USB Types Explained: Compare USB-A, USB-C, and More
USB connectors are essential for charging devices and transferring data in our tech-driven world. With so many types—USB-A, USB-C, Micro-USB, and more—it can be confusing to figure out which one you have or need and why. This guide will break down each type’s differences, advantages, and common uses so you’ll always be prepared to pick the correct connector for your devices. Let’s get started.
What Is USB Used For?
USB stands for Universal Serial Bus. It’s simply a type of computer port designed to be universally accepted in a wide variety of devices. These ports are used to charge electronic devices that utilize rechargeable battery power and transfer data between two devices, like from your phone to your laptop or computer to a printer.
Since they were first developed in the 1990s, these connectors have evolved into multiple forms, including newer, smaller ones offering faster charging and transfer speeds than ever before.
What Are the Different Types of USB Connectors?
Here are the different types of connectors that you may come across.
USB-A
USB-A is the original flat rectangular connector developed in the 1990s. They must be inserted right-side-up in order to work, leaving people frustrated when trying to plug it in the wrong way. These cables originally always had a USB-A on one end and some other plug on the other end to go into a computer, gaming console, phone, or other device, allowing for charging and data transfer from one device to another. Now, they come with multiple other ends.
Initially, USB 1.0 offered very slow charging and data transfer. In 2001, the 2.0 version offered speeds of 1.5MB/s to 480MB/s. The 3.0 version came out in 2011 with much better transfer speeds, between 5.0 and 20GB/s. Now, all of our devices are slowly switching to the newest USB 4.0, which can transfer data at 20 to 40GB/s.
USB-B
This is a less common connector type that some people may not be familiar with. It’s mostly used on larger devices, like scanners or printers. The connector looks much more square than rectangular. Most of these cables are USB-B to A. However, some newer ones go to a Micro or Mini-USB.
Micro-USB
For several years, this connector type became very common in smartphones and Android tablets because it was small and made data transfer and charging easier. They came in both Type-A Micro and Type-B Micro. While they have largely been replaced, some manufacturers still use them because they’re cheap. The major drawback is that you still have to plug it in a certain way, leaving people fumbling or putting on their reading glasses to figure out which way it goes.
Mini-USB
The Mini-USB is a smaller version of its predecessor, and it was used to charge or transfer data from tablets before the Micro versions came out. We generally don’t use these anymore, but you’ll still see them if you use older electronics like MP3 players or Playstation 3 controllers.
USB-C
Then came the USB-C, which changed how we charge and transfer data. This is the type you see on almost all new devices, including smartphones, earbuds, microphones, game controllers, and even newer laptops. Apple was one of the few holdouts that stuck to its own charging ports, so you could only use Apple cords. However, Apple recently joined the bandwagon when legislation in the European Union required all mobile devices sold to have a universal USB-C port by the end of 2024, eliminating the need for excess charging cords and the waste it creates.
There are two primary advantages to this type of connector. One is that it’s small and oblong, making it reversible, so you no longer need to examine the plug to determine which way to insert it.
The other advantage of this new plug is that its 100W connection allows for much faster charging and data transfer than ever before, including on larger devices like laptops, printers, and TVs. It can transfer data at 40GB per second and deliver 5K video to monitors.
The EcoFlow RAPID Power Bank is a Qi-certified portable wireless charger. It also has a male Type C plug, so you can charge your phone using a cord or use both for even faster charging. It is also easy to recharge your charger since it has a Type C female port. You can charge it with a cord in a wall plug or plugged into a portable power station like the EcoFlow RIVER 3 Series for versatile recharging options.
The best part of the EcoFlow RIVER 2 + 110W Solar Panel and other EcoFlow power stations is that they all have female ports for USB-A and USB-C for easy portable charging on the go without having to pack a bunch of adapters. Then, you can recharge the power station using portable solar panels like its highly efficient 110W solar panel, so you can stay off-grid and keep your devices charged up for as long as you want.
What Is the Difference Between Male and Female USB Connectors?
The difference between male and female connectors is that one gets plugged into something while the other gets something plugged into it.
The female connector is the port that you plug into. It’s also called a slot, socket, or receptacle. You will see this on the side of your laptop or tablet; it is the receiving end where your charging cords or peripherals are plugged in.
For instance, the  EcoFlow RIVER 2 Series Solar Generators offer female ports for Type A with regular and fast charging options and Type C ports for versatile output options.
The male connector is typically called the plug. It’s usually found at the end of a cable or sometimes attached to a small accessory device like a memory stick. The plug is inserted into the female port on the receiving device.
You will always need male and female connectors since this is required to make that critical connection, allowing you to charge your device or transfer data from one device to another.
EcoFlow RIVER 3 Portable Power Station
245Wh capacity, 300W rated output, X-Boost up to 600W Up to 2× runtime for light-wattage appliances 1 30% smaller than the industry average <20 ms UPS for uninterruptible backup <30dB whisper quiet for 24/7 use 1-hr fast charging, no battery damage IP54 waterproof-rated battery pack Charge up to 6 appliances at the same time
How Do I Know if I Have USB-A or C?
You can tell which type you have by looking at the shape of the connector. USB-A is a larger, rectangular plug that can only be inserted one way. On the other hand, Type C connectors have a smaller, oblong plug that can be inserted in either direction.
USB technology has come a long way since the 1990s, evolving from clunky connectors that had to be inserted a certain way to sleek, efficient USB-C cables that dominate the modern tech landscape. Understanding the differences between connector types can help you make better decisions when charging devices or transferring data. Need versatile and efficient charging solutions? Check out the EcoFlow RIVER 3 Series for convenient charging options, featuring ports for both USB-A and USB-C, so you don’t need to carry adapters.
