Alberta Snowstorm: Check Alerts, Roads and Your Home
Before an Alberta snowstorm, check your local weather alert, your planned route and your electricity distributor's outage updates. Each answers a different question about staying home, travelling or preparing for lost power.
A clear street outside your window doesn't tell you what's happening farther along the highway. Before conditions worsen, gather household supplies and decide how you'll keep selected devices running if electricity fails.
Where Can You Check Alberta Snowstorm Updates?
Check the source that matches your next decision. Weather alerts describe the hazard, road reports describe the route, and your distributor reports electricity interruptions.
Use these starting points, then confirm the location and update time.
What You Need to Know | Official Starting Point | What to Check |
Weather at home or your destination | Affected area, issue time, expected hazards and recommended actions. Read the full alert, including its risk colour. | |
Your planned highway route | Conditions, closures, incidents and travel advisories along the route. A forecast doesn't confirm that a road is open. | |
An electricity interruption | Your address's electricity distributor | Its outage map, reporting options and restoration updates. Your electricity retailer may be a different company. |
Snowfall and blowing snow can create different problems. ECCC's winter weather alerts distinguish significant snowfall, poor visibility, and winter storms, which can bring several hazards.
Read the expected impacts and actions rather than relying on one snowfall total. ECCC's alert colours show increasing risk from yellow to orange to red.
If the lights go out, use the Alberta outage information to find the right distributor. Save its reporting number before you need it.
Prepare Home Essentials Before Conditions Worsen
Gather supplies while stores and roads are still accessible. Your household needs food, water, and warmth, as well as a plan for devices that need electricity.
EPCOR recommends supplies for at least 72 hours. Keep drinking water, no-cook food, warm clothing, lights and a battery-powered radio within reach.
Write down household contacts and choose how you'll check in if mobile service becomes unreliable. Use a home and car emergency checklist to fill gaps before departure or snowfall.
For backup power, start with your fridge's measured energy use, then add lighting and communication devices. If your estimated energy needs add up to several kilowatt-hours, the EcoFlow DELTA 3000 Gen4 provides 3,072 Wh of nominal storage and 3,600 W of total rated AC output.
Its capacity is fixed, so you can't add an extra battery later. Choose it for a checked device plan that fits its usable energy, rather than assuming the battery covers every appliance.
Your router also needs your internet provider's network to stay available. A charged power station can't restore a failed network.
The 72-hour target applies to household supplies. Plan battery runtime separately from that target, using your actual devices and hours of use.
Finish these checks before the storm:
Charge the power station and test the devices you intend to connect.
Choose a dry indoor location with clear ventilation. Follow its temperature limits, including charging only from 0 °C to 45 °C. An unheated garage may be too cold.
Agree on a safe place to go and who can help if your home becomes unsafe.
Match Backup Energy to the Outage Plan
Size the battery for selected devices and the hours you want to cover. Keeping those devices running doesn't ensure that your home has safe heat.
A longer fridge-and-lighting budget may call for more stored energy or room to expand. The EcoFlow DELTA 3800 Gen4 starts with 3,763 Wh and supports expansion advertised up to 12 kWh.
Expansion requires compatible extra batteries and the EcoFlow Smart Extra Battery Expansion Adapter. Confirm the exact battery combination before ordering, since different combinations provide different totals.
Its 3,600 W total rated AC output matches the 3000s. The extra storage gives you a larger energy budget, rather than higher output for heating equipment. Treat the two models as alternatives, not a required pair.
Budget Energy, Then Check Output
Watts measure how much power a device draws. Watt-hours measure the energy it uses over time, which helps you build a battery-capacity plan.
For a hypothetical six-hour period, these assumed loads use the following energy:
Illustrative Load | Assumed Use | Energy Before Losses |
Network equipment, 20 W | 6 hours | 120 Wh |
Two LED lamps, 12 W combined | 6 hours | 72 Wh |
Total | Planning example, not a device test | 192 Wh |
Multiply each load's watts by its hours of use, then add the results. This small example alone doesn't justify either Gen4 model.
A refrigerator needs a separate check because its compressor cycles on and off. Measure energy across a useful period, check its starting demand, and allow for conversion losses and a reserve.
Also check combined running power and each outlet's limit. The battery's nominal Wh figure isn't the energy you'll receive at its AC sockets.
Keep the Heating and Shelter Plan Separate
Most furnaces need electricity even when they burn gas, as ATCO's outage advice explains. Before planning backup, check your furnace's voltage, running watts, starting demand, and permitted connection method.
Both Gen4 models supply 120 V AC. They don't directly power a 240 V heat pump, central air conditioner, or an entire HVAC system. Hardwired equipment needs compatible, approved integration and a qualified electrician, without improvised wiring or backfeeding.
Never bring a fuel generator, barbecue, or camp stove indoors. Follow Alberta's outage safety advice and local relocation instructions if conditions become unsafe. Remaining battery charge doesn't tell you whether it's safe to stay home.
Let Road Conditions Decide Whether You Travel
Postpone non-essential travel when conditions make the route unsafe. Arrange supplies and an alternative place to stay early, before a difficult drive becomes your only option.
Recheck the Route Before Leaving
Check your whole route on Alberta 511, including communities beyond your departure point. Look for closures and travel advisories again shortly before leaving, since an earlier report may no longer reflect conditions.
Transport Canada recommends checking weather and carrying winter supplies. Pack a shovel, scraper, blankets, warm clothing, food, water and a light that you can reach.
Tell someone your route and expected arrival time. Agree on when to contact each other, especially if you're travelling between communities with limited services.
Don't use clear skies as your only reason to leave. Blowing snow can lift snow already on the ground and sharply reduce visibility after snowfall stops.
Know What to Do if You Become Stranded
Stay with your vehicle and call for help, following Alberta's winter-storm guidance. If the vehicle risks being struck, tell emergency services and follow their directions.
Call 911 for immediate danger. Alberta 511 provides road information, so it isn't a substitute for emergency help.
Use blankets and extra layers to conserve warmth. Don't walk into a whiteout to look for help.
If you run the engine for warmth, beware of exhaust fumes and a snow-blocked tailpipe. Follow official instructions, including allowing fresh air through a slightly open window on the sheltered side. There's no fixed idling schedule that guarantees protection from carbon monoxide.
Check the Home Before Returning to Normal
Check access and equipment even after the sky clears or power returns. Snow-covered openings, damaged lines and appliances that haven't restarted still need attention.
Use this short recovery checklist before resuming your normal routine:
Keep a safe path to exits and clear snow from accessible furnace and exhaust vents. Calgary's winter-storm advice also calls for checking on neighbours when it's safe.
Restore appliances gradually, following your distributor's instructions. EPCOR's recovery steps include checking the furnace, fridge, freezer, and other equipment after power returns.
Stay at least 10 m from downed lines, as FortisAlberta advises. Don't move nearby branches or clear snow around damaged electrical equipment.
Report damage and contact the utility or a qualified professional if heating or electrical faults persist. Leave roof work and electrical repairs to qualified help.
Follow your municipality's clearing and parking instructions. For Edmonton residents, snow-clearing and parking information provides local context that doesn't apply across Alberta.
Replace used supplies and recharge equipment within its temperature limits. Check whether your contact plan worked, and fix any gaps while the experience is fresh.
Make the Next Safe Decision Before the Snow Arrives
Prepare for a snowstorm in Alberta by checking your location, route, and power supply separately. Gather supplies before travel gets difficult, and know where you'll go if your home becomes unsafe.
Write down the devices you want to keep running, their energy needs, and their connection limits. Compare EcoFlow portable power stations against that measured plan before choosing backup power.
Is a snowstorm the same as a blizzard?
No. A blizzard involves strong winds and widespread poor visibility from falling or blowing snow. A snowfall total alone doesn't describe that hazard, so read your local alert's expected conditions and recommended actions.
Can Alberta get snowstorms in spring?
Yes. Alberta's account of the April 2026 Highway 63 storm describes heavy spring snow, blowing snow, and stranded traffic. That historical event shows why you should check spring travel conditions too, rather than rely on the season.
Is Alberta 511 an emergency number?
No. The official 511 FAQ describes a traveller-information service for road conditions, incidents, and related updates. Call 911 when you face immediate danger or need an emergency response.
Can a portable power station run my furnace during a snowstorm?
Some furnaces may work with suitable backup, but you must check voltage, running and starting demand, and the approved connection. A hardwired furnace needs compatible installed equipment and a qualified electrician. A station with 120 V output doesn't directly supply a 240 V heating system.
