Canada Wildfires 2026: Where Fires Are Burning & How to Prepare
Canada's 2026 wildfire season opened quietly before forest fires in Canada escalated through July. Evacuations followed in several provinces, crews reached capacity, and smoke spread beyond fire zones, leaving households facing evacuation risks and potential power outages.
This guide tracks where fires are burning, how this season compares with recent years, and practical ways to prepare. Backup options such as the EcoFlow DELTA 3 Max Plus, DELTA 3 Ultra Plus, and DELTA Pro Ultra are also covered. Conditions change daily, so figures include sources and dates. For live updates, the Canadian Wildland Fire Information System and FireSmoke.ca remain useful resources.
Canada's Wildfire Situation in 2026
Where are the forest fires in Canada this season? National figures move constantly during peak wildfire months, so the sections below pair dated agency numbers with live tools that keep them current:
Where Are the Forest Fires in Canada Right Now?
Wildfire conditions remain active across Canada in August 2026, with changing fire locations and risk levels tracked by the Canadian Wildland Fire Information System (CWFIS). The federal government says extreme heat, dry conditions, and gusting winds have intensified numerous fires this summer.
For the latest locations, check the CWFIS fire maps, while Public Safety Canada’s Wildfires: Federal Response page provides current federal response information and links to provincial and territorial wildfire agencies.
How Many Forest Fires Has Canada Had in 2026?
The Government of Canada's July update, published on 9 July 2026, recorded 3,137 fires for the season. Beyond this, 796 were active and 60 burning out of control, with roughly 1.4 million hectares burned.
Natural Resources Canada figures cited in early August 2026 put the area burned above 3 million hectares. At the same point in 2025, Canada had logged fewer fires at 2,913 but a far larger burned area of 4,614,713 hectares.
Forest Fires in Ontario, Canada: Current Situation
Ontario has carried the heaviest load in eastern Canada. CBC News wildfire coverage for Northwestern Ontario listed 110 active forest fires in Ontario, Canada on 8 August 2026. The Ontario government's forest fire updates showed 112 active fires in the Northwest Region around the same date.
Of those, 12 were not under control, 7 were being held, and 6 were under control. A restricted fire zone order took effect on 7 August 2026.
Other Major Wildfire Regions Across Canada
Fire pressure is not spread evenly. The table below shows where big forest fires in Canada were causing the most concern in early August 2026:
Region
Preparedness status
Fire danger outlook for August 2026
British Columbia
Agency Level 5
Southern Interior above normal
Ontario
Agency Level 4
Northwestern districts staying dry
Northwest Territories and Nunavut
Level 2 or 1
Highest modelled danger nationally
Northern Manitoba
Level 2 or 1
Dry, with elevated fire danger
Quebec
Level 2 or 1
Elevated potential in the north
Preparedness levels describe how heavily an agency's resources are committed, not the size of any single fire.
How Does the 2026 Wildfire Season Compare With 2023 and 2025?
Recent seasons give these figures context. The last 3 all rank among the 10 worst on record, according to data on Canada’s recent wildfire seasons.
Season
Area burned
Ranking
Defining feature
2023
About 16.5 million hectares
Worst on record
Record-breaking national area burned
2025
Over 8.3 million hectares
Second worst on record
Fires affected nearly every province and territory
2026, late July
Over 3 million hectares
Below the record totals of 2023 and 2025 so far
Significant wildfire activity continued through July
The headline for 2026 is pace rather than total. Analysis published in August 2026 noted that a season starting below average escalated quickly through a hot, dry July.
What Causes and Intensifies Forest Fires in Canada?
Most large forest fires in Canada begin with lightning or human activity, then grow according to weather and fuel. Lightning starts many fires deep in the boreal forest. In remote areas, some can keep burning for weeks before crews can reach them.
  • Drought: Long precipitation deficits leave forest fuels dry enough to carry fire.
  • Heat: Sustained high temperatures lower fuel moisture and extend the burning window.
  • Wind: Gusts push fire fronts forward and carry embers past the perimeter.
  • Fuel Load: Dense vegetation and deadfall give a fire more to consume.
EcoFlow guide to how wildfires start in Canada covers ignition sources and human causes in more detail.
How Wildfires Threaten Homes, Health, and Power
Distance from a fire front does not equal safety. You do not have to live near the flames to feel the effects. Smoke can travel a long way, while fires can also knock out power in affected communities.
Why Wildfires Cause Power Outages
Power lines often cross wooded areas, so an approaching wildfire can reach them directly. Poles, conductors, and substations can all be damaged, and repairs cannot begin until the area is safe for crews.
Utilities also de-energize circuits deliberately when fire is nearby, which protects line workers and stops equipment from sparking new ignitions.
How Wildfire Smoke Affects Indoor and Outdoor Air Quality
Health Canada notes that wildfire smoke can travel thousands of kilometres from the fire zone. Poor air quality therefore reaches communities with no visible flames nearby. Fine particulate matter, known as PM2.5, is the main health risk.
The Air Quality Health Index runs from 1 to 10+, and during smoke events it is calculated hourly using PM2.5 alone. Therefore, Health Canada advises reducing outdoor exertion and filtering indoor air. Filtration depends on electricity, since purifiers and furnace fans stop when the power does.
What Stops Working During an Extended Power Outage
Outages during big forest fires in Canada are rarely minor inconveniences. Here is what typically goes down once grid supply drops:
  • Refrigeration: Fridges and freezers start losing safe temperature within hours.
  • Water Supply: Rural properties on well pumps lose running water entirely.
  • Climate Control: Furnaces and heat pumps need power for controls and fans.
  • Air Filtration: HEPA purifiers stop circulating filtered air during smoke events.
  • Communication: Routers, modems, and phone charging become unreliable.
  • Medical Equipment: CPAP machines and oxygen concentrators need continuous supply.
What to Do Before, During, and After a Wildfire
Canadian agencies use a 2-stage notification system, and the stage you are in changes what you should be doing.
Before a Wildfire or Evacuation Alert
An evacuation alert means conditions could worsen and you should be ready to leave on short notice. Alberta's guidance notes this window can be as short as 30 minutes.
  1. Pack an Emergency Go-Bag: Include clothing, medications, and copies of important documents.
  2. Map Two Evacuation Routes: Identify a primary and secondary route, then drive both in advance.
  3. Keep Your Vehicle Fuelled: A full tank removes one decision from a compressed evacuation timeline.
  4. Fully Charge Essential Devices: Bring phones, radios, and any power station to full capacity.
  5. Sign Up for Local Alerts: Register for provincial or local emergency notifications where available.
When an Evacuation Order Is Issued
Once an evacuation order is issued, staying is no longer an option. Leave the area and take the route officials have marked out. Orders are enforced by local authorities or the RCMP and stay in force until formally rescinded.
Do not detour to collect belongings, and do not drive through a forest fire in Canada unless officials direct you. Settling roles and meeting points early makes this faster, and an EcoFlow personal emergency evacuation plan built before fire season removes the hesitation.
Returning Home After a Wildfire
Return only once officials confirm the area is safe. Canadian outage guidance is specific about the electrical steps that follow.
  • Stay Clear of Downed Power Lines: Treat every fallen or sagging line as live and report it immediately.
  • Wait for Power to Stabilize: Give the supply time to settle before reconnecting appliances to reduce surge-related damage.
  • Reconnect Appliances Gradually: Bring devices back online in stages instead of switching everything on at once.
  • Inspect Refrigerated Food: Discard food that has been above a safe temperature for too long.
  • Check for Smoldering Hot Spots: Watch for heat or smoke in debris, since material can continue burning after a fire passes.
Build a 72-Hour Wildfire Emergency Kit
Check where the forest fires are in Canada before planning ahead. Canadian agencies use 72 hours as the preparedness baseline for emergencies. Our 72-hour emergency kit for Canada guide covers the full supply list. The 5 steps below focus on backup power:
Step 1. Identify the Devices You Must Keep Running
Start with the things you would actually miss in a blackout. That might be the fridge, Wi-Fi, a few lights, an air purifier, or medical equipment. Check their power draw before choosing backup capacity.
Step 2. Keep Phones and Essential Electronics Charged
A phone becomes much more important once an evacuation alert arrives. Charge it early, keep a power bank nearby, and add a battery radio as a fallback if mobile service drops.
Step 3. Use a Portable Power Station for Short Outages and Evacuation
This is where a portable power station comes in. It can run selected essentials at home, then go in the car with you if evacuation becomes necessary.
Step 4. Add Solar Charging for Longer Power Outages
For an outage that runs into several days, portable solar panels can recharge your power station. Just expect less output when thick wildfire smoke cuts the available sunlight.
Step 5. Scale Up to Whole-Home Backup
For heating, well pumps, and larger appliances, consider an EcoFlow whole-home backup system designed to support higher household power demands.
EcoFlow Backup Power Options for Canadian Homes
For forest fires in Canada, EcoFlow offers backup options for different needs. These 3 scale from evacuation portability to whole-home coverage.
1.1 EcoFlow DELTA 3 Max Plus (2048Wh)
Households planning mainly for evacuation and shorter outages will find the DELTA 3 Max Plus (2048Wh) a practical starting point. It carries easily to a vehicle, runs indoors without fumes, and handles the kitchen and communication load that matters most on the first day away.
DELTA 3 Max Plus
· 2048Wh capacity, 3000W rated AC output, 6000W surge. · X-Boost 3.0 supports heavy-duty appliances drawing up to 3800W. · Expandable from 2kWh to 10kWh, charging 0 to 80% in 43 minutes.
1.2 EcoFlow DELTA 3 Ultra Plus (3072Wh)
Larger households facing multi-day outages from big forest fires in Canada can use the DELTA 3 Ultra Plus (3072Wh) for greater portable backup capacity. EcoFlow rates the unit for essential power needs across a 4-to-10-hour outage, with battery expansion available for longer events.
DELTA 3 Ultra Plus
· 3072Wh capacity, 3600W rated AC output, 7200W surge. · Expandable from 3kWh to 11kWh with smart extra batteries. · Reaches 0 to 80% in 48 minutes on solar and generator charging.
1.3 EcoFlow DELTA Pro Ultra
Properties that need heating, water pumps, and major appliances online through a long outage sit in different territory. The DELTA Pro Ultra is a stackable whole-home system rather than a portable unit, and EcoFlow lists certification to both UL1973 and UL9540.
DELTA Pro Ultra
· 7.2kW per inverter, rising to 21.6kW with three inverters and the Smart Home Panel 2. · Expandable to 90kWh across 15 stackable battery units. · LFP cells rated beyond 3,500 cycles. 20ms automatic switchover when paired with Smart Home Panel 2.
Why Portable Battery Power Works Well During Wildfire Evacuations
Fuel generators serve a purpose, but evacuation conditions quickly expose their limits. A battery answers several of those constraints at once:
  • Indoor Operation: No combustion means no carbon monoxide risk indoors.
  • Silent Running: Quiet operation matters in reception centers and shared accommodation.
  • No Fuel Storage: There is no jerry can to source or transport while displaced.
  • Recharge Flexibility: Solar, wall power or a vehicle can each restore capacity.
Portable Power Station vs. Fuel Generator for Wildfire Backup
Both have a place, and the better choice depends on runtime, location, and what you are powering. The comparison below covers what matters most during a forest fire in Canada:
Factor
Fuel Generator
Indoor Use
Safe indoors, no exhaust
Outdoor only, carbon monoxide risk
Noise
Quiet enough for occupied rooms
Loud, often restricted in shared spaces
Fuel
None, recharges from solar or grid
Needs gasoline, propane or diesel
Runtime
Limited by capacity unless recharged
Continues while fuel is available
Maintenance
Minimal, no engine servicing
Oil changes and seasonal servicing
Evacuation use
Travels in a vehicle or to a shelter
Impractical to move while displaced
Plenty of Canadian households run both. A battery covers indoor essentials and smoke-event filtration, while a generator handles outdoor high-draw loads.
Canada's 2026 wildfire season is changing quickly, so track forest fires in Canada through CWFIS and FireSmoke.ca. Being ready can make a real difference, so keep your 72-hour kit packed, know when to evacuate, and have a plan if the power goes out. EcoFlow backup power options can help keep essential devices running when grid power fails.
1. What Months Are Wildfire Season in Canada?
Health Canada describes the wildfire season as running from early April through October. Peak activity falls in July and August, when heat and low humidity meet dry fuels. Western provinces often see activity begin earlier than eastern ones.
2. How Far Can Wildfire Smoke Travel?
Wildfire smoke does not stay close to the flames. Health Canada notes that it can travel thousands of kilometres, affecting air quality far from the source. In July 2026, smoke from forest fires in Ontario, Canada moved across eastern North America. The air can also be unhealthy before any haze becomes visible.
3. Can a Portable Power Station Be Used Indoors During a Wildfire-Related Outage?
Yes, and this is one of its clearest advantages over a fuel generator. A portable power station stores electricity in a battery and produces no combustion exhaust, so it carries no carbon monoxide risk indoors. That suits an air purifier or medical device in a sealed room. Fuel generators must always run outdoors.
4. Can Wildfires Continue Burning Through the Winter in Canada?
Yes, some fires smolder underground through winter in peat and deep organic soil, then resurface once conditions dry in spring. These are commonly called overwintering or zombie fires. After the record 2023 season, roughly 150 fires re-ignited as early as February 2024.
5. What Is the Difference Between a Wildfire Evacuation Alert and an Evacuation Order?
If an evacuation alert is issued, get ready to go. You may need to leave with little warning. Once an evacuation order comes through, it is time to go. Take the route local officials have directed residents to use.
Power Outages
