Intelligent Load Shedding Extending EcoFlow DELTA Pro Ultra X Runtime by 42%
Offering up to 180 kWh of capacity, the EcoFlow DELTA Pro Ultra X is more than just a battery. It's an energy-efficient power station for your home that can help you run off-grid indefinitely.
Whether your home power generation system is just for emergencies or part of your daily life, intelligent load shedding can help you keep your essential circuits powered for 42% longer than a traditional system.
In this article, we'll take a look at how the EcoFlow DELTA Pro Ultra X can intelligently manage your systems to keep what matters to you running longer.
What Is Intelligent Load Shedding in Home Backup Power?
Intelligent load shedding is a strategy to determine what stays on and what switches off in your home. A load-shedding strategy helps keep essential systems running when capacity is limited, for instance, during a power outage or bad weather.
Intelligent shedding responds in real time. It continually monitors available battery capacity, incoming solar power, and usage patterns to determine where your power should go.
Although it's especially important during emergencies like outages, it's also a good system to set up for your day-to-day energy needs. A smart energy consumption strategy can help you run more systems with fewer resources, getting the best possible use from your home energy system.
Why Load Prioritization Matters When Capacity Is 12.2kWh to 61kWh
Having a large whole-home backup system, like the EcoFlow DELTA Pro Series, can give you a sense of security. However, even a robust 61kWh system can get drained if high-draw appliances run unchecked. Things like heaters, compressors, and resistive loads consume energy much faster than lighting, networking equipment, or fridges.
Of course, the smaller your system, the more you need to prioritize the load you place on it. A 12.2kWh battery system makes load shedding even more important. It's not hard to burn through 5 to 7kWh per day, even if you're being relatively careful. Add things like clothes washing and heating to that, and you could go through your entire capacity quickly.
How the EcoFlow App Prioritizes Circuits to Stretch Runtime
Available for both iOS and Android, the EcoFlow app lets you monitor and optimize energy use from anywhere. AI-driven energy management gives you insight into your usage patterns, and you can set up custom schedules to recharge your batteries at off-peak times or control third-party smart devices, such as thermostats.
Priority Tiers for Essential Comfort and Convenience Loads
  • Critical loads: Things like refrigerators, devices, essential lighting, Internet networks, and security systems.
  • Comfort loads: Televisions, ceiling fans, small kitchen appliances.
  • Deferred loads: Things you can put off to a later date, like laundry, dishwashing, electric vehicle charging, and pool pumps.
  • High-demand loads: Central air conditioning, electric heating, water heating.
Establishing a tiered priority list lets your system drop unnecessary loads first, keeping critical power going longer.
What Changes When Solar Input and Recharge Windows Shift
Solar input can change your shedding behavior significantly. During daylight hours, you can set your system to temporarily re-enable comfort loads when the incoming power from the sun exceeds your demand. Then, after the sun sets, priorities automatically tighten to keep essential systems running.
Recharge windows are also important. If you expect the grid to come back soon, you can be a little freer with the power that you use. But in an outage of uncertain duration, you want to use any available solar input to recharge batteries and increase your run time.
Real World Scenarios Where Intelligent Shedding Extends Runtime
Imagine a winter nighttime outage. Intelligent load shedding can pause electric heating while keeping refrigeration, lighting, and Internet systems online. Likewise, during a summer blackout, you can lose central AC but maintain your home office and security system.
Daytime vs Nighttime Backup Strategy for Long Outages
If you have solar input feeding into your system, intelligent shedding can allow:
At night, intelligent load shedding can automatically narrow your priorities. Lighting and refrigeration remain important, but you can cut some high-draw comfort loads to add hours of runtime.
How to Set Up Intelligent Load Shedding on EcoFlow DELTA Pro Ultra X
The EcoFlow DELTA Pro Ultra X can run 42% longer by using intelligent load shedding. Here's how to do it:
  1. Pair the app. Open your EcoFlow app, tap Add Device, and scan the QR code or select EcoFlow DELTA Pro Ultra X, then Connect Smart Home Panel 3. Grant location and Bluetooth permissions.
  2. Tag circuit priorities. In your app dashboard, go to Smart Home Panel → Circuits → Assign Priorities. The app uses AI to predict loads so that you can decide what you really need and which loads you can shed.
  3. Configure shedding modes. Go to System Settings → Operating Mode → Select Self-Powered, Scheduled Tasks, or Savings Mode.
From here, you can set:
  • Backup reserve
  • Charge and discharge limits control when your device will stop and start delivering power.
  • Conditional supply. Provide continuous power or assign a percentage of the battery's charge to low-priority loads.
  1. Enable intelligent features. Adaptive Start auto-detects appliances and handles surges. Load Isolation cuts faulty circuits. The AI Assistant can adapt to your usage patterns and to changing weather.
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
What Does Runtime by 42% Longer Mean in Real Household Terms?
A 42% runtime increase can translate to hours or even days of additional capacity, depending on your usage. For example, a system that powered your essentials for 24 hours could reach 34 hours by shedding non-essential loads.
Can Load Shedding Protect Sensitive Electronics During an Outage?
Yes. A smart energy system can prevent overloads and voltage instability. Intelligent shedding reduces the risk of sudden shutdowns or stress on sensitive electronics like routers, medical devices, and computers.
Will Intelligent Shedding Work if My Home Uses Electric Heat or Central AC?
It can. Hydro systems like air-conditioning and electric heat are usually placed in lower-priority tiers. You can set your system to run them when capacity allows, for instance, during the day when your solar system is generating power. Then, intelligent shedding can cut them off when your power supply decreases.
Ready to Extend Backup Runtime With EcoFlow DELTA Pro Ultra X?
The EcoFlow DELTA Pro Ultra X offers more than just a powerful whole-home backup system. Combined with the EcoFlow app, its intelligent load shedding can significantly increase your off-grid runtime. Plus, it can also optimize your power usage, improving battery life. Take a look at EcoFlow’s intelligent backup systems to see which best suits your energy needs.
Portable Power Stations
