Solar Camping Lights Guide: Brightness, Runtime, Weather Resistance and Charging
You leave a lantern on the picnic table all afternoon, expecting it to last through dinner. Then the sun stays behind clouds, and the light dies an hour after dark. Solar camping lights are handy because they run quietly and don't need disposable batteries, but their performance depends on more than sunshine. Brightness, runtime, weather resistance, and charging options all matter. This guide explains what to check before buying, compares common lights for tents and RVs, and shows how to keep them charged when the weather doesn't cooperate.
What to Look for in Solar Camping Lights
Product labels list lumens, runtime, and charging times, but those numbers often describe different settings. Compare lights in the same mode, then check how each one recharges before relying on its advertised runtime.
What to Look for in Solar Camping LightsWhat to Look for in Solar Camping Lights
Brightness (lumens)
Lumens measure how much visible light a lamp produces. A higher number generally means more light, but you don't need the brightest lantern for every campsite task. For example, Goal Zero lists its Crush Light at 60 lumens on high, 25 lumens on medium, and 6 lumens on low. The high setting can help with cooking or cleaning up after dinner, while the lower settings may work well inside a tent or as a table light. Think about where you'll use the light. A lantern for reading in a tent has a different job from one lighting a cooking area or helping you find the restroom after dark.
Runtime per mode
Check how long a light runs at each brightness setting. The headline runtime often refers to the lowest mode, which uses less energy than the brightest setting. Goal Zero lists the Crush Light for three hours on high, six hours on medium, and 35 hours on low. That 35-hour figure doesn't mean you'll get a full weekend of bright light. If you plan to use high mode most evenings, pay closer attention to that shorter runtime.
Water and dust resistance
Camping lights can face dew, dust, splashes, and unexpected rain. Look for an Ingress Protection (IP) rating on the manufacturer's specification sheet rather than relying on a vague description such as “weatherproof.” The first digit of an IP rating describes protection against solid objects and dust. The second describes protection against water. Check the exact rating and its stated protection level before leaving a light outside overnight. Don't assume every solar lantern can handle heavy rain or submersion.
How it charges
Solar camping lights generally fall into three charging categories:
  • Built-in solar panel: The light charges directly from sunlight, so you don't need a separate panel. The small panel can take a long time to recharge the battery.
  • Solar and USB charging: You can use sunlight during the day and a compatible USB source when the weather turns cloudy.
  • USB charging only: The light needs a USB power source or a separate compatible solar panel. It won't recharge from sunlight on its own.
If you camp under trees or expect several cloudy days, a USB input gives you another way to recharge. Before buying, check the cable and input requirements so you know what to pack.
Types of solar lights for camping, tents and RVs
Most campsites need more than one kind of light. You might want a lantern inside the tent, string lights under an RV awning, and a small light near the path. Choose each one for the job rather than expecting one light to cover the whole campsite.
Light type
Typical use
Charging to check
Watch out for
Collapsible or inflatable lantern
Tent ceiling, table
Built-in panel, often with a USB input
Slow solar charging in shade or on cloudy days
Solar string lights
Awning, canopy, RV trailer outline
Separate panel or detachable power hub
Panel placement in full sun; cable length
Solar stake or path lights
Tent lines, walkways
Small built-in panel
Low brightness; mostly marker lights
Solar headlamp or flashlight
Walking at night, hands-free tasks
Built-in panel plus USB
Small panel; USB is usually the main charge
Lantern with power bank
Light plus phone top-ups
Solar and USB in, USB out
Charging a phone uses the light's own battery
For RV and trailer camping, string lights can make an awning easier to use after dark. Path lights can also help mark walkways around the campsite. If you're comparing options for your yard, see how solar garden lights work. Keep cables out of walkways and follow the manufacturer's mounting and outdoor-use instructions. Don't wire standalone lights into the RV's 12V system unless a qualified RV technician confirms the setup is suitable.
Why Solar Camping Lights Run Out on Cloudy Days and How to Recharge Them
A small solar panel takes time to charge a lantern, even in good sunlight. Shade from trees, a tent, or an RV can slow it down, and cloudy weather can stretch charging time further. Goal Zero's Crush Light gives a useful example of how charging method and brightness affect performance.
Example (Goal Zero Crush Light)
Maker's figure
What it means at camp
Charge from the built-in panel
20 hours
More than one sunny day to fill from empty
Charge from a USB source
2.5 hours
A short top-up from any compatible USB port
Runtime on low
35 hours
Several nights of marker light
Runtime on high
3 hours
About one evening of bright light
These figures are estimates, not guarantees. Actual charging time depends on sunlight, shade, panel angle, and weather. To get more from your lights, keep the panel clean, place it in direct sun, and use low mode when you don't need bright light. If your light supports USB charging, pack a compatible cable and backup power source.
A backup charging option for cloudy trips
A light with a USB input gives you another way to recharge when sunlight isn't enough. The EcoFlow DELTA 3 Classic can charge compatible lanterns and phones, making it useful for trips when you can't count on steady sunshine. It won't recharge a light that only accepts power through its built-in solar panel, so check the light's charging requirements first.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
A simple recharge estimate
Goal Zero lists a 1.85Wh battery pack in the Crush Light. Four fully drained lights would need about 7.4Wh to recharge on paper (4 × 1.85Wh), before charging losses. That's a small share of the EcoFlow DELTA 3 Classic's 1,024Wh capacity. Actual needs vary by light, so check its battery capacity and whether it accepts USB-A, USB-C, or AC charging. The EcoFlow DELTA 3 Classic has no 12V car outlet or Anderson output, so 12V-only lights won't connect directly. For more camping power options, compare portable power stations and portable solar panels that support your devices' charging requirements.
Using Solar Tent Lights and Camper Lights Safely and Making Them Last
Using Solar Tent Lights and Camper Lights Safely and Making Them LastUsing Solar Tent Lights and Camper Lights Safely and Making Them Last
Solar lights are useful inside tents because they don't burn fuel or produce exhaust during use. They still need basic care, especially if they're exposed to dust, moisture, or changing temperatures throughout a trip. Follow these practical steps:
  • Clean the panel: Wipe away dust, pollen, and grime so sunlight can reach the cells.
  • Follow the storage instructions: Use the battery storage and charging guidance in the light's manual. Don't assume every model should be stored at the same charge level.
  • Check weather protection: Bring lights inside during storms if their rating doesn't cover the expected conditions.
  • Keep fuel lanterns outside: Never use fuel-burning lanterns inside a tent or camper. They can produce carbon monoxide, a dangerous gas you can't see or smell. Follow the U.S. Consumer Product Safety Commission's carbon monoxide safety guidance.
Before a trip, charge your lights fully at home and pack the correct cables. It's easier to sort out a missing charger in the driveway than after you reach a campsite with limited sun and no nearby outlets.
Choose solar camping lights by comparing brightness and runtime in the same mode, checking the manufacturer's water and dust rating, and confirming how each light recharges. Built-in solar panels are convenient, but they can take a day or longer to refill a battery, especially when clouds or shade get in the way. Charge your lights before leaving home, keep their panels clean, and bring a compatible USB cable for models that support it. If you want backup charging for lanterns and phones, the EcoFlow DELTA 3 Classic can supply power to compatible devices when sunlight isn't enough. Check the input requirements first, and you'll know what your setup can handle before night falls.
Do solar camping lights work on cloudy days?
Yes, but they charge more slowly because less sunlight reaches the panel. A small built-in panel may need a full sunny day or longer to recharge a depleted light. Models with a compatible USB input give you another charging option.
How many lumens do I need for a camping light?
It depends on the task. A dim light may be enough inside a tent or along a path, while cooking and campsite cleanup may call for a brighter setting. Compare lumens at the same mode across models.
Can I leave solar lights out in the rain?
Only if the manufacturer's water-resistance rating covers the conditions. Check the IP rating on the specification sheet, and bring the light inside during heavy storms if its rating doesn't provide enough protection.
How long do solar camping lights last on one charge?
Runtime depends on the light and brightness setting. For example, Goal Zero lists the Crush Light at about three hours on high and 35 hours on low. Check the manufacturer's runtime figures for the mode you'll use most.
Can a portable power station charge solar lanterns?
Yes, if the lantern has a compatible USB or AC charging input. A light that charges only through its built-in solar panel can't be charged directly from a power station. Check the light's input requirements and cable before you pack.
Camping
