Portable Generator Safety in Cooler Weather
When temperatures drop in the winter, snow or ice can disrupt the electric grid. If you’re in a blackout due to cold weather conditions, you may reach for your portable generator to stay warm and keep your electronics and appliances running. But is it safe to use in these conditions?
Learn about how to use a portable generator safely in cooler weather and steps you can take to prepare your generator and maintain its operation.
Why Portable Generator Safety Is Important in Cold Conditions
Cold air can trap generator emissions, creating higher safety risks in winter conditions.
Cool weather makes the air heavier, and heavier air can more easily trap gas and other pollutants, known as thermal inversion. If you’re using a gas or propane generator, you should never use it inside, but the carbon monoxide risk becomes even higher in cooler weather.
Battery-powered portable generators are a much safer option, but even they require specific considerations when using them in cold weather. Battery performance can drop as much as 50% in freezing temperatures, so you likely won’t get as much power from one battery charge.
Knowing where to set up your generator, how to protect it from cold temperatures, and other precautions to take around your home will help keep your home and family safe.
Where Should You Set Up Your Portable Generator?
Gas and propane generators should only be used outside and set up at least 20 feet from windows, doors, and vents. They should be placed in a covered but well-ventilated area that’s not fully enclosed and on a level and stable surface out of reach from wind, snow, or ice.
Battery-powered solar generators like the EcoFlow DELTA 3 Plus can be used indoors because they produce clean power with no emissions and pose no safety risks, such as carbon monoxide poisoning. LiFePO4 batteries are designed to perform in extreme cold, allowing portable power to stay reliable in winter. They’ll operate reliably in temperatures as low as -4ºF, and, when paired with a solar panel, can continue charging the battery in winter conditions as long as the sun is out. You can use its multiple outlets to support lights, heating devices, and electronics until the grid power returns.
EcoFlow DELTA 3 Plus in back of car
How to Prepare Your Generator for Cold Weather Use
If you need to use a generator during a bout of cold weather, stop and work through these few steps before you start operating it.
  1. Check your battery charge levels before the temperature drops and try to keep the battery at least 80% charged.
  2. Clean the air filters and vents on the generator to eliminate moisture or debris.
  3. Inspect the cords for any damage or cracking caused by cold weather.
  4. Store your generator in a climate-controlled space, such as a storage closet or air-conditioned garage, when possible.
  5. If using a gas or propane generator, invest in winter-grade extension cords rated for outdoor use and cold weather.
  6. Test its startup performance in moderate weather so you can notice any abnormalities when starting it up in cold weather.
  7. Perform routine maintenance, such as checking filters, oil levels, and spark plugs, to ensure all parts function as intended.
  8. Stock up on supplies like extra fuel for extended outages, or opt for a battery-powered generator that pairs with solar panels for continuous operation.
  9. Keep your generator dry. If water or ice gets into the electrical panel area, it can short-circuit the frame, create a static charge, or cause an electrical arc. These constitute a significant risk and can lead to serious injury or even death.
What Safety Precautions Should You Take?
Whether using a gas generator or a portable power station like the EcoFlow DELTA Pro 3, you should always practice these safety precautions to prevent harm when using a generator in cold weather.
First, install battery-powered carbon monoxide detectors throughout your home and regularly test that the batteries work. These devices save lives and will alert you if there’s a CO2 leak from your gasoline, propane, or natural gas generator.
Never operate fuel-powered generators indoors or in an enclosed space. Set them up outside and direct the exhaust away from your home’s air intakes and vents. You want clear ventilation paths around the unit, so don’t set it up against a wall or too close to other items or equipment.
Keep a fire extinguisher nearby in the home and ensure everyone knows where it is and how to use it.
Specific precautions for a battery-powered generator include:
  • Avoid charging the batteries when the temperature is below freezing, as it can cause permanent damage.
  • Allow cold batteries to warm up gradually before you use them.
  • Monitor the battery temperature during operation.
  • Store batteries between 50-80% charge when not in use.
  • Use manufacturer-approved cold-weather accessories like a heat jacket, etc.
  • Insulate battery components if storing them outdoors long-term.
EcoFlow DELTA Pro 3 plugged into wall outlet
Can You Run a Portable Generator in Cold Weather?
You can run a portable generator in cold weather if you take proper precautions and ensure your equipment is rated for that temperature. Check for the manufacturer’s minimum operating temperature. Note that performance may be reduced, and it may require more frequent monitoring and maintenance, but it should still be functional.
How Cold Is Too Cold for a Portable Generator?
Your portable generator should generally only be operated in temperatures within the equipment’s rated operating temperature range. The lower limit for gas generators is typically between 40º-32ºF; the rating is often 0ºF for battery generators.
Cold Weather Demands Careful Generator Use
Cold weather doesn’t mean your portable generator is inoperable. However, depending on the temperature, you may need to check your manufacturer’s minimum operating temperature and monitor its performance more closely. Battery generators that use LiFePO4 batteries, like the EcoFlow DELTA Pro 3, can withstand much colder temperatures than propane, natural gas, or gasoline generators because the battery technology performs much better in the cold. If you live in a climate that sees snow and frigid temperatures, it’s well worth the investment.
Portable Power Stations
