Flathead Electric Outage Map: How to Read It, Report an Outage, and Get Updates
The house goes quiet. The fridge stops humming, the Wi-Fi drops, and you reach for your phone to see whether Flathead Electric already knows about the outage. The first place to check is the Flathead Electric outage map, which shows reported and planned outages across the co-op's service area. Once you know what the map icons mean, you can tell whether an outage has been reported, whether a crew has been assigned, and whether Flathead Electric has posted an estimated restoration time. Here's where to find the map, how to report an outage, and what to do while you wait.
Where to Find the Flathead Electric Outage Map and How to Read It
Flathead Electric Cooperative hosts its live outage map at outage.flathead.coop:8181. You can also use flatheadelectric.com/outage which sends you to the same map. It covers the co-op's service area, including the Flathead Valley and Libby. Before relying on the map, make sure Flathead Electric is your utility. If your electric bill comes from another provider, its outage won't appear here.
Where to Find the Flathead Electric Outage Map and How to Read ItWhere to Find the Flathead Electric Outage Map and How to Read It
What the four icons mean
The map uses four main symbols. Once you know them, you can get a quick read on what's happening without digging through outage notices.
Icon on the map
What Flathead Electric says it means
Blue square
A planned outage
Solid orange hexagon
An outage that has been reported but is not yet confirmed by dispatch or crews
Solid red hexagon with a number
A reported, confirmed outage. The number is the estimated number of meters affected
Red hexagon with black diagonal lines
A crew has been assigned to a reported, confirmed outage
The difference between orange and red matters. An orange icon means someone has reported a problem, but Flathead Electric hasn't confirmed it yet. A red icon means the outage has been confirmed. When the red icon gets the black diagonal lines, a crew has been assigned.
What you can see by clicking an icon
Click the icon connected to your outage and you may see more information, including the cause when Flathead Electric knows it and an estimated restoration time after crews have provided one. Don't worry if an estimate doesn't appear right away. Crews first have to get the right equipment, travel to the location, find the problem, and report what they find. Until that happens, there's often not enough information to give a useful restoration estimate.
How to tell if your outage is already reported
If you use the Flathead Electric online account or My Co-op app, the message can tell you whether the outage has already been reported. A red outage notice that says “We are working to resolve outages in your area” means the outage is already in the system. If you see “No outages are reported in your area” with a blue icon, you should report it.
What if the map is behind?
The outage map can lag during a widespread outage. When that happens, Flathead Electric says it posts the latest information on its website home page and Facebook page. So don't keep refreshing the map for hours if a major storm has taken out power across the area. Check those other channels too. Once you see that the outage hasn't been reported, there's one number worth saving.
How to Report a Flathead Electric Power Outage
Flathead Electric uses the same number for outage calls and texts: (406) 751-4449. You can also report an outage through your online member account or the My Co-op app. Report the outage once, then leave the phone lines open for other members who may need help.
Method
What to do
Text
Text OUT to (406) 751-4449
Phone
Call (406) 751-4449
App or online
Use the My Co-op app or the online account at flatheadelectric.smarthub.coop
Text keywords worth saving
Flathead Electric keeps outage reporting simple through a handful of text commands. Save these somewhere handy so you don't have to look them up during an outage:
  • OUT: Report an outage
  • STATUS: Check the current outage status
  • ISSUE: Report a problem with electric equipment
  • STOP or QUIT: Opt out of outage texts
  • FLATHEAD: Opt back in
If your cell number is linked to your account, Flathead Electric can also text you when an outage is confirmed at your location and again when power is restored. Check your account ahead of time to make sure the phone number on file is current.
What to do about a downed line
Stay at least 10 feet away from a downed power line and assume it's energized. Don't drive over it or approach damaged electrical equipment. Report the problem by calling or texting ISSUE to (406) 751-4449. If a line is sparking or there's an immediate danger, call 911 first. The Kalispell and Libby office numbers aren't outage-reporting lines, so save the outage number instead. Reporting the outage gets the co-op working on the problem, but it doesn't keep your refrigerator, well pump, furnace blower, or internet running while you wait. That's where having backup power can make the outage easier to manage.
Backup Power for the Hours the Map Stays Red
Flathead Electric's outage preparation guidance tells members to keep water on hand because electric pumps won't work without power and to have an alternate heat source ready. A battery power station can keep smaller essentials running without using a fuel-burning generator indoors, while a whole-home battery system can handle larger hardwired loads when properly installed.
EcoFlow DELTA Pro Ultra X
•Whole-Home Backup (with the right setup): 12kW output and 12kWh capacity in the standard bundle (1 inverter + 2 Smart Extra Batteries), expandable up to 36kW and 180kWh with added inverters and batteries. Whole-home backup requires Smart Home Panel 3 installed by a licensed electrician, and coverage depends on your home's loads. • Fast Switchover: Automatic switchover in about 20ms with Smart Home Panel 3, so selected circuits stay on when the grid drops. • Installation: Plug-and-play design that EcoFlow says can be installed in 7 days. Permitting, your electrical panel, and installer schedules can change that timeline. • Comprehensive Safety: End-to-end system protection built to high safety standards.
If you need more than a few plug-in essentials, the EcoFlow DELTA Pro Ultra X takes backup power to the whole-home level. Its larger capacity and higher output are designed for homes with bigger loads and properly installed backup circuits.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Max is suited to plug-in essentials such as a router, phone chargers, lights, or a refrigerator for a renter or cabin. The EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 is the larger, wired option for hardwired loads such as a furnace blower or well pump, with the system sized to the home's electrical needs by a licensed electrician.
Estimated runtime (labeled estimate)
Runtime depends on what you plug in and how often those appliances cycle. The estimates below use 85% of the stated battery capacity to account for inverter and conversion losses. That 85% is a planning assumption, not an EcoFlow specification.
Steady load
EcoFlow DELTA 3 Max (2,048Wh × 0.85 = about 1,741Wh)
EcoFlow DELTA Pro Ultra X standard bundle (12,000Wh × 0.85 = 10,200Wh)
100W
about 17 hours
about 102 hours
300W
about 5.8 hours
about 34 hours
600W
about 2.9 hours
about 17 hours
1,500W
about 1.2 hours
about 6.8 hours
Real runtime can be different. A refrigerator compressor or well pump, for example, draws more power when it starts than it does while running. Appliances also cycle on and off rather than pulling the same wattage continuously. For backup generators wired into a home, Flathead Electric requires a transfer switch and warns that an improperly installed generator can backfeed the utility lines and put lineworkers at risk.
A whole-home battery system should likewise be connected through the proper equipment and installed by a qualified electrician. The same planning applies to a well pump. Get the pump's nameplate information before deciding how much battery capacity you need. A storm outage can happen without warning. A planned outage gives you something better: time to prepare.
Flathead Electric Cooperative Planned Power Outages: How Notices Work
Not every blue square on the outage map means an emergency. Flathead Electric schedules some outages for repairs, maintenance, testing, upgrades, and other work on the system. These appear as blue squares on the outage map.
Why planned outages happen
Scheduled outages can give crews a safe window to repair equipment, address problems that could cause future outages, perform routine maintenance and testing, make system upgrades, or meet regulatory requirements. Flathead Electric says it will make every effort to notify affected members ahead of time through automated text messages or phone calls when possible. That only works if your contact information is current. The co-op directs members to update their information online or through the Kalispell office at (406) 751-4483. That's an office number, not the outage-reporting line.
What to do when you get a notice
Check the outage map and the Alerts section of Flathead Electric’s website when you receive a maintenance notice. The notice should give you a scheduled outage window, giving you time to prepare before the power goes off. Before the power goes off:
  • Charge your devices: Top off phones, laptops, and battery power stations.
  • Save your work: Save open files and shut down computers properly before the outage starts.
  • Plan for equipment that needs power: If you use a well pump or electric garage door, handle anything you may need before the scheduled outage.
  • Protect sensitive electronics: Unplug computers, TVs, and other sensitive equipment before the power goes out.
  • Keep emergency supplies nearby: Put flashlights, lanterns, and other outage supplies somewhere easy to reach.
Flathead Electric also receives much of its power through Bonneville Power Administration (BPA) transmission lines. Maintenance on those lines can require scheduled outages that affect co-op members. A scheduled notice gives you time to handle these basics before the lights go out, rather than scrambling once the outage begins.
What Causes Flathead Electric Outages
Flathead Electric's outage FAQ groups unplanned outages into three main categories: animals, weather, and people. And the first one may not be the category you'd guess.
What Causes Flathead Electric OutagesWhat Causes Flathead Electric Outages
Animals
Animals, including squirrels, can cause power outages when they come into contact with energized electrical equipment. These incidents can interrupt service to nearby homes and businesses and may occur without warning, even on otherwise clear days.
Weather
Weather and trees are major causes of power outages in Flathead Electric’s service area. Strong winds can bring trees and branches down onto overhead power lines, while snow and ice can weigh down branches and damage electrical infrastructure. Flathead Electric reports more than 5,300 miles of energized line, with more than 60% underground. The remaining overhead lines can still be exposed to trees and severe weather, particularly in wooded areas. For current conditions and warnings, check the National Weather Service forecast office in Missoula rather than relying on a general weather app.
People
Human activity accounts for another group of outages. Vehicle crashes involving utility poles, damage from digging near underground lines, and vandalism can all take down power. That's why calling 811 before digging matters. A few minutes of checking can prevent damage to an underground utility line.
Wildfire season: why a BPA shutoff can reach your home
Flathead Electric says it does not use Public Safety Power Shutoffs (PSPS) on its local distribution system. Members can still lose power during a wildfire-related shutoff because much of the co-op's electricity comes through Bonneville Power Administration (BPA) transmission lines. BPA can de-energize those lines during extreme wildfire conditions as a last-resort measure, separate from Flathead Electric's local outage decisions.
If a shutoff affects your area, Flathead Electric may share updates through text messages, its website, social media, local news, and emergency partners. Keep your contact information current and plan ahead for medical equipment, wells, and livestock. The co-op also notes that a PSPS notice is not an evacuation order. Its wildfire work includes equipment inspections, vegetation management, wildlife protection, protective devices, updated construction standards, and undergrounding where practical. Preparing for a public safety shutoff means having a plan for water, refrigeration, and medical devices if the power stays off.
Riding out a winter outage in Northwest Montana
A summer outage is mostly a disruption. A January outage in Northwest Montana can quickly become a heating and safety issue. Flathead Electric recommends keeping an alternate heat source ready, storing water where it won't freeze, and having extra food, formula, and pet food on hand. Keep flashlights, power banks, lanterns, and radios charged, and top off the gas tank because gas stations also need electricity. Sealing drafts, insulating pipes, and using battery-backup carbon monoxide detectors can help you prepare before the temperature drops.
During an outage, use generators outdoors and away from windows, and never use a gas stove to heat the home. Keep refrigerator and freezer doors closed, disconnect major appliances and electronics, and check on neighbors who may need help. Plan ahead for refrigerated medicine and powered medical equipment, too. For battery backup, the EcoFlow DELTA 3 Max operates from 14°F to 113°F and charges from 32°F to 113°F, so keep it indoors at room temperature rather than in an unheated garage or shop. For the EcoFlow DELTA Pro Ultra X, follow the installer's guidance for placement. Check NWS Missoula for current cold-weather forecasts, and prepare for a winter power outage before the cold and an outage arrive together.
The Flathead Electric outage map tells you whether an outage is planned, reported, confirmed, or assigned to a crew. Save (406) 751-4449 for outage calls and texts, and make sure your cell number is current for automatic alerts. Before the next outage, decide how you'll handle water, heat, refrigeration, and medical equipment. For smaller plug-in loads, the EcoFlow DELTA 3 Max is one option. For larger home loads, the EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 is a system to discuss with a licensed electrician.
How do I check the Flathead Electric outage map?
Go to outage.flathead.coop:8181 or visit flatheadelectric.com/outage. Red hexagons show confirmed outages, orange hexagons indicate reported but unconfirmed outages, and blue squares mark planned outages.
What number do I call or text for a Flathead Electric power outage?
Call (406) 751-4449 or text OUT to the same number to report an outage. You can also text STATUS to check the current outage status.
How do I get a Flathead Electric power outage update?
Check the outage map or text STATUS to (406) 751-4449. During widespread outages, the map may take longer to update, so Flathead Electric also recommends checking its home page and Facebook for current information.
How will I know about a Flathead Electric Cooperative planned power outage?
Planned outages appear as blue squares on the outage map. Flathead Electric also says it tries to notify affected members through automated text messages or phone calls when possible, so keep your contact information up to date.
Does Flathead Electric shut off power for wildfire risk?
Flathead Electric says it does not use Public Safety Power Shutoffs on its local distribution system. However, Bonneville Power Administration can de-energize transmission lines that supply the co-op during extreme wildfire conditions.
Power Outages
