The Best Festival Power Companion in Canada: Why Performers & Fans Choose EcoFlow
Whether you’re preparing for the music festival performance of a lifetime or are getting ready to rock out in the crowd, there is something to be said about having the perfect power companion to make the experience all the more enjoyable.
EcoFlow is a sustainable and reliable backup power brand offering a wide range of great, portable devices perfect for bringing to any outdoor music festival. If you’ve been looking for a device to power your festival experience, you’ve come to the right place.
Why Do You Need Portable Power at Festivals?
If you’ve ever attended a music festival, you know there is much to see and do throughout the experience.
To ensure you have a way of staying connected and capturing your favourite moments, it’s important to have a reliable way to charge your device, assuming you will not have regular access to a traditional charging port.
Portable devices are great and will provide quick and easy access to backup power in a pinch.
What Makes EcoFlow Ideal for Festivals?
  1. EcoFlow products are typically lightweight and easy to transport.
  2. Provide clean and safe energy to use even in crowded spaces.
  3. Offer multiple charging ports and options for all of your mobile devices.
  4. Designed with durability in mind, making them a great companion for outdoor events.
  5. Easy to use and control with a downloadable app.
  6. Small and compact models are allowed at the majority of festivals, unlike larger, more traditional power generators.
Why Should Performers Choose EcoFlow at Events?
Music performers require a certain calibre of equipment to put on a great show. Here are some of the main reasons performers flock to EcoFlow for their power needs.
High Power Capacity
Outdoor gigs can be challenging without adequate power to keep your instruments and devices connected. With the majority of EcoFlow products, you can easily provide power to a full setup of equipment, including amps, guitars, laptops, and even lighting fixtures.
Low Volume When in Use
EcoFlow products are known to run at an incredibly low decibel. Unlike other, more traditional generators, these products are barely heard when in use and will not take away from the live performance.
Fast Charging
Are you playing multiple sets in one day at the festival? With EcoFlow products, you won’t have any issue keeping your setup fully charged and ready to go. These portable power stations can quickly charge up your devices in under an hour, making it easy to be prepared and perform as soon as the curtain drops.
No Fumes
A traditional generator can wreak havoc in the vicinity where it’s being used. Fuels like gasoline emit dangerous fumes and can cause an issue during a performer's set, so it’s recommended to use clean, battery-powered devices instead.
For example, the EcoFlow WAVE 3 is a portable cooler that provides clean, reliable, and sustainable power. It’s perfect for performers and festival-goers who want to stay sweat-free in their downtime.
EcoFlow WAVE 3 next to tent in woodland
Why Should Festivalgoers Choose EcoFlow?
Whether you are an avid festival-goer or prepping to attend your first one, it can be incredibly beneficial to pack a power companion for your weekend at the event. Phones are notorious for dying quickly in these packed settings, and having a portable charging device can really help in a pinch.
Here are a few reasons why EcoFlow products are considered the best festival power companions.
Portability
You have to travel light to enjoy a music festival to the fullest. EcoFlow’s portable power stations are designed with portability in mind and are easy to take on the go. Their lightweight and compact chargers are small enough to keep on your person but powerful enough to keep your devices charged and connected throughout the weekend.
Reliablility
The portable power devices are designed for these types of outings and can hold their charge for days on end. You can have peace of mind knowing your EcoFlow device will be ready for the entire music festival experience.
Fast Charging Capabilities
The last thing you want to worry about during your festival experience is waiting around for your device to charge. With EcoFlow’s RAPID Magnetic Power Bank (10,000mAh), you can charge a dead phone battery in under 30 minutes and have it ready to go for the next music set.
EcoFlow RAPID Magnetic Power Bank (10000mAh)
Can I Bring a Portable Power Station to Music Festivals in Canada?
Yes! Small portable power stations are allowed at music festivals throughout Canada. Some sites ban power stations that require fuel like gasoline or propane, so be sure to bring a device that is explicitly permitted at the event you are attending.
Are Portable Power Stations Safe to Use Inside Tents or Trailers?
Traditional generators are not safe to use inside tents or trailers, but there are other options. Battery-powered portable power stations are generally safe to use in enclosed settings and are equally capable of providing your space with adequate power.
Will a Solar Generator Work in Cloudy Weather at a Festival?
Yes, solar generators can work even in cloudy conditions. These devices may charge a bit slower than they would in direct sunlight, but they can still provide power to any connected devices.
Festival-Goers Rely on EcoFlow for Safe, Silent Power
It’s easy to see why having a power companion at any music festival can elevate your overall experience. EcoFlow’s catalogue of products has the perfect device for every occasion, whether you’re seeking something compact to charge your phone or a more robust power station for your campsite.
Ready to upgrade your festival experience? Check out the EcoFlow RIVER 3 + 45W Solar Panel for a sustainable and reliable solution to your on-the-go backup power needs.
Off-Grid Power
