Black Friday Sales in Canada: 2026 EcoFlow Deals
EcoFlow's Black Friday sales in Canada start at CAD $699 across these three power stations. Choose a lighter trip kit, double the stored energy for $290 more, or step up to a larger home-backup option.
The best buy is the one you'll use, whether that's charging camera batteries on a trip or keeping key devices running at home.
The current early sale runs from November 2 to 18, 2026. Black Friday in Canada falls on November 27, followed by Cyber Monday on November 30.
Match Your Budget to the Devices You'll Use
Start with the devices you want to use, then match the sale price to that job. Extra storage pays for itself by giving you more time between charges.
Watts (W) show power at one time, while watt-hours (Wh) show stored energy.
These standalone offers were checked on November 12, 2026. DELTA 3 Max and Gen4 offers are labelled member-only, so confirm your eligible offer and final total before paying.
Displayed Price, CAD
Main Difference
DELTA 3 Classic
$699
1,024 Wh storage and 1,800 W rated AC output. About 12.1 kg for a smaller vehicle-based trip kit.
DELTA 3 Max
$989, member-exclusive. Advertised 53% off.
2,048 Wh storage and 2,400 W total rated AC output. About 20.3 kg for a larger plug-in device plan.
DELTA 3000 Gen4
$1,599, member-only. Advertised 36% off.
Fixed 3,072 Wh storage and 3,600 W total rated AC output. About 26 kg, with no battery expansion.
All three supply 120 V AC in their Canadian versions. Prices cover the selected station, without solar panels, and can change with the offer period. Advertised discounts use the reference prices shown with each offer.
Keep a Smaller Kit for Vehicle-Based Trips
Start with the gear you already take, such as a portable cooler, camera batteries, and lights. Check the cooler's running and starting power before choosing a battery.
The EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) is $699 for a smaller trip kit, with 1,024 Wh of stored energy. Its 1,800 W rated AC output must cover the devices you plan to use together.
1. 4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 2. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and heated blankets. 3. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
At about 12.1 kg, it's the lightest of these three options and is easier to pack into a vehicle. That makes it worth a look when you want portable power without the larger unit's cost or weight. Plan a dry, ventilated place to use it.
When choosing a camping power station, count the time between chances to recharge. If you only need phone charging, a small power bank may already cover the trip.
Add More Stored Energy for Essential Devices
More devices or longer gaps between charges can make the middle option useful. A home plan might put a fridge, LED lights, and phone charging ahead of less urgent loads.
The EcoFlow DELTA 3 Max Portable Power Station (2048Wh) is $989 under the member-exclusive offer. You get 2,048 Wh of stored energy and 2,400 W total rated 120 V AC output for devices whose running and starting demands fit.
EcoFlow DELTA 3 Max (2048Wh)
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport. 5. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
For $290 more than the Classic, you get twice the rated storage. That step can make sense if your fridge and lights need more energy between charges. It does not guarantee twice the runtime, since device use and AC energy losses affect the result.
The Max weighs about 20.3 kg. Choose a spot you can reach and lift into safely, rather than buying first and finding space later.
This is DELTA 3 Max, not Max Plus. Use the selected Max ratings when checking your equipment.
Choose a Larger Fixed Battery Only When the Plan Needs It
A larger battery can cover a bigger gap between charges, but it doesn't always give you room to expand. Decide how much energy your device list needs before moving up a price tier.
At $1,599, the EcoFlow DELTA 3000 Gen4 Portable Power Station pairs 3,072 Wh of storage with 3,600 W total rated 120 V AC output. It's a step up for more demanding plug-in devices or a longer gap between charges.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The $610 step from the Max adds 1,024 Wh of rated storage and higher total output. Choose it when those gains serve your home plan. The 3000 model doesn't support capacity expansion, so buy for the storage you need now.
Its higher total output also doesn't mean every socket can supply the full amount. The ordinary AC outlets have a 20 A limit each, within the shared total, and motors can need extra power when starting.
At about 26 kg, it needs a planned place and a manageable lift. Keep it dry and well ventilated. Its IP20 rating doesn't make it suitable for rain or snow.
None of these standalone choices directly supplies 240 V appliances or connects itself to hardwired home circuits. Treat watts, stored energy, and the connection method as separate checks.
 A diagram separates device power, stored energy, and connection checks when choosing a power station. A diagram separates device power, stored energy, and connection checks when choosing a power station.
Compare the Whole Basket Before Adding Extras
Compare Canadian Black Friday deals using the same needed parts, rather than the lowest headline price. An accessory earns its place when it fills a gap in your power plan.
An EcoFlow DELTA 3000 Gen4 stands in a dry kitchen beside household appliances.An EcoFlow DELTA 3000 Gen4 stands in a dry kitchen beside household appliances.
Check What the Selected Price Includes
A standalone station can be enough if you already have suitable wall-charging access. A solar bundle adds panels, but the exact contents still depend on the option you select.
Compare the bundle with the current cost of buying those same needed parts separately. Include any required cable or connector so one basket doesn't look cheaper simply because it leaves something out.
Check the written contents for the exact model, number of units, panels, and charging cables. A product photo can show how a setup works without showing everything included in that price.
You don't need to buy a panel just because the larger bundle has a bigger discount badge. Keep the money for a part you will use, or choose the simpler kit.
Give Each Charging Extra a Job
Think about where the next charge will happen. Reliable wall access before each outing may make a standalone purchase the cleaner choice.
Compatible solar panels can help where suitable sunlight is available, and wall power isn't. Check the station's solar input limits, the panel's voltage and current, and the cable needed to connect them.
The panel's rated watts don't promise that output through a Canadian winter day. Shade, short daylight hours, and weather can change how much energy you collect.
Keep the station dry and ventilated, within its allowed charging temperatures. A cover doesn't make wet operation safe, and a door or window isn't a safe place to pinch a charging cable.
 An EcoFlow DELTA 3 Max charges in a dry utility area with clear ventilation. An EcoFlow DELTA 3 Max charges in a dry utility area with clear ventilation.
Check the Dates and Terms Behind Your Offer
Each Black Friday sale in Canada has its own dates and conditions. Confirm the offer attached to your chosen model, rather than assuming every banner or code applies.
Confirm Eligibility and the Final Cost
Review the details that can change your order total or delivery plan:
  • The exact model and standalone or bundle option.
  • The current offer dates and any member requirement.
  • Whether a code applies to that selected product.
  • Applicable taxes, shipping charges, and postal-code eligibility.
  • The delivery estimate for the complete order.
The current Gen4 subscription offer excludes the standalone DELTA 3000 Gen4. Don't take another 5% off its displayed price when comparing these three options.
Current campaign rules allow only one coupon per order. Don't assume it can stack with EcoCredits or another offer.
Qualifying orders may also include a gift under the campaign rules. Gifts are randomly assigned, with one per order based on the highest qualifying spending tier. Adding an item you don't need just to reach a tier can still raise your final cost.
Read Return and Price-Protection Conditions
Check the return and refund terms before ordering equipment you may struggle to lift, store, or use. Return shipping and transaction fees can apply, so a change of mind isn't always cost-free.
Keep the original packaging and follow the return process. If your order includes a promotional gift, check what must come back with the main product.
Price protection is a separate check. The current campaign excludes Flash Sale items from its 30-day price-match guarantee, while a product launch can have different rules.
Don't assume a later price drop will qualify for a refund. Check the exact product, purchase period, and claim process. Keep your order details.
A laptop and notebook are ready for checking an online order's contents and terms.A laptop and notebook are ready for checking an online order's contents and terms.
Choose the Deal That Fits Your Power Plan
Put your budget toward the power you'll use. At the checked prices, $699 buys the lighter Classic, $989 buys twice its rated storage in the Max, and $1,599 brings more storage and output with Gen4.
Ready to choose? Match your device list to the current EcoFlow Black Friday offers, confirm the final total, and pick the setup that fits. A useful sale purchase should still feel right once the box arrives.
Should I buy on Black Friday or wait for Cyber Monday?
Buy when the confirmed offer meets your needs and budget, rather than assuming Cyber Monday will be cheaper. If you may want to claim a later price adjustment, check the exact product's price-protection terms before ordering.
Does a power-station deal include solar panels?
Only a selected bundle that lists panels includes them. A standalone station and a solar bundle can share a product page, so use the chosen option's written contents to confirm what you're buying.
Can I combine a sale price with another discount code?
You can combine discounts only when the terms for that product and offer allow it. Check the exclusions before applying a code, and don't assume coupons, EcoCredits, and other benefits can be used together.
Are EcoFlow Black Friday offers available everywhere in Canada?
The current campaign excludes the Northwest Territories, Nunavut, and Yukon. Check eligibility and shipping for your postal code, since a Canadian store listing doesn't guarantee delivery to every address.
