keep a power station ready for the essentials. Do that and the outage comes down to a few hours of waiting, with your phone charged, your router up and a lot less to sort out when the lights come back.
How Long Do Planned Hydro One Outages Usually Last?
Duration depends on the work, site conditions and any changes crews encounter. Use the start and end times in the current Hydro One notice or outage map and continue checking for updates.
Does Hydro One Notify Customers Before a Planned Outage?
Yes. Hydro One notifies affected customers by automated phone call, text message, email or mail before scheduled maintenance.
Where Can I Report a Power Outage in My Area?
You can report a power outage through the Hydro One online outage reporting service, by calling its 24/7 outage line at 1-800-434-1235, or by texting “OUT” to 92887 (WATTS). You can also use the Hydro One mobile app to check outage information in your area.
Do I Need to Flip the Breaker After a Power Outage?
Follow Hydro One’s instructions for the specific interruption. Switch off or unplug sensitive and high-draw equipment when it is safe to do so, and do not operate the main breaker unless official guidance or an evacuation plan calls for it.
Where Can I Find the Latest Outage Map for Hydro One in Ontario?
Use Hydro One’s official Storm Centre outage map or the Hydro One mobile app, and search the service address for current information.
Power Outages
