Night Fishing Lights: Powering Your Setup with EcoFlow
There’s a lot to recommend about night fishing. There’s less human and boat traffic disturbing the water. If temperatures are high during the day, it’s pleasantly cool and comfortable. Certain species are active at night as well.
This article looks at the impact night fishing lights have on angling success, and how to use them to your best advantage. We also consider how to set up an effective lighting plan and what equipment you’ll need.
Night Fishing Lights Explained: What They Do and When to Use Them
How Light Draws Baitfish and Predators
Different types and colors of light can attract fish to your area; these include above-water lights (those on a boat or on a dock) and underwater lights.
It’s a known fact among anglers and fishermen that green is one of the best colors to attract fish and baitfish for night fishing.
Green works in different water types (fresh and salt water) and clarity levels, and it penetrates water deeper than other colors.
It sets off a chain reaction that starts with tiny organisms and insects in the water, attracted by the green wavelengths. These organisms cluster around the light source and attract the smaller baitfish, which feed on them. This then attracts larger species of game fish.
Choosing the Right Night Fishing Light Setup for Your Spot
Underwater, Dock, and Boat-Mounted Options
Different types of underwater and above-water lights can attract fish to your location.
Above-water lights can be secured on the dock or mounted on your boat.
Boat-mounted lights are typically hardwired and operate directly off the batteries. However, they can be run from a portable battery, which is also what you’ll need if you’re fishing from a dock.
Don’t forget high-visibility fishing line on your night fishing gear list, which will betray line movement that’s hard to see otherwise.
How to Power 12V Night Fishing Lights Off-Grid Without Hassle
Portable power stations like the EcoFlow DELTA 3 Classic are easy to transport for dockside or onboard use, providing a reliable power source without the bulk of larger systems.
This unit can handle essential night fishing needs, with multiple output ports to support lighting as well as smaller devices like navigation or communication equipment.
Battery clips can help keep the station secure on a boat. It offers a range of ports, including 12V outputs that can run fishing lights for extended periods, along with the ability to support other essentials like small coolers.
If you want to use appliances like a refrigerator, microwave, or AC-powered lights (anything with a standard plug), the built-in inverter allows the EcoFlow DELTA 3 Classic to convert stored battery power into usable AC electricity.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
Estimate Runtime and Build a More Efficient Lighting Plan
Simple Wattage Math and Real-World Runtime Variables
A simple calculator allows you to input your portable power station’s capacity in watt-hours (Wh) and then factor in the wattage of the devices you plan to use to understand the runtime.
The calculator will reveal the estimated runtime for each device. Always build a margin for error into these figures to allow for variables like device and inverter efficiency.
Safety and Legal Basics for Fishing After Dark
Night fishing throws up some unique safety aspects — remember, you’ll need to be visible to other people for safety reasons.
  • Ensure your boat has appropriate navigation lights so other boat users can avoid you.
  • Carry distress flares for emergency situations.
  • Use a headlamp or flash lamp to stay safe in your immediate surroundings on board or on dry land.
  • Whether on a vessel or dry land, take care of your own visibility with reflective clothing.
  • If you’re wearing a life jacket, then attach a strobe light to it so you’re easy to see if you fall into the water.
  • Keep a checklist to run through before each trip to ensure equipment is present and in working order.
What Power Source Is Best for Running 12V Night Fishing Lights All Night?
A portable power station is a safe and portable way to run 12V night fishing lights for several hours. Fishing is a waiting game, so you want a dependable power source that won’t fade your lights towards the end of a long session.
How Do I Calculate How Long My Fishing Lights Will Run On a Portable Power Station?
Determine the total wattage of your fishing lights. Find the total battery amp hours (Ah) of the portable power station. Runtime hours equal total wattage (W) divided by battery amp hours (Ah) x voltage (V). Remember to factor in additional loads if you are also plugging in other devices; these will reduce the available runtime.
Do I Need Navigation Lights Even if I’m Using Bright Fishing Lights?
Navigation lights allow your location to be seen and understood by other vessels and river traffic, key to safety on the water. Red indicates the port or left side of the boat and green the starboard or right side. A white stern light mounted at the back of the vessel shows the boat’s direction to people behind it.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh) on a table inside an RV
Power Longer, Safer Nights on the Water With EcoFlow
Fishing lights are essential for successful night fishing, helping attract baitfish and extend your time on the water well after sunset.
A reliable portable power source ensures your lights stay consistent throughout the night while also supporting essential gear like navigation lights, communication devices, and small appliances.
Portable solutions like the EcoFlow DELTA 3 Classic provide a safe, quiet, and easy-to-use way to power your setup without relying on fuel or fixed wiring, making them ideal for dockside and boat-based fishing.
Off-Grid Power
