Generac Generators Cost in Canada: Equipment, Installation, and Ownership
Generac generators cost about C$4,800 to C$8,300 for current Canadian 10kW to 18kW equipment examples.
A complete standby installation may cost from C$7,000 to C$25,000. Your total will change based on the transfer switch, gas work, wiring, permits, delivery, and site conditions.
If you only need selected plug-in devices or compatible circuits, the EcoFlow DELTA 3 Ultra Plus Portable Power Station (3072Wh) offers a battery option without a permanent fuel line.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3600 W AC output with 7,200 W surge output •3072 Wh base capacity, expandable from 3–11 kWh • 6 charging options, with 0–80% in 48 minutes using solar + generator dual charging • 10 ms auto-switch plus Smart Output Priority for critical backup planning
Use the costs below to compare each quote with the loads you need to keep running.
How Much Does a Generac Generator Cost in Canada?
First check what the listed price includes, because it may cover only the generator, a package with a transfer switch, or the full installation.
Homeowners should separate these price levels before comparing quotes. A low retail price may exclude delivery, tax, installation, permits, and startup testing.
Current non-clearance Canadian retail examples put many 10kW to 18kW standby units between about C$4,800 and C$8,300. Regional contractor estimates place complete projects between about C$7,000 and C$25,000.
This wide installed range is a planning limit, not a national average. A short gas line and a modern electrical panel may keep costs lower. Trenching, panel work, difficult access, or a larger unit can raise the total.
A search for Generac power generator prices may also mix portable and standby products. Portable generators use different connections and are not part of the pricing below.
To find out how much a Generac costs, you still need the model size, fuel choice, package description, and installation location. Current Generac home generator prices show how much those details can change the result.
Current Canadian Example
Retail Price Checked
Package Limitation
10 kW standby models
About C$4,830 to C$6,250
Transfer-switch inclusion varies
14 kW standby models
About C$6,260 to C$8,285
Package contents vary
18 kW standby model
About C$7,310
Transfer switch not included
22 kW standby model
About C$8,077
These Generac standby generator prices are research examples, not official Canadian list prices. They do not form a simple price ladder because the retailers, packages, and included parts differ.
Canadian homeowner reviewing the cost of a standby generator installation.Canadian homeowner reviewing the cost of a standby generator installation.
What Makes Up the Total Generac Cost?
The full cost of a Generac includes more than the generator. Your project may also need transfer equipment, electrical work, a fuel connection, site work, permits, testing, and tax.
Use an itemized quote to see where your money will go.
Cost Component
What It May Include
What Raises the Price
Generator
Unit, enclosure, controller, and starter battery
Higher output, cooling type, and added features
Transfer equipment
Automatic transfer switch and load controls
More circuits or whole-service switching
Electrical work
Wiring, conduit, breakers, and panel connection
Long cable routes, an old panel, or a service upgrade
Fuel connection
Natural-gas pipe or propane equipment
Trenching, pipe size, meter capacity, or a propane tank
Site work
Base, grading, drainage, and delivery
Poor access, excavation, or landscaping repairs
Permits
Electrical, gas, and local approvals
Local rules and project size
Cold-weather parts
Approved battery or oil-heating accessories
Model needs and local winter conditions
Startup
Testing and homeowner instructions
Extra testing or repair work
Ongoing plan
Monitoring or service agreement
Coverage and subscription level
Generator and Transfer Equipment
Some Generac models come with a transfer switch, while others do not. The switch separates your home from the utility grid and changes the power source during an outage.
Load controls can turn off lower-priority appliances when demand is high. This may help you use a smaller generator, but it does not increase the unit’s output.
Electrical, Gas, and Site Work
Long routes between the generator, panel, and fuel source need more labour and material. Your installer may also need to add conduit, dig a trench, build a level base, improve drainage, or repair landscaping.
An older electrical panel may need repairs or replacement. Your gas meter and pipe must also support the planned fuel demand. Natural gas and propane systems have different equipment and site costs.
A model may produce different output on natural gas and propane. Ask the installer to size the system using the fuel you plan to use.
Permits and Professional Installation
Electrical, gas, setback, noise, and inspection rules vary across Canada. A qualified electrical and gas contractor should check the rules for your address.
For example, the Ontario Electrical Safety Authority requires notification when a generator is hardwired to a transfer switch. In British Columbia, Technical Safety BC requires permits for regulated gas work, although some cities issue their own permits.
These are provincial examples. Your installer must confirm the rules that apply to your project.
How Does Generator Size Affect Generac Home Generator Prices?
Generator size affects the equipment price, but home size alone cannot tell you which model to buy.
A 2,000-square-foot home with gas heat and city water may use far less electricity than an all-electric home. Heat pumps, well pumps, electric ranges, central air, and EV chargers can raise both running and startup demand.
Decide whether you want to cover essential circuits or a broader set of household loads. Then record each device’s running watts, startup watts, voltage, and likely use during an outage.
The following tiers are planning examples, not model recommendations.
Capacity Tier
Typical Planning Goal
Loads That Can Change the Result
10 kW to 14 kW
Essential circuits or a managed-load plan
Furnace blower, sump pump, refrigerator, and lights
18 kW to 22 kW
Broader household coverage
Central air, heat pump, well pump, and cooking equipment
24 kW to 28 kW
Higher demand at the same time
Several HVAC systems, electric cooking, and large pumps
Motor-driven equipment may need a brief surge when it starts. The generator must handle that surge along with the loads already running.
Load controls may pause a lower-priority device, such as an air conditioner, while another device starts. Oversizing can increase equipment and fuel costs. Undersizing may stop key appliances from starting or overload the system.
Some Generac sizing guidance uses 18 kW to 22 kW as a starting point for some 2,000-square-foot homes. However, the load list still matters more than floor area. Calculating what size backup generator your home needs will show which devices drive the quote.
Homeowner identifying electrical loads before sizing a standby generator.Homeowner identifying electrical loads before sizing a standby generator.
What Does a Generac Cost to Own Over Time?
Your initial Generac cost does not include every expense. Fuel, testing, maintenance, monitoring, repairs, and replacement parts may add to the total over time.
Fuel and Exercise Cycles
A standby generator burns natural gas or propane while it runs. Fuel use changes with the model, electrical load, outage length, and local fuel rate.
A propane system needs enough stored fuel for the planned runtime. You must also consider refill access after a storm. A natural-gas connection avoids on-site fuel storage, but the gas supply should not be treated as impossible to interrupt.
Standby generators also run short exercise cycles. These checks help confirm that the engine can start, but they use a small amount of fuel.
Maintenance, Monitoring, and Repairs
Engine care may include oil, filters, spark plugs, a starter battery, inspections, and load testing. The correct schedule depends on the model and operating hours.
Monitoring and dealer service plans may have added fees. Extended use during a long outage can also lead to early service or repair work.
Estimate ownership costs for the number of years you plan to keep the system:
Estimated ownership cost = installed price + scheduled service + fuel + monitoring + repairs
Ask local installers for current service-plan prices. You should also request the maintenance schedule for the exact model in your quote.
What Are the Disadvantages of a Generac Standby Generator?
A Generac standby generator can start on its own, but it needs outdoor space, fuel, professional installation, and regular engine care.
Permanently installed standby generator outside a Canadian home.Permanently installed standby generator outside a Canadian home.
The main drawbacks of a Generac standby generator include:
  • A high installed cost
  • Electrical and gas permits
  • Permanent outdoor placement
  • Engine and exhaust noise
  • Natural-gas or propane use
  • Propane storage and delivery needs
  • Exercise cycles and routine service
  • Mechanical wear and repair costs
  • Exhaust and carbon monoxide risks
  • Possible load controls for high-demand homes
A standby generator is mainly used during outages and test cycles. Some battery systems can also store solar energy or support daily energy plans.
The generator’s location must follow its site guide and local rules. Portable-generator spacing should not be used as a substitute for standby placement instructions.
Fuel-burning equipment can release carbon monoxide. Follow Health Canada’s carbon monoxide guidance, maintain working carbon monoxide alarms, and keep exhaust away from doors, windows, and vents.
Is Battery Backup a Better Alternative to a Generac Generator?
Battery backup removes fuel use and engine service, but its runtime is limited by stored energy, household loads, and charging options.
Compare both systems using the same loads, runtime, voltage, and connection plan.
Standby generator and battery backup options for a Canadian home.Standby generator and battery backup options for a Canadian home.
Decision Factor
Battery Backup
Energy source
Natural gas or propane
Stored electricity, grid charging, or solar
Runtime
Runs while fuel and safe conditions allow
Limited by capacity, loads, and recharging
Maintenance
Engine, oil, filters, plugs, and battery
No engine service, but system checks may apply
Sound
Quiet during battery use
Installation
Outdoor site, fuel work, switch, and permits
Plug-in or installed, based on the connection
Indoor use
Generator stays outdoors
Approved equipment may operate indoors
Home coverage
Based on output and load control
Based on output, storage, voltage, and integration
Daily use
Mainly outage backup
Some systems support solar storage or energy plans
Battery backup is not always cheaper. Extra batteries, home connection equipment, and professional installation can raise its cost.
You can compare home battery backup and standby generator costs after dividing your Generac quote into equipment, installation, and ongoing expenses.
Battery Backup for Selected Loads
The EcoFlow DELTA 3 Ultra Plus Portable Power Station (3072Wh) has 3,072 Wh of base storage, 3,600 W of output, and 7,200 W of surge output. Supported setups can expand from 3 kWh to 11 kWh.
Its 10 ms auto-switch can support compatible connected devices. It can also connect through a compatible manual transfer switch or inlet box.
Use it for verified plug-in devices or selected compatible circuits. It does not power central heating, air conditioning, or every household circuit by default. Added batteries increase stored energy, but they do not raise the inverter’s output.
Broader 120V and 240V Home Backup
The EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) starts with 6,144 Wh of storage and 7,200 W of continuous output. It supports 120 V and 240 V loads and has 10.8 kW of surge output.
One inverter can support up to 30 kWh of storage. Larger figures, such as 90 kWh of storage and 21.6 kW of output, require three inverters and supported system equipment.
Broader circuit coverage may use an EcoFlow Smart Home Panel 2. The final plan must match your loads, local permits, and installation needs.
•7.2 kW AC output, expandable up to 21.6 kW with supported configurations • 6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 • Automatic battery self-heating below 0°C for cold-weather operation
How Should You Compare Generac Installation Quotes?
Compare itemized quotes that use the same generator size, fuel, transfer setup, and installation plan.
Take this checklist to each contractor:
  1. Confirm the exact generator model.
  2. Check its output on your planned fuel.
  3. Ask if the automatic transfer switch is included.
  4. Confirm which circuits and devices it will support.
  5. List any load-control modules.
  6. Check the wiring, conduit, breakers, and panel work.
  7. Confirm the gas line or propane equipment.
  8. Ask about gas-meter or electrical-service upgrades.
  9. Include the base, grading, trenching, and delivery.
  10. Confirm who handles permits and inspections.
  11. Check cold-weather accessories.
  12. Separate equipment, labour, tax, and optional plans.
  13. Review equipment and workmanship warranties.
  14. Ask how unexpected work will be approved.
The lowest unit price may lead to a higher final bill if key work is missing. Compare at least two or three local quotes based on the same load list.
Compare the Complete Backup Cost Before You Buy
Start with the loads that must keep running. Then compare the full installed cost instead of the equipment price alone.
Add fuel, maintenance, monitoring, and likely repairs to your budget. Compare each option using the same output, runtime, voltage, and circuit coverage.
Once those needs are clear, compare home battery backup systems by output, stored energy, expansion, charging, and connection method.
What is the average price to install a Generac generator?
Installation can add several thousand Canadian dollars to the unit price. Electrical work, fuel service, transfer equipment, trenching, permits, and site access vary too much for one national average to fit every home.
What are the disadvantages of a Generac generator?
The main disadvantages are the installed cost, outdoor space, fuel use, engine noise, maintenance, and repair needs. Your project may also need gas work, electrical permits, load controls, and changes to the planned location.
How much is a Generac for a 2,000-square-foot home?
Generac uses 18kW to 22kW as a starting point for some 2,000-square-foot homes. Your final size and cost must reflect the heating system, pumps, cooking equipment, startup surges, fuel, and loads that will run together.
How much does it cost to install a Generac whole-house generator in Canada?
Regional Canadian estimates range from about C$7,000 to C$25,000 for complete standby projects. Ask for a site assessment that separates the generator, transfer equipment, wiring, fuel work, permits, labour, and tax.
Home Backup
