Solar Battery Explained: Everything You Need to Know
As electricity costs continue to rise and power outages become more common, homeowners are seeking smarter ways to manage their energy. Solar panels have long been a popular solution, but their effectiveness is limited to the hours when the sun is shining. That’s where solar batteries come in.
A solar battery stores the excess electricity generated by your solar panels during the day and makes it available whenever you need it—whether it’s at night, on cloudy days, or during an unexpected grid outage. By pairing solar panels with a battery, you can reduce reliance on the grid, save on energy bills, and gain greater control over how your home uses electricity.
In this guide, we’ll explore everything you need to know about solar batteries—from how they work and the types available, to the benefits they offer and the key factors to consider when choosing one. Whether you’re planning a new solar installation or looking to upgrade your current system, this guide will help you make an informed decision and get the most out of your solar investment.
What Is a Solar Battery?
A solar battery is an energy storage device that stores electricity generated by solar panels for use at a later time. Unlike conventional batteries used for small electronic devices, solar batteries are designed to handle the energy needs of a home or building, providing a reliable reserve of power when the sun isn’t shining.
The key function of a solar battery is to capture surplus energy produced during periods of high solar generation and hold it until it is needed. This allows a solar power system to operate beyond the hours of direct sunlight, storing energy during the day and releasing it during the evening, night, or cloudy periods.
In essence, a solar battery serves as a bridge between electricity production and electricity use, ensuring that the energy generated by solar panels can be used efficiently and on demand.
How Does a Solar Battery Work?
A solar battery works by storing the electricity generated by solar panels and releasing it when needed. Solar panels produce electricity in the form of direct current (DC) when sunlight hits their photovoltaic cells. This electricity can either be used immediately in your home, or stored in a solar battery for later use.
Inside the battery, chemical reactions allow energy to be safely stored. In most modern home systems, lithium-ion batteries are used. When charging, electricity from the solar panels moves lithium ions from one electrode to another, storing energy as a chemical potential. When the battery is discharging, the ions move back, releasing electrons that flow as usable electrical current to power appliances in your home.
Solar batteries can be connected in different ways depending on your system:
  • DC-coupled systems send electricity directly from the solar panels to the battery in its original DC form, converting it to alternating current (AC) only when powering your home.
  • AC-coupled systems first convert the electricity from DC to AC via an inverter for immediate household use, and then convert any excess AC electricity back into DC to charge the battery.
This process allows solar batteries to store energy during the day and provide electricity at night, during cloudy periods, or even during power outages, effectively bridging the gap between solar energy production and household energy needs.
Types of Solar Batteries
Solar batteries come in several types, each with unique chemical compositions, performance characteristics, and ideal use cases. Understanding these differences helps homeowners choose the right battery for their energy needs.
Lithium-Ion Batteries
Lithium-ion (Li-ion) batteries are the most widely used type in residential solar storage today. They are compact, lightweight, and offer high energy density, meaning they can store more energy in a smaller space. Li-ion batteries typically provide a higher depth of discharge (DoD), allowing homeowners to use a larger portion of their stored energy without shortening battery life.
Pros:
  • High energy density and compact size
  • Long lifespan and high cycle durability
  • Low maintenance
Cons:
  • Higher initial cost compared to lead-acid batteries
  • Requires thermal management to prevent overheating
Lithium Iron Phosphate (LFP)
A subtype of lithium-ion, lithium iron phosphate batteries are gaining popularity for home use due to their excellent thermal stability and long cycle life. They are also cobalt-free, making them a more sustainable option. LFP batteries can often last 6,000–10,000 cycles at 80% DoD, translating to 15–20 years of reliable use.
Pros:
  • Exceptional safety and thermal stability
  • Long cycle life and high DoD
  • Environmentally friendly chemistry
Cons:
  • Slightly lower energy density than other lithium-ion variants
  • Higher upfront cost than traditional lead-acid batteries
Lead-Acid Batteries
Lead-acid batteries are one of the oldest technologies used for energy storage. They are often found in off-grid or budget-conscious solar installations. While reliable and cost-effective, they are heavier, bulkier, and offer a lower depth of discharge, meaning less usable energy per cycle.
Pros:
  • Affordable and widely available
  • Proven, reliable technology
  • Simple maintenance (especially sealed variants)
Cons:
  • Lower DoD (typically 50%)
  • Shorter lifespan and larger physical footprint
  • More maintenance is required for flooded types
Benefits of Solar Batteries
Adding a solar battery to your home solar system offers multiple benefits, extending the value and flexibility of your renewable energy setup.
1. Store Excess Solar Energy
Solar panels often generate more electricity than a household needs during peak sunlight hours. A solar battery captures this surplus energy for later use, ensuring that every kilowatt-hour your panels produce is maximized.
For households aiming to maximise solar self-consumption, pairing a solar battery with a high-capacity portable power station provides added flexibility.
The EcoFlow DELTA Pro 3 Portable Power Station can store excess solar energy generated during the day and supply reliable power at night or during outages. With high output suitable for essential appliances such as refrigerators and lighting, it offers a scalable solution for greater energy independence and less grid reliance.
The EcoFlow DELTA Pro 3 Portable Power Station is designed for solar-powered homes, offering 4096Wh capacity and 4000W output at 230V to support most household appliances, including a 500W washing machine. With up to 2600W solar input, it stores excess solar energy generated during the day for nighttime use or shedding protection. A 10ms UPS switchover keeps essential devices powered, while using stored solar energy helps households reduce grid reliance and save on electricity costs.
For more compact or portable needs, the EcoFlow RIVER 3 Portable Power Station provides a convenient solar-ready solution. With 245Wh capacity and 300W output, it is well suited for powering small appliances and essential electronics. It can be recharged via solar panels to store excess energy for later use, helping maintain reliable power for basic home needs.
With solar compatibility supporting up to 110W input, the EcoFlow RIVER 3 Portable Power Station can store excess solar energy for flexible home use. It delivers extended runtime for low-power devices under 100W, making it suitable for essential electronics during outages or load shedding. Its compact design 30% smaller than the industry average and four charging options provide convenient energy access, helping households maintain basic power needs and move toward greater energy independence.
2. Provide Backup Power
A solar battery ensures your home has electricity even during grid outages, providing reliable backup power and complementing other load shedding solutions available in your area.
3. Reduce Electricity Bills
By storing solar energy during the day and using it during peak rate periods, a battery helps reduce reliance on the grid. This strategy, often called energy self-consumption or time-of-use optimization, can lower monthly electricity costs significantly.
4. Increase Energy Independence
With a solar battery, your household becomes less dependent on external power sources. You gain more control over your energy usage, making your home resilient to fluctuating utility rates and potential grid instability.
5. Support a Greener Lifestyle
Using a solar battery allows you to rely more on clean, renewable energy and less on fossil-fuel-based electricity. This reduces your carbon footprint and contributes to a more sustainable energy future.
Factors to Consider When Choosing a Solar Battery
Selecting the right solar battery for your home goes beyond just picking the biggest or most expensive option. A well-chosen battery ensures optimal performance, cost-effectiveness, and long-term reliability. Here are the key factors to consider:
1. Battery Capacity
Battery capacity, measured in kilowatt-hours (kWh), indicates how much energy the battery can store. To choose the right size, consider your household’s daily electricity consumption. A properly sized battery should allow you to store enough energy during the day to cover your evening and nighttime needs.
2. Depth of Discharge (DoD)
Depth of discharge determines the percentage of a battery’s total capacity that can be used safely without damaging the system. Batteries with higher DoD allow you to utilize more of the stored energy, maximizing efficiency and savings.
3. Power Output
Measured in kilowatts (kW), power output determines how much electricity the battery can supply at a given moment. For households with high-power appliances, such as air conditioners or electric ovens, ensure the battery can handle peak demand.
4. Battery Chemistry and Lifespan
Different chemistries offer varying lifespans, efficiency, and thermal stability. Lithium Iron Phosphate (LFP) and Lithium Nickel Manganese Cobalt (NMC) batteries are the most common for home use, offering long cycle life and reliable performance. Lead-acid batteries are cheaper but have a shorter lifespan and lower efficiency.
5. Efficiency
Round-trip efficiency measures how much stored energy is actually usable after charging and discharging. Higher efficiency means less energy lost during conversion, which translates to more savings and better system performance.
6. Compatibility and Installation
Ensure your chosen battery is compatible with your existing solar panels, inverters, and household electrical system. Some systems are AC-coupled or DC-coupled, which affects installation complexity, efficiency, and whether the battery can be easily added to an existing solar setup.
7. Incentives and Cost
Consider upfront costs, potential rebates, and available tax incentives. While a higher-priced battery may offer better performance or longevity, incentives can help offset initial investment, improving overall return on investment.
Choosing the right solar battery is a crucial step in creating a smart and efficient home energy system. By understanding your household’s energy needs, evaluating different battery types, and planning for future usage, you can make an informed decision that fits your lifestyle and budget.
The next step is simple: take action and build home battery backup system to provide your home with reliable, flexible power storage. Doing so ensures your solar setup delivers maximum efficiency while laying the foundation for long-term energy independence.
How much is a 10kW solar battery for a house?
The cost of a 10kW solar battery depends on the battery type, brand, and installation requirements. Lithium-ion batteries, which are the most common for home use, tend to be more expensive than lead-acid batteries but offer higher efficiency, longer lifespan, and deeper discharge. On average, a 10kW lithium-ion battery system can range from $8,000 to $15,000 USD, including installation. Additional costs may include inverters, wiring, and permits. Incentives, rebates, or tax credits in your area can reduce the upfront investment, making the system more affordable while maximizing long-term savings.
How many hours will a solar battery last?
The duration a solar battery can power a home depends on its capacity, the household energy demand, and the depth of discharge. For example, a fully charged 10kW lithium-ion battery can theoretically provide 10 kilowatts of power for one hour, or 5 kilowatts for two hours. In practical use, most homes draw varying amounts of energy for appliances, lighting, and HVAC systems, so a 10kW battery may supply essential loads for several hours to a full day. Weather, solar panel production, and usage patterns also influence the battery’s operational time.
Is a battery for solar worth it?
In South Africa, frequent load shedding and rising electricity costs make a solar battery a worthwhile investment. It stores excess solar energy during the day for use at night or during outages, ensuring essential household power remains uninterrupted. Reducing reliance on the grid, it can also help cut electricity bills. For households aiming for greater energy independence and long-term savings, a solar battery offers a practical and reliable solution.
