Winter Plug In Car: When and How to Plug in Your Car
Anyone who has started a car at -30 degrees Celsius in Saskatchewan or Alberta knows how stubborn a cold engine can be. Cold weather thickens engine oil, reduces battery performance, and makes starting tougher than usual.
That’s why plugging in is a common winter habit across the Prairies and most of Canada, and an engine block heater is the accessory that makes it work.
Every fall, people look for advice on plugging in a car in winter, so this guide tackles the practical questions: when to plug in, how long to stay connected, how block heaters operate, and how to prepare your vehicle for harsh cold.
What Does Plugging in Your Car During Winter Do?
Plugging in turns on an engine block heater, which is a small electric heater that keeps the engine warm while the vehicle is parked. According to Natural Resources Canada, a block heater warms the coolant, which then warms the engine block and lubricants. Using a block heater at temperatures around -20°C can also improve overall fuel economy by up to 10%. Actual benefits depend on the vehicle, driving conditions, and trip length.
Many drivers wonder whether a plug in car winter routine is worth the effort. In deep cold, the answer is usually yes, because a warmer engine suffers less strain at startup.
What is an Engine Block Heater and How Does it Operate?
A block heater uses electricity to warm either the engine coolant or the engine block, depending on its design. Some replace a freeze plug in the block, while others heat the coolant or the oil pan. A short cord, often tucked behind the grille, connects to an extension cord and then to an outlet.
Warmer components make cold starts easier, and because the engine starts closer to its operating temperature, the heating system produces warm air sooner. Some systems also have a thermostat. The recommended temperature for using a block heater varies by vehicle, so consult your owner's manual.
Does Plugging in Your Car Charge the Battery?
No. An engine block heater is not connected to the 12V battery, so it does not charge or maintain it. A battery maintainer or charger is a separate device. Because cold weather reduces battery performance, have the battery load-tested before winter and follow your vehicle manufacturer’s recommendations. You can also clean the terminals and consider replacement if the battery is four to five years old.
When Should You Plug Your Car In Winter?
The right moment depends on the outdoor temperature and on your vehicle’s design. Many Canadian drivers begin using block heaters when temperatures fall below approximately -15°C. Some vehicle manufacturers recommend their use at around -18°C or lower. The appropriate threshold depends on the engine, oil specification, and vehicle design, so always consult the owner's manual.
What Temperature Should Your Winter Car Plug In?
Engine oil gets thicker as temperatures fall. Below -15°C, it thickens enough to make cold starts noticeably harder, which is why block heaters matter most in severe cold. Above that range, many modern engines start without one.
Diesel vehicles may require additional cold-weather preparation because diesel fuel can gel at low temperatures. Use winter-grade diesel fuel and only manufacturer-approved anti-gel additives when recommended. Keeping the fuel tank adequately filled can also help reduce moisture accumulation, particularly during extended storage.
How Long Should You Leave Your Car Plugged In?
A common recommendation is to allow two to four hours before driving. Leaving a vehicle plugged in causes no harm, but it wastes electricity. An outdoor-rated timer takes care of this by turning on the heater a few hours before you leave. Leaving it connected overnight is generally unnecessary.
Can You Use a Portable Power Station to Plug in Your Car During Winter?
Sometimes there is no convenient outlet. You may park outdoors at a rental, at a cottage, at a camping area, or in temporary winter storage. In those cases, a portable power station can provide AC power for a compatible 120V block heater, which is one way to plug in your car in winter without a fixed outlet. Before choosing a unit, check the heater’s voltage, wattage, plug type, and how long you need to run it. The label on the heater or in the manual will list these.
Portable Backup Electricity for Car Block Heaters
Imagine an early-morning drive on a -25°C day, with no outdoor outlet within reach of the car. The EcoFlow DELTA 3000 Gen4 has a 3,072Wh battery, 3,600W of continuous AC output, and 7,200W of surge capability. Its 120V AC output can run compatible block heaters within its rated limits. Actual operating time depends on the heater’s wattage and the unit’s conversion efficiency.
Higher-Capacity Portable Power for Longer Winter Heating Requirements
If you need more stored energy for longer heating periods or other essential equipment, consider the EcoFlow DELTA 3800 Gen4. It offers 3,763Wh of capacity, 3,600W of continuous AC output, and 7,200W of surge capability. EcoFlow lists expandable capacity up to 12kWh. Under comparable conditions, the extra capacity provides more operating time than the DELTA 3000 Gen4.
A runtime reality check: A 1,500W block heater uses about 1.5 kWh per hour. The 3,072Wh unit will run for about two hours at that load on paper, and the 3,763Wh unit about two and a half hours. Conversion losses will reduce real-world runtime, so don’t expect either unit to deliver 2 to 4 hours at 1,500W. Lower-wattage heaters last longer. For example, a 600W heater could theoretically run for about five hours on the backup power of DELTA 3000 Gen4.
Temperature limits: EcoFlow specifies a discharge temperature range of -10°C to 45°C and a charging temperature range of 0°C to 45°C for both units. Keep the power station in a dry, sheltered and ventilated location, within its specified temperature limits. Do not expose it directly to rain, snow, or extreme outdoor temperatures. When powering an outdoor block heater, keep the power station protected indoors and route only a suitable outdoor-rated power cord to the vehicle.
How to Plug Car in Winter Safely
Before the first deep freeze, inspect the block heater cord for cracks, frayed insulation, and loose connections. It is recommended to check it every year. Use electrical equipment rated for outdoor use and for the heater’s load, and unplug the cord before you drive away.
Use an Outdoor-Rated Extension Cord
Cold makes ordinary cords stiff and brittle. Choose a cold-weather-rated outdoor extension cord with an electrical rating suitable for your block heater. Check it for cracks, damaged insulation, exposed wiring, and loose plugs, and replace it if anything looks worn.
Use a Suitable Outdoor Electrical Outlet
Plug into a properly installed outdoor receptacle with GFCI protection and a weather-resistant cover. Keep connections out of standing water, snow banks, and other moisture, since snowmelt can reach an exposed plug.
Consider an Outdoor Timer
A timer switches the heater on a few hours before you leave, so you don't have to run out in the dark. It also avoids paying to heat an engine overnight when two to four hours is enough. Choose one rated for outdoor use and for the heater’s wattage.
Plugging in a car during extreme cold makes starting easier and reduces cold-start strain on the engine. Follow your manufacturer’s recommendations, use a timer, and keep outdoor connections safe. When no outlet is available, the EcoFlow DELTA 3000 Gen4 and DELTA 3800 Gen4 can supply compatible block heaters. For more cold-weather planning, read EcoFlow’s guides on preparing a home for winter and backup power for warmth and safety.
Ready to choose? Explore EcoFlow’s portable power stations.
Why plug car in winter?
Plugging in powers the block heater, which warms the engine, so it starts more easily in extreme cold, reduces strain on engine parts, and brings cabin heat sooner.
How do you plug in your car in winter?
Find the block heater cord. It's usually by the grille. Plug it into an outdoor-rated extension cord and then into a GFCI-protected outdoor outlet, preferably with a timer. Turn it off before you drive.
At what temperature should you plug your car in Canada?
Many sources suggest plugging in at about -15°C or colder. Some systems only begin working near -18°C, so check your owner’s manual.
Can I leave my car plugged in all night?
You can not harm the vehicle, but it is generally unnecessary and wastes electricity. Two to four hours before driving, set on a timer, is usually enough.
