Best Generator for Power Tools: How to Size Running and Starting Watts Safely
The best generator for power tools can handle the running load and the highest load at startup. Saws and compressors may draw extra current as they start. A tool rated 15 A at 120 V has a rated apparent power of 1,800 VA. On U.S. construction sites, OSHA's ground-fault protection rule lets employers use approved GFCIs or an assured equipment grounding conductor program. This guide shows how to size the unit and set up the job safely.
How Do You Size a Generator for Power Tools?
Picture a Saturday deck build: a saw, a couple of work lights, and a charger topping off drill batteries. List the loads you'll run together and check each tool's running and starting requirements. If you start one tool at a time, add its total starting watts to the running watts of the other loads. If the manufacturer gives extra starting watts, add that amount to the full running total. Check each planned startup and use the highest combined load.
List Every Tool You'll Run Together
Start with a real plan for the day, not a list of everything in the truck. Most people don't run a table saw and a miter saw at the same moment. They do keep lights, a radio, and a battery charger going all day while one saw starts and stops.
So split your list into two groups. The first group is the steady loads that stay on for hours. The second group is the tools that cycle on and off, like saws, grinders, and compressors. That split tells you which loads drain the battery or fuel tank over time and which ones set your peak.
Read the Label the Right Way
Many tools show only amps and volts. Multiplying the two gives volt-amperes (VA), not true watts. The two match only when the power factor is 1, and motors usually sit below that, as Fluke's guide to how power factor works explains.
So how many circular saw watts should you plan for? A 15 A, 120 V nameplate gives a rated apparent power of 1,800 VA. Use the manufacturer's input watts or a properly rated power meter for the running load under normal working conditions.
A properly rated power meter can show what the tool draws while it works. A saw spinning freely draws less than a saw cutting lumber. For running watts, measure a typical cut within the ratings of the tool and the meter.
Why Starting Watts Matter
A motor can draw a brief burst of current as it spins up. Check the tool manufacturer's startup specifications first. If those figures are unavailable, a qualified person can use an inrush-capable meter to verify starting current. Compare the load with the generator's or power station's supported surge rating and duration.
Tool (example)
Nameplate
Running watts
Starting requirement
Circular saw
15A, 120V label
Input watts from manufacturer or a running measurement. Nameplate rating: 1,800 VA.
Manufacturer data or qualified inrush measurement
Table saw
Check label
Manual input watts or meter reading
Air compressor
Check label
Battery tool charger
Check label
Input watts on charger label
Not usually listed
LED work light
Check label
Watts on label
Not usually listed
Put the Numbers Together
Here's a quick example with made-up readings. Say your meter shows 100 W for lights, 150 W for a charger, and 1,500 W for a saw while cutting. Your running total is 1,750 W. With the lights and charger already running, add their 250 W to the saw's total starting watts. If the manufacturer lists extra starting watts above the saw's 1,500 W running draw, add only that extra figure to the 1,750 W running total.
Try not to plan right at the limit, either. If your running total lands just under a unit's rated output, one extra tool can push it over. Leaving some room gives you space for a work light someone adds later in the day.
Once you have those numbers, the next question is what kind of machine supplies them. Battery units split the job by load size, so let's start there.
Which Battery Power Stations Fit Power Tool Work?
A remodel crew charging drill batteries all day doesn't need the same box as someone ripping plywood on a table saw. Match the station to the tools on your list. Then check both running and starting watts against its specs, and see the limits of running power tools on solar before a big job.
Portable Power for Power ToolsPortable Power for Power Tools
Steady Loads vs. Short Bursts
Lights and chargers pull a small, steady load for hours. They don't need much output, but they add up over a full day. A corded saw is the opposite. It needs a lot of output for a short time, plus a starting spike every time you pull the trigger.
That's why one station rarely suits every job. Is your day mostly charging cordless packs, or is it mostly corded cutting? Your answer points you toward a smaller unit with steady capacity or a bigger one with more output and surge room.
Picking the Right EcoFlow Unit
A battery generator for tools has one clear edge indoors. EcoFlow power stations run with no fumes, so they can work inside a remodel or a garage. Size them from each tool's label or meter reading, not a guess, and sort out GFCI and grounding before the first cut.
Work lights and cordless tool chargers are the steady loads that run all day on most sites. The EcoFlow DELTA 3 Classic is matched to that kind of work. It's a 1,024Wh unit with 1,800W of output, per EcoFlow, and its fast AC recharge helps if you can plug it in over lunch.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Corded saws are a bigger ask. The EcoFlow DELTA 3000 Gen4 adds output for a confirmed 120V corded circular saw or table saw, as long as the tool's running and starting watts fit. There's one catch, though. EcoFlow's page says it ships in early January 2027 and lists it as a pre-order, so treat it as a plan-ahead pick, not a fix for a job or an outage happening right now.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How Long Will a Charge Last?
The figures below are estimates, not test results. We counted 85% of each unit's rated capacity as usable and divided by an example running load. The loads are made-up meter readings, so swap in your own.
Load (example)
Running watts
EcoFlow DELTA 3 Classic (870Wh usable, est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable, est.)
LED work lights
About 100W
About 8.7 hours
About 26 hours
Circular saw, continuous cutting
About 1,500W (example reading)
About 0.6 hours
About 1.7 hours
Saws run in short bursts, so a real workday usually stretches further than the continuous-cutting row suggests. Here's how the two units divide the job:
  • EcoFlow DELTA 3 Classic: lights and chargers
  • EcoFlow DELTA 3000 Gen4: confirmed 120V corded saws
  • Both: Confirm your site's ground-fault protection method and follow the unit's manual.
Recharging Between Jobs
Run time is only half the story on a multi-day job. You also need a way to refill the battery. EcoFlow lists the EcoFlow DELTA 3 Classic at 0 to 80% in about 45 minutes on AC, so a lunch break near a working outlet can make a real difference.
For the EcoFlow DELTA 3000 Gen4, EcoFlow lists up to 1,800W of AC input and up to 1,000W of solar input. Solar output changes with weather and panel setup, though. On a cloudy week, plan on wall charging and treat solar as a bonus.
Power is only half the setup, though. The other half is keeping everyone on the site safe from shock.
Why Does GFCI Protection Matter for Power Tools?
Wet ground and a nicked cord are a bad mix. A ground-fault circuit interrupter (GFCI) compares the current going out with the current coming back. If some leaks away, possibly through a person, it cuts power fast.
What OSHA Requires on Job Sites
Under OSHA's construction wiring rule (29 CFR 1926.404(b)(1)), employers choose approved GFCIs or a compliant assured equipment grounding conductor program to protect employees. If the employer uses the GFCI option, it covers nonpermanent 120 V, single-phase, 15 A and 20 A receptacles used by employees. The grounding conductor program has its own inspection, testing and recordkeeping requirements.
An OSHA interpretation letter on generators explains the narrow exception under the GFCI option. It applies to receptacles on two-wire, single-phase portable or vehicle-mounted generators rated 5 kW or less when their circuit conductors are insulated from the generator frame and all other grounded surfaces.
Checking a Power Station's Outlets
Don't assume a power station's outlets are GFCI-protected. The EcoFlow product pages we checked don't mention GFCI, so look in the manual for your exact model. EcoFlow's DELTA 3 Classic support FAQ also says its off-grid output is a floating-ground system, and outlet testers may show reversed wiring.
Before work starts, ask EcoFlow support and your site's competent person or an electrician whether a listed portable GFCI works with that output and meets your site's rules. For outdoor jobs at home, use GFCI outlets for outdoor power wherever you plug in.
Cords and Daily Checks
A GFCI can't fix a bad cord. Look over every extension cord before you plug it in, and set aside any cord with cut insulation, a bent prong, or a missing ground pin. Use grounded cords rated for the load you're running.
Where you set the unit matters too. Keep it out of rain and standing water, and route cords where people won't trip over them or roll a wheelbarrow across them. If a GFCI trips, find the cause before you reset it.
Once your outlets are protected, there's one last decision left. Should your power come from fuel or a battery?
Should You Choose Gas or Battery for Power Tools?
Your choice depends on where you work and how long you run. A portable gas generator can run between refuels and handle bigger loads, depending on the model. A battery unit runs quietly with no fumes, and many crews pair cordless tools with a battery for charging.
Gas vs. BatteryGas vs. Battery
Factor
Portable gas generator
Battery power station
Run time
Refuel to keep going
Recharge from AC or solar
Indoor work
Never indoors or in a garage
No fumes, so it can work inside
Noise
Engine noise
Quiet operation
Big loads
Check the model's rated output
Check the model's rated and surge output
Fumes and Placement
Safety is the biggest split. CDC's carbon monoxide guidance says never to use a generator inside your home or garage, even with doors and windows open. It also says to use generators only outside, more than 20 feet from windows, doors, and vents. That rule is aimed at portable fuel-burning generators, which give off carbon monoxide.
That distance can be hard to manage on a tight city lot or inside a garage workshop. A long cord run from a portable gas unit also adds more cord to inspect and more spots to trip on. Before you start the engine, walk the site and pick a spot that meets the distance rule and stays dry.
Noise and Neighbors
Noise matters too, especially in neighborhoods with quiet hours or HOA rules. If you're working inside a finished home, a battery unit avoids exhaust in the work area altogether. That can make early starts easier on the homeowners and the folks next door. If your town or HOA sets work hours, check them before the job so a loud engine doesn't become a complaint.
When a Mix Makes Sense
You don't always have to pick just one. Plan battery power for tool uses on remodel jobs, and keep a gas unit for long, heavy days outdoors if you need one. Many crews already run mostly cordless tools, so a battery station that recharges packs all day can cover much of the work.
Choose a generator that covers the combined running load and the highest startup load. When starting one tool at a time, combine its total starting watts with the running watts of the other loads. On a construction site, confirm whether the employer uses GFCIs or an assured equipment grounding conductor program. Consider the EcoFlow DELTA 3 Classic for lights and chargers. For a 120 V corded saw, check its running and starting requirements against the EcoFlow DELTA 3000 Gen4 once it ships.
What size generator do I need for power tools?
Add up the running watts of all the loads you'll use together. If you start one tool at a time, check the peak for each startup by adding that tool's total starting watts to the other loads' running watts. If the maker gives an extra-starting-watts figure, add it to the full running total. Compare the running total with the unit's continuous rating and the highest startup load with its surge rating and duration.
How many watts does a circular saw use?
A 15 A, 120 V nameplate gives a rated apparent power of 1,800 VA. For running watts, check the saw manufacturer's data or use a properly rated power meter under a typical load. For startup, use the manufacturer's starting figures or have a qualified person check the inrush current with a suitable meter.
Do job-site generators need GFCI?
On U.S. construction sites, 29 CFR 1926.404(b)(1) allows employers to use approved GFCIs or a compliant assured equipment grounding conductor program. Under the GFCI option, the rule covers nonpermanent 120 V, single-phase, 15 A and 20 A receptacles used by employees. The exception covers receptacles on two-wire, single-phase portable or vehicle-mounted generators rated 5 kW or less if the circuit conductors are insulated from the frame and all other grounded surfaces.
Can a battery power station run a table saw?
Yes, if the saw's running and startup loads fit the station's continuous and surge ratings, including its outlet limits. Check the saw manufacturer's data and the station's manual. Confirm the site's ground-fault protection method before using the saw.
Is gas or battery better for tools?
It depends on the job. Gas suits long, heavy use outdoors, as long as the generator stays outside and away from openings. A battery unit suits quiet, fume-free work indoors and all-day charging for cordless tools.
Portable Power Stations
