Kitchen Renovation: A Practical Guide to Cost and Planning
Almost every kitchen renovation starts with somebody standing in front of a drawer that won't close, announcing that the cupboards have to go. What begins as new counters has a way of ending with an electrician shaking their head at a panel that hasn't been touched since the house went up.
In Canada, four things drive the final cost: the size of the kitchen, the materials, the labour rates and how much of the existing layout you change. Here's what it costs, how to plan it, which permits you'll need and how to keep it on budget.
What Does a Kitchen Renovation Involve?
Scope is a polite word for how much of the room you’re willing to tear apart. Keep the sink and the stove where they are and you’re refinishing; move them and you’re into plumbing, wiring and permits.
Assess the Existing Kitchen Layout and Condition
Start by looking past the cabinet doors, because the expensive problems are the ones you can’t see. Pull the base drawers out and check the floor beneath for level; then press along the drywall behind the sink. Anything spongy means a slow leak is quietly rotting the framing. If two people can’t open the fridge and the oven at the same time, that traffic pattern deserves your money long before any finish does.
Define the Renovation Scope and Priorities
Renovations generally fall into three distinct tiers: cosmetic refreshes, partial overhauls, and full gut renovations. Most people are sure they’re doing the first one until the invoice says otherwise. Some items genuinely have to happen, like replacing a failing countertop, adding pantry storage, or investing in the top energy efficient home improvements; the rest can be dropped if plumbing or structural work eats into your contingency fund. Split the list in two along exactly that line.
Identify Electrical and Energy Needs
This is the line item that catches people out, because it stays invisible until it’s expensive. Induction cooktops and dual-fuel ranges need dedicated 240V circuits rated for 40 to 50 amps. Built-in microwaves, dishwashers and countertop small appliances need their own 120V, 15A or 20A circuits. Most older houses weren’t wired for that load, so meeting it often means upgrading the main electrical panel (from 100 amps to 200 amps). Find that out in week one, not after the drywall’s painted, as you might need a portable power station to keep your fridge running while the home’s power is temporarily shut off for the upgrade.
How Much Does a Kitchen Renovation Cost in Canada?
When homeowners ask how much a kitchen renovation will cost, the reality is that a dollar doesn’t buy the same kitchen in Saint John as it does in Mississauga. Labour rates and material costs vary from province to province, so anchor to the national benchmarks and adjust from there.
Average Kitchen Renovation Costs in Canada
Most Canadian homeowners spend between $25,000 and $65,000 CAD on a standard kitchen renovation. A modest refresh in Calgary or Winnipeg sits near the lower end. If you are planning a kitchen renovation in Toronto (GTA) or Metro Vancouver, that same scope can run $80,000 to $100,000+ CAD once custom finishes and structural changes are involved.
Kitchen Renovation Costs by Project Scope
Each tier comes with different labour, different specs and a different price tag:
Project ScopeTypical Cost Range (CAD)Included Upgrades & FeaturesAverage Timeline
Minor Updates$12,000 – $22,000Cabinet refacing or painting, new hardware, updated sink & faucet, entry-level quartz or laminate counters, fresh paint 2 – 4 weeks
Partial Renovation$25,000 – $50,000Semi-custom cabinets, mid-range stone counters, new flooring, standard appliance package, minor electrical additions4 – 8 weeks
Full Renovation$55,000 – $90,000+Complete gut, custom millwork, layout changes, premium surfaces, 200A panel upgrade, high-end built-in appliances8 – 14+ weeks
Major Factors That Affect Kitchen Renovation Costs
Materials and labour make up most of the bill, but three factors tend to move the total the most:
  • Custom Cabinetry vs. Prefab Units: Custom millwork built around awkward ductwork can run two or three times what you'd pay for modular, flat-pack units. What you're paying for is cabinetry that fits, not filler strips hiding the gaps.
  • Moving Plumbing and Gas Lines: Keeping the sink, dishwasher, and stove in their original locations saves thousands. Moving those lines through concrete slabs or finished basements drastically inflates mechanical costs.
  • Regional Trade Labour Rates: Licensed plumbers and electricians bill more per hour in the urban centres of Ontario, British Columbia and Alberta than they do in smaller communities.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
What Should You Plan Before a Kitchen Renovation?
Before the first cabinet comes off the wall, five things have to be settled: layout, electrical, permits, materials, and money.
Plan the Kitchen Layout Around Daily Use
While it is fun to browse for new kitchen renovation ideas, design for the Wednesday morning version of your life, not the dinner party one. Keep the classic “work triangle” between cooktop, fridge and sink, and leave at least 36 to 42 inches of clearance along the busy pathways. Put the trash pull-out and the dishwasher where two people won’t be working elbow to elbow, and give some thought to the route from the back door, because in February that path carries boots, hockey bags and a dog.
Plan Electrical and Lighting Requirements Early
Plan the kitchen lighting for a Canadian January, when the light goes grey before five in the afternoon, not for a showroom. Skip the one big ceiling fixture and layer the light instead: task lighting under the uppers, recessed pot lights overhead, pendants over the island. Space the outlets along the backsplash the way the Canadian Electrical Code (CEC) requires, and give wet areas dedicated GFCI protection. If you plan to back up your kitchen essentials with a solar generator down the road, let your electrician know early on. Put the switches where your hands land.
Check Permit and Professional Requirements
Skipping permits looks like a shortcut until a buyer’s inspector finds the unpermitted work two days before closing. In most Canadian municipalities you need a building permit to take down a load-bearing wall, alter ductwork or move plumbing rough-ins. In Ontario, for example, wiring has to be inspected and certified by the Electrical Safety Authority (ESA), and other provinces have their own equivalents.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
Key Considerations for Long-Term Kitchen Energy Planning
With every province pricing hydro differently and storms testing the grid, kitchen planning should look beyond the finishes to long-term energy resilience.
Explore Solar and Energy Storage
A kitchen renovation is the natural moment to rethink your home’s power strategy, especially if you’re adding a high-wattage induction range or a second fridge. The walls are open and the electrician is there. Integrating solar panels and localized storage creates flexible energy options that offset daytime utility peaks.
For targeted resilience, a portable power station like the EcoFlow DELTA 3 Max Plus provides backup power without requiring electrical panel re-wiring. It can run kitchen essentials during grid outages, such as full-size refrigerators, microwaves, coffee makers, and portable countertop induction burners.
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Connect With Whole-Home Energy Goals
Tying kitchen upgrades to a broader home energy plan keeps the lights, the fridge and the cooktop going when severe weather hits. Ice storms and high winds knock out lines across the provinces, and a full fridge and freezer are usually the first casualties. A full chest freezer holds a couple of hundred dollars' worth of food, and that bill isn't getting any smaller.
Incorporating a larger system like the EcoFlow DELTA Pro Ultra Whole-Home Backup Power integrates your kitchen into a whole-home backup setup. With expandable battery capacity and higher output, it powers critical circuits, from refrigerators and task lighting to water pumps, keeping household appliances running through short blackouts or prolonged winter grid failures.
6kWh-90kWh capacity, whole house backup for weeks with comfort. One hour of solar for one day of power. Powers through the most challenging situations. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items.
How Can You Keep a Kitchen Renovation Within Budget?
While applying for a local home renovation savings program can help offset initial costs, budgets rarely die from one big decision. They die from forty small ones, each perfectly reasonable at the time.
Prioritize Structural and Electrical Work
Few people admire a kitchen’s wiring, but homeowners quickly notice when it fails. When trade-offs become necessary, spend on what sits behind the walls before splurging on finishes. Tile and decorative brass hardware can go in later, but undersized cable, inadequate venting or an uninsulated exterior wall will cost real money to fix once the walls are closed.
Compare Material and Appliance Options
Good engineered quartz shrugs off the daily spills and thermal stress that punish porous natural marble, and it needs a fraction of the upkeep. A reliable mid-tier appliance will outlast a commercial-grade unit whose control board fails, leaving you waiting on a back-ordered part from overseas.
Avoid Unplanned Changes During Construction
Change orders are the leading cause of blown budgets and delayed handovers. Altering an island dimension or switching a faucet model mid-build stalls every trade that follows, with restocking fees and idle hours attached. Before demolition, finalize the spec sheet, rough-in location and finish, and set aside a strict 15% to 20% contingency fund for genuine structural or code surprises. That money is for rot, not for a better backsplash.
Kitchen renovation costs in Canada vary widely, so define the scope and budget before choosing finishes or appliances. Get the electrical, plumbing, layout and permits sorted early; keep a contingency fund for the surprises; and once construction starts, leave the specifications alone. These steps will do more for the final cost than cutting corners on essential structural or electrical work.
What Is the Most Expensive Part of Redoing a Kitchen?
Cabinetry and millwork lead the list by a comfortable margin, typically 30% to 40% of the renovation budget. Between fabrication, hardware and a finish carpenter’s hours, they almost always outstrip appliances, countertops and flooring.
What Not to Do When Renovating a Kitchen?
Never begin demolition before the design layouts and materials are finalized and the essential long-lead appliances are ordered. A twelve-week appliance backorder has stalled more renovations than any structural surprise. Avoid moving plumbing or gas lines without good reason, do not skimp on ventilation, and don’t treat your 15% emergency contingency fund as upgrade money.
What Time of Year Is the Cheapest to Remodel a Kitchen?
Late winter, roughly January through early March, is generally the most cost-effective time to remodel. After the holidays and before the spring outdoor work picks up, contractors and trades hit a lull, and that’s when they’re most willing to negotiate labour rates. The catch is that eating on the deck, or using your outdoor kitchen renovation ideas for a temporary cooking setup, isn’t an option in February.
How Long Does a Kitchen Remodel Take?
It depends on scope. Minor refreshes run 2 to 4 weeks and partial remodels 4 to 8 weeks. A full gut renovation runs 8 to 14 weeks or more, and that’s before permit inspections, millwork lead times and structural wall removals enter the picture.
Can You Live in Your House During a Kitchen Remodel?
Yes, as long as you set up a working temporary kitchen elsewhere in the house. Budget for takeout and expect plenty of dust during demolition, but a kettle, a microwave, a toaster oven and a mini-fridge in the dining room will carry you through. Put the kettle where you can reach it without stepping over a sawhorse.
