Vermont Fall Foliage 2026: Peak Season, Scenic Drives, and Travel Tips
Vermont does not change color all at once. The first strong reds often show up on cool northern ridges while the valleys below are still green. Central Vermont follows. Southern hills may hold their leaves well into October.
For a Vermont fall foliage trip in 2026, late September through mid-October is the safest span to consider, with later color possible in the south. Those dates are a starting point, not a promise. Warm nights can delay the turn. Drought, hard rain, and wind can bring an early finish. A good plan leaves room to move.
When Is Vermont Fall Foliage Peak in 2026?
The best time to see fall foliage in Vermont generally shifts from north to south and from higher elevations to lower terrain. That is the usual progression, though individual valleys and slopes rarely cooperate with a neat statewide calendar. Use these windows for booking, then rely on current foliage reports as the trip approaches.
| Region | Elevation & Key Destinations | Typical 2026 Peak Window | Foliage Highlights |
| Northern Vermont & High Peaks | Northeast Kingdom, Jay Peak, Stowe mountain gaps (1,500+ ft) | Late September – Early October (approx. Sept 24 – Oct 5) | Sugar maples, yellow birch, dark evergreens, quiet backroads |
| Central Vermont | Route 100 corridor, Woodstock, Killington, Mad River Valley | Early October – Mid-October (approx. Oct 3 – Oct 14) | Maple-covered ridges, farm valleys, foggy mornings |
| Southern Vermont | Manchester, Bennington, Mount Snow, Brattleboro | Mid-October – Late October (approx. Oct 10 – Oct 22) | Bronze oaks, late maples, warmer valleys, roadside farm stands |
Note: These ranges are planning estimates, not fixed 2026 forecasts; check the Vermont fall foliage tracker and the state’s official weekly report as the trip approaches.
Northern Vermont and High Elevation
The Northeast Kingdom and the high country around Jay Peak usually lead the season. Newport, Montgomery, Burke, and the roads near Lake Willoughby are good early choices. Around Mount Mansfield, color may be well underway above Stowe before the village reaches its best week. That unevenness gives travelers options. If the valleys look green, head into a gap or toward a higher trail. If the ridges are already bare, drop down and follow the rivers.
Central Vermont
Early October is the customary target for Stowe, Waterbury, the Mad River Valley, Killington, and Woodstock. This is familiar calendar country: bright maples above weathered barns, fog tucked into low fields, and narrow roads beside cold streams.
It is also busy. On a clear Saturday, Route 100 slows near villages, trailheads, and overlooks. Leave before the late-morning rush and resist the urge to collect towns. Stowe, Waitsfield, and Woodstock may look close on a map, but driving all three in one day leaves little time to enjoy any of them.
Southern Vermont
Color generally arrives later around Manchester, Bennington, Brattleboro, and the Deerfield Valley. Mid-October is a sensible target. Red oak and beech add copper and russet after many northern sugar maples have dropped, so the season does not simply end when the high peaks go bare. Still, check conditions before a late-October drive. One windy front can clear a hillside overnight, while a sheltered valley a few miles away remains colorful.
Which Scenic Drives Are Worth Taking in Vermont?
Route 100 gets most of the attention, but Vermont has no shortage of good foliage roads. Pick one corridor for the day. Add a walk, a meal, or a farm stop rather than viewing the whole state through a windshield. A portable power station can keep cameras and navigation devices charged during planned roadside or picnic stops.
Route 100 Through the Green Mountains
Route 100 follows the Green Mountains and links many of the state’s best-known fall towns. Wilmington, Ludlow, Rochester, Warren, Waterbury, and Stowe all sit along or near the route. The quieter stretches between towns are often as memorable as the named stops. This corridor also works well as the backbone of a fall foliage road trip, with stops adjusted to current color.
For a one-day drive, choose a section. The Mad River Valley is convenient for farm stands and short hikes. Rochester and Plymouth have a slower, less resort-driven feel. Farther south, Wilmington works naturally with the Deerfield Valley. Pull fully off the road for photographs; stopping on a blind curve is dangerous, even when the view seems impossible to pass up.
Route 108 Through Smugglers’ Notch
Route 108 between Stowe and Cambridge squeezes through a rocky mountain gap beneath steep walls and dense forest. It is dramatic, but it is not a road to hurry. Tight turns leave little space for large vehicles, commercial tractor-trailers are prohibited, and roadside parking is limited. Use marked pullouts and keep the travel lane clear. The Notch section closes for winter, so check road status if cold weather or early snow reaches the mountains before your visit.
Route 4 Through Central Vermont
Route 4 crosses the state through Killington, Woodstock, and Quechee. It offers mountain scenery without committing the entire day to small backroads. Quechee Gorge and Woodstock are the obvious stops, and both become crowded during peak weekends.
Decide what you want to do before you arrive. A walk through Woodstock, a visit to the gorge, and lunch can easily fill half a day. The first legal parking space may be more useful than circling the village for one closer to the green.
Molly Stark Byway in Southern Vermont
The Molly Stark Byway follows Route 9 from Brattleboro to Bennington, climbing through the southern Green Mountains and passing Wilmington along the way. Hogback Mountain is a big overlook. In clear weather, the view reaches across ridges in Vermont, Massachusetts, and New Hampshire. On a cloudy day, it may not. That is reason enough to include smaller stops and walks instead of making one panorama carry the whole trip.
Road Trip Power Tip:
Phones, cameras, navigation, and camping gear see steady use on an all-day drive. The EcoFlow DELTA 3 Max (2048Wh) + 500W Alternator Charger can recharge from the vehicle while you are on the road, keeping stored power available for later stops. Confirm installation requirements and vehicle compatibility before leaving home.
What Can You Do During Vermont Fall Foliage?
Foliage may set the date, but it does not need to fill every hour. The best trips mix driving with time outside the car. Guided Vermont fall foliage tours can combine scenic travel with local stops when travelers prefer not to plan every route themselves.
Hiking for Mountain and Forest Views
Mount Philo near Charlotte is a manageable choice for broad views over Lake Champlain toward the Adirondacks. Camel’s Hump calls for more time, stronger legs, and proper hiking gear. Mount Ascutney also offers high views, with hiking trails and seasonal road access.
By October, trail conditions can change over the course of a morning. Wet leaves cover roots and rocks. An exposed summit may feel much colder than the parking area. Carry water, a warm layer, and a downloaded map. Sunset arrives earlier each week, which matters on a descent through thick woods.
Apple Picking at Local Orchards
Apple harvest overlaps with the foliage season, though available varieties change from week to week. McIntosh, Honeycrisp, Cortland, and cider apples are common finds. Check the farm’s picking report before driving over; a popular block may be gone after one busy weekend. Cold Hollow Cider Mill in Waterbury is a well-known Route 100 stop for cider and donuts, but midday lines can be long. Go early, and do not assume every orchard offers U-pick access.
Gondola Rides for Fall Views
Stowe’s Gondola SkyRide and Killington’s K-1 Gondola reach high views without a long climb. They work particularly well for mixed-age groups.
Fall operating days are limited, and wind or poor visibility can interrupt service. Check the resort calendar before the trip and again that morning. A gondola ticket is less useful when the summit is inside a cloud.
Covered Bridges and Historic Small Towns
Woodstock’s Middle Covered Bridge is within walking distance of the village center. Taftsville is a few miles east, and Quechee adds the gorge, shops, and river scenery nearby. These bridges remain part of everyday local roads. Park legally, avoid blocking an entrance, and let residents pass before lining up a photograph.
A picnic from a bakery, cheese shop, and farm stand is an easy way to avoid the noon restaurant rush. Find a public picnic area rather than settling on private land or beside a busy bridge approach.
For a longer photography stop or a nearby campsite, the EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) can provide a quiet place to recharge cameras, a laptop, and other small devices away from an outlet. Keep the equipment dry and place the cables where no one will trip over them.
How Should You Plan a Vermont Fall Foliage Trip?
Reserve the parts that are hard to replace, especially lodging. Keep the daily route loose until you know the weather, road conditions, and where the best color has developed. For travelers pairing the drive with a permitted campsite, a solar generator can support charging and campsite lighting during the overnight stay.
Choose Your Trip Length and Pace
A weekend works for one region. Three to five days allows for rain, a slower morning, or an unplanned stop that turns out to be the best part of the trip. Plan one anchor for each day, such as Route 108 and Stowe, the Mad River Valley and an orchard, or Woodstock and Quechee. Leave the rest open. Vermont looks small on a national map; it feels larger on a winding two-lane road behind foliage traffic.
Pick a Convenient Vermont Home Base
Stowe suits trips focused on Mount Mansfield, Smugglers’ Notch, and northern Route 100. Waterbury sits between Stowe and the Mad River Valley. Waitsfield keeps central backroads close, while Woodstock is convenient for Route 4, Quechee, and the Upper Valley.
There is no practical base for the entire state. Start with the places you care about most, then choose the town that shortens those drives. A cheaper room far from the route may cost you two extra hours in the car every day.
Build a Flexible Foliage Itinerary
Read the latest foliage report and weather forecast each morning. Compare ridges with valleys. If high elevations are past peak, lower and more protected roads may still look good. If the valleys have not turned, a mountain pass or gondola may put you closer to color. Keep an indoor option for rain, and check for construction or closures before taking a remote road. Detours are not unusual, and cell service is not guaranteed where you discover one. A New England leaf-peeping guide can help compare nearby routes when weather or color shifts beyond Vermont.
Book Lodging Early for Peak Foliage
Popular inns, cabins, and hotels fill well ahead of October weekends, particularly in Stowe, Woodstock, and Manchester. Book once your dates are reasonably firm if you need a family room, pet-friendly property, or a tight price range.
Pay attention to cancellation terms. A flexible reservation leaves room to adjust when weather changes. Dinner reservations also help in smaller towns. A dining room with a few dozen seats cannot absorb everyone who finished the same scenic drive at sunset.
Vermont’s usual foliage sequence is easy to understand: northern mountains first, central Vermont next, southern valleys later. The exact week is harder to call. For 2026, begin with the late-September-to-mid-October window, then narrow it using current reports and forecasts.
One region per day is enough. Route 100, Smugglers’ Notch, Route 4, and the Molly Stark Byway each show a different side of the state. Add a trail, orchard, gondola, or covered bridge, but do not schedule every minute. There should be time to turn down a promising road and stay for a while.
What Is a Good 3-Day Itinerary for Vermont in Fall?
Use Stowe as the first-day stop, with a gondola ride or Smugglers’ Notch drive if Route 108 is open. On day two, follow Route 100 through Waterbury and the Mad River Valley, stopping at a farm, orchard, or short trail. Spend day three around Woodstock, Quechee Gorge, and nearby covered bridges. If the current color is stronger elsewhere, keep the three-day pace and change the region.
Is Maine or Vermont Better for Fall Foliage?
Vermont is the better fit for a compact road trip built around farm valleys, mountain gaps, covered bridges, and closely spaced towns. Maine combines foliage with rocky shoreline, lighthouses, larger wild areas, and Acadia National Park. Neither has objectively better leaves; the surrounding trip is what separates them.
Where Is the Best Place to Stay in Vermont to See Fall Foliage?
Stowe, Waterbury, and Waitsfield are useful bases for a first visit because they provide access to Route 100 and the central mountains. Woodstock makes more sense for Route 4, Quechee, and eastern Vermont. Timing matters too. A northern base is often more useful in late September, while later October trips may favor the south.
Which Town in Vermont Is Best to Visit in the Fall?
Woodstock offers the classic combination of a walkable center, historic buildings, nearby farms, and covered bridges. Stowe has more of a mountain-resort atmosphere, along with access to Mount Mansfield and Route 108. Travelers who prefer quieter streets might look at Waitsfield, Rochester, Montgomery, or towns in the Northeast Kingdom.
How Long Does It Take to Drive Route 100 in Vermont?
The entire route is about 216 miles and takes roughly five to six hours without meaningful stops. Foliage traffic, village speed limits, construction, and photo breaks make the real trip longer. Allow two days for the full road, or choose one section for a relaxed day. Route 100 is far more enjoyable when there is time to get out of the car.
