EcoFlow DELTA 3 Series Review: Which Is Right for You?
South Africa’s electricity supply has become more stable, but unexpected power outages can still result from municipal faults, severe weather, damaged infrastructure or planned maintenance. When the mains supply fails, stored energy can keep essential devices running, maintain internet access and reduce disruption to home offices and daily household routines.
The EcoFlow DELTA 3 Series covers three different levels of demand. DELTA 3 Plus provides compact backup for essential devices, DELTA 3 Max increases capacity and output for longer household use, while DELTA 3 Ultra Plus supports higher combined loads and expandable storage. This guide compares their specifications and suitable applications to help you choose the right model.
EcoFlow DELTA 3 Series Comparison at a Glance
The main differences between the three models are their battery capacity, AC output, portability and expansion potential.
Feature
EcoFlow DELTA 3 Plus
EcoFlow DELTA 3 Max
EcoFlow DELTA 3 Ultra Plus
Base capacity
1,024 Wh
2,048 Wh
3,072 Wh
Expandable capacity
Up to 5 kWh
Check compatible extra-battery options
Up to 7 kWh
Rated AC output
1,800 W
2,400 W
3,600 W
Surge output
3,600 W
4,800 W
7,200 W
X-Boost
Selected appliances over 2,400 W
Selected appliances up to 3,200 W
Selected appliances up to 4,700 W
Solar Input
Up to 1000W
Up to 1000W
Supports solar charging with higher-capacity setups
UPS switchover
10 ms
Under 10 ms
Under 10 ms
Noise Level
Quiet operation(<30 dB)
Ultra-low noise (≤25dB at 600W)
Ultra-quiet operation (≤25dB)
Smart Features
App control and UPS protection
App control, UPS protection, and intelligent energy management
Advanced app control and energy management features
Best suited to
Essential devices and home offices
Longer home backup and higher loads
Multiple appliances and extended backup
How to Choose the Right DELTA 3 Model
Start by listing the appliances you want to run simultaneously and adding their rated power in watts. Appliances with compressors or motors, such as fridges and pumps, may draw additional power when starting.
You should also consider:
  • How long the appliances need to remain powered.
  • Whether you need a portable or more permanent setup.
  • Whether you want to add solar panels.
  • Whether you may need more battery capacity later.
  • Whether your devices require UPS protection.
For a short power outage affecting only internet access and a home office, DELTA 3 Plus may provide sufficient capacity. For longer local outages involving a fridge, television and several household devices, DELTA 3 Max or DELTA 3 Ultra Plus offers more runtime and output.
EcoFlow DELTA 3 Plus: Compact Backup for Essential Devices
For smaller homes, flats and home offices, the EcoFlow DELTA 3 Plus Solar Generator (160W Lightweight Solar Panel) provides a compact combination of stored energy and portable solar charging.
DELTA 3 Plus offers a 1,024Wh capacity, 1,800W rated AC output and 3,600W surge output. It can support Wi-Fi routers, computers, monitors, lights, televisions and selected small appliances, provided their combined consumption remains within its rated output. Its 10ms UPS switchover also helps reduce the risk of compatible computers, NAS systems and networking equipment shutting down during an unexpected outage.
The included 160W Lightweight Solar Panel has a conversion efficiency of up to 25% and is easy to carry, position and store. It provides a convenient way to top up the power station when mains electricity is unavailable or when the system is used in a caravan or off-grid location.
Best for:
  • Flats and smaller homes.
  • Home offices and remote work.
  • Routers, computers, monitors and lights.
  • Buyers purchasing their first solar generator.
  • Users who prioritise portability and easy storage.
DELTA 3 Plus supports up to 1,000W of solar input, so users can connect a larger compatible solar configuration in the future if faster solar charging is required.
The EcoFlow DELTA 3 Plus Solar Generator (160W Lightweight Solar Panel) is a compact and efficient backup power solution for everyday use. With 1024Wh capacity and 1800W output, it keeps essentials like Wi-Fi routers, lights, laptops, and TVs running during power interruptions. The included 160W lightweight solar panel provides convenient recharging for off-grid flexibility. Perfect for apartments, small homes, and first-time buyers seeking affordable, reliable backup power in South Africa.
EcoFlow DELTA 3 Max : More Runtime for Household Backup
For households that need longer runtime and higher output, the EcoFlow DELTA 3 Max Solar Generator (400W Lightweight Solar Panel) provides a more capable solar generator setup.
DELTA 3 Max offers a 2,048Wh capacity, 2,400W rated output, 4,800W surge output and X-Boost support for selected appliances up to 3,200W. Compared with DELTA 3 Plus, its larger battery can keep essential household devices operating for longer and support a higher combined load.
It is suitable for powering combinations of appliances such as a fridge, Wi-Fi router, television, lighting and home-office equipment. During a longer municipal or weather-related outage, the additional capacity can help a household maintain refrigeration, connectivity and basic lighting for longer. Its UPS function switches to battery power in under 10 ms, helping compatible computers, networking equipment and security systems remain operational when a local power fault interrupts the mains supply.
The included 400W Solar Panel provides a stronger solar charging option than the smaller 160W bundle. Actual solar generation will depend on sunlight, panel angle, temperature and shading.
Best for:
  • Families needing longer backup runtime.
  • Fridges, routers, televisions and lighting.
  • Home offices with several devices.
  • Workshops and caravan use.
  • Users who want a balance of capacity, output and portability.
Users should calculate the combined running and starting wattage before connecting several high-power appliances at the same time.
Combining a 2,048Wh battery, 2,400W output and a 400W solar panel, this setup provides longer runtime and higher output for household appliances and home-office equipment. It is a balanced choice for users who need more power than DELTA 3 Plus while retaining the flexibility of a portable system.
EcoFlow DELTA 3 Ultra Plus : Expandable Power for Higher Household Demand
For larger household loads and longer backup requirements, the EcoFlow DELTA 3 Ultra Plus Portable Power Station + 2 x 400W Rigid Solar Panel provides the highest capacity and output of the three recommended combinations.
DELTA 3 Ultra Plus has a 3,072Wh base capacity, expandable storage from 3kWh to 7kWh, a 3,600W rated AC output and a 7,200W surge output. It can support several essential household devices simultaneously, including fridges, televisions, networking equipment, computers, lighting and selected kitchen appliances.
During an extended power outage, its higher output and expandable capacity allow households to prioritise several essential appliances instead of relying on a small group of low-power devices. Its UPS switchover takes under 10 ms, helping reduce interruptions to compatible computers, NAS systems, routers and security equipment.
The two 400 W rigid solar panels provide up to 800 W of combined rated panel capacity under ideal test conditions. When mains power remains unavailable during the day, the panels can replenish part of the energy used by essential appliances, subject to sunlight and installation conditions.
Best for:
  • Larger homes with several essential appliances.
  • Extended household backup.
  • Home offices and small businesses.
  • Users planning to expand battery capacity.
  • Households building a larger solar charging setup.
Although DELTA 3 Ultra Plus offers the highest output in this comparison, users should still calculate their total load and manage high-consumption appliances carefully.
At the top end of the DELTA 3 Series, the EcoFlow DELTA 3 Ultra Plus Portable Power Station + 2x400W Rigid Solar Panel is built for longer outages and higher household energy demands. Beyond providing backup power, it adds smarter energy management features to help optimise electricity usage during extended power outages.
For longer power outage periods, the EcoFlow DELTA 3 Ultra Plus offers extended backup power and greater energy flexibility. With a 3072Wh battery capacity, 3600W output, and expandable capacity from 3kWh to 7kWh, it provides reliable support for more essential appliances and longer outages. Paired with 2×400W Rigid Solar Panels, it supports efficient solar charging with up to 1600W solar input, offering greater flexibility for households looking for longer-lasting backup power and reduced reliance on the grid.
Which EcoFlow DELTA 3 Model Should You Choose?
Model
Suitable outage scenario
Typical devices
DELTA 3 Plus
Short outages affecting internet, lighting or a home office
Router, computers, monitors, lights and TV
DELTA 3 Max
Longer household outages requiring more runtime
Fridge, router, TV, lights and office equipment
DELTA 3 Ultra Plus
Extended outages involving several essential appliances
Multiple household appliances, office systems and security equipment
Choose DELTA 3 Plus if portability and essential backup are your priorities. DELTA 3 Max is more suitable when you need greater runtime and higher output. DELTA 3 Ultra Plus is intended for users who want to support several appliances and expand their storage capacity over time.
The right EcoFlow DELTA 3 model depends on the appliances you want to run, their combined wattage and the required backup time. For short, unexpected outages, DELTA 3 Plus is a practical choice for internet equipment, essential electronics and home offices. For longer municipal faults or weather-related outages, DELTA 3 Max provides twice the base capacity and a higher rated output.
DELTA 3 Ultra Plus is better suited to households and small businesses that need to run several devices during an extended power interruption, add fixed solar panels or expand their stored energy over time. Before choosing, check the running and starting wattage of your appliances and decide whether portability, runtime or future expansion matters most.
Is EcoFlow Delta 3 worth it?
Yes, the EcoFlow DELTA 3 Series can be worthwhile for households that need portable backup power, fast recharging or solar compatibility. DELTA 3 Plus suits essential devices, while DELTA 3 Max and DELTA 3 Ultra Plus provide greater capacity for longer outages and higher combined loads.
Can I leave EcoFlow plugged in all the time?
DELTA 3 Series models can remain connected to mains power when used in UPS mode. The built-in battery management system monitors charging and battery conditions. Follow the instructions in the product manual, keep the unit in a well-ventilated area and use the recommended storage charge level if it will not be used for an extended period.
How long will EcoFlow Delta 3 run a refrigerator?
The runtime depends on the refrigerator’s power consumption, usage cycle, and the specific DELTA 3 model. A typical household refrigerator may run for several hours on the DELTA 3 Series during outages, with larger-capacity models providing longer backup time. For the most accurate estimate, check the refrigerator’s wattage and compare it with the power station’s battery capacity. In South Africa, factors such as fridge size, ambient temperature, and how often the compressor starts can also affect the actual runtime.
Portable Power Stations
