Electric Generator for Home: How to Choose the Right Backup Power
- What Is an Electric Generator for Home?
- Types of Home Generators Compared
- Portable Electric Generators for Home vs Whole-Home Backup
- How Much Generator Power Does Your Home Need?
- Gas vs Battery-Powered Electric Generators for Homes
- What Can a Home Electric Generator Run?
- How Long Can a Generator Power a Home?
- Generator Fuel and Recharging Options
- How Much Does an Electric Generator for Home Cost?
- Do You Need a Transfer Switch for Home Generator Power?
- Generator Safety During a Power Outage
- What Should Canadians Consider Before Buying a Home Generator?
- Which Electric Generator Setup Is Right for Your Home?
- Conclusion
- Frequently Asked Questions
When the power goes out, an electric generator for home can keep essentials such as refrigerators, lights, and sump pumps running. Options include portable fuel, standby, inverter, and battery-based systems, with differences in output, installation, portability, charging, and safety. Canada also advises households to consider backup power when preparing for outages. Government of Canada power-outage guidance
For battery backup, the EcoFlow DELTA 3 Max Plus can support selected essential loads, while the EcoFlow DELTA Pro Ultra is designed for larger home-energy needs. Neither burns fuel, making them different from conventional generators.
Power Essential Home Loads with EcoFlow DELTA 3 Max Plus
Scale Up Home Backup with EcoFlow DELTA Pro Ultra
An electric generator for home provides backup electricity during an outage, but the term covers different systems. Fuel generators produce power using gasoline, propane, or natural gas, while standby models are permanently installed. Portable generators can be moved where needed.
Battery power stations instead store electricity for later use and can recharge from the grid or compatible solar panels. Before comparing wattage or prices, understand the difference, as EcoFlow’s guide to home backup electrical generators explains.
A generator for home electricity comes in several types, each differing in power source, portability, installation, and use.
Type | Energy Source | Portability and Install | Indoor Use | Automatic | Typical Use |
Portable Gas Generator | Gasoline | Movable, no install | Outdoors only | No | Occasional short outages |
Dual or Tri-Fuel Generator | Gas, propane, natural gas | Movable, no install | Outdoors only | No | Flexible fuel supply |
Inverter Generator | Gasoline or propane | Movable, no install | Outdoors only | No | Quieter, cleaner output |
Standby Generator | Natural gas or propane | Fixed, professional install | Outdoors only | Yes | Extended outages, fuel supplied |
Portable Battery Station | Stored electricity | Movable, no install | Safe indoors | Near-instant | Essential-load backup |
Whole-Home Battery Backup | Stored electricity | Fixed, panel integration | Safe indoors | Yes | Broad household backup |
Compare the table below to see how an electric generator for home differs between portable and whole-home systems:
Factor | Portable | Whole-Home |
Location | Moves between outdoor locations or properties | Fixed installation |
Coverage | Selected appliances and devices | Larger household loads |
Circuits | Plugged in directly | May support multiple circuits |
Installation | Little or none required | Usually needs electrical integration |
Capacity | Limited by the model chosen | Higher capacity and output |
Best Suited to | Essential-load backup | Automated or broader backup |
EcoFlow DELTA 3 Max Plus for Portable Home Backup
Households wanting emergency electricity without an installation sit on the portable side. The EcoFlow DELTA 3 Max Plus is built for that, covering compatible appliances, electronics, refrigeration, home-office equipment and other essential loads:
Rated at 2,048 Wh of storage with 3,000 W of AC output.
Handles 6,000 W surges, which matters when a fridge or pump starts.
Expands toward 10 kWh with compatible extra batteries.
EcoFlow DELTA Pro Ultra for Whole-Home Backup
Larger requirements move to the other column, where output and capacity grow together. The EcoFlow DELTA Pro Ultra is the higher-capacity option for expandable storage, larger household loads, solar charging and electrical integration:
Delivers 7.2 kW from one inverter, scaling to 21.6 kW with three.
Expands from 6.1 kWh up to 90 kWh of battery capacity at the system level.
Supports solar, grid, and generator charging, with up to 5.6 kW solar input per inverter.
Keep both distinct from a combustion machine. They store electricity and release it rather than producing it continuously from fuel, which caps runtime but removes exhaust entirely.
For portable electric generators for home, required power depends on the appliances running together, as shown below:
Appliance | Typical Running Load | Adds a Startup Surge? |
Refrigerator or Freezer | 150 W to 800 W | Yes, briefly two to three times higher |
Lighting | Low with LED fixtures | No |
Router and Modem | Very low | No |
Phone Chargers | Very low | No |
Laptop or Computer | Low | No |
Sump Pump | 800 W to 1,000 W | Yes, and substantially |
Furnace Fan | 500 to 800 W | Yes, motor-driven |
Well Pump | 700 W to 2,000 W | Yes, often the largest in the house |
Microwave | 1,000 W to 1,500 W | No |
Running watts cover normal operation, while starting watts account for brief startup surges. Add the running loads used simultaneously, then allow headroom for the largest surge. Most importantly, size the generator from actual appliance requirements, as Consumer Reports recommends.
An electric generator for home differs by power source, with key gas and battery differences shown below:
Factor | Gas Generator | Battery System |
Energy Source | Burns fuel on demand | Releases stored electricity |
Upfront Cost | Lower per watt of output | Higher per stored kilowatt-hour |
Fuel or Recharging | Ongoing fuel purchases | Recharges from grid or solar |
Runtime | Continues while fuel lasts | Capped by capacity unless recharged |
Noise | Heard from the neighbors | Effectively silent |
Exhaust | Carbon monoxide produced | None in normal battery operation |
Indoor Usability | Never indoors | Safe indoors |
Maintenance | Oil, filters, seasonal servicing | Minimal |
Solar Charging | Not applicable | Supported on compatible systems |
Storage Between Uses | Fuel degrades over time | Holds charge, needs periodic top-up |
Automatic Backup | Requires compatible transfer equipment | Often built into the system |
Long Outages | Strong with fuel access | Depends on recharging |
Neither option suits every home. Fuel generators run while fuel remains, whereas batteries require recharging. Solar can reduce grid dependence but remains weather-dependent, as our gas generator vs solar generator comparison explains.
A home electric generator supports essential appliances during outages when sized correctly. Refrigerators, lights, routers, phone chargers, and compatible medical equipment need modest power.
Pumps, heating, air conditioning, cooking, water heating, and laundry demand substantially more power. These loads require more output, so portable units cannot necessarily power everything at once.
Runtime for portable electric generators for home varies by load and energy source. Compare Generac generators and accessories for different backup requirements. Battery runtime depends on these factors:
Usable battery capacity, which is lower than the headline figure.
Connected load.
Appliance duty cycle, since a fridge cycles rather than running constantly.
Conversion losses through the inverter.
Additional batteries, where the system expands.
Solar or grid recharging availability.
A rough estimate is easy enough. Divide usable battery capacity by the average connected load for an approximate theoretical runtime. Real performance falls short, because duty cycles, conversion losses and surges all take their share.
Fuel and recharging choices affect how long portable electric generators for home can operate, as the table below compares:
Source | What It Involves |
Gasoline | Widely available, needs safe storage and refuelling |
Propane | Stored on site, more stable in storage than gasoline |
Natural Gas | Piped supply, usually paired with standby installations |
Grid Charging | Fills stored capacity before or between outages |
Solar | Renewable recharging for compatible battery systems |
Hybrid Generator and Battery | Combines fuel generation with storage where compatible |
No single source suits every household. Weigh expected outage duration, local availability, how much you can safely store, and what the household needs to run.
The cost of an electric generator for home varies across Canada, so compare the main expenses in the table below:
Cost Factor | What Drives It |
Generator Type | Portable, standby or battery-based |
Power Output | Rated wattage or kilowatts delivered |
Battery Capacity | Stored kilowatt-hours purchased |
Fuel Capability | Single fuel, dual fuel or tri-fuel |
Transfer Equipment | Manual or automatic switching |
Electrical-Panel Modifications | Age and capacity of existing service |
Professional Installation | Required for permanent systems |
Permits | Electrical approvals, plus gas where applicable |
Fuel Storage or Connection | Tanks, or a new gas line |
Solar Panels | Where battery recharging is planned |
Battery Expansion | Additional units added later |
Fuel generators carry ongoing fuel and maintenance costs, with proper operation and maintenance emphasized in Government of Canada generator guidance. Battery systems concentrate more spending upfront without routine fuel costs. Compare total ownership cost rather than purchase price alone.
With an electric generator for home, a transfer switch serves several important purposes, including these outlined below:
A transfer switch or equivalent equipment directs backup electricity into your circuits.
It keeps backup electricity properly isolated from the utility supply.
Requirements depend on the generator type and your existing electrical setup.
Permanently integrated systems must follow applicable electrical codes and manufacturer requirements.
Use a qualified electrician wherever panel integration is involved. This is not territory for improvised wiring, and the isolation function partly protects utility crews on the line.
Safe operation matters just as much as selecting the right generator for home electricity, especially during outages.
Run fuel-burning generators outdoors, at least 6 metres from homes or buildings.
Never operate a combustion generator inside a home, garage or enclosed space.
Keep working carbon monoxide alarms and test them regularly.
Shelter equipment from severe weather without blocking required ventilation.
Store fuel safely, in approved containers.
Connect backup power to circuits only through approved equipment.
Stay within the manufacturer's stated load limits.
Battery stations produce no combustion exhaust during normal operation, allowing safer indoor use. For fuel-powered models, our guide to using a portable generator during a power outage explains proper operation and safety practices.
Before buying a generator for home electricity, Canadian households should consider these practical questions:
Question | What It Determines |
Which Appliances Must Stay Powered? | Required output |
How Long Do Local Outages Usually Last? | Fuel or storage requirements |
Portable or Whole-Home Backup? | System type |
Is Fuel Readily Available Here? | Whether a fuel generator is practical |
Is Indoor Backup Important? | Technology choice |
Does Quiet Operation Matter? | Generator type |
Do You Have Solar? | Battery recharging options |
Do You Need Automatic Backup? | Integration requirements |
Will it Work in Expected Temperatures? | Suitability for Canadian conditions |
Can Capacity Expand Later? | Room for changing needs |
The temperature question deserves more attention than it usually gets. Check the manufacturer's stated operating range rather than assuming every generator or battery performs identically through a Canadian winter.
Key buying priorities help narrow the right electric generator for home, with each factor and its impact shown below:
What You Need to Power | Where to Start |
Phones, Router and Small Electronics | Power bank or smaller battery system |
Refrigerator plus Essential Electronics | Portable generator or power station |
Several Essential Household Appliances | Higher-output portable system |
Repeated Multi-day Outages, Fuel Nearby | Appropriately sized fuel generator |
Quiet Backup Usable Indoors | Portable or home battery system |
Whole-Home Coverage | Standby generator or integrated battery |
Existing or Planned Solar | Battery storage with solar charging |
Within the EcoFlow range that maps cleanly enough. Selected essential loads and portable backup point to the DELTA 3 Max Plus, while expandable whole-home and higher-demand requirements point to the DELTA Pro Ultra. Neither answers every household, and our guide to choose a generator for home in Canada compares them.
The right electric generator for home depends on essential loads, outage duration, installation needs, and available energy sources. Compare fuel, portable battery, and whole-home systems based on actual requirements. Prioritize proper sizing, safe operation, and long-term usability. For flexible battery backup, EcoFlow offers options for portable and whole-home power needs.
Can a portable electric generator power a refrigerator and furnace at the same time?
Often yes, provided the unit handles both running loads plus the larger startup surge. A fridge and furnace fan together usually sit within reach of a mid-sized portable system. Add a well pump or air conditioning and some portable units may exceed their output.
How often should a home generator be tested?
Standby units may run automatic self-tests weekly, biweekly, or monthly, depending on their configuration. Portable models should be maintained and exercised according to their manufacturer's specified maintenance schedule instead. Battery systems require maintenance and storage according to their manufacturer's instructions.
Can you leave a portable generator outside in the rain?
Not without protection of some kind. Generators need shelter from precipitation, but any cover must preserve the ventilation and clearances the manufacturer specifies. Purpose-built enclosures exist for exactly this problem. Never run one inside a shed or garage simply to keep it dry.
Is a battery generator suitable for an apartment or condo?
Yes, and often a more practical indoor option. Battery stations produce no exhaust and run quietly, so they suit indoor use where a fuel generator would be unsafe and prohibited. Check your building rules, since some restrict large batteries.
How long can gasoline be stored for an emergency generator?
Untreated gasoline degrades within months, and stale fuel is a common reason generators fail when needed. Fuel stabilizer extends that window considerably. Rotate stored fuel on a schedule and keep it in approved containers away from living spaces.
