High Wind Warning: What It Means and What to Do
When you get notice of a High Wind Warning, it’s best to take it seriously, even if it still looks calm outside. Sustained winds of around 40 mph or higher, or wind gusts reaching approximately 58 mph or more, can uproot trees, damage roofs, and leave entire neighborhoods without power. A few simple preparations can help protect your home and family before conditions get dangerous. Here’s what the warning means, how to prepare, and what to do when strong winds arrive.
What Does a High Wind Warning Mean?
Weather alerts often change as a storm approaches. Understanding National Weather Service (NWS) high wind alerts means you can decide whether to continue your daily activities or take immediate steps to prepare.
High Wind Warning Definition and Wind Speed Criteria
A High Wind Warning is issued by the National Weather Service when dangerous, non-thunderstorm winds are present or about to occur. Across much of the United States, the warning is issued when forecasts include:
  • Sustained winds of 40 mph or higher for at least one hour.
  • Wind gusts of 58 mph or higher for any duration.
These are general thresholds that can vary by region, particularly in mountainous and coastal areas. In any area, a High Wind Warning means conditions could become dangerous and your preparations should start now.
High Wind Warning vs. High Wind Watch vs. Wind Advisory
Just because it’s windy, doesn’t mean it requires emergency preparations. The NWS uses different alerts to communicate the severity and likelihood of hazardous winds.
Alert Level
Typical Wind Criteria
What It Means
Recommended Action
Wind Advisory
Sustained 31–39 mph or gusts 46–57 mph
Strong winds may cause minor damage and difficult driving conditions.
Secure loose objects and use caution outdoors.
High Wind Watch
Sustained 40+ mph with gusts 58+ mph possible
Damaging winds may develop within the next 12–48 hours.
Review emergency plans and prepare your property.
High Wind Warning
Sustained 40+ mph with gusts 58+ mph occurring or imminent
Dangerous winds are expected or already occurring.
Stay indoors and avoid unnecessary travel.
Note: Wind speed thresholds are typical reference values and may vary by region and local National Weather Service (NWS) offices. Always check local NWS alerts for the specific criteria and instructions applicable to your area.
How Long Does a High Wind Warning Last?
Most High Wind Warnings last between 3 and 12 hours, although some go on for a full day or longer. A fast-moving cold front may bring several hours of intense gusts. A slow-moving storm over the Great Lakes or the Santa Ana winds in Southern California can produce hazardous conditions for much longer. Once the winds start to ease, continue monitoring the NWS for local updates before heading outside.
EcoFlow TITAN 5000 EcoFlow TITAN 5000
What Are the Potential Dangers of High Winds?
High winds don’t need to be joined by heavy rain or lightning to cause serious damage. The effects of high winds can include falling branches and trees, property damage, and extended power outages that may continue long after the winds have passed.
Falling Trees, Flying Debris, and Property Damage
Strong winds can put considerable pressure on trees, which is particularly dangerous when the ground is saturated from recent rain or snowmelt. Trees and large branches can fall onto roofs, fences, and parked vehicles. Unsecured patio furniture, trampolines, trash cans, and seasonal decorations can also become airborne. This can cause nearby windows to break or damage your neighbor’s property.
Downed Power Lines and Power Outages
Falling branches that damage utility poles and knock down power lines can cause outages across entire neighborhoods. Since repair crews may need to wait until wind speeds decrease, even a relatively small outage can last overnight. Planning what to do when the power goes out helps you prepare for hours without lighting, refrigeration, or reliable communication. Downed power lines are especially dangerous. Always assume they are energized, even if there are no visible sparks. Keep away from nearby water, metal fences, and other objects they may be touching.
Dangerous Driving Conditions and Travel Disruptions
Sudden crosswinds can make it difficult to control a vehicle, especially on open highways and bridges. High-profile vehicles such as semi-trucks, RVs, and cars towing trailers need to be particularly careful to avoid rollovers. Besides potential road closures, strong winds can also cause flight delays and cancellations. Always check local travel conditions before leaving home.
Increased Wildfire Risk in Dry and Windy Conditions
Across the Western U.S. and the Plains, strong winds combined with low humidity can cause wildfires to spread rapidly. Gusts can easily carry burning embers across existing fire lines, making containment more difficult. When the risk of wildfires is elevated, utilities in states such as California and Colorado may implement Public Safety Power Shutoffs (PSPS) to reduce the risk of electrical equipment starting fires.
Because these preventive shutoffs can interrupt household power, a home battery can be part of advance planning for essential circuits, provided compatible equipment is properly installed before severe weather.
What Should You Do Before High Winds Hit?
If damaging winds are forecasted, take time before they come to prepare your property. Secure outdoor belongings and buy any essential supplies you may need if there’s an outage. If you plan to use a portable power station, charge it before winds arrive and check the power requirements of the devices you intend to connect.
Bring Outdoor Furniture and Loose Objects Indoors
Check your porch, backyard, and patio for anything that could be lifted or knocked over by strong winds. Bring patio chairs, potted plants, bicycles, recycling bins, and lightweight decorations into a garage, shed or under cover. Larger items, such as grills and trampolines, should be properly tied down if they cannot be moved indoors. Keep them away from windows and glass doors where possible.
Close and Secure Windows, Doors, and Garage Doors
Make sure all windows are firmly latched, lock exterior doors, and fully close your garage door. Closing curtains or blinds will help limit the spread of broken glass if a window is damaged. Pay particular attention to older garage doors. Their large surface area makes them vulnerable to wind pressure, and if they fail, it exposes everything inside to high winds.
Charge Backup Power Sources and Prepare Emergency Supplies
To prepare, be sure to have bottled water, nonperishable food, flashlights, spare batteries, and a first-aid kit. Charge your phones, computer, battery banks, and backup power sources before a potential outage.
If the high winds have damaged power lines and caused a power outage, a portable power station such as the EcoFlow DELTA 3 Max Plus Portable Power Station can be a lifesaver. This system can help keep essentials like the refrigerator, Wi-Fi router, phones, and lamps running. During an extended outage, it can also be recharged with compatible solar panels once the weather clears.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
1. 3000W Powerful Output: 6000W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. 2. 2-10kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. 3. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
If the high winds come along with heavy rain or freezing temperatures, keeping other essentials running like a sump pump or heating system is a priority. These appliances often have higher startup and running power requirements. The EcoFlow TITAN 5000 is capable of 120V/240V split-phase output and can support compatible household circuits and heavy-duty appliances within its operating limits. Before the storm, make sure your transfer switch and essential circuits are properly configured so your backup system is ready to switch over when needed.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $2,900/year, with ROI in 3 years. 3. Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, including upfront purchase, installation, and long-term use.
Make an Emergency Plan for Your Family
In extreme high winds you may need to shelter in place. Choose a safe area on the lowest floor of your home, preferably an interior hallway or area away from windows. Make sure everyone knows where to shelter and how to stay in contact if mobile service becomes unreliable. It’s also worth keeping shoes and flashlights within easy reach, particularly if strong winds are expected overnight. Bring pets indoors for protection before conditions worsen. An emergency preparedness checklist can help you organize supplies and review the plan before severe weather.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
What Should You Do During a High Wind Warning?
If you’re at the Warning stage, high winds are upon you. Avoid going outside to make last-minute preparations. At this point, staying sheltered and keeping track of local weather conditions are your main priorities.
Stay Indoors and Away from Windows
Watching the storm through a large living room window may be tempting, but flying branches and debris can break glass without warning. It’s best to shut the curtains just in case a window breaks. Move to an interior room on the lowest safe level of your home, away from windows and exterior doors. Wait until conditions improve before venturing out to check for property damage.
Avoid Driving and Keep Away from Hazards
Postpone unnecessary trips until the warning expires. If you’re already driving, reduce your speed and keep both hands on the steering wheel. Also, allow extra space around trucks and RVs. Never drive over fallen power lines or through fallen branches that may conceal electrical wires. Stay at least 35 feet away from downed lines and report them to 911 or your local utility company.
Follow Weather Alerts and Emergency Instructions
Keep Wireless Emergency Alerts (WEA) enabled, but do not rely on them as your only source of weather information. Check a reliable weather app regularly or have a battery-powered or hand-crank NOAA Weather Radio on hand. The radios are especially helpful if a prolonged outage disrupts internet access and mobile service. If you search for ‘high wind warning near me,’ verify your location and the alert’s issue and expiration times on the NWS website.
Know What to Do If You're Caught Outside
If you’re walking outside, stay away from tall trees, utility poles, scaffolding, and anything that looks like it can fall over. Look for shelter in a sturdy, enclosed building rather than staying underneath a carport or bus stop. If no suitable building is nearby, seek a protected location away from falling objects and shield your head and neck. If there’s heavy rain, also avoid low-lying areas where flooding may occur.
Don’t wait until trees are swaying or the patio furniture starts sliding to respond to a High Wind Warning. Bring outdoor furniture inside if you can, secure doors and windows, and prepare your backup power system ahead of time. These steps can make a difficult situation with power outages much more manageable. Once the storm arrives, stay indoors, follow local NWS updates, and give utility crews time to restore power safely. Even after the wind subsides, remain cautious around damaged trees and fallen electrical wires.
What Wind Speed Is Enough to Knock You Down?
Wind speeds around 50 to 60 mph are strong enough to knock an average adult off balance, especially during sudden gusts. At 40 mph, walking against the wind already takes noticeable effort, and once gusts top 60 mph, staying upright becomes difficult—particularly for children, older adults, or anyone carrying bulky items that catch the wind like a sail.
Will 60 Mph Winds Break Windows?
60 mph winds alone rarely shatter intact modern windows, as standard residential glass is built to withstand much higher direct wind pressure. However, 60 mph gusts easily hurl gravel, patio chairs, trash cans, and heavy tree branches through the air—and flying debris is what actually breaks most windows during a windstorm.
What Wind Speed Can Flip a Car?
Winds of around 60 to 70 mph can pose a rollover risk for high-profile vehicles, such as empty semi-trucks, box trucks, and RVs. Standard passenger sedans generally require much stronger winds, often exceeding 100 mph, to reach similar rollover conditions. However, sudden crosswinds of roughly 58 mph or higher on slick highways or exposed bridges can still push lightweight compact cars and SUVs out of their lanes, potentially causing a serious loss of control. Actual risk varies depending on vehicle design, wind direction, road conditions, and driving speed.
Can a House Withstand 100 Mph Winds?
Most modern homes built to current U.S. building codes can withstand 100 mph winds without major structural failure, though minor damage like missing roof shingles, bent gutters, or torn window screens is common. Older homes, manufactured homes, or houses with unreinforced garage doors and aging roofs face a much higher risk of significant structural damage when gusts hit triple digits.
Home Backup
