What is Hurricane Evacuation Zone? What to Charge, Pack, and Power Before You Leave
Safety Disclaimer
This guide provides general preparedness information for hurricane season 2026. It does not replace evacuation orders, local emergency management instructions, medical advice, utility guidance, or professional emergency planning. Always follow official updates from the National Hurricane Center, FEMA, your state emergency management agency, county officials, and local law enforcement first.
Quick Answer: What Should You Do First?
If a hurricane may affect your area, start with three actions:
  • Check your zone: Look up your address through your county or state evacuation zone tool before a storm arrives.
  • Charge essentials: Fully charge phones, power banks, medical devices, vehicle gear, refrigerated medication coolers, and backup power.
  • Leave when told: If local officials order your zone to evacuate, leave as soon as practical and do not wait for conditions to worsen.
Hurricane evacuation zones identify areas where storm surge, flooding, or local hazards may make staying unsafe during a tropical storm or hurricane. If you live in one of these zones, you may need to leave quickly when local officials issue an order. This guide explains how hurricane evacuation zones work, how to check yours, and what to charge, pack, and power before you go.
What Are Hurricane Evacuation Zones?
Hurricane evacuation zones are mapped areas used by local emergency managers to decide who should leave before a storm arrives. They are usually based on storm surge risk, elevation, proximity to water, road access, and local flood vulnerability.
A hurricane evacuation zone is not the same as a flood zone. Flood zones are often used for insurance and long-term property risk. Evacuation zones are used for emergency action. During a hurricane, local officials may order Zone A to leave first, then Zone B, Zone C, or other levels depending on the expected storm surge and local conditions.
The National Hurricane Center explains that storm surge is an abnormal rise of water generated by a storm, and it can cause extreme coastal flooding when combined with tides and wave action. Storm surge is one of the most dangerous hurricane hazards, especially along the U.S. East and Gulf coasts.
If your address falls inside hurricane evacuation zones, the safest plan is to know that before hurricane season, not when roads are already busy.
Modern living room with lightning storm outside window, wall-mounted EcoFlow transfer panel paired with stacked EcoFlow DELTA Pro Ultra portable power station, indoor emergency home backup energy system
How Do You Find Your Hurricane Evacuation Zone?
Most coastal counties and cities provide online evacuation zone maps. You can check your county's evacuation map to find your zone.
Check Local Emergency Sources First
Use local sources because evacuation maps are not the same everywhere. One state may use letters, another may use numbers, and some counties may include separate rules for mobile homes, barrier islands, low-lying roads, or flood-prone neighborhoods.
You should check:
  • County emergency management website
  • State emergency management website
  • Local government hurricane page
  • Local National Weather Service updates
  • Local TV or radio emergency announcements
Do not rely only on social media screenshots. They may be outdated, cropped, or missing important shelter and timing details.
Example: How To Look Up A Florida Evacuation Zone
Here is a simple example using a fictional address.
  1. Search for your county emergency management website, such as “Pinellas County evacuation zone lookup” or “Miami-Dade evacuation zone map.”
  2. Open the official county or state emergency management page.
  3. Enter the home address, apartment address, RV park address, or vacation rental address.
  4. Write down the zone shown, such as Zone A, B, C, D, or E, depending on the local system.
  5. Save a screenshot offline and share it with everyone in your household.
  6. Recheck the same official page when a storm approaches because local instructions can change.
This matters because evacuation zones hurricane maps can guide decisions before official orders are issued. If you already know your zone, you can act faster when the forecast changes.
Why Should You Follow Local Officials?
Local officials know the roads, bridge closures, shelter capacity, low-lying areas, and timing of local hazards. They also coordinate evacuation timing to reduce traffic problems and keep routes open for emergency response.
A storm does not need to be a Category 5 to make evacuation necessary. Storm surge depends on storm size, wind direction, forward speed, coastline shape, and seafloor slope. The National Hurricane Center notes that storm surge is sensitive to small changes in storm intensity, speed, size, angle of approach, and coastal features.
That is why a lower-category hurricane can still be dangerous for certain coastal areas. If local officials tell your zone to leave, the order is based on expected local impact, not just the headline storm category.
Mandatory Vs Voluntary Evacuation
A mandatory evacuation means officials are telling people in that area to leave because staying may be unsafe. A voluntary evacuation means conditions may become dangerous, especially for people who need extra time, have medical needs, live in mobile homes, or rely on powered equipment.
If you are in evacuation zones for hurricane surge or flooding, waiting too long can create bigger problems. Roads can flood, bridges can close, fuel can run low, and emergency services may not be able to reach you during peak conditions.
What Should You Charge Before You Leave?
Before you evacuate, power planning should start early. Once an evacuation order is issued, you may not have much time to find cables, charge devices, or organize backup power.
If you live in a storm-prone area, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power can help keep essentials charged before evacuation, with large expandable capacity and multiple charging options.
Never fear blackouts w/the ultimate home backup solution. Up to 1 month of power & 21.6kW of AC output. Run your whole home off-grid w/solar. Zero downtime
Charge Communication Devices
Start with anything that helps you receive alerts or contact others:
  • Phones
  • Tablets
  • Power banks
  • Two-way radios
  • Weather radio
  • Laptop
  • Hotspot
  • Vehicle jump starter
  • Flashlights and lanterns
Set all phones to low power mode before leaving. Download offline maps, shelter addresses, insurance documents, and emergency contact lists in case cell service becomes unreliable.
Charge Vehicle And Travel Gear
If you are evacuating by car, charge and pack:
  • Dash cam
  • Tire inflator
  • Portable air pump
  • GPS device
  • Car emergency light
  • USB-C and Lightning cables
  • 12V car charger
  • Portable battery starter
Keep one charging cable in the driving area and another in your emergency bag. During an evacuation, you do not want to unpack everything just to find one cable.
Charge Medical And Care Devices
If your household depends on powered medical or care equipment, plan earlier than everyone else. This may include:
  • CPAP machines
  • Nebulizers
  • Mobility devices
  • Hearing aid chargers
  • Refrigerated medication coolers
  • Breast pumps
  • Baby monitors
  • Electric thermometers
If any device is medically necessary, contact your doctor, pharmacy, utility provider, and local emergency management office before hurricane season. Ask about evacuation support, shelter options, and backup power needs.
Example Evacuation Timeline: 72 Hours To 1 Hour Before Leaving
A timeline helps turn preparation into action. Adjust this example based on local orders, storm speed, traffic, medical needs, and household size.
72 Hours Before Possible Impact
Check your evacuation zone, follow NHC forecasts, monitor county emergency updates, and confirm where you will go. Charge power banks, check your portable power station, refill prescriptions if needed, and review pet or medical shelter options.
48 Hours Before Possible Impact
Pack documents, food, water, medication, chargers, pet supplies, and baby supplies. Fill your vehicle fuel tank, test flashlights, download offline maps, and contact family members about your plan.
24 Hours Before Possible Impact
Move outdoor items indoors, take photos for insurance, set refrigerator and freezer colder if power loss is possible, pack the car, and confirm shelter, hotel, or family destination availability.
1 Hour Before Departure
Do a final check for phones, medication, IDs, keys, wallet, chargers, pets, and children’s supplies. Unplug nonessential electronics if time allows. Leave immediately if your zone is under an evacuation order.
EcoFlow DELTA Pro Ultra X
What Should You Pack For A Hurricane Evacuation?
A hurricane evacuation bag should cover the first 24 to 72 hours away from home. It should be easy to carry and organized by category.
Essential Documents
Pack waterproof copies or digital backups of:
  • Driver’s license or ID
  • Insurance policies
  • Medical records
  • Prescription list
  • Emergency contacts
  • Pet vaccination records
  • Home ownership or rental documents
  • Bank and credit card information
Keep paper copies in a sealed bag. If your phone dies or cloud access fails, printed documents can still help.
Food, Water, And Personal Supplies
Bring water, ready-to-eat food, and basic hygiene items. Good options include protein bars, canned food with a pull tab, shelf-stable snacks, baby food, electrolyte packets, wipes, sanitizer, and trash bags.
Pack clothing for several days, including rain gear, closed-toe shoes, and a light jacket. Shelters, hotels, and evacuation stops can be colder or more crowded than expected.
Pet And Baby Supplies
For pets, pack food, water bowls, leash, carrier, medication, waste bags, and vaccination records. For babies, pack diapers, wipes, formula, bottles, extra clothing, blankets, and comfort items.
If you use powered baby gear, charge it before you leave. Do not assume every shelter or hotel room will have easy outlet access.
How Do You Protect Your Home Before Leaving?
If officials tell you to evacuate, your first priority is leaving safely. Do not delay too long trying to make the house perfect. Focus on fast, practical steps.
Before You Leave
If time allows:
  • Bring outdoor furniture inside
  • Move trash cans, grills, and loose items
  • Close windows and interior doors
  • Unplug nonessential electronics
  • Move valuables away from low floors
  • Set the refrigerator and freezer colder before a power loss
  • Take photos of rooms and valuables for insurance
  • Turn off water or gas if instructed by local officials
Do not tape windows. It does not protect glass from hurricane-force debris. Use approved shutters or plywood if you have time and safe conditions.
For Refrigerated Medication
If you have medication that must stay cold, use an insulated cooler with ice packs and a thermometer. Keep medication in waterproof packaging and avoid direct contact with loose ice unless the pharmacy confirms it is safe.
Ask your pharmacist how long the medication can stay outside its normal temperature range. Do this before storm season, not during evacuation traffic.
What Should You Power After You Return?
Returning home after evacuation can be just as challenging as leaving. Power may be out, water may be unsafe, roads may be blocked, and local officials may restrict access.
Contemporary minimalist concrete villa with open garage housing electric vehicle and EcoFlow DELTA Pro Ultra whole-house power backup unit, residential off-grid solar storage exterior scene
Wait For Official Return Notices
Do not return just because the storm has passed on radar. Floodwater, downed power lines, gas leaks, unstable trees, and blocked roads can remain dangerous. Follow local emergency management updates and return only when officials say your area is open.
Prioritize Essential Loads
Once home, prioritize:
  • Refrigerator or freezer
  • Phones and communication devices
  • Medical devices
  • Fans or small cooling devices
  • Lighting
  • Internet equipment if service is available
  • Sump pump or water removal tools where needed
Avoid powering everything at once. A better plan is to rotate loads and preserve backup power for essential needs.
How Can You Build A Better Evacuation Power Plan?
A good evacuation power plan has three levels: small devices, travel power, and home backup.
Level 1: Personal Charging
This includes power banks, cables, and car chargers. Every adult should have a small personal charging kit.
Level 2: Travel And Cooler Support
This includes a portable power station, solar panel, or vehicle charging setup that can support phones, lights, small appliances, and medical or pet-care devices while away from home.
Level 3: Home Backup
This supports essential home circuits before you leave or after you return. It can help keep food cold, maintain communications, and power critical equipment during extended outages.
The best setup depends on your evacuation zone, household size, medical needs, vehicle space, and storm risk. For people living in coastal hurricane evacuation zones, the key is to charge early and leave when told, not wait until power fails.
Know Your Zone And Prepare Power Before The Storm
A hurricane evacuation zone tells you whether your home may need to evacuate because of storm surge, flooding, or local hazards. Know your zone, follow local officials, and prepare your charging list before a storm approaches. For whole-home backup before and after evacuation, EcoFlow DELTA Pro Ultra offers expandable capacity, high output, and multiple charging options for essential power needs.
Stacked EcoFlow DELTA Pro Ultra portable power station powering PC, aquarium and workshop electronics in cozy home garage studio, emergency backup energy for household hobby spaces with a resting dog
Q1: How Do I Know My Evacuation Zone in Florida?
Use your local county or city evacuation zone lookup tool. Enter your address and save the result. Confirm via local emergency management websites before a hurricane hits to ensure accurate information.
Q2: Should I Evacuate If I'm Not In An Evacuation Zone?
If you are outside an official evacuation zone, evacuation may not be required. However, consider your personal risk, local flood history, access roads, and advice from authorities. Safety should always come first.
Q3: How Far Inland Do You Have to Evacuate During a Hurricane?
Evacuation distance depends on storm surge forecasts, rainfall, terrain, and local emergency guidance. Coastal and low-lying areas may require moving several miles inland; always follow official instructions.
Q4: What Is The Best Flood Zone To Live In In Florida?
Higher elevation zones with minimal flood history are generally safest. Look for areas with strong drainage, no recurring storm surge, and that fall outside designated FEMA high-risk flood zones.
Q5: What Areas of Florida Are Safest From Hurricanes?
In general, central and northern inland regions face lower hurricane risk. However, no location is completely risk-free. Check historical storm paths, local building codes, and evacuation planning when choosing where to live.
Home Solutions
