DIY Solar Panels: A Step-by-Step Guide to Building Your Own System
Hiring a solar installer can quickly become expensive, but that’s not the only way to get a solar system at your house. With some research, the right tools, and the best solar panels you can find, you can create your solar power system and avoid additional labor costs.
Below, find the essential equipment you’ll need, considerations before you start, and a step-by-step guide to generating your own solar power at home.
Essential Equipment and Tools
  • Solar panels: The most obvious item is solar panels, which produce the energy for your system.
  • Batteries: A compatible battery is needed to store excess energy rather than waste it.
  • Charge controller: This improves your battery charging efficiency and safety.
  • Inverter: This component will convert the direct current (DC) power generated by your solar panels into usable alternating current (AC) to power appliances and systems in your home.
  • Wiring: You will need wires to connect all the system components.
  • Miscellaneous Items: Fuses or breakers, connectors (may already be integrated into equipment), cable ties, terminal lungs, etc.
  • Tools: Wire stripper, pliers, crimping tool, screwdriver, and wrenches.
Can I Build My Own Solar Power System?
Yes, you can easily use EcoFlow Solar Panels to build your own residential solar power system. It’s a relatively straightforward process, and it costs about half the amount to do it yourself than to hire a solar installer to outfit your home with an array.
You’ll need all of the above equipment and a general understanding of how to set up your system. To learn what to do, search for online tutorials and videos.
Factors to Consider When Building Your Own Solar Panel System
Before starting the DIY process, consider a few key factors. These will determine everything from how many panels you need to whether you’ll still be connected to the grid for backup power.
Energy Consumption
How much electricity do you actually use? The answer will shape the entire design of your system and determine how many solar panels you’ll need to power your house. Look at your utility bills for your average monthly kilowatt-hour (kWh) usage. If you aim to go fully solar, your system must generate at least that much—plus a little extra to account for inefficiencies and cloudy days. A smaller setup might be enough if you’re just supplementing your power.
Location and Shading
Not all rooftops (or yards) are created equal when it comes to solar power. Your panels will be the most productive if they get direct sunlight for most of the day. Shade from trees, chimneys, or neighboring buildings can reduce efficiency. If your roof isn’t ideal, ground-mounted panels could be a better option. Also, consider the angle of your roof—the ideal angle for solar panels on a roof is between 15 and 40 degrees facing south if you’re in the U.S.
Battery Storage
Do you want to store excess energy for later or sell it back to the grid? If you prefer the former, you’ll need a battery system to store unused generated power that you can tap into at night or on cloudy days. Even if you’re staying connected to the grid, a battery can act as backup power in case of outages. The downside is that batteries can be expensive, so weigh the cost against your energy needs.
On-Grid vs. Off-Grid
Are you looking for total energy independence, or do you want to stay connected to your utility company? Going off-grid means you’ll rely entirely on solar panels and batteries, which gives you freedom from electric bills but also requires careful planning to ensure you always have enough power. It may be the only option if you live in a remote area. Staying on the grid allows you to sell excess energy back to the utility company (in many places) and use grid power when needed.
Steps for Creating a Solar Panel System
Follow this simple step-by-step process to install a solar panel system.
Calculate the Load
First, calculate your energy needs using basic math. List all the appliances you plan to run with your solar panels and multiply their wattage by the number of hours you will need to run them each day. This gives you the watt-hours. Add up all the watt-hours for a total load, leaving you with your daily energy needs.
Select Your Battery
Next, determine if you want to install your system with a battery backup. Most homeowners opt for backup power for short-term outages and solar power at night or when the sun is not shining. Look for a deep-cycle battery, preferably a lithium-ion battery like a LiFePO4.
Choose Your Solar Panels
Once you’ve selected your battery, it’s time to choose your solar panels. The solar panels should provide sufficient output to power your daily energy load. For rooftop installations, consider EcoFlow Rigid Solar Panels, such as the EcoFlow 400W Rigid Solar Panel, which are designed to be fixed in place. If you’re creating a lawn set-up or prefer an array that can be moved or adjusted, EcoFlow Portable Solar Panels, including the EcoFlow 400W Portable Solar Panels, may be a better option.
Choose Your Charge Controller and Inverter
The charge controller is placed between the solar panel and the battery and regulates the current and voltage coming from your panels. There are three types of charge controllers to choose from: ON/OFF (least efficient), MPPT (highly efficient but expensive), and PWM (sufficient performance and affordable price). We recommend either the MPPT or PWM options.
As for your inverter, this converts the DC power into AC to run your appliances. Your inverter options include Square Wave (lowest price, not adequate for all systems), Modified Sine Wave (not suitable for some devices such as refrigerators or microwaves), or Pure Sine Wave (sufficient for most appliances and the most efficient). Your inverter’s power should be higher or at least equal to your total load from step one.
Mount the Panels
Map out how you will mount the panels and use the panel fixtures to mount each one in its place on your roof. There should be built-in holes on the panel to screw it in. More detailed instructions may be in your solar panel’s manufacturer’s guide.
Connect the Components and Wire the System
Finally, it’s time to connect the components of your system and wire them correctly to your home. If you wish to remain connected to the grid, this is also the time to set up your grid connection.
Connect the charger controller to the battery to calibrate it, then connect the charge controller to the solar panel using the wires found in the junction box. If you’re having issues getting the system to work, we recommend contacting a professional electrician to troubleshoot any problems.
Pros and Cons of a DIY Solar Panel System?
There are clear upsides and downsides to creating your own solar panel system. You won’t have the protection of manufacturing warranties or the professional knowledge and skills, but it’s something you can learn along the way. On the upside, taking the DIY route is much more affordable.
Pros
Build Your Skills
By building your own solar panel system, you can build up your technical skills and emergency preparedness.
Provide Emergency Repairs
If your system malfunctions, your experience installing it may allow you to repair broken panels or fix common issues in an emergency.
Inexpensive and Relatively Simple
It’s cheaper to DIY the process and simple enough to figure it out without professional support.
Learn Something New
You can turn it into a fun learning experience that will come in handy.
Cons
No Warranty
DIY panels don’t come with a manufacturer’s warranty, so you’ll need to cover the cost of repairs or replacements yourself.
Risk of Injury
Working with electricity can be dangerous, and there’s always the risk of electrocution. Follow home wiring safety tips and be cautious.
Lack of Expertise
A lack of professional expertise may make the process more difficult, potentially making it longer or more frustrating.
Is It Cheaper to Build Your Own Solar System?
Building and installing your own solar system can be cheaper than hiring a professional installer. You’ll avoid paying additional labor costs and will only have to purchase the equipment, but you should consider whether you have the time and expertise to build the system yourself.
It’s entirely possible, relatively easy, and quite affordable to create your own solar panel system at home. Rather than pay for professional labor, you can outsource the work to yourself and save money with the same result: a fully functioning rooftop solar array that can power your home. Do your research and pick the right solar panels, as they’re the foundation of your system. Browse EcoFlow Solar Panels to see the available outputs and model types.
