Glamping Power: How to Add Comfort to Your Tent Setup
A glamping trip allows you to experience being surrounded by nature while enjoying the home comforts that you don’t get in a standard tent. But you can’t enjoy complete comfort unless you have access to electricity to power your devices.
Read on to find out how to integrate safe, clean off-grid electricity into your glamping setup.
What Makes a Tent Setup Feel Like Glamping?
A device like the EcoFlow DELTA 3 Ultra Plus + 500W solar panel can make all the difference, letting you go from surviving the elements to enjoying true comfort with all your devices charged up.
EcoFlow DELTA 3 Ultra Plus +500W solar panel
Traditional camping is all about minimalist gear and basic meals, while glamping is about luxury and convenience.
A structured canvas bell tent you can stand up in, a full-sized bed, comfortable furniture, and a kitchen area with culinary tools can all help convert a basic camping trip into something more luxurious.
What Devices Do You Need Power For in a Glamping Tent?
When packing for your glamping trip, a few essential devices need electricity for extra luxury.
Lighting
You'll need lighting for your evenings. Warm lighting, dimmable bedside lamps, decorative lanterns, and even exterior LED string lights will make your setup feel like home. LEDs also use very little energy, making them easy to sustain over your trip.
Charging and Entertainment
A portable Wi-Fi hotspot, smartphones, laptops, and cameras are all worth taking, and a power strip lets you charge multiple items at once.
Heating and Cooling
Portable AC units will keep the tent cool for extra comfort, or you could use a high-velocity floor fan if you want to use less energy. If you go glamping outside of summer, an electric blanket is an option to stay cozy at night.
Small Appliances
Coffee makers, kettles, blenders, and compressor refrigerators are smaller appliances that add extra comfort.
DELTA 3 Ultra Plus Portable Power Station
The EcoFlow DELTA 3 Ultra Plus delivers 3072Wh of smart, reliable backup power you can scale up to 11kWh. Prioritize essential circuits, power heavy appliances with 3600W output, and recharge fast with 48-minute Dual Charging. With long-lasting LFP cells, 10ms auto-switching, ultra-quiet operation, and OASIS 3.0 app control, it’s a compact, future-ready solution for seamless home backup.
What Are Your Power Options for a Glamping Tent?
Whether you're planning a weekend of glamping or heading to a festival like Stagecoach, you'll need a suitable energy source. What you choose depends on your campsite's setup.
Extension Cords and Shore Power
At a premium site with electricity hookups, you can access shore power. Use heavy-duty extension cords rated for outdoor use to draw electricity from the utility pedestal into your tent. It's reliable, but it restricts you to more developed campgrounds.
Portable Power Stations
These offer the most flexibility. Take one in the car, charge it up beforehand or at the campsite, and use it safely in your tent without noise or fumes.
Solar Panels
Pair your portable power station with solar panels, and you'll have a fully independent setup. Charge up the battery during the day using the sun by simply placing the solar panels in a sunny spot, use your power station's battery pack to store the energy, and use it whenever you need it.
It's ideal if you want more energy independence or you're heading to remote locations.
Choosing the Right Portable Power Station for Glamping
You'll need a power station that provides adequate power for your needs, with battery storage capacity and continuous inverter output as the main considerations.
Capacity is measured in watt-hours (Wh) — the unit's total energy storage. About 500Wh to 1,000Wh is practical for minimalist glamping, while 2,000Wh to over 3,000Wh works better for climate appliances or space heaters.
Also check that your appliances' combined running wattage stays under the unit's continuous output rating, and that its surge rating can handle your biggest appliance's starting wattage.
How to Set Up Power Safely Inside a Tent
You need to be careful when setting up any power source in a tent, but portable power stations are safe to use. Keep yours on a flat, dry surface, clear of water and damp cloths, with the ventilation ports unblocked. OSHA guidance on lithium-ion battery safety recommends dry, cool storage with adequate airflow to protect the battery.
Good cord management is also essential to avoid tripping hazards, and don't daisy-chain several power strips into one outlet on the power station.
How Can You Keep Your Power Running All Weekend?
Taking a portable power station with more capacity is the simplest way to avoid running out of energy before the trip ends.
You can also change how you use it. Running devices like lights and fridges on 12V DC ports instead of converting to AC helps maximize runtime, and turning off anything you're not using stretches your power further.
Pairing your station with solar panels, as covered above, extends this even further by letting you recharge during the day and use the energy at night.
Can You Run an Air Conditioner in a Glamping Tent?
Yes, you can. However, you'll need a high-efficiency portable AC unit for camping as well as a heavy-duty power station with enough capacity. AC units draw a lot of continuous power, so check the unit's running and starting wattage against your power station's output before you head out.
How Many Watts Do You Need to Power a Glamping Setup?
To run LED lights, a small fan, and a few devices like laptops and phones, you'll want a power station that's capable of delivering between 500 and 1,000 continuous watts. For additional heating elements, coffee makers, and other more energy-hungry devices, you'll need 2,000 to 3,000 watts of output.
Is It Safe to Run a Power Station Inside a Tent?
Yes, portable power stations are safe for tent use because they don't have any emissions. However, you should still use your device according to the instructions. Keep it on a flat, dry surface, away from water, and make sure the ventilation ports stay unblocked so it doesn't overheat.
Can Solar Panels Fully Power a Glamping Tent?
Solar panels can power your glamping tent during your stay. You'll need to have a portable power station with enough capacity and panels that can generate enough energy to refill the battery bank, but it's perfectly possible to enjoy full off-grid independence.
Reliable Portable Power Turns Any Tent Into a Comfortable Glamping Retreat
With modern portable power solutions, you can enjoy a fully remote glamping experience and relax in luxury wherever you go. Just make sure you have the right setup for the appliances you want to use.
Search EcoFlow's collection of portable power stations and solar generators to find the best option for your next glamping trip.
Camping
