Electric Floor Heating: How Much Electricity Does It Use?
Electric floor heating makes stepping barefoot onto a warm bathroom floor on a January morning in Calgary or Ottawa hard to beat. An electric in-floor heating setup can add comfort without warming every room. Before the heating mats go under the tile, though, it’s worth knowing what they’ll add to your hydro bill. This guide walks you through a quick way to estimate that cost, with numbers for a few common room sizes, before getting into what pushes the bill up or brings it down.
How Does Electric Floor Heating Work?
Electric radiant floor heating uses thin cables or mats laid just beneath the finished surface to warm the room from below. A thermostat switches them on and off as needed, so the system keeps the floor comfortable without running nonstop.
How Electric Heating Cables Generate Heat
The heating element is resistance wire, either laid loose over an uncoupling membrane (a thin plastic underlay that goes beneath tile) or pre-spaced on a mesh mat. As current passes through the wire, its resistance turns electricity into heat on the same principle as a toaster’s coils, just nowhere near as hot. The heat then spreads across the floor and rises into the room, warming people and nearby surfaces without the airflow of a forced-air furnace.
How Thermostats Control Floor Temperature
Much as cruise control holds a car at a steady speed, a digital or smart thermostat keeps the floor at the temperature you pick. When a sensor beneath the surface shows the floor has reached your setting, the thermostat switches the heating cables off, and they turn back on as it cools. Typical settings and limits depend on the flooring laid over the cables:
  • Tile and stone: typical setting 26°C–29°C
  • Engineered hardwood and luxury vinyl: more heat-sensitive, usually capped at 27°C
Check your flooring manufacturer's limit before you set the thermostat.
EcoFlow TITAN 5000 Classic Whole-Home Backup PowerEcoFlow TITAN 5000 Classic Whole-Home Backup Power
How Much Electricity Does Electric Floor Heating Use?
Electric floor heating systems can keep a bathroom floor warm from breakfast to bedtime without drawing power for every one of those hours. Once the tiles reach temperature, the thermostat cuts the power and lets the warm floor coast, then switches the cables back on in short bursts to top up the heat. What lands on your hydro bill comes down to the heated square footage, the wattage per square foot and the hours the cables actually spend drawing power.
How to Calculate Electric Floor Heating Consumption
Multiply those three numbers and divide by 1,000 to turn watts into the kilowatt-hours you're billed for:
Daily energy use (kWh) = Heated area (sq. ft.) × Power density (W/sq. ft.) × Daily operating hours ÷ 1,000
Take a 60-square-foot bathroom with 12-watt-per-square-foot mats running 5 hours a day:
(60 × 12 × 5) ÷ 1,000 = 3.6 kWh per day. The same load calculation is useful when checking whether a portable power station has enough continuous output and usable capacity for selected plug-in equipment.
Average Electricity Consumption per Square Foot
The W/sq. ft. rating, or how much power each square foot draws, sits between 10 and 15 for most Canadian systems, and 12 is the norm. Rooms that lose heat faster call for the higher end of that range:
  • 10–12 W/sq. ft.: standard for well-insulated rooms, upstairs bedrooms, or extra warmth over an already-heated subfloor
  • 12–15 W/sq. ft.: common in tiled bathrooms, basement suites and rooms over uninsulated concrete slabs
Daily and Monthly Electricity Usage
In a well-insulated room, the thermostat’s on-and-off bursts usually add up to about 4 to 8 hours a day through winter. The table runs the formula for four common room setups, using 12 W/sq. ft., about 6 hours of run time a day, an illustrative energy rate of $0.14 per kWh and a 30-day month:
Room Type
Heated Area (Sq. Ft.)
Total Wattage (W)
Daily Consumption (kWh)
Est. Monthly Cost (CAD)
Powder Room / Small Ensuite
35 sq. ft.
420 W
~2.5 kWh
~$10.50
Full Master Bathroom
70 sq. ft.
840 W
~5.0 kWh
~$21.00
Kitchen Work Zone
120 sq. ft.
1,440 W
~8.6 kWh
~$36.10
Basement Living Area
300 sq. ft.
3,600 W
~21.6 kWh
~$90.70
Note: Actual costs vary by utility, province and rate plan. These examples use an illustrative energy charge of $0.14/kWh. Check the energy, delivery and other charges on your own bill before estimating monthly cost; eligible Ontario customers can compare current plans and prices through the Ontario Energy Board.
What Factors Affect Electric Floor Heating Electricity Use?
The same heating system can cost very different amounts to run from one home to the next. Comparing home heating systems also shows why the best operating-cost choice varies by climate, building envelope and local energy price. Floor area sets how much power the cables pull while they’re on, and insulation, outdoor temperatures, thermostat settings and flooring type decide how long they stay on.
Room Size and Heated Floor Area
Only the open floor you actually walk on needs cable, because running it beneath a vanity, bathtub or heavy kitchen island warms square footage nobody stands on. Whatever sits on top also traps that heat like a lid, which can overheat the cable and burn it out.
Insulation and Outdoor Temperatures
Over an uninsulated subfloor or concrete slab in sub-zero weather, warmth drains down into the colder layer beneath. That’s conductive heat loss, like trying to keep a mug of coffee hot on ice. A good thermal break—an insulating layer beneath the cables—blocks that downward path and keeps the floor warm longer. A drafty room leaks heat too, so the thermostat switches back on more often. When preparing a home for winter, check basement rim joists and accessible insulation gaps that can contribute to cold floors.
Thermostat Settings and Heating Schedules
When the tile’s ice-cold underfoot, cranking the thermostat to maximum feels like the fastest way to warm the floor. That does about as much good as jabbing an elevator button over and over, since the cables put out the same heat whatever the setting and a higher target just keeps them running longer. A steady 26°C (79°F) uses far less electricity than 30°C (86°F), and a guest bathroom left at full heat all day with nobody in it just racks up kilowatt-hours.
Flooring Materials and Heat Transfers
Flooring affects how fast the floor warms and how long it holds the heat after the cables shut off:
  • Ceramic and Porcelain Tiles: heat up fast and hold warmth well
  • Natural Stone: slower to warm, but soaks up heat like a cast-iron pan and keeps radiating it after shut-off
  • Engineered Hardwood and Luxury Vinyl Tile (LVT): moderate conductors kept under about 27°C to prevent warping, which also trims energy use
How Can Canadian Homeowners Reduce Electric Floor Heating Costs?
Over a long Canadian winter, a few practical choices keep floor heating costs in check. A solar generator can provide another charging source for selected loads, but it does not reduce the floor-heating circuit’s wattage or the home’s heat loss. Insulation and a thermostat schedule are the easiest places to start, and households on Time-of-Use (TOU) rates may also be able to shift some of that use into cheaper hours.
Improve Floor and Basement Insulation
Before spreading thinset (the mortar that holds the tile) or setting the mats in place, lay down high-density insulation boards or a thermal uncoupling membrane. This matters most in a basement, where cables laid straight onto bare concrete lose much of their warmth into the cold ground. An insulated underlayment does for the floor what a thick insole does for a winter boot, sending nearly all the heat up into the room. The floor reaches your setting sooner, so the cables spend less time switched on.
Adjust Thermostat Settings and Heating Schedules
A smart or programmable thermostat stops the floor from heating an empty house, because nobody has to remember to turn it down. Set a weekday schedule like this one once, and the floor follows your routine on its own:
  • Morning: warm-up starts 30 minutes before the alarm
  • Daytime: idle while everyone's at work or school
  • Evening: back up to temperature for the after-work routine
Turning the setting down by just 2°C can noticeably trim costs, since each heating cycle ends a little sooner and those few minutes add up across a whole winter.
Manage Energy Use with Home Battery Storage
For Canadian households using electric floor heating, winter can increase total electricity demand. Beyond adjusting setpoints and schedules, a compatible home battery may provide more flexibility in managing selected household circuits around measured operating needs.
The EcoFlow TITAN 5000 Classic Whole-Home Backup Power starts at 5kWh and expands up to 30kWh of capacity. For households with higher power requirements, the EcoFlow TITAN 5000 Plus Whole-Home Backup Power also supports 5–30kWh capacity expansion while delivering up to 7.2kW of output. Paired with compatible solar PV and battery setups, it can reach up to 10kW of total output.
1. 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. 2. 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. 3. <30 dB. Quiet enough for indoor use—quieter than a whisper.
Both systems feature OASIS 3.0 smart energy management. Once the appropriate Smart Home Panel 10 (SHP10) is integrated into your home’s circuits, you can easily automate charging and discharging around regional TOU or tiered hydro rates. By storing electricity during off-peak, lower-cost hours and discharging battery power during expensive peak-rate windows, you can strategically cushion winter heating spikes. Note that the TITAN 5000 Classic pairs with the 120V version of the SHP10, whereas the TITAN 5000 Plus pairs with the dual-voltage 120V/240V version.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $1,100 per year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle.
Whether an electric floor heating circuit can connect directly to the system depends on its rated power, voltage and circuit compatibility. The SHP10 must be installed by a certified electrician, who can verify that it suits your household’s electrical service capacity and complies with the Canadian Electrical Code (CEC).
With electric floor heating, you pay for the hours the cables actually run, not every hour the floor feels warm. What that adds up to depends on how much floor you heat, how well it’s insulated and how you set the thermostat. Multiply your system’s total wattage by its daily run time and divide by 1,000 for kWh, then multiply by your hydro rate for the cost. Run the numbers before you install or use them to fine-tune a system you already have, and January means warm tile underfoot and a hydro bill with no surprises.
How Long Does It Take for Electric Underfloor Heating to Heat Up?
From a cold start, most electric floors reach their set temperature in 30 to 90 minutes, depending on the flooring and what’s beneath it. Thin ceramic tile over insulated backer board warms up fast, while thick stone or slate set over concrete takes longer to absorb heat but keeps radiating it well after the cables shut off.
Why Is My Underfloor Heating so Expensive to Run?
Most high bills trace back to a thermostat set high and left there, poor insulation under the floor, or running the system during on-peak hours when each kWh costs the most. Insulation is the easiest to miss. When cables sit directly on uninsulated concrete, heat bleeds down into the slab instead of rising into the room, so the thermostat keeps them running almost nonstop to hit its setting.
Can You Leave the Underfloor Heating on All Night?
Yes, as long as it’s controlled by a reliable thermostat. Rather than keeping full daytime warmth, drop it to a setback temperature of around 18°C–20°C (64°F–68°F) overnight. The tiles hold on to a comfortable bit of warmth, and you aren’t paying full price to heat a floor nobody’s standing on.
What Is the Most Efficient Heating System in Canada?
Cold-climate air-source heat pumps (ccASHPs) and geothermal heat pumps are the most efficient whole-home heating systems available in Canada today. Because they move existing heat in from the outdoor air or the ground instead of generating it through electrical resistance, they often reach 200%–400% efficiency (a COP of 2.0–4.0). In other words, each unit of electricity they use does the work of two to four. Electric underfloor cables convert electricity one-for-one, so they work best as zone-specific supplementary heating that adds comfort to a room, not as a standalone primary heat source for the whole home.
