La Niña Watch: What It Means for Florida and Southeastern States
NOAA’s Climate Prediction Center has issued a La Niña Watch for the end of 2025, lasting into the start of 2026. It’s not uncommon for this weather watch to be issued, or its counterpart, an El Niño Watch. It’s important to understand the differences between the two and what it means for your region.
Keep reading to learn more about the La Niña Watch, what ESNO is, and the weather outlook for the Southeastern United States. Use our expert tips to prepare for the upcoming weather effectively.
What is the La Niña Watch and How Does ENSO Work?
The La Niña Watch means that conditions in the Pacific Ocean are favorable for La Niña to develop in the next few months, but it’s not a full confirmation. La Niña and El Niño are part of the irregular climate cycle known as El Niño-Southern Oscillation (ENSO). Changes in water temperatures in the Pacific Ocean drive these two shifts in the cycle that ultimately impact weather conditions worldwide.
How Likely is La Niña This Fall and Winter?
In September, below-average temperatures in the Pacific Ocean were recorded, indicating a shift in the ESNO cycle. At the beginning of October, there was a 55% chance of a La Niña developing late fall and lasting until late winter. Since there’s only a La Niña Watch issued, this upcoming weather pattern isn’t confirmed, but it’s highly likely. If an advisory is issued, then La Niña conditions are active.
Residential home with solar setup
The Regional Outlook for Florida and the Southeast This Winter
Warmer-than-average temperatures are predicted for the Southern United States if La Niña conditions persist. Florida will have its warmest days during the heart of winter, December to February. However, colder fronts can still impact the South; they just won't last very long.
Precipitation in the Southeast typically decreases during La Niña, especially in Florida. Georgia, the Carolinas, and other Southern interior states are more likely to experience a mix of precipitation, with spells of both wetness and dryness.
All in all, Florida and other Southern states can prepare for a warmer and drier winter than in recent years.
Broader U.S. Seasonal Trends Under La Niña
During the La Niña cycle, only one jet stream impacts the U.S., and it sits over the northern part of the country. During an El Niño event, two jet streams form, one covering the North and the other hovering over the South. With only one jet stream in the North, storms will be funneled into the northern states, while the South will have a quieter storm season.
That’s why states like Florida, Georgia, the Carolinas, and those in Louisiana will experience warmer temperatures and less precipitation. States in the Pacific Northwest, Northern Rockies, and Ohio Valley are expected to experience wetter conditions, which may lead to flooding. This trend isn’t guaranteed and varies depending on other ongoing climate patterns, but the hallmark of La Niña is a distinct split between a dry South and a wet North.
Prepare for Power Resilience This Winter
ESNO impacts each region in the U.S. differently. Still, there are a few tips to prepare for the upcoming winter, regardless of the predicted weather pattern for your area.
Prevent heat or AC loss by weatherproofing your home. Seal windows and doors, and insulate pipes and the attic. Install a smart thermostat to manage your energy effectively.
Lower your energy costs with renewable energy systems, such as the EcoFlow DELTA 3 Ultra Plus. This portable power station can power appliances and other electronics in your home, eliminating the need to rely on the power grid. You’re more likely to experience a power outage during extreme weather conditions, like La Niña.
Update your family’s emergency plan, stock up on non-perishable food, water bottles, and first aid supplies. Check that you're subscribed to emergency alerts on your phone.
How Long Does a La Niña Event Typically Last?
The length of La Niña can vary. It usually lasts from 9 to 12 months, but it has occasionally lasted up to two years. It all depends on the ocean-atmosphere conditions in the Pacific. La Niña typically occurs in late fall to early winter and weakens by the spring.
Can La Niña Increase the Risk of Hurricanes in Florida?
Absolutely, during La Niña years, there are more named storms in the Atlantic and Gulf, raising the chances of these storms making landfall. This happens because of changing wind patterns and temperatures, which makes it easier for storms to form and persist.
Which States Outside the Southeast Are Most Affected by La Niña?
La Niña reshapes the jet stream and storm track across the whole country, which impacts each region. The Southwest is typically drier and warmer, while the Pacific Northwest is wetter and cooler. The Great Lakes and Ohio Valley regions are wetter, experiencing more frequent storms, and the North is slightly warmer. The Upper Midwest is colder and snowier.
What Steps Can Families Take to Improve Energy Security During La Niña Winters?
The first step is to prepare your home by inspecting the weather sealing around doors and windows, as well as the insulation around pipes. Invest in backup energy options, such as a robust power station, extra batteries, and additional fuel. Diversify energy reliance with renewable sources, such as solar panels, in the event of grid failure.
DELTA 3 Max Plus Portable Power Station
The EcoFlow DELTA 3 Max Plus delivers 3000W of reliable power (6000W surge) with X-Boost™ to handle heavy-duty appliances. Charge to 80% in just 43 minutes, expand up to 10kWh, and control circuits smartly via the app. Durable, whisper-quiet, and backed by up to 5 years of warranty, it’s power you can count on anywhere.
Ready to Discover How EcoFlow’s Renewable Energy Solutions Can Enhance Your Home’s Power
With the La Niña watch in effect and a 55% probability of its occurrence, now is the time to prepare for the upcoming winter season. In Florida and the Southeast U.S., predicted warmer temperatures mean that everyone will have their AC running this winter. Protect your home and keep your energy bill low with simple preparations, such as weatherproofing and updating your emergency plans.
Enjoy peace of mind with total energy independence by investing in a portable power station like the EcoFlow DELTA 3 Ultra Plus. Power your home with reliable, robust energy no matter the weather.
