How to Keep Upstairs Cool in Summer: Everyday Fixes and a Plan for Outage Days
It's 10 p.m., the kitchen feels fine, and you head up to bed only to find the bedrooms still warm and stuffy. Most two-story households know that moment well. If you've been looking up how to keep upstairs cool in summer, this guide starts with quick fixes, from closing south- and east-facing blinds to sealing the attic. Then it covers the harder case: a summer outage that shuts off the central air while you still need one livable room upstairs. Fans also have a temperature limit, so the heat illness signs near the end are worth knowing.
How to Keep Upstairs Cool in Summer: 8 Fixes From Free to Professional
Upstairs rooms sit right under the attic and the roof, and they usually take the strongest afternoon sun. Some fixes cost nothing and work today, while others are projects for a contractor. If you're figuring out how to cool upstairs on a budget, start with the free ones and work down the list.
Fix
What to do
Why it helps
Effort
Close blinds and curtains
Close window coverings on sunny upstairs windows during the hottest part of the day
ENERGY STAR's room AC sizing guide treats a "very sunny" room as needing 10 percent more cooling capacity, so cutting the sun load matters
Free, today
Set ceiling fans to summer direction
Run the fan counterclockwise and turn it off when you leave the room
ENERGY STAR says counterclockwise creates a "wind-chill effect," and fans cool people, not rooms
Free, today
Keep heat sources away from the thermostat
Move lamps and TVs away from a room AC's thermostat
ENERGY STAR notes that extra heat near the thermostat makes the AC run longer
Free
Set the thermostat sensibly
Set it as high as is comfortable
ENERGY STAR's room AC guidance: "typically 78° F"
Free
Seal attic air leaks
Seal gaps around recessed lights, plumbing holes, the furnace flue or duct chase, and the attic hatch
ENERGY STAR lists uneven room temperatures as a sign a home would benefit from attic air sealing
DIY project or contractor
Add attic insulation
Bring the attic up to the recommended R-value for your area
ENERGY STAR's seal and insulate program pairs insulation with air sealing
Weekend DIY or contractor
Balance airflow to the second floor
Ask an HVAC technician about duct leaks, balancing dampers, or zoning
Commonly recommended by utilities and HVAC companies; this is a job to hand to a pro
Professional
Add room cooling upstairs
A correctly sized window AC or a ductless system for the hottest room
ENERGY STAR's sizing table (see the sizing section below)
Purchase or contractor
One caution before you seal near a chimney or flue. Building codes usually require a 1-inch clearance from metal flues and 2 inches from masonry chimneys, and ENERGY STAR says to close those gaps with aluminum flashing and high-temperature caulk.
Before buying more cooling, check how attic insulation R-value works. A thin attic layer keeps feeding heat into the bedrooms below. When a summer outage hits, closed blinds, a sealed attic, and insulation keep slowing the heat coming in. Fans and central air are what stop working, so what can you do upstairs once they go quiet?
Keeping One Upstairs Room Cool in a Power Outage With EcoFlow DELTA 3 Max
Knowing how to keep an upstairs room cool in the summer gets harder when the grid goes down. The goal shifts to one room: plug-in fans first, then a small window AC if its numbers fit the battery. EcoFlow DELTA 3 Max runs what you plug into it, so it won't run central AC or a hardwired ceiling fan.
Flexible Cooling with EcoFlowFlexible Cooling with EcoFlow
Step 1: Fans first
Use plug-in box, tower, or pedestal fans. Lasko lists its Pinnacle 40" DC Tower Fan (DST100) at 5 W to 36 W on 120V. DELTA 3 Max stores 2,048Wh, or roughly 1,741Wh after about 15 percent conversion loss. As an estimate, one DST100 at 36W runs about 48 hours, and two run about 24 hours. Check your own fan's label for its watts.
Fans have a limit, though. The CDC says to use fans only below 90°F indoors, because above that a fan can raise body temperature.
Step 2: A window AC, if the numbers check out
Running wattage. LG's spec sheet for its LW6017R 6,000 BTU window unit lists 520 watts and 4.9 rated amps at 115V. That's well under the 2,400W rated output, so you don't need X-Boost, which lowers voltage and isn't rated output.
Compressor startup. A compressor draws extra power for a moment when it starts. LG doesn't list that figure, so check the manual or ask the maker, then compare it with the 4,800W surge rating.
Voltage and plug. The AC outlets are 120V, 60Hz, so a 240V window unit won't work. Follow the AC manual on extension cords and plug it straight into the power station.
Real runtime. At a nonstop 520W, 1,741Wh lasts about 3.3 hours by estimate, or about 3.1 hours with one 36W fan added. The compressor cycles once the room cools, so you may get longer, but don't count on all-night cooling.
Room choice. Pick the smallest upstairs room with the fewest sunny windows, then close the door and blinds. ENERGY STAR sizes a 6,000 BTU unit for 150 up to 250 square feet.
If those numbers fit your setup, here are the DELTA 3 Max specs that decide which upstairs fans and window units it can carry. Each one ties back to the checks above.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
EcoFlow DELTA 3 Max fits one upstairs room: fans for a long stretch, or a small window AC for a few hours. It won't back up central AC or fix attic heat, and you'll carry its 44.8 pounds up the stairs.
If you recharge from a gas generator, the CDC says to keep it outside at least 20 feet from doors, windows, and vents. A charged battery is one part of a plan for heat wave outages, along with water and nearby cooling centers.
Stop the Heat Coming In: Attic, Roof, and Windows
If you want to know how to make upstairs cooler in summer for good, look up. The second floor shares a ceiling with the attic, and that's where ENERGY STAR says you'll usually find some of "the largest opportunities to save energy in your home." Windows are the other big heat path.
Air seal before you insulate
Dirty patches in attic insulation are evidence that air is moving through it. ENERGY STAR's attic air sealing project guide lists the usual leak points: recessed lights, the attic hatch, plumbing holes, the flue or duct chaseway, and dropped soffits. Use caulk for gaps of 1/4 inch or less and expanding foam for 1/4 inch to 3 inches.
Insulation levels
Seal first, because insulation alone won't stop leaking air. Then check ENERGY STAR's recommended home insulation R-values for where you live, since an attic in Phoenix and one in Minneapolis don't need the same depth.
Windows and roof
Close blinds on sunny south- and east-facing windows during the hottest hours. If you're replacing a roof in a hot climate, ask about lighter-colored or reflective roofing. Both are common advice on how to keep second floor cool in summer. Keeping heat out is half the job, and moving cool air upstairs is the other half.
Move Cool Air Upstairs: Ducts, Fans, and a Right-Sized Room AC
Many central systems have one thermostat downstairs, so they shut off once the first floor cools. When you're sorting out how to cool upstairs in summer, a technician can check duct leaks and balancing, and a correctly sized room AC handles a single room.
Direct Cool Air UpstairsDirect Cool Air Upstairs
Ducts, dampers, and zoning
If you're working out how to keep the upstairs cool without replacing your system, ask an HVAC technician about leaky ducts, balancing dampers, or zoning. Don't start closing downstairs registers on your own, since a pro can tell you what your system can handle.
Ceiling fans the right way
ENERGY STAR says to run ceiling fans counterclockwise in summer for a wind-chill effect that makes you feel cooler. Turn the fan off in empty rooms, and adjust your thermostat when it's running.
Sizing a window AC for an upstairs bedroom
A unit that's too small runs nonstop without catching up. Here's ENERGY STAR's room AC sizing chart for an 8-foot ceiling.
Room area (sq ft)
Capacity (BTU per hour)
100 up to 150
5,000
150 up to 250
6,000
250 up to 300
7,000
300 up to 350
8,000
350 up to 400
9,000
400 up to 450
10,000
Add 10 percent for a very sunny room, subtract 10 percent for a shaded one, and add 600 BTU per person beyond two. Keep the unit level so it drains, since ENERGY STAR warns that a poorly installed one "leaks as much air as a 6-square-inch hole."
Before buying, compare window AC wattage and BTU to see whether a unit could run on a portable power station. Even so, a heat wave can push an upstairs bedroom past safe levels.
When a Hot Upstairs Becomes a Health Risk
Heat builds up in upstairs bedrooms while people sleep, which makes cooling upstairs in summer a health issue, not only a comfort one. The National Weather Service heat index measures how hot it really feels. Its values assume shade and light wind, and full sunshine can raise them by up to 15°F. CDC's fan rule still applies: fans only below 90°F indoors.
CDC's "Heat-Related Illnesses" fact sheet lists two conditions to watch for. Here's how to spot each one and what to do.
Condition
Signs
What to do
Heat stroke
Body temperature 103°F or higher; hot, red, dry, or damp skin; fast, strong pulse; headache; dizziness; nausea; confusion; passing out
Call 911 right away; move the person somewhere cooler; use cool cloths or a cool bath; give nothing to drink
Heat exhaustion
Heavy sweating; cold, pale, clammy skin; fast, weak pulse; nausea or vomiting; muscle cramps; tiredness or weakness; fainting
Move to a cool place; loosen clothes; use cool, wet cloths or a cool bath; sip water; get medical help right away if you're throwing up, symptoms get worse, or they last longer than 1 hour
If your home gets too hot, the CDC says to use air conditioning or find a place that has it by dialing 2-1-1, or to call your local health department. The NWS heat safety tips also point to air-conditioned spots like malls and libraries. Since the upstairs heats up first, moving beds to the lowest floor can help during the worst stretches. During humid heat waves, the heat index versus actual temperature gap makes a stuffy bedroom feel hotter than it reads.
Learning how to keep upstairs cool starts with blocking sun and attic heat, setting ceiling fans counterclockwise, and sizing room cooling to ENERGY STAR's chart, with ductwork and zoning left to a pro. Pick one upstairs room as your outage room now, note the watts on its fan and AC labels, and remember CDC's 90°F fan limit. If summer outages hit your area, EcoFlow DELTA 3 Max can run plug-in fans or a small 120V window AC in that room for a limited time.
Why is my upstairs so much hotter than downstairs?
They sit right below the attic and roof and catch the strongest afternoon sun. A downstairs thermostat often shuts the system off before the bedrooms cool.
What is the fastest way to cool an upstairs room?
Close the blinds and run a fan while you're in the room. Above 90°F indoors, switch to a correctly sized window AC.
Which way should a ceiling fan spin in summer?
ENERGY STAR recommends counterclockwise, which creates a wind-chill effect. Turn it off when nobody's in the room, since it cools people, not air.
What size window AC do I need for an upstairs bedroom?
ENERGY STAR recommends 6,000 BTU for 150 to 250 square feet. Go about 10 percent higher if the room gets a lot of sun.
Can a portable power station run a window air conditioner?
Yes, if it's a 120V unit whose running and starting watts fit the station's ratings. As a rough estimate, EcoFlow DELTA 3 Max runs a 520W unit for about 3.3 hours at full draw.
