Génératrice Électrique: Read the Label Before You Buy
A génératrice électrique label doesn't tell you whether the unit burns fuel or stores electricity.
That distinction comes before the big wattage number. A generator with an electric starter can still run on gasoline or propane.
For Canadian home backup, check the energy source, voltage, and connections together. You also need a safe place to run or store the unit.
What Does Génératrice Électrique Mean on a Listing?
The label describes an electricity supply, but it doesn't specify how that electricity is produced or stored. Electric start is a starting feature, not a promise of fuel-free operation.
King Canada's generator listings include gasoline models with electric start. The starter turns the engine over, while fuel supplies the energy for generation.
BE's equipment filters also separate fuel type from engine-starting method. Read both fields before deciding whether a unit suits your property.
Use this comparison to identify the next specification you need:
Listing Term | What It Tells You | What to Check Next |
Electric start | A starter helps turn a fuel engine. | Fuel type, running output, and safe outdoor placement. |
Battery power station | Stored electricity supplies connected devices. | Capacity in Wh, rated output, voltage, and recharge access. |
Solar generator | Compatible solar panels and storage form a system. | Included panels and cables, electrical compatibility and charging conditions. |
Apply the same energy-source check to a générateur d'électricité listing. Neither the broad name nor the starter button tells you whether it can supply your home's fixed circuits.
An electric starter also doesn't establish automatic backup. Confirm how the unit starts, how you connect loads, and whether transfer equipment is required separately.
The home-generator comparison covers the wider portable-versus-installed decision. First establish which type you're comparing, then examine its actual ratings.
Which Battery Figures Matter for Plug-In Backup?
For stored electricity, compare what the unit can supply with how much energy it holds. These numbers answer different questions, even when they appear beside each other in a listing.
Match a Fixed Energy Store to a Defined Device List
Write down the plug-in devices you want to support, such as a refrigerator, selected lights, and communication equipment. Measure their energy use before choosing a battery size.
For a defined essentials budget, the EcoFlow DELTA 3000 Gen4 Portable Power Station provides 3,072 Wh of nominal storage. It doesn't support capacity expansion, so check that its usable energy covers your plan after losses and reserve.
Its approximately 26 kg weight also affects where you'll keep it. Choose a dry, stable storage and operating spot you can reach safely, rather than assuming it will be easy to move between floors. If you only need phone charging, a much smaller supply may suffice.
Check What Extra Capacity Actually Changes
If your planned energy use calls for more storage or later expansion, consider the EcoFlow DELTA 3800 Gen4 Portable Power Station. Its base capacity is 3,763 Wh, with advertised expansion up to 12 kWh using compatible extra batteries and the correct expansion adapter. Confirm those components separately rather than assuming they're included.
Both models list 3,600 W rated AC output at 120 V. The larger capacity gives you more stored energy, not a higher rated output or a new 240 V supply.
These are two separate options, not products that you need to purchase together or connect to each other. Neither directly supplies a 240 V heat pump, central air conditioner, or entire HVAC system. Hardwired equipment requires a verified professional connection plan.
Check current delivery timing when buying for future preparation. An expected shipment isn't equipment you can rely on during an active outage.
Read Output, Capacity and Voltage as Separate Limits
Read each specification separately before connecting a device. Enough battery capacity won't solve a mismatch in voltage, starting demand, or outlet rating.
Separate Running Power From Starting Power
Running watts describe normal operation, while some motors and compressors need more power briefly to start. NB Power distinguishes these demands when explaining generator sizing.
Use the actual device label or manual, not a generic appliance average or fixed percentage allowance. Check which devices may run or start at the same time.
Keep the socket limit separate too. Both Gen4 models have four AC outlets rated at 20 A maximum and one at 30 A maximum, within the station's total output limit. One ordinary 20 A outlet cannot supply the entire 3,600 W rating.
A surge figure describes a brief capability, not continuous output. It doesn't override an individual outlet's rating.
Turn Planned Use Into Energy, Then Check the Connection
Watts measure power, while watt-hours measure energy used over time. As a hypothetical example, an assumed 100 W combined load running for five hours uses 500 Wh.
That calculation excludes conversion losses, standby use, and a reserve. It's a unit example, not measured household demand or a runtime promise for either product. Use battery sizing for the fuller worksheet.
If devices cycle on and off, use measured energy over a suitable period instead of assuming constant draw.
Next, check the device's voltage and connection method. A compatible plug-in appliance and a hardwired circuit are different projects, even if their wattages look similar. Have a qualified electrician assess any fixed-circuit backup arrangement under your local requirements.
Check What a Solar or Recharge Claim Includes
Find out how you'll replace the energy you use. A solar label doesn't mean a bare battery charges itself or receives its maximum input throughout the day.
Confirm the Panels, Cables and Input Limits
A générateur solaire combines solar collection with electricity storage for later use. Check the exact package, since the name alone doesn't confirm that panels and all charging cables are included.
The Gen4 charging instructions should be read alongside the Canadian model specifications. The 3000 lists up to 1,000 W solar input through one port. The 3800 lists up to 2,000 W total across two ports.
Those figures are input ceilings, not a forecast of solar production. Confirm panel voltage, current, and required cables for the exact package before selecting an array. Adding panels doesn't remove the station's electrical input limits.
Compare the Next Charge With the Next Tank of Fuel
A battery can supply only the energy it holds until you recharge it. Ordinary wall charging isn't available while that electricity supply is out, and solar charging depends on daylight, shade, season, and conditions.
Fuel equipment may suit a longer interruption where you have a safe operating place, suitable fuel and a maintenance plan. Stop the engine and let it cool before refuelling, following its instructions.
Compare replenishment as part of the purchase, rather than assuming either source is unlimited. Don't count on a generator-to-battery connection or automatic hybrid operation without verifying the exact equipment and setup.
Choose a Safe Operating Place Before You Buy
Check the operating location before paying for equipment. A unit that fits your electrical needs may still be unsuitable for the space you have.
Health Canada's portable fuel-generator precautions require outdoor operation, away from enclosed or partly enclosed spaces. Keep the generator at least 6 m from your home and its doors, windows and vents, with exhaust directed away.
A garage, shed or nearby balcony isn't made safe by a quiet engine or CO shutoff. Keep carbon monoxide alarms working, and don't improvise a fuel-generator location when your property can't provide the required space.
Battery units need a dry, stable, ventilated location with clear vents and suitable temperatures. These Gen4 models list charging from 0 to 45 °C and discharging from minus 10 to 45 °C, so an unheated garage may be unsuitable.
Battery equipment doesn't burn fuel during operation, but cooling fans can still make noise. Check the conditions behind a noise specification before treating a quietness claim as silence.
Follow Canadian outage guidance on generator connections: never feed backup power into household wiring through a wall outlet. Ordinary wall charging sends power into a battery and is a different operation.
For installed backup, Ontario ESA describes approved transfer equipment and professional installation. Ontario's requirements aren't a national rulebook, so check the electrical authority where you live. Permanently installed standby equipment also has its own siting requirements.
Buy for a Power Plan You Can Explain
Before buying a génératrice électrique, write a short plan naming the energy source, devices, replenishment method, and operating place. Ask the seller to resolve any missing specification before you order.
If that plan points to plug-in battery backup, compare EcoFlow portable power stations against it and confirm the current Canadian package. Choose the equipment that fits the plan, including its limits and required accessories.
Which type of generator is best for a home?
The best fit depends on your devices, safe operating space, and access to fuel or charging. Selected plug-in loads need a different plan from installed circuit coverage, which requires compatible equipment and qualified design.
Does electric start mean a generator is battery-powered?
No, electric start describes how the engine starts, not the energy source that supplies your appliances. Check the fuel field and manual, since gasoline and propane generators can also have electric starters.
What size generator does a house need?
Size it from actual loads, starting demand, voltage, and connection needs, rather than floor area alone. A household appliance chart is only a starting reference, so verify your own equipment and realistic simultaneous use.
How much does home backup power cost?
Compare the complete setup, including equipment, required accessories, installation where needed, charging or fuel, and maintenance. Get a current Canadian quote for that configuration instead of relying on a generic national price range.
