EcoFlow DELTA 2 Overview: A Complete Competitors Comparison Guide
As more industries move toward renewable energy sources, more consumers are waking up to the value of owning a portable power station (PPS). But how do you know which one to invest in with your hard-earned money? The market is bursting with new additions, all as seemingly impressive as the last.
Through this comparison guide, we’re confident you’ll find many reasons that make the new EcoFlow DELTA 2 the ideal choice for a portable power station. We review specific metrics, using detailed information comparing EcoFlow DELTA 2 and its immediate competitors. By the end, you’ll have an informed opinion.
Let’s take a closer look.
Introducing the New EcoFlow DELTA 2 Portable Power Station
The EcoFlow DELTA 2 is no ordinary power station. It can power 90% of home appliances with 1024Wh capacity and expandable power capacity up to 3040Wh if you need it. It charges exceptionally fast thanks to its unique X-Stream technology, reaching 80% in just 50 minutes, and possesses the highest power output in its weight category.
Speaking of weight, the EcoFlow DELTA 2 weighs just 27lbs (12kg), making it highly portable. You can take it anywhere you need to, inside or outside the home, and stay powered up for longer.
Innovative technology puts complete control in your hands through the EcoFlow DELTA 2’s Bluetooth connectivity and smartphone app. Innovative design lets you control and track power use through the PPS metrics.
What Makes the EcoFlow DELTA 2 Different?
The EcoFlow DELTA 2 is not only highly efficient, but it’s also unique. From patented technology to innovative design, the EcoFlow DELTA 2 meet the needs of an ever-changing world. Listed below are just a few ways that it achieves this aim.
Driven by Eco-Friendly Motives
The world is continuously moving towards greener ways of doing things and recognizing the importance of renewable energy. By now, we are all aware of the dangers of climate change. Most of us understand that our planet is under severe threat if our behavior doesn’t change to meet these new challenges. Artificial intelligence, electrification, and alternative clean energy sources are all new frontiers to explore. Why should portable power stations be left behind?
With the EcoFlow DELTA 2, we are proud to introduce a power station that meets your needs without compromising the climate. By adding portable solar panels, you can instantly turn your EcoFlow DELTA 2 PPS into a powerful solar generator at any time.
We believe in an aspirational, eco-friendly future, and every step of our design process has reflected that. Allowing for smartphone access and utilizing solar power are just two of the many ways we push the envelope with what portable power stations can do.
Patented Technology
From our Smart Charge battery to our X-Stream recharge speeds, EcoFlow thrives on innovation. The EcoFlow DELTA 2 benefits from multiple patented technologies that revolutionize how power stations operate.
X-Stream enables the EcoFlow DELTA 2 to reach 80% charge in just 50 minutes. The Smart Battery Management system fully optimizes how your station stores and provides power, using an intelligent algorithm to provide you with the best possible results.
In short, the EcoFlow DELTA 2 goes the extra mile to ensure you have a positive experience.
The Next Home Essential for Your Family
Your home should feel like a sanctuary. A place where you can relax at the end of a long day and not have to worry. That’s why at EcoFlow, our focus is on family, keeping you and your loved ones safe and comfortable no matter what unexpected situation unfolds. A huge part of this is having access to electricity.
It is easy to forget just how integral power is to everything we do in our daily lives. It isn’t just vital for entertainment — it also provides light, heating, refrigeration, air conditioning, and more. With so much reliance on electricity, it’s no surprise that the average home uses around 893kWh per month.
It’s hard to overstate electricity’s importance, which is why we put so much emphasis on keeping your essential devices and appliances running for as long as possible. We’ve built the EcoFlow DELTA 2 to give you peace of mind, no matter the circumstance.
How Does the EcoFlow DELTA 2 Compare to Competitors?
If you’ve been trying to source the perfect portable power station, you already know the sheer variety currently on the market. It can be hard to know who to trust.
With that in mind, we have detailed below some key ways the EcoFlow DELTA 2 stands out from the competition.
EcoFlow DELTA 2Power Station APower Station BPower Station CPower Station D
Capacity1024Wh1002Wh1024Wh1002Wh1229Wh
Net weight27lbs / 12kg25.4lbs / 11.5kg29.8lbs / 13.5 kg22lbs / 10kg43.9 lb / 19.9 kg
Dimension15.7 x 8.3 x 11.1in / 40 x 21.1 x 28.1cm13.39 x 10.32 x 10.06 in / 34 x 26.2 x 25.5cm13.78 x 7.4 x 11.61 inches / 35 x 18.8 x 29.5 cm13.1 x 9.2 x 11.1 in / 333 x 233 x 283 mm18.2 x 11.3 x 9.3 in/ 463 x 288 x 237 mm
AppYes, Wi-Fi&Bluettooth supported////
Extra Batterysupported, capacity expands up to 3040Wh////
Total Output ports13 (4ac+9dc)7 (2ac+5dc)12 (6ac+6dc)7 (2ac+5dc)9 (2ac+7dc)
AC Output4 outlets, 1800W total (Surge 2700W)2 outlet, 1000W (2000W surge)6 outlets, 1000W (surge 1500W)2 outlets, 1000W (2000W surge)2 outlets, 1500W (2400W surge)
Max Device(s) Power Supported by X-Boost2400W////
USB-A Output2 ports, 5V, 2.4A, 12W Max per port/2 ports, 12W per port/4 ports, 12W per port
USB-A fast charge2 ports, 5V, 2.4A / 9V, 2A / 12V, 1.5A, 18W Max per port2 ports, Quick Charge 3.0, 18W Max/2 ports USB-A Quick Charge/
USB-C Output2 ports, 5/9/12/15/20V, 5A, 100W Max per port2 ports, 100W Max, (5V, 9V, 12V, 15V, 20V up to 5A)3 ports (1*100W, 2*60W)2 ports, 100W Max, (5V, 9V, 12V, 15V, 20V up to 5A)2 ports (1*100W 1*60W)
Car Power Output1 port, 12.6V, 10A, 126W Max1 port, 12V,10A1 port, 12V, 10A1 port, 12V, 10A1 port, 12V, 10A
DC5521 Output2 ports, 12.6V, 3A////
AC charging0-80% in 50mins, 0-100% in 80mins (1200W max)1.8 hours (AC adapter)4.1 hours (AC adpater+USB-C)0-80% in 5.5hrs, 0-100% in 7hrs (AC adapter)0-80% in 1hr, 0-100% in 1.5hr
Solar charging3-6 hours (11-60V, 15A, 500W max)2DC input ports, 1.8 hours (4x SolarSaga 200W Solar Panel) / 9 hours (2x SolarSaga 80W Solar Panel)5.5 hours (200W max, 11-28V)8 hours, with 2 SolarSaga 100W (126W max, 12~30V, 7.5~8.33A) 3.6+ Hour to 80% (300W max)
Smart Generator charging0-100% in 80mins (1100W max)////
Car charging11 hours (support 12V/24V)4.37 Hours (12v car adapter)14 hours
Battery ChemistryLFPNCMLFPNCMLFP
Cycle life3000 cycles to 80%+ capacity1000 cycles to 80%+ capacity3000 cycles to 80%+ capacity500 cycles to 80%+ capacity3000 cycles to 80%+ capacity
Warranty 5 years5 years5 years2 years5 years
The Most Powerful in its Weight Class
The EcoFlow DELTA 2 provides an energy capacity of 1024Wh, outsized only by an Anker PPS. However, considering the size and weight of these stations, the EcoFlow DELTA 2 wins every time. The Anker PPS weighs a hefty 43.9lb (19.9kg), whereas the EcoFlow DELTA 2 is just 27lbs (12kg). That’s almost a 20lb difference, with the EcoFlow DELTA 2 still achieving an impressive power capacity.
The Most Available Output Ports
If you want to charge as many devices as possible with your station, the EcoFlow DELTA 2 should be your first choice. It provides you with available ports in almost every category, including:
  • USB-A
  • USB-A Fast Charge
  • USB-C
  • Car Power
  • DC55521
No matter your requirements, you’ll have the ports to meet your needs. None of the EcoFlow DELTA 2’s competitors feature such a wide range of output ports. For example, Jackery’s competing PPS only offers only 3 AC outputs compared to the EcoFlow DELTA 2’s 6 and Jackery doesn’t support DC55521 output at all!
You won’t find versatility like this anywhere else on the market.
The Fastest Charging Speeds
The EcoFlow DELTA 2 can reach full charge in a much shorter timeframe than its competitors, especially given its power capacity, reaching 80% charge in just fifty minutes when connected to a wall outlet and a full charge in just 80 minutes.
Only one of Anker’s products comes close to this, reaching 80% in sixty minutes, but it is a much larger, heavier power station.
With optional EcoFlow Solar Panels, the EcoFlow DELTA 2 reaches full charge within 3-6 hours. It is similar to one of Anker’s products, except the EcoFlow DELTA 2 provides an additional 200W power.
Utilizes Smart Generator Charging
If you thought the high-speed charging was impressive, just wait til you experience the patented Smart Generator charging. The EcoFlow DELTA 2 is the only power station of its kind to utilize this.
Smart generator charging allows the EcoFlow DELTA 2 to reach its full 1024Wh capacity in just 80 minutes, which is something none of its competitors can do. This kind of cutting-edge technology is just one of the ways the EcoFlow DELTA 2 stands out in the market.
Wi-Fi and Bluetooth Supported
You can operate the EcoFlow DELTA 2 via the smartphone app, which you can’t do with any of the other competitors. Connect to the PPS using Wi-Fi and Bluetooth, depending on your needs.
Smart, wireless technology adds new functionality to your power station, allowing you to alter settings remotely and improve energy efficiency.
Extra Battery for Expandable Capacity
Last but certainly not least, the EcoFlow DELTA 2 sets itself apart by enabling expandable energy storage capacity with the addition of another battery.
You have complete control over your maximum capacity. If you look at the base product and feel like it isn’t enough, you have the option to make improvements! You won’t have this opportunity with any competing power stations.
• 1-3kWh expandable capacity with DELTA 2 Smart Extra Battery • Huge AC output(2200W with X-Boost Technology) • 7 x Faster AC charging • Go green without sacrificing speed • Built to last 6 x longer • Control from anywhere • 5-year warranty
So there you have it, a complete comparison of the EcoFlow DELTA 2 and how it stands up to its competitors. This portable power station excels from the fastest charging speeds to the largest power output in its weight class. You’ll feel the difference in power and speed when you try it out for yourself. Get the EcoFlow DELTA 2 today for all your portable power station and renewable energy needs.
Home Backup
