Fraser Valley Flood Guide: Past Disasters, Current Risk and How to Stay Ready
The Fraser Valley holds some of Canada's most productive farmland, spread across a broad floodplain. Major floods hit in 1948 and again in November 2021, when Sumas Prairie turned back into a lake. In December 2025, another atmospheric river brought evacuation orders and states of local emergency to the area. For people who live and farm here, a Fraser Valley flood is a real and recurring risk. This guide explains why the valley floods, what history shows, and how to check alerts and prepare.
Why the Southern Fraser Valley Floods
The Fraser Valley floods for more than one reason. Snowmelt, heavy rain and old land use decisions all play a part. Knowing which threat is active helps you read the warnings correctly.
Spring Freshet: Snowmelt Floods on the Fraser
The Fraser River drains a huge area of the B.C. Interior. Each spring, melting snow pushes the river higher in a yearly rise called the freshet. According to Environment and Climate Change Canada, snowmelt peaks on B.C. streams typically happen from May to mid-July. Risk is highest after a big snowpack and a cool spring followed by a sudden hot spell. That pattern drove the 1948 flood.
Atmospheric Rivers: Fall and Winter Rain Floods
Fall and winter bring a different threat. Long bands of moist Pacific air can stall over the coast for days. Atmospheric rivers that soak the coast can overwhelm smaller rivers quickly. In the southern Fraser Valley, the Nooksack River in Washington State is a key concern. When it overflows, water can spill north across the border into the Sumas River and Sumas Prairie. Both the 2021 and December 2025 floods followed this pattern.
Sumas Lake, Dikes and Pump Stations
Sumas Prairie was once Sumas Lake. Heritage Abbotsford notes the lake covered about 10,000 acres and often tripled in size during the freshet. Drainage began in 1920 and soon turned the lakebed into farmland. Today, the Province of B.C. says 40 km of flood protection dikes and 16 pumps help protect Sumas Prairie.
The Barrowtown Pump Station is the heart of this system. It moves water from the Sumas River into the Fraser. When floodwaters overwhelm it, as they did in 2021, the old lakebed can refill.
Flood Driver | Typical Season | What Triggers It | Areas Most at Risk |
Fraser River freshet | May to mid-July | Rapid snowmelt in the Interior | Low-lying land along the Fraser, behind dikes |
Atmospheric river rain | Fall and winter | Days of heavy Pacific rain | Sumas Prairie, Chilliwack River, smaller tributaries |
Nooksack River overflow | Fall and winter, during heavy rain | Overflow from Washington State | Sumas Prairie and south Abbotsford |
Understanding the causes makes the big floods easier to follow. Here is what happened in the three events people still talk about most.
Fraser Valley Flooding in History: 1948, 2021 and 2025
Fraser Valley flooding has a long record. Each major event changed how the region builds dikes and plans for emergencies. These events fit a wider pattern of flooding across British Columbia, but the valley's low farmland makes it especially exposed.
The Great Flood of 1948
The 1948 flood was a freshet flood. The Fraser Basin Council's FloodWise site ranks it as the second largest Fraser flood on written record, after 1894. Over a dozen dike systems were breached.
November 2021 Atmospheric River and Sumas Prairie
In mid-November 2021, a series of atmospheric rivers hit southern B.C. The Nooksack River overflowed, and the old Sumas lakebed flooded. Highway 1 flooded, and other closures cut road links between the Lower Mainland and the rest of Canada.
December 2025 Atmospheric River
In December 2025, another atmospheric river soaked the region, and the Nooksack spilled into Sumas Prairie again. Hundreds of properties were placed under evacuation orders or alerts.
This flood was less severe than 2021. Still, it showed the risk has not gone away.
Event | Main Cause | Verified Key Facts | Source |
1948 | Spring freshet | Peak of 7.6 m at Mission on June 10; over 22,000 hectares flooded; about 16,000 people evacuated | Environment and Climate Change Canada; Coquitlam heritage records |
November 2021 | Atmospheric rivers and Nooksack overflow | Provincial state of emergency on Nov. 17; $675 million in insured losses; 628,000 poultry, 12,000 hogs and 420 dairy cattle lost | Province of B.C.; Insurance Bureau of Canada; B.C. Minister of Agriculture |
December 2025 | Atmospheric river and Nooksack overflow | Flood warnings for the Sumas and Chilliwack rivers; FVRD and Chilliwack states of local emergency; evacuation orders and alerts | BC River Forecast Centre; FVRD; City of Chilliwack |
The Insurance Bureau of Canada calls the November 2021 floods the most costly severe weather event in B.C. history.
History shows floods often bring power outages, closed roads and short notice to leave. That makes planning ahead the most useful step you can take.
Preparing Your Home, Family and Backup Power Before a Flood
Preparation works best before the forecast turns. A good plan covers your home, your people and the power you need for a few days away.
Protect Your Home
Clear storm drains, gutters and ditches near your property before heavy rain.
Move valuables, documents and electronics to an upper floor.
Know where your main electrical panel and gas shut-off are.
Turn off power only if you are told to evacuate and the house is not yet flooded.
Check whether your home insurance includes overland flood coverage.
Make an Evacuation Plan
Evacuation orders in the Fraser Valley can come with very little notice. Agree on a meeting place outside the flood zone. Plan two routes out, since low roads often close first. Having a written plan for leaving quickly helps every household member know their job. Farm families should also plan early for moving or sheltering livestock.
Keep Essentials Powered During Outages and Evacuation
Floods often knock out power, sometimes for days. A portable power station can keep phones, lights, a radio and Wi-Fi running while you wait for updates.
Placement matters as much as capacity. Keep a power station dry, raised off the floor and well away from standing water.
The DELTA 3 Ultra Plus offers 3072Wh of capacity for essential devices during a flood-related outage. Runtime depends on load, and it can be transported with you if it is safe to do so.
If you evacuate, recharging becomes the next challenge. An alternator charger lets a compatible power station, such as the DELTA 3 Ultra Plus with the correct cable, recharge while you drive.
Install it before flood season, check vehicle compatibility first and consider a professional install. Never idle a vehicle in a garage to charge anything.
With a plan in place, the next step is knowing where to look when the rain starts.
How to Check Fraser Valley Floods Today
During a flood, official sources update faster than social media. Bookmark them now, before you need them. Many of the same tools also track storm warnings and highway closure updates across the province.
Source | What It Tells You | Best For |
BC River Forecast Centre | River levels, forecasts and advisory levels | Knowing if a river is rising |
EmergencyInfoBC | Provincial emergency updates, evacuation orders and alerts | Confirming official orders |
City of Abbotsford (abbotsford.ca and city social media) | Local flood updates and road closures | Sumas Prairie and Abbotsford residents |
City of Chilliwack (Alertable) | Free app, text, email or phone alerts | Chilliwack residents and visitors |
FVRD (Alertable) | Alerts for the FVRD's eight electoral areas | Rural Fraser Valley residents |
DriveBC | Highway conditions, closures and webcams | Planning evacuation routes |
Environment Canada weather alerts | Rainfall warnings and forecasts | Knowing when heavy rain is coming |
What River Forecast Centre Advisories Mean
The BC River Forecast Centre uses three levels, and each one signals a different level of risk:
High Streamflow Advisory: River levels are rising or may rise quickly, but major flooding is not expected. Minor flooding in low-lying areas is possible.
Flood Watch: River levels are rising and may approach or exceed bankfull. Areas next to the river may flood.
Flood Warning: River levels have exceeded bankfull or will very soon. Flooding of nearby areas will result.
Evacuation Alert vs. Evacuation Order
An evacuation alert means you should be ready to leave on short notice. An evacuation order means you must leave now. EmergencyInfoBC posts both as they are issued. Pack your grab-and-go kit during the alert stage, not after the order arrives.
Knowing what is coming is one part of staying safe. The other part is knowing what to avoid once water arrives.
Staying Safe During and After a Fraser Valley Flood
Most flood injuries happen when people misjudge water or electricity. A few firm rules can prevent the worst mistakes, whether you stay or return after an evacuation.
During the Flood
Never walk or drive through floodwater. Fast-moving water can sweep away a person or a vehicle. Stay away from riverbanks, ditches and dikes. In practice, staying safe when water starts rising usually means moving to higher ground early.
Electrical Safety in a Flooded Home
Never operate electrical equipment while standing in water.
Do not touch electrical panels or controls if your home is already flooded.
Do not re-energize flooded circuits yourself.
Technical Safety BC says not to turn on flood-exposed electrical or gas equipment until a licensed contractor has checked it.
Have flood-affected appliances inspected by a qualified person before use.
Returning Home
Only return when officials say it is safe. Treat floodwater as contaminated, and wear gloves and boots during cleanup. Photograph damage before you remove anything, since insurers will ask for it.
The Fraser Valley faces two flood seasons: the spring freshet and fall and winter atmospheric rivers. History from 1948, 2021 and 2025 shows floods can arrive fast and cut off roads and power. Bookmark official alert sources, make an evacuation plan and follow electrical safety rules. A dry, elevated EcoFlow DELTA 3 Ultra Plus can help keep essentials running. Paired with an 800W Alternator Charger, it can also recharge on the road.
When Is Flood Season in the Fraser Valley?
There are two. The Fraser River freshet typically peaks between May and mid-July. Atmospheric river floods usually happen in fall and winter.
What Caused the 2021 Sumas Prairie Flood?
Atmospheric rivers made the Nooksack River overflow into the Sumas River system, refilling the former Sumas Lake bed.
How Can I Check for Fraser Valley Floods Today?
Start with the BC River Forecast Centre and EmergencyInfoBC. Then sign up for local Alertable notifications and use DriveBC for road closures.
Can I Use a Portable Power Station During a Flood?
Yes, if it stays dry and elevated. Do not connect it to flooded home wiring until a licensed electrical contractor has checked the system.
What Was the Biggest Flood in Fraser Valley History?
The 1894 Fraser River flood is the largest on written record, followed by 1948. By insured losses, November 2021 was the costliest.
