How to Start Pickup Truck Camping and Build a Comfortable Setup for Your Next Adventure
Pickup truck camping is one of the best ways to explore and enjoy every moment with limited gear requirements. Camping in a pickup truck bed, instead of a massive, boring standard RV, lets you explore more remote areas without breaking the bank or worrying about costly setups. With a setup that includes the portable ecoflow power generator, you're in for a ride! Whether you’re going on short trips or lengthy ones, this article has advice for turning your pickup truck bed into a comfy camping home.
How to Create a Comfortable Sleeping Setup in Your Pickup Truck Bed
The pickup truck camping bed is where you’ll spend the most time, so you must make it habitable before thinking of adding other camping essentials. Here’s a breakdown of how to prepare the perfect vehicle-based camping setup for your adventure.
  1. Know your pickup truck bed size first: The size of your truck bed will dictate what kind and how much gear you can take along on the trip. Truck beds vary in length and can be standard (6.5 feet), short (5.5 feet), and long-bed (8 feet). Long-bed pickups basically give you more room to spread out and organize your gear. Short beds are more compact. Now find a truck bed mattress or sleeping pad that fits the space available without making it difficult to move around.
  2. Check for uneven floors: After you’ve worked out space and bed requirements, scan the truck for uneven floors. For example, if your pickup truck bed has wheel wells, it can be difficult to create a perfectly flat sleeping space. So think about using a platform to level the unevenness and add some extra storage space beneath.
  3. Prioritize security and protection plans: During pickup truck camping, making security and protection plans is a no-brainer. Find a bed cover or camper shell and window curtains to protect against the elements and add extra privacy. Also, ensure that your sleeping bags and blanket match the conditions you’re expecting, i.e., during cold nights or mosquito swarming, depending on your camp location.
The Essential Truck Camping Gear You Need for a Comfortable Outdoor Experience
The tools you must add to your truck camping gear list depend on where you’re going, how long you’re staying, and what facilities are available. However, rather than turning the truck into a complete campsite, try focusing on what you really need for sleeping, shelter, food, cooking, and power.
Sleeping Gear
You can get all the basic sleeping gear such as a mattress or sleeping pad that fits your truck bed dimensions, blankets, and ergonomic pillows. You’ll also need additional bedding suitable for the temperatures you’re likely to encounter and dustproof bags to keep bedding clean while traveling.
Shelter and Weather Protection Gear
Weather can change quickly when camping, so you can never be too careful when making shelter plans. Having a truck bed cover (or camper shell), a retractable awning system, and an insect screen (or netting) can provide optimal protection for any pickup truck camping equipment setup. Ensure these coverings do not obstruct ventilation so your truck bed doesn’t feel like a sealed room.
Cooking Gear
To have enough room for other facilities in your pickup truck bed, you must make your kitchen as portable as possible. With a portable propane stove, fuel, cookware and utensils, and food and water storage containers, you’re good to go. For the best experience, find a portable, high-efficiency fridge/freezer to store food and have ice ready for anytime you need it.
Power and Lighting Gear
When you’re camping in pickup, you can’t go wrong with a reliable off-grid electricity supply. Portable ecoflow power generators can run camp lights, charge electronics, and run appliances without the need for fuel like huge campsite generators. Also plan for lighting needs, as it might get pretty dark after sunset. Headlamps, phones, dimmable LED light strips, and other small equipment can give illumination that makes everything from cooking to finding what you need at any moment much easier.
The EcoFlow Delta 3 Classic is an ideal power generation source for beginner campers who want readily available power in a portable device. It delivers stable, compact, plug-and-play power up to 1024Wh capacity and 1800W output. Power your camping lights, phones, and other appliances using the Delta 3 Classic, which charges fast via solar panels, AC wall outlets, or your truck’s 12V car socket. It is best suited for short-term trips where you only need to power small appliances without compromising your truck bed spacing.
Powerful 1024Wh and 1800W AC output (3600W surge) that easily power essential appliances. At just 30 dB, it's super quiet, and features a 10ms auto-switch UPS and can be recharged from 0-80% in 45 minutes. Powered by robust automotive-grade LFP cells, it gives 10 years of dependable power for home backup and outdoor adventures.
However, you’ll need a stronger power station to match a camping activity at far off-grid distances with devices that need much power. The EcoFlow Delta 3 Max series offers reliable 2048Wh capacity with a 2400–3000W output range. It delivers enough electricity to run heavier appliances like refrigerators, coffee makers, washers, etc. The EcoFlow Delta 3 Max and Delta 3 Max Plus power generators also feature smart charging, making them ready to use after only about 40–60 minutes of charging. Although heavy-duty, the Delta 3 Max series is portable, lightweight, and won’t cost you extra space in the pickup truck camping bed.
EcoFlow Delta 3 Max
The EcoFlow DELTA 3 Max has a 2048Wh capacity and 2400W AC output (4800W surge) that can power up to 3400W with X-Boost. It features a 10ms UPS auto-switch, runs silently at ≤25 dB, and can be charged to 80% in 68 minutes. This home backup and off-grid power solution is easy to set up, lightweight, and has long-lasting 10-year LFP batteries.
Practical Tips That Make Pickup Truck Camping Easier and More Comfortable
Since you’re trying to create the best camping experience with the little space in your pickup truck, organization is very crucial. Consider the tips below, alongside the overlanding gear and setup ideas above, to make your pickup truck camping enjoyable and less complicated:
Manage Limited Space
The space of a truck camping bed is limited and should be used wisely. Do not pack and store camping gear separately. Use storage bins to keep like things together instead. This will help you stay organized and have easy access. Store frequently used items near the pickup tailboard for easy reach.
Don’t Overpack
Overpacking is when you crowd the pickup truck with unnecessary items for a camping trip. To avoid this, select items that fit your destination, weather expectations, facilities, and activities you’ll be doing. You probably won’t use every piece of gear that appears on a camping checklist, so choose and carry only the indispensables.
Secure Equipment Before Driving
Your car’s motion, bumps, and wiggle while driving can create a mess in the truck if your camping items are not organized and secured before the trip begins. Place heavier items where they won’t shift or fall. Strap things down where needed or use the right tie downs.
Practice Personal Hygiene
The truck bed serves as both your campsite and bedroom, so clutter and dirt can complicate your health. You do not want to fall ill while camping far from home. So, keep shoes, dirty clothes, cooking equipment, and other outdoor items out of the sleeping area, and practice daily item reorganization to keep the place comfortable, clean, and organized.
We recommend trying out your pickup truck bed camping setup on a short overnight trip close to home before you head out for long distances. This way you can learn the essentials and make any changes before you head off on the main trip.
You can enjoy a nice camping trip with your pickup truck bed without having to spend as much money as you will with RVs or huge trucks. First things first, keep it simple, pack wisely, and make sure you have a good power source. For short camping trips, the EcoFlow Delta 3 Classic will do the trick, while the EcoFlow Delta 3 Max series is good for longer, more power-hungry camping adventures. The idea is to find a suitable arrangement that fits your camping needs, so start small, do short test excursions initially, then increase your items and distance when you are confident you are ready.
Frequently Asked Questions About Pickup Truck Camping
Is pickup truck camping comfortable?
Yes, pickup truck camping may be comfy but your experience depends on how well you prepare your truck for the camp. Equip it with a comfortable sleeping pad or mattress, weather protection, gear organization, and a reliable power source, and you’ll have a superb space to camp.
What do I need to sleep comfortably in a pickup truck bed?
A simple setup consists of a truck bed mattress or sleeping pad, a sleeping bag or blanket, pillows, and something to shield you from the elements. Campers also often utilise a truck bed cover, camper shell or awning for comfort and privacy.
Can you use a portable power station for pickup truck camping?
Yes, a portable power station is a good option for camping in a pickup truck. You get electricity without burning fuel, without noise, without pollution. You may use it to power lights, charge electronics, power small appliances, or run a portable fridge when you’re off the grid.
How do I organize gear in a pickup truck bed?
Storage bins, drawer systems and waterproof containers can help you maximize and organize your pickup truck bed space. Keep things you use frequently close. Keep your sleeping space clean by separating your cooking and outdoor gear from your sleeping gear.
Portable Power Stations
