Electric Generators: When You Might Need One
Electric generators supply backup electricity when grid power is unavailable. They support off-grid living, emergencies, and outdoor events with dependable energy. But in reality, roadtrips, power outages, emergencies, and outdoor events require unique power solutions.
An electric generator could be a worthwhile investment, but it's critical to know what to look for when shopping and understand the different use cases for these devices. Here’s everything you need to know.
What Is an Electric Generator?
Electric generators convert fuel or solar energy into AC power. This electricity powers appliances, tools, and devices during outages or off-grid use. Electric generators can use fuel or solar power to create AC electricity, which most appliances and devices rely on.
Types of Electric Generators
  • Gas: Gasoline generators are easy to refuel as gas is available everywhere. They work well for job sites or backup power, but you may struggle to find gas during natural disasters or emergencies.
  • Propane Generators: These generators run on a different type of fuel: propane. They tend to burn cleaner, and the propane has a longer shelf life, allowing for better and safer storage.
  • Solar: Solar generators like the EcoFlow DELTA Pro 3 Solar Generator (PV400W) are connected to solar panels, which capture DC energy. The energy then gets converted to AC power in a quiet, clean-running manner.
  • Standby Generators: Whole-home or standby generators are typically connected to natural gas lines and automatically kick on during power outages. They’re great for those who rely on power for medical devices, etc.
  • Portable Generators: Portable generators are lightweight and easy to move, making them great for camping or temporary needs.
  • Inverter Generators: Inverter generators provide stable power, critical for sensitive electronic devices.
When Might You Need an Electric Generator?
If your grid power works well, you might think you’re not a good candidate for an electric generator. The trouble is, you’re not thinking big enough. Grid power can’t be 100% reliable, and it’s best to protect yourself in emergencies. They’re also helpful for more fun applications, like camping and outdoor events or activities.
Power Outages
US electricity customers deal with about 5.5 hours of electricity loss in a year. When the grid goes out due to weather, an accident, or regular maintenance, having an electric generator at home means you’re not in the dark. It keeps your lights and essential appliances running, giving you a sense of safety and security until power is restored.
Off-Grid Living
Off-grid living does not have the luxury of utility power. Generators become essential for electricity and can pair well with solar and wind systems. Without some sort of generator, off-grid living would be a lot more difficult.
Camping or RVing
Some campsites offer shorepower, but an electric generator gives you more freedom and flexibility to set up wherever is most convenient without worrying about how you’ll keep things lit, cook, or charge your devices.
Construction Sites
Job sites often lack access to the grid, but you still need to find a way to power tools, lights, and heavy equipment. Electric generators are essential to keeping a construction job progressing.
Outdoor Events
Generators solve the problem of outdoor power at events like weddings, fairs, or festivals. They can run sound systems, food setups, and lights without the limitations of the grid.
Emergencies or Disasters
When grid power is lost in natural disasters, a generator can power vital medical devices, refrigerate medicine and food, and keep communication open. They’re more than nice to have; they’re critical for health and safety.
How to Choose the Right Electric Generator for Your Power Needs
  • Power Needs: Determine how much wattage you’ll need to run your essential devices. Make a list with precise calculations so you don’t under- or overbuy.
  • Fuel Type: Decide between gas, propane, diesel, or solar-compatible models based on what’s easiest and safest for your situation. Solar is the only type that does not require an external fuel source and does not produce toxic fumes when operating.
  • Portability: Consider how often you’ll move it. Do you need something lightweight and easy to carry or a bigger unit that stays put? If portability features like handles and wheels matter to you, look for them. A model like the EcoFlow RIVER 3 Max Plus is a great option.
  • Noise Level: Some generators can be really loud. If you’re camping or in a quiet neighborhood, look for a quieter model.
  • Run Time: Check how long it can run on a full tank or charge, especially if you expect extended outages or off-grid use.
  • Start Method: An electric start is much easier than a pull-start, especially in emergencies. You can typically find these in solar generators.
  • Budget: Balance the upfront cost with reliability and fuel efficiency. (Pro Tip: Sometimes spending more upfront saves money and headaches later.)
Harness up to 2600W solar input via dual PV ports for flexible setups and faster charging with high conversion efficiency. Enjoy powerful AC output and 99% MPPT efficiency for optimal energy capture. Manage it all seamlessly through the app—monitor usage, set priorities, and stay powered effortlessly.
Can an Electric Generator Power a House?
Yes, an electric generator can power a house if its output and capacity are large enough to power all the home’s appliances and devices. You can determine this by adding up all the wattages of the appliances and multiplying that by how many hours you need to run them. If the generator's capacity can reach that, it can power your whole house.
What Are the Disadvantages of Electric Generators?
Electric generators that run on fuel can be noisy and produce environmentally damaging fumes. Storing and accessing extra fuel can be a hassle during emergencies, and they require regular maintenance. Solar electric generators avoid these issues but rely on sunshine.
Everyone can use an electric generator. Whether you like to camp, set up backyard movie nights, throw outdoor parties, or just want peace of mind during emergencies or power outages, a reliable electric generator can make it all happen. While fuel-powered generators are attractive due to their lower price, they can be noisy, produce toxic fumes, and be challenging to refuel in an emergency. Solar generators that combine solar panels and a battery, like the EcoFlow DELTA Pro 3, are quiet, clean-running, and only need sunlight to run. Consider investing in a solar electric generator for outdoor adventures and peace of mind.
Off-Grid Power
