Igloofest Power Kit: Stay Warm, Charged, and Ready for Winter Raves
Held outdoors in the freezing cold of winter in Quebec and Alberta, Igloofest is known as the “coldest music festival in the world” for good reason. If you’re bold enough to brave the elements, it’s a unique and exciting way to experience live music surrounded by ice decor, stylish snowsuits, and good vibes.
But if you’re not warm, Igloofest will be anything but fun! Staying cozy, charged, and ready for the raves ahead is critical. We’re walking you through everything you need for a comprehensive Igloofest power kit, including the EcoFlow RIVER 3 Plus portable power station to help you stay charged.
What Makes Igloofest One of the Most Unique Winter Festivals?
While most music festivals plan their timing around gorgeous weather, Igloofest is bucking the norm and instead embracing the harsh Canadian winter to create a unique experience for all its partygoers.
Igloofest takes place in the high winter season, with dates across Montreal, Gatineau, and Quebec from January to March. It’s become one of the world’s largest outdoor winter music festivals and one of the most popular outdoor winter activities in Canada.
The temperatures here are not for the amateur—they can drop to -20ºC and colder, making proper dressing and equipment for the elements crucial. But rather than treating the cold as a reason to stay indoors, festival-goers don their best snowsuits (and even compete for a “best snowsuit” prize!), dance hard to stay warm, and treat the temperature as part of the experience.
Why Portable Power Is Ideal for Igloofest
Sub-zero temperatures are serious, and they require reliable power that can withstand the battery drain to ensure you stay warm. A power bank won’t cut it, but you can’t bring your entire whole-home generator! You need something that falls in the middle, providing portable yet ample power.
Heated gloves, jackets, and boots can help you stay warm in extreme cold, but they all draw continuous power. A portable power station is compact enough to stash in your bag but robust enough to run multiple devices simultaneously.
It can also keep your phone alive for finding your way (or finding friends), ride-hailing, and emergency communication. You can recharge it as needed between sets or during breaks without needing to find an outlet.
What to Pack in an Igloofest Power Kit
Your power kit includes your power source and every device you’ll charge with it, such as heating clothing and accessories. Be thoughtful and ensure every item serves a purpose, because dead weight in brutal temperatures will use energy you can’t spare.
To avoid running out of power, prioritize gear with efficient power draw so you don’t burn through your capacity too quickly.
But buying the equipment is only half the process. Remember to test your gear at home before heading to the festival so you know how it works and ensure it works without problems.
Heating Essentials
  • Heated jacket or vest with USB input
  • Heated gloves or mittens to keep your hands functional
  • Heated insoles to extend time on your feet
  • Hand warmers (rechargeable > disposable for long days)
Charging Devices and Accessories
  • Smartphone—keep your map, tickets, contacts, and emergency services on hand
  • Cables reinforced for cold weather
  • Backup charging cables
  • Multi-port USB hub or splitter for simultaneous charging
Lighting and Visibility
  • Clip-on LED light or headlamp
  • Festival-safe glow accessories (hats, wristbands)
Power Source
  • The EcoFlow RIVER 3 Plus is the perfect anchor for all your Igloofest power needs. It can handle cold weather, charge multiple devices at once, and is lightweight enough to fit in your gear pack.
    • 286Wh capacity
    • Only weighs 10.4 lbs
    • Can top up the battery in the car on the way to the festival
    • 3 AC ports, 2 USB-A ports, 1 USB-C port, 1 car port
    • Whisper quiet <30 dB
Tips for Managing Power at Igloofest
  • Charge your devices the night before so you arrive with full batteries (including the power station itself).
  • Set your heated gear to medium levels (not max) so you can minimize power draw. You’ll feel warmer once you’re moving and dancing!
  • Turn on battery-saver mode on any devices you can, especially your phone. This will minimize background drain.
  • Disable Wi-Fi and use cell service only. If your phone is searching for networks to join, it will burn through your battery faster.
  • Whoever is carrying the portable power station should serve as the “power hub.” Having this one centralized power source will be more efficient than everyone in the group managing their own.
  • Keep your power station in an insulated bag within your backpack to minimize cold ambient temperatures and improve output efficiency.
Under 10ms UPS protection, 600W output (1200W with X-Boost), and expandable up to 858Wh—perfect for light appliances. Enjoy 1-hour fast charging, up to 220W solar input, and ultra-quiet <30dB operation in a compact, wire-free design.
What Kind of Music Is Igloofest?
Igloofest features top electronic music artists, including genres such as techno, house, and bass-heavy DJ sets. Local and international DJs travel to Canada to perform on multiple outdoor stages throughout the night. The set list focuses on high-energy dance music to keep crowds dancing and moving for warmth.
Is Igloofest Free?
Igloo fest is not free; it is a ticketed event that requires tickets for general admission or VIP tiers. You can purchase tickets online in advance, with prices varying based on which night you attend and who’s on the lineup. Early-bird pricing may be available. Check the official website to see all options.
Portable Power Stations Support Heating Gear and Devices at Igloofest
If you’re not afraid of freezing weather and enjoy electronic dance music, Igloofest might be the next unique experience to add to your list. You can dance, enjoy icy decor, explore food trucks, and feel the camaraderie that’s only possible in such extreme conditions. The idea is to embrace the freezing temperatures and make it part of the fun—keep dancing to keep warm!
Beyond that, a well-built power kit featuring the EcoFlow RIVER 3 Plus can ensure your night is unforgettable in the best ways. It can keep your heated clothing, gear and devices charged all night long, maintaining your comfort and safety no matter what the night brings.
Off-Grid Power
