What Is Inshore Fishing? A Beginner's Guide
Inshore fishing keeps you close to shore, but the experience can vary a lot from one part of the U.S. to another. A trip in Florida may mean working shallow flats for redfish, while anglers in the Pacific Northwest might fish sheltered bays and estuaries. This guide covers what counts as inshore fishing, how it differs from offshore fishing, what you can catch, and the basic gear you'll need.
What Actually Counts as Inshore Fishing
Inshore fishing takes place in shallow, protected water close to shore. Bays, estuaries, flats, and tidal creeks are common examples, and anglers are often within sight of land. The exact depth isn't set in stone, but inshore areas commonly range from a few feet deep to around 20 or 30 feet.
What Actually Counts as Inshore FishingWhat Actually Counts as Inshore Fishing
Where you'll find inshore water
The term covers a range of coastal environments, so an inshore trip can look pretty different depending on where you fish. Most U.S. inshore fishing takes place in saltwater or brackish water, with the Great Lakes being a notable freshwater exception. For example, Florida's coast offers a mix of shallow flats, bays, and other nearshore areas where anglers can fish without heading far into open water. This guide to fishing in Florida shows how inshore fishing can vary by location. Understanding what counts as inshore water also makes it easier to see where inshore fishing ends and offshore fishing begins.
Inshore vs. Offshore Fishing
The biggest difference between inshore and offshore fishing is how far you travel from land and the conditions you'll face on the water. Inshore trips stay in shallower, more protected areas, while offshore fishing takes you into deeper water with more exposure to open-water swells.
Factor
Inshore fishing
Offshore fishing
Typical depth
A few feet to around 30 feet
Dozens to hundreds of feet
Boat size
Smaller, shallow-draft boats
Larger, more heavily built boats
Conditions
Calmer, more protected
Rougher, open-water swells
Typical species
Redfish, snook, trout, flounder
Grouper, tuna, mahi-mahi, marlin
For inshore anglers, the smaller boat also means onboard power can be limited. A fish finder, livewell aerator, phone, and other electronics can all draw from the boat's battery during a long day. Planning how you'll keep those devices running is part of preparing for the trip, and this guide to boat accessory batteries covers the basics. Keeping that onboard equipment running is worth planning for before heading out.
For smaller boats, having a separate power source can take some pressure off the boat's main battery. A portable power station can give you extra capacity for charging phones, running compatible fishing equipment, and keeping essential electronics powered throughout the day.
Keeping Power Onboard for a Day of Inshore Fishing
A full day on the water can put steady demand on your boat's battery. Your fish finder may run for hours, while a livewell aerator keeps running to protect your catch. Add phone charging and other small electronics, and the battery can drain faster than you expect. A portable power station gives you a separate source of electricity that doesn't rely on the boat's main battery. Charge it before you launch, and you'll have extra power available when you need it. For smaller boats, that extra power can be especially useful because onboard battery capacity and storage space may be limited.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
For a smaller boat or a shorter trip, the DELTA 3 Plus gives you a compact way to carry extra power without depending entirely on the boat's battery. If you need more stored energy for a longer day or more demanding equipment, the DELTA 3 Max offers a larger 2,048Wh capacity and higher 2,400W AC output.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
With power taken care of, the next thing most anglers want to know is what's swimming in those shallow waters. They also want to know which species they're most likely to encounter on an inshore trip.
Popular Inshore Species by U.S. Coast
The species you'll encounter while inshore fishing depends a lot on where you are. Coastal water temperatures, habitats, and local conditions all play a role. An angler fishing along the Northern Atlantic may have a very different experience from someone fishing on the Gulf Coast or the West Coast.
Northern Atlantic states
Striped bass and fluke are classic inshore targets across the Northern Atlantic states. These fish can be found in coastal waters and other shallow areas near shore. This gives anglers plenty of opportunities without requiring a long trip into deeper water.
Southern Atlantic and Gulf states
Redfish, speckled trout, and snook are among the familiar inshore targets along the Southern Atlantic and Gulf coasts. The region has plenty of bays, flats, marshes, and other shallow coastal areas where anglers can fish close to land. Water conditions and the species available can change with location, so the best setup for a Florida trip may not be the same one you'd use farther west along the Gulf.
West Coast
West Coast inshore fishing has its own mix of species and fishing environments. Calico bass, halibut, and sheepshead are common inshore catches, with anglers fishing around coastal structure and other nearshore areas. Since conditions vary along the coast, it's useful to check what species are active in your local area before choosing your tackle.
If you're planning to stay on the water for most of the day, power is another part of the setup worth considering. These fishing power setups cover options for keeping equipment running beyond your basic rod and reel. Species vary by coast, but the core gear list stays fairly consistent nationwide.
Inshore Fishing Gear Checklist
You don't need a huge collection of tackle to get started with inshore fishing. A few well-chosen pieces of gear can cover many of the species and conditions you'll run into, especially if you're fishing familiar waters and learning what works in your area.
Inshore Fishing Gear ChecklistInshore Fishing Gear Checklist
Rod and reel
A medium-heavy spinning or casting rod around 6.5 to 8 feet long is a solid starting point for many inshore setups. Pair it with a saltwater-rated reel and line in the 15- to 20-pound range. The right setup can vary with the species you're after and the type of water you're fishing, so local conditions should have the final say.
Lures and tackle
Keep a mix of soft plastics, topwater lures, and popping corks in your tackle box. These options can cover a range of common inshore fishing situations and give you ways to adjust when the fish aren't responding to one presentation. Start with a few proven options for the species in your area instead of buying every type of lure at once.
Check the local fishing rules
Fishing regulations vary by state and can include licensing requirements, seasons, size limits, and catch limits. Check your state's current rules before you head out, and make sure you have the required license with you. If you're fishing in Florida, this guide to Florida fishing licenses can help you get started.
Inshore fishing keeps you close to shore, with shallow, protected waters offering different species and conditions than offshore trips. Match your rod, reel, and tackle to the fish in your area, and check local fishing rules before you launch. If you're fishing from a small boat, bring backup power for essential electronics such as a fish finder, livewell aerator, or phone. EcoFlow's DELTA 3 Plus and DELTA 3 Max give you a separate power source to keep compatible gear running through a full day on the water.
What is the difference between inshore and offshore fishing?
Inshore fishing takes place in shallow, protected water close to shore, such as bays, flats, estuaries, and tidal creeks. Offshore fishing takes you farther from land and into deeper, more exposed water. The two also differ in boat size, water conditions, and the species you’re likely to target.
Do I need a boat for inshore fishing?
No, you can fish many inshore areas from shore, piers, docks, and other accessible spots. A small boat or kayak can take you farther into bays, flats, and shallow coastal areas, but you don't need one to try inshore fishing.
What size rod is best for inshore fishing?
A medium-heavy spinning or casting rod around 6.5 to 8 feet long works well for many inshore fishing setups. The best size depends on the species you're targeting, the lures you're using, and the type of water you're fishing.
What fish are considered inshore species?
Common inshore species vary by region. Redfish, speckled trout, and snook are popular along parts of the Southern Atlantic and Gulf coasts, while striped bass and fluke are common targets in the Northern Atlantic. West Coast anglers may target calico bass, halibut, and sheepshead.
Is inshore fishing good for beginners?
Yes, inshore fishing can be a good place to start because you can fish close to shore without taking on the conditions of open water. You can learn basic casting, tackle selection, tides, and local species while fishing from shore, a kayak, or a smaller boat.
Outdoors
