Beach Camping Essentials: Portable Power for Coastal Adventures
Beach camping offers direct access to the water, open skies, and a more remote outdoor experience. But limited access to electricity can make it harder to keep essential devices running.
Thankfully, portable power solutions are available in a range of sizes, from compact power banks to higher-capacity stations designed for off-grid trips and easy to bring along on your next coastal adventure.
This guide goes over the importance of portable power for beach camping and tips for using it safely and effectively.
Why Power Matters for Coastal Camping Trips
There are several reasons why power is important to consider on your coastal camping trips.
For starters, it lets you enjoy many of the comforts and conveniences of an electrified camping site, while being right up on the water in a more secluded location. This includes lighting, portable fans, small appliances, and more.
It’s also important for keeping food and drink safe and helping you practice good beach camping safety habits.
For example, having access to power ensures you can charge up your phone, navigation system, or emergency radio to make sure you can communicate with others and avoid getting lost.
The Challenges of Staying Powered at the Beach
However, there are a few challenges when it comes to staying powered at the beach that it’s important to be aware of, including:
  1. There’s often a lack of places to plug in your devices, which underscores the importance of portable power.
  2. The air near saltwater beaches carries salt particles that can corrode, rust, and damage technology if you’re not careful.
  3. The hot temperatures and the sun may overheat your devices, as well as the power bank or portable charger you’re using to power your devices.
  4. Sand or water could enter the internal components of your charger or devices, which may damage them.
  5. There’s not much wind protection at the beach, which could knock over and/or unplug your chargers if it’s bad enough.
An EcoFlow DELTA 3 Plus + 220W Solar Panel bundle
4 Beach Camping Essentials That Need Power
Here’s a closer look at a few different groups of beach camping essentials that need power to either stay fully charged or operate in general.
Smartphones
Of course, you need power to keep your smartphone charged up.
Your phone is one of the most important tools while camping. It’s your way to communicate with others, navigate safely, capture stunning photos, and keep yourself entertained with music throughout your beach camping adventure.
While some phones may last a day or two without a charge, going any longer than that is risky and could leave you stuck without any way to reach out to others in case of an emergency.
Lighting
If you’re camping off-the-grid near the beach, there’s a chance there won’t be many lights nearby. While fine during the day, it’ll get pretty dark and dangerous at night.
Whether they’re solar-powered, battery-powered, or rely on power from a portable power station, having lights at your camp is important. It ensures you can always find your way back after a hike, improves the atmosphere of your camp as a whole, and helps prevent you from tripping or slipping while walking around at night.
For lightweight setups, compact systems like the EcoFlow DELTA 3 Plus + 220W Solar Panel provide enough power to keep phones, lights, and small devices running throughout your trip.
Camping Setup
Your camp itself is likely full of items that need power, as well. This includes your Bluetooth speaker, an air pump (either for your mattress/sleeping pad or inflatable beach toys), and possibly even a portable fan if you’re summer camping.
Small Appliances
If you bring any appliances with you when you camp, many of them rely on power to work. This may include a mini fridge or cooler, coffee maker, blender, electric kettle, or electric grill.
While you don’t need these to camp, they can make the experience more comfortable and enjoyable.
Thankfully, many of these smaller appliances can run on compact and portable power solutions, and won’t require large, fixed backup systems designed for home use.
If you’re running more demanding gear like portable refrigerators or multiple devices, mid-capacity systems like the EcoFlow DELTA 3 Max Solar Generator + 220W Solar Panels offer additional runtime and flexibility.
An EcoFlow DELTA 3 Max Solar Generator + 220W Solar Panel bundle
7 Tips for Using Portable Power at the Beach
Here are some crucial tips to keep in mind when using portable power at the beach:
  1. Make sure your portable power station and your devices all stay elevated. Keeping them away from sand and water helps prevent them from damage.
  2. Have a tarp, awning, or other type of protection ready to hang up and protect your devices in case of rain.
  3. Keep your chargers and devices in stable locations so they don’t blow over. Watching and being aware of the wind is one of the most important beach camping tips, as there generally aren’t many trees by the beach to provide wind protection.
  4. Consider making sure someone stays near the portable power bank or charger while it’s in use, so it doesn’t get stolen if there are other people around. If this isn’t possible, keep it locked in your camper, tent, or vehicle.
  5. Avoid storing or using your portable power solutions in direct sunlight, as this could cause them to overheat.
  6. Ensure you fully charge the portable charger itself before going to the beach.
  7. Make sure the portable power station you choose is easy to transport. For RV camping or extended beach stays, higher-capacity systems like the EcoFlow DELTA Pro 3 + 400W Solar Panel can support multiple appliances and provide consistent power from a central setup.
What Devices Should You Power While Beach Camping?
While beach camping, some devices you may need to power include phones, tablets, portable speakers, portable fans, camp lights, or small appliances like coffee makers, kettles, or portable coolers.
Are Portable Power Stations Safe to Use Near Sand and Water?
It depends on the model. Many aren’t safe around sand and water, as they could damage internal components, while others may be sand and water-resistant to minimize potential damage.
Portable Power Supports Better Beach Camping Experiences
If you want the best beach camping experience possible, you can’t forget about power. Staying powered helps keep you safe, improves comfort and convenience, and ensures you stay connected.
To build a complete beach-ready setup, explore EcoFlow’s portable power and solar bundles designed for off-grid use.
Camping
