Ecoflow Delta Series vs River Series: Which Is Right for You?
EcoFlow DELTA series is a range of high-capacity portable power stations built for household backup, demanding outdoor use and power outages. EcoFlow RIVER focuses on smaller, lighter units for everyday electronics and travel. Choosing between them comes down to what you need to power and for how long. For South African households, remote workers, and campers, this guide compares capacity, output, and portability across five common use cases to help you find the right product.
Key Takeaways
  • Choose an EcoFlow RIVER portable power station when small-device backup and carrying weight are your priorities.
  • Consider DELTA for higher appliance loads or a larger energy reserve, after checking your required runtime.
  • Compare rated AC output, battery capacity and startup capability separately. X-Boost is not a substitute for the rated output or surge specification.
  • Charging speed, solar input, battery expansion and backup switching vary by model, even within the same series.
  • Check the exact South African model and any required batteries, cables or adapters before ordering.
EcoFlow DELTA vs RIVER Series at a Glance
These five models show how DELTA and RIVER compare. RIVER is generally easier to carry and suited to smaller devices, while DELTA typically offers greater capacity and higher output for more power-hungry appliances. Start with where you will use your power station, what you need to run and how often you expect to move it.
Feature
EcoFlow RIVER 3
EcoFlow RIVER 2 Max
EcoFlow DELTA 3 Plus
EcoFlow DELTA 3 Max
EcoFlow DELTA 3 Ultra Plus
Battery capacity
245Wh
512Wh
1024Wh
2048Wh
3072Wh
Battery chemistry
Rated AC output
300W
500W
1800W
2400W
3600W
Supported appliance rating with X-Boost*
Up to 600W
Up to 1000W
Up to 2400W
Up to 3200W
Up to 4700W
Backup switchover
Standard: <20 ms; 10 ms UPS version: <10 ms
30 ms switchover
<10ms UPS
<10ms UPS
<10ms UPS
Approximate weight
3.55kg
6kg
≤12.5kg
20.3kg
33.7kg
AC charging time**
0–100% in 60 minutes
0–100% in 56 minutes
0–80% in 51 minutes
0–80% in 75 minutes
*X-Boost supports selected compatible appliances. Its appliance rating is not the unit’s continuous output or startup surge rating. Charging times use different charge ranges, as shown, and reflect the manufacturer’s stated conditions. Actual results vary with settings, temperature and use.
Weight note: DELTA 3 Max’s overview states 20.3kg, while its specification table prints “20.3+0.4kg”. Confirm the supplied unit’s weight if this affects your lifting or packing plans.
What Are the Key Differences Between DELTA Series and RIVER Series?
Battery Capacity and Runtime
Battery capacity, measured in watt-hours (Wh), tells you how much energy a unit stores. Rated output, measured in watts (W), tells you how much power it can supply at once. A higher output rating does not, on its own, give you a longer runtime.
In the comparison above, the RIVER models have smaller batteries and the DELTA models store more energy. Runtime still depends on the connected load, conversion losses and the power station’s own consumption. A larger battery does not guarantee a full working day or an entire weekend of power.
Rated Output, Startup Demand and X-Boost
A fridge, microwave or power tool presents a different challenge from a phone charger. Understanding which appliances use the most electricity helps you plan what to power and for how long. Check each device’s running wattage and allow for startup demand where a motor or compressor is involved.
Add the loads that will operate together and keep them within the unit’s total rated AC output and individual outlet limits. For a microwave, use its electrical input rating, not its advertised cooking output.
X-Boost can support selected compatible appliances above the normal rated-output figure. It does not turn that figure into a new continuous output rating or establish that a fridge compressor or power tool will start. Check the appliance and model-specific guidance instead of choosing by the largest wattage in an advert.
Weight and Portability
Portability matters when you carry a battery from the house to the car, move between workspaces or pack around camping equipment. A smaller unit is also easier to position beside a desk or store between trips.
The featured RIVER models are easier to carry than the featured DELTA models. For a larger unit, consider lifting it into a bakkie or caravan and securing it during travel. Compare the actual weight with how far and how often you will move it.
AC Charging and Solar Input
All five models offer AC and solar charging, but the limits differ. Compare like-for-like charge ranges: a time quoted for 0–80% is not a full-charge time.
Solar input varies by model: RIVER 3 supports up to 110W, RIVER 2 Max 220W, DELTA 3 Plus 1000W across two inputs, DELTA 3 Max 500W and DELTA 3 Ultra Plus 1600W. A larger battery does not necessarily mean a higher solar input limit.
Check the panel array’s voltage, current and connectors as well as its wattage. Actual solar generation depends on sunlight, shading, panel position and temperature. For an unpowered campsite, plan how much energy you can realistically replace each day.
Battery Expansion and Backup Switching
Selected EcoFlow DELTA models let you add compatible batteries as your runtime needs grow. Expansion increases stored energy; it does not automatically increase the main unit’s AC output.
DELTA 3 Plus supports expansion to approximately 5kWh with a compatible extra battery. DELTA 3 Ultra Plus supports approximately 7kWh with a DELTA Pro 3 Smart Extra Battery and the specified EcoFlow Smart Extra Battery Expansion Adapter. Check the bundle contents; the standalone power station does not include these accessories.
RIVER 3 offers two versions with different transfer times, while RIVER 2 Max lists a 30 ms switchover. The three featured DELTA models specify <10 ms UPS switching. Refer to the table for each version and test your connected equipment: transfer time alone does not guarantee that every device will avoid restarting.
Which Series Suits Your South African Home or Trip?
The following recommendations connect each model to a practical use case. Use them as a starting point, then check your own equipment’s running power, startup requirements and desired runtime. Charging figures below refer to AC charging under suitable conditions; actual results vary with settings, temperature and use.
Keeping Home Essentials Running
A power outage during dinner preparation can leave you juggling an unfinished meal, a dark kitchen and a fridge that needs to stay cold. Decide which devices must remain on and which can wait until mains power returns. Running cooking appliances one at a time can help keep simultaneous demand manageable.
Small changes help stretch stored energy. Following Eskom’s advice on efficient fridge use, such as checking door seals and avoiding unnecessary opening, can reduce the work your fridge needs to do. Check your fridge’s startup demand before connecting it, and leave enough output headroom for anything else that will run alongside it.
The EcoFlow DELTA 3 Plus Portable Power Station combines flexible charging, expandable storage and versatile power output to support everyday routines and unexpected outages. If the power goes off while you are preparing dinner, it can keep a kitchen light on, support your fridge and power a compatible microwave to warm a dish. Check the combined running load, fridge startup demand and battery capacity needed for your planned use.
- 1024Wh LFP Battery - Expandable to Approximately 5kWh - 1800W AC and Up to 2400W with X-Boost - 3600W Surge Output - Ups Mode <10 ms switchover
Working from Home with a Laptop, Router and Monitor
A power interruption during a video meeting can disconnect your router and switch off your monitor, even when your laptop still has battery power. Include the fibre ONT, router and screen in your backup plan, and check their combined consumption. If you need these devices to stay on during the changeover, check their tolerance for a brief interruption as well.
The EcoFlow RIVER 3 Portable Power Station combines a compact design, flexible charging and automatic backup switching for everyday use at home or on the move. Beside your desk, its UPS function can help maintain power to compatible networking equipment and other work essentials when mains electricity fails. Choose the appropriate version and test your connected setup before relying on uninterrupted operation.
- 245Wh LFP Battery - 300W Rated AC Output - UPS Switchover Under 10/20ms - 100W Maximum USB-C Output - 0 to 100% AC Charging in about 1 Hour
Camping and Day Trips with Small Electronics
A day outdoors might involve taking photos, checking your route on your phone and switching on a campsite light after sunset. If you stay overnight, you may also need to recharge camera batteries or use a laptop to organise your photos. List the devices you will bring and confirm access to charging at your destination. Although some campsites in South Africa have electricity, check the facilities at your specific accommodation or pitch before planning your recharges.
The EcoFlow RIVER 2 Max Portable Power Station combines portable energy storage, multiple connection options and flexible charging for everyday routines and trips away. At camp, you can use it to charge your phone and camera batteries, power compatible lighting or connect your laptop to review the day’s photos. Recharge through a suitable campsite socket, compatible vehicle connection or solar setup, depending on your itinerary.
- 512Wh LFP Battery - 500W Rated AC Output - Approximately 6kg Carrying Weight - Up to 220W Solar Input - 4 Charging Options
Overlanding and Outdoor Events with Heavier Loads
On an overlanding trip, you may need to keep food chilled during the drive, switch on campsite lights after sunset and prepare a meal when you stop. An outdoor event can bring a similar mix of refrigeration, lighting and cooking equipment. Plan which devices will run together and where you can recharge along the way.
The EcoFlow DELTA 3 Max Portable Power Station combines substantial battery capacity, versatile AC output and flexible charging options for use at home, on the road or at an event. It can support a compatible camping fridge, lighting and selected cooking appliances, provided their combined demand stays within its output limits. Match your planned runtime to the available battery capacity, and schedule charging around your journey or event.
- 2048Wh LFP Battery - 2400W AC Output - Up to 3200W with X-Boost - Lightweight and Easy to Carry - 0 to 80% AC Charging in about 51 Minutes
Powering Workshops and Extended Off-Grid Stays
Working in a workshop without convenient mains access or spending several days off-grid requires a clear power plan. Identify the tools and appliances you need, check their startup requirements and estimate daily energy use. Plan when and how you will recharge between tasks.
Your connection method also matters. In Cape Town, requirements for installed solar and battery systems differ from those for portable plug-in equipment. Consult your electricity provider and a qualified installer before connecting backup power to building wiring.
The EcoFlow DELTA 3 Ultra Plus Portable Power Station combines substantial AC output, expandable storage and flexible charging options for household backup, practical projects and extended trips. In a workshop, it can power compatible tools and lighting within its output and battery limits. For connections to building wiring, consult your electricity provider and a qualified installer.
- 3072Wh LFP Battery - Expandable to 7kWh Capacity - 3600W AC and Up to 4700W with X-Boost - 7200W Surge Output - 5 DC Outlets
Choose by Power Needs, Runtime and Portability. EcoFlow DELTA series is the stronger fit for heavier appliances and longer backup needs, while EcoFlow RIVER series suits portable power for smaller devices. Start with your equipment list, total the loads that will run together, and estimate how many hours you need. Then consider carrying weight and charging access. Choose the model that covers that routine with sensible headroom, rather than selecting the largest battery by default.
Can a RIVER Power Station Run a Refrigerator?
A RIVER power station can run a refrigerator if the appliance’s running power and startup demand fall within the specific model’s capabilities. Check both before connecting it, and estimate the runtime from the fridge’s measured energy use. X-Boost ratings should not be treated as startup surge ratings.
What Should You Check Before Taking a Power Station Camping?
List the devices you will bring, estimate their daily energy use and check your campsite’s charging facilities. Allow enough battery capacity for the time between recharges. If you plan to use solar panels or vehicle charging, confirm compatibility with your power station and the required cables.
How Do You Choose a Power Station for Home Backup?
Start with the appliances you need during an outage and how long they must run. Add the wattage of devices operating together, allow for motor startup demand and calculate the required battery capacity. For a connection to fixed household wiring, ask a qualified installer to assess compatibility and installation requirements.
Portable Power Stations
