What Is the Hottest City in Canada? Rankings, Records, and Facts
Ask ten Canadians which city is the hottest and the answers won't agree. Windsor, Kelowna, and Lytton have each earned a real claim to the title, just by different measures. Hottest city Canada searches usually assume there's one answer, but the hottest place in Canada actually depends on how "hottest" gets measured: average summer heat, most days above 30°C, the warmest year-round climate, or the single hottest day on record. This guide breaks down how that title actually gets decided, the top contenders by each method, and how to handle the heat if a hot-weather city is home.
What Does "Hottest City in Canada" Actually Mean?
The title depends entirely on which measure gets used, and several different cities can each have a fair claim depending on the question being asked.
Average summer daily high, the number of days above 30°C, the highest annual mean temperature, and the single hottest day on record all crowns a different winner. On average, summer daily highs among Canada's major metro areas, those with a population over 100,000, Windsor, Ontario comes out on top, with a June-through-August average daily high of about 26.9°C, per Environment and Climate Change Canada's 1981 to 2010 climate normals.
Lytton, BC isn't part of that major-city ranking at all, since its population is too small to qualify, despite holding the actual national temperature record. That distinction matters for the rest of this guide, since Lytton's record is a different kind of "hottest" than Windsor's.
Windsor wins on the "typical summer" measure, but the single hottest day in Canadian history belongs somewhere else entirely.
Lytton, BC: Canada's Hottest Place on Record
hottest part of canadahottest part of canada
On June 29, 2021, Lytton hit 49.6°C, the highest temperature ever officially recorded anywhere in Canada, confirmed by Environment and Climate Change Canada. That single reading is why Lytton is called Canada's hottest place, even though it isn't usually counted among the country's hottest cities.
The reading broke the previous national record of 45°C, set in Saskatchewan back in 1937, by nearly 5 degrees, and it did that during a single week of the 2021 heat dome that pushed temperatures across Western Canada to levels nobody had measured before. An 84-year-old record didn't just break, it got obliterated.
It's worth being clear that this was a historic outlier, not a typical Lytton summer. The town's average summer high normally runs somewhere between 32°C and 35°C, hot by Canadian standards but nowhere near the 49.6°C spike that puts it on the map. Spotting the early symptoms of heat stress before they escalate matters most in exactly this kind of sudden spike, since dizziness, confusion, and a rapid heartbeat can show up before anyone thinks about checking a thermometer.
EcoFlow WAVE 3 Portable Air Conditioner
Delivers 6,100 BTU of cooling power (about 1,800 W) in a rapid-cool mode that drops room temperature by 8°C in 15 minutes, and doubles as a 6,800 BTU heater for cooler nights. Runs wirelessly off an EcoFlow DELTA power station or its own add-on battery rather than needing a dedicated wall circuit, with 2 to 8 hours of runtime depending on the battery paired with it, and operates at 44 to 58 decibels. Priced around $1,129 CAD, though EcoFlow runs periodic sales worth checking before buying.
Windsor and Lytton each hold one title, but a handful of other cities have a real claim too.
Other Cities That Claim the "Hottest" Title
Windsor and Lytton don't have the field for themselves. A handful of other cities beat both of them on at least one measure.
Kelowna, BC leads the country on the number of days at or above 30°C, with about 26 a year, narrowly ahead of Windsor's average daily high by only around 0.2°C on the broader summer measure. The two cities essentially trade the top spot depending on which specific number gets compared.
Osoyoos, BC claims a different title entirely, with the warmest annual mean daily temperature anywhere in the country and most days over both 20°C and 30°C of any Canadian location, a claim the town leans into with its own "Canada's warmest welcome" tourism slogan.
Kamloops, BC and Medicine Hat, AB round out the list. Both sit in semi-arid interior or Prairie climates with long stretches above 30°C most summers, even though neither shows up at the very top of any single ranking.
That kind of repeated, multi-week heat is exactly what heat warnings across the BC Interior and the Prairies are designed to catch early, since the risk compounds the longer a stretch runs rather than resetting each morning.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
Starts at 3,072 Wh, expandable with add-on batteries. 3,600 W continuous output with a 7,200 W surge, and a full charge from empty to 80 percent in about 48 minutes using solar and generator input together. Sized to keep a fridge and fans running if grid strain during a multi-week heat stretch turns into an actual outage. Priced around $1,899 CAD, though EcoFlow runs periodic sales worth checking before buying.
Knowing which city is hottest is one thing, deciding whether to actually live there is another.
Is One of Canada's Hottest Cities a Good Place to Live?
Hottest doesn't automatically mean best, or worst, it just means different trade-offs depending on what actually matters day to day.
The Okanagan cities, Kelowna and Osoyoos among them, get warm, dry summers, while Windsor's heat comes with real humidity, and that difference changes how the same number on a thermometer actually feels. Central air conditioners running close to nonstop across thousands of homes at once is when the local grid starts to feel real strain, the same pattern that shows up whenever a multi-day heat wave settles over the Greater Toronto Area.
Winters differ just as sharply. The Prairie and BC Interior cities that run hot in summer, Kelowna, Osoyoos, Kamloops, Medicine Hat, also get genuinely cold winters, while Windsor's stay comparatively mild. That's worth weighing for anyone relocating specifically for the warm weather rather than just visiting in July.
Wherever you land on that list, the practical question is the same: how do you handle the heat once it's here?
How to Handle Extreme Heat in Canada's Hottest Cities
Canada's Hottest CitiesCanada's Hottest Cities
The specifics change by city, but the core playbook for surviving a heat wave doesn't.
  • Stay hydrated throughout the day, not just when thirsty.
  • Identify one genuinely cool room and spend peak hours there.
  • Close blinds and curtains during peak sun hours, before the room has already heated up.
  • Check on elderly or vulnerable neighbours, since heat risk climbs fastest for them.
  • Know the signs of heat stroke: confusion, a rapid pulse, hot skin that isn't sweating.
Overnight lows matter just as much as the daytime high, since a night that never drops below 20°C doesn't give a home, or a body, much chance to recover before the next day's heat starts building on top of it. That's the same logic behind treating cooling and backup power as season-ahead prep rather than something to sort out once a heat warning is already flashing on a phone.
With the rankings and the safety basics covered, here's the short version.
There's no single hottest city in Canada, it depends entirely on the measure. Windsor wins on average summer heat, Kelowna on the most days above 30°C, Osoyoos on annual warmth, and Lytton on the all-time record. Whichever hot-weather city is home or next on the list, the practical move is the same: treat cooling and backup power as season-ahead prep. The WAVE 3 and DELTA 3 Ultra Plus covered above are worth having charged and ready well before the first heat warning of the year.
What is officially the hottest city in Canada?
There's no single official answer, since it depends on the measure. Windsor, Ontario has the highest average summer daily high among Canada's major cities, based on Environment and Climate Change Canada's climate normals.
Is Lytton, BC still considered the hottest place in Canada?
Yes, for the all-time record. Lytton hit 49.6°C on June 29, 2021, the highest temperature ever recorded anywhere in the country. It's usually left out of the "hottest city" rankings because its population is too small to qualify as a major city, not because the record doesn't count.
What's the hottest city in Canada to actually live in long-term?
That depends on personal preference more than any ranking. The Okanagan cities offer warm, dry summers with cold winters, while Windsor's summers are hotter and more humid with milder winters. Neither is objectively better, they're just different trade-offs.
Which Canadian city has the most days above 30°C?
Kelowna, BC leads with roughly 26 days a year at or above 30°C, narrowly ahead of Windsor.
Is Windsor or Kelowna hotter in summer?
It's close enough to call a tie. Windsor leads on average summer daily highs by about 0.2°C, while Kelowna leads on the number of days that actually reach 30°C or higher.
How do I stay safe if I live somewhere with frequent extreme heat?
Stay hydrated, keep one room genuinely cool, close blinds during peak sun hours, and check on elderly or vulnerable neighbours during a heat warning. Having backup cooling and power ready before summer starts, something like an EcoFlow WAVE 3 paired with a charged power station, matters more than scrambling once a heat dome is already forecast.
Home Backup
