DIY Solar System Setup: A Hands-On Guide
A home solar system is often installed professionally, but if you prefer a DIY approach, solar is still within reach. DIY solar system setups are becoming more common as solar has become more accessible and affordable. Manufacturers like EcoFlow understand that homeowners want to take the opportunity into their own hands, so they’ve made it easier to install systems without professional help.
Use this as your hands-on guide to planning and installing your very own solar energy system at home. From the essential components to each detailed step, we’re giving you everything you need to become powered by renewable energy.
Planning Your DIY Solar System
Before you get your hands dirty, planning out your DIY solar system is vital. Skipping this stage can result in silly mistakes that are otherwise easy to avoid. Ensure you have all the necessary components and understand how much solar power you need so your system can come together flawlessly when it’s time for setup.
What Components Are Needed for a DIY Solar System?
Panels are just one part of the system. You’ll also need an inverter, mounting equipment, wiring, basic tools, and a battery if you want to optimize the system or go off-grid.
  • Panels: Solar panels are the core, converting sunlight into direct current (DC) electricity. The size and number of panels determine how much power you can generate.
  • Inverter: The inverter converts the DC electricity from your panels into alternating current (AC), which is used by most home appliances and the power grid.
  • Mounting System: This secures the panels to your roof or a ground-based structure, ensuring they’re stable and positioned for optimal sun exposure.
  • Wiring: Wires connect the components, carrying electricity safely from the panels to the inverter, battery (if used), and home circuits.
  • Tools: Basic tools like a drill, screwdriver, wire strippers, and a multimeter are essential for assembling and safely installing the system.
  • Battery (Optional): A battery stores excess electricity you can use when the sun isn’t shining, providing energy backup and greater self-sufficiency if you're off-grid or need power during outages.
How Do I Calculate How Much Solar Power I Need?
To calculate how much solar power you need, determine your daily energy usage. Check your utility bill for your average monthly kilowatt-hour (kWh) consumption and divide that by 30 to get your daily demand. If your home uses 900 kWh per month, that’s about 30 kWh daily.
Next, consider your location’s solar potential. A home in sunny Arizona or Florida may get 5 to 6 peak sun hours per day, while one in the Pacific Northwest might get closer to 3 or 4. Divide your daily usage by your area's average sun hours to estimate how much solar panel output you need.
Here’s an example. If you use 30 kWh per day (piggybacking off our above example), and get about 5 hours of peak sunlight, your array will need to produce around 6 kW per hour. From there, choose panels and a battery (if you want) to match this demand.
Pro Tip: Remember to account for potential future increases or seasonal changes.
Step-By-Step Installation Guide
  1. Choose a Solar Panel System That Meets Your Needs: To account for fluctuations, choose the right system that generates slightly more than your daily demand.
  2. Get Required Permits: Contact your local government to learn what permits and inspections are necessary.
  3. Gather Supplies: Gather all the above essential components, from panels to mounting and wiring.
  4. Install Panel Mounts: Safely access your roof and install the panel mounts on the south-facing side of your home.
  5. Install Panels: Once the mounts are securely attached, install panels such as the EcoFlow 400W Rigid Solar Panels to complete your array.
  6. Secure Wiring: Next, add the wiring and connect the panels.
  7. Connect Inverter: Connect the panel wires to the inverter to ensure captured energy gets converted into usable AC power.
  8. Connect Battery and Inverter (Optional): If you plan to go off-grid or want backup energy for cloudy days or blackouts, connect the inverter to your battery for storage.
  9. Connect to Grid and Home Electricity: You can connect the system to the grid if you choose. You will likely need to contact your utility provider to ensure the equipment is connected correctly. Even if you’re not connecting to the grid, you’ll need to connect it to your home electricity system so it can power your appliances.
  10. Activate the System: Activate your system and check that it’s working. If all is well, enjoy your new renewable energy source!
Common DIY Solar System Pitfalls To Avoid
  • Buying the Wrong Panels: If you’re installing on your roof, opt for a rigid panel meant to be permanently installed. However, if you’re kitting out a van (for example), get a portable panel like the EcoFlow 160W Portable Solar Panel instead.
  • Improper System Size: Ensure your array is large enough to meet your energy demands and has room for growing needs.
  • Buying the Cheapest Panels: Cheaper does not mean better when it comes to panels. More expensive panels are often better made, more efficient, and longer-lasting.
  • Failing to Get Permits: Skipping permits can lead to delays, fines, or forced removal.
  • Forgetting About Maintenance: Bi-annual maintenance and cleaning will ensure your panels work correctly and extend their lifespan.
Can I Install a Solar System Without Professional Help?
Yes, you can install a solar system without professional help if you use equipment designed for DIY use, such as EcoFlow products. However, you must have all the necessary components and understand the proper steps to install a working system.
What’s the Difference Between On-Grid and Off-Grid Solar Systems?
On-grid solar systems are connected to the electricity grid, which a local utility company runs. These are still subject to potential grid outages. Off-grid systems are not connected to the grid and require a battery to work effectively. They are insulated from grid outages.
Do I Need Permits or Inspections for a DIY Solar Installation?
Yes, you will need proper permitting to install a regulation DIY solar system. Every area has its own specific regulations, permits, and utility requirements. Check local building codes and zoning laws, and consult your local government to confirm that you follow all requirements.
Installing your own solar system at home is easier than you may think. It comes down to understanding the installation process, having all the right equipment, including a system designed for DIY use, like the EcoFlow DELTA 3 Plus Solar Generator (PV220W), and following all permitting and regulation requirements in your area.
Solar Panels
