Anker Solix F3800: Specs, Price, and How It Actually Compares
If you're shopping for a high-capacity portable power station, you've probably noticed the Anker Solix F3800 showing up in a lot of conversations. With a 3,840Wh battery and 6,000W of continuous output, it sits in a category that blurs the line between portable backup and whole-home energy storage. But specs on a page only tell part of the story. Before committing to a unit at this price point, it helps to understand what the F3800 actually delivers, what it costs, and how it stacks up against alternatives from EcoFlow's DELTA Pro lineup.
Anker Solix F3800 Specs and Dimensions
When you're comparing power stations in this capacity range, the numbers matter more than marketing language. How much energy can the unit store? How much power can it deliver at once? How fast can it recharge from solar panels? These are the practical questions that determine whether a unit fits your needs or falls short. If you're still getting familiar with how portable power stations work, the specs below are a good place to start. Here's what the anker solix f3800 specs look like on paper.
Spec
Anker Solix F3800
3,840Wh, LFP
6,000W continuous, 120V/240V dual voltage
Surge Output
9,000W
3,000+ cycles
Solar Input
Up to 2,400W (dual 1,200W XT-60 ports)
AC Charging Input
Up to 1,800W
Weight
132.3 lbs
27.6 x 15.3 x 15.6 in (including wheels)
EV Charging
NEMA 14-50 port, up to 6,000W
5 years
Max Expansion
Up to 53.8kWh (two units, twelve batteries)
The Solix F3800 ships on wheels as standard, which is worth noting given its 132-lb base weight. Moving a unit this heavy without wheels would be a serious challenge for most people.
Its expansion ceiling of 53.8kWh puts it in genuine whole-home territory when fully built out, not just a large portable unit. For context, the U.S. Energy Information Administration reports that the average American home uses roughly 29 kWh per day, so a fully expanded F3800 system could theoretically cover close to two days of typical consumption. If you're evaluating options at this scale, understanding what goes into a whole house battery backup helps frame the comparison.
Built-in EV charging through a NEMA 14-50 port is a feature that sets the Anker Solix F3800 solar generator apart from most units in its size class, which typically require an adapter or separate accessory. If you own an electric vehicle and want your backup power to double as a charging station, that's a meaningful convenience. EcoFlow's guide to portable power for EV trips covers what to expect from that setup.
Anker Solix F3800 Price: What It Actually Costs
Budget is usually one of the first factors that narrows the field. If you're considering the Anker Solix F3800 portable power station, you're looking at a meaningful investment, so knowing the real cost before comparing alternatives is worth your time.
Reported pricing for the base unit puts the Anker Solix F3800 price in the $3,799 to $3,999 range across retailers and reviewers, though Anker's own site doesn't consistently display a static list price. Current retailer listings tend to be the more reliable check at the time of purchase. Bundled configurations with solar panels or expansion batteries push the total meaningfully higher, following the same pattern seen across large-capacity power stations generally.
At this price point, the F3800 sits closer to entry-level whole-home battery systems than mid-tier portable units. That's the more useful price comparison to keep in mind. The Anker Solix 3800 price puts it in the same neighborhood as dedicated backup systems rather than smaller portable generators. Understanding the differences between a home battery and a portable power station helps you evaluate which approach fits your situation better. If you're trying to find the right portable power station for your budget, comparing total cost of ownership across several options is the clearest path forward.
How the Anker Solix F3800 Compares to EcoFlow's DELTA Pro Line
With price and specs established, the real decision most shoppers are making is which alternative in this capacity range actually fits their situation. That's where direct comparison helps. EcoFlow's DELTA Pro lineup covers three distinct tiers, so there's a useful comparison point for nearly every buyer.
Spec
Anker Solix F3800
EcoFlow DELTA Pro
EcoFlow DELTA Pro 3
EcoFlow DELTA Pro Ultra
3,840Wh
3,600Wh
4,096Wh
6,144Wh
6,000W
3,600W
4,000W (6,000W X-Boost)
7,200W
Surge Output
9,000W
7,200W
8,000W
10,800W
3,500 to 80%
4,000 to 80%
3,500 to 80%
Solar Input
2,400W
1,600W
2,600W
5,600W
Weight
132.3 lbs
99 lbs
113.5 lbs
70 lb inverter + 111.8 lb battery
Starting Price
~$3,799 to $3,999
~$2,799 list (frequent sales)
~$2,549 to $3,699
~$4,199 (inverter + 1 battery)
The F3800 outputs more continuous and surge Anker Solix F3800 power than both the DELTA Pro and DELTA Pro 3 individually, while the DELTA Pro Ultra surpasses it across output, solar input, and expansion capacity. For homeowners considering solar pairing, the Department of Energy's guide on solar and resilience basics explains how battery storage and solar panels work together during outages.
If you're looking for dependable backup power without spending at the top of the market, the EcoFlow DELTA Pro balances capacity and portability at a price point that works for most households.
EcoFlow DELTA Pro
1. 3,600Wh LFP capacity at 99 lbs, the lightest of EcoFlow's Pro-tier options 2. - Expandable up to 25kWh for larger backup needs - 3,600W AC output (7,200W with two units) 3. - 1,600W maximum solar input 4. - 3,500+ cycle life to 80% capacity 5. - A strong fit for buyers prioritizing portability and price over maximum output
For buyers who want solid backup without bulk, the DELTA Pro delivers where it counts.
When fast recharging and long battery life matter as much as raw output, the EcoFlow DELTA Pro 3 stands out as the most balanced option in the lineup.
EcoFlow DELTA Pro 3
1. 4,096Wh LFP capacity with 4,000W continuous output (6,000W with X-Boost) 2. - Recharges to 80% in approximately 50 minutes, the fastest of the three 3. - 2,600W maximum solar input for flexible charging 4. - 4,000+ cycle life to 80%, the longest in the lineup 5. - 113.5 lbs with 120/240V split-phase output 6. - The closest output match to the F3800 at a generally lower price
If you need Anker Solix F3800 power station-level performance with faster recharging and longer cycle life, the DELTA Pro 3 is worth a closer look.
For homeowners planning true whole-home backup that can scale well beyond a single unit, the EcoFlow DELTA Pro Ultra is built for that level of coverage.
1. 6,144Wh single-unit capacity with 7,200W continuous AC output 2. - Expandable up to 90kWh system-wide for true whole-home coverage 3. - 5,600W maximum solar input, the highest across all three options 4. - 10,800W surge output handles high-draw startup loads 5. - Modular inverter-plus-battery design (70 lb inverter, 111.8 lb battery) 6. - Built for whole-home-scale backup beyond what a single F3800 covers
If your goal is a backup system that grows with your household, the DELTA Pro Ultra is where that path starts.
What Reviewers Say About the Anker Solix F3800
Reading spec sheets is one thing. Hearing from people who've actually used a unit in their home or garage is another. If you're looking for Anker Solix F3800 reviews from independent testers, a few patterns come up consistently.
What Reviewers Say About the Anker Solix F3800What Reviewers Say About the Anker Solix F3800
Most Anker Solix Reviews describe the F3800 as a strong fit for buyers who want near-whole-home output without managing a full modular ecosystem. Reviewers frequently cite single-unit simplicity as a real plus versus multi-component systems, especially for homeowners wanting a no-frills setup.
Almost every review of the unit consistently points out the Anker Solix F3800's built-in EV charging port and dual-voltage output as standout features. For buyers who need both home backup and EV charging capability, the F3800 addresses both without requiring extra accessories.
The most common caveat across Anker Solix F3800 reviews is weight and footprint. Even with wheels, 132 lbs in a single unit creates a meaningfully different handling experience than lighter, modular alternatives. That's worth factoring in if you don't have flat, wheel-friendly access to the spot where you plan to keep the unit. FEMA's power outage preparedness guidance recommends choosing backup power options that fit your home's layout and available storage space, which is practical advice when you're deciding between a single large unit and a modular system.
Which EcoFlow Alternative Fits Your Situation Best
Choosing between these options depends less on which unit has the biggest numbers and more on how you actually plan to use backup power. Are you covering essentials during occasional outages, or building a system that scales with your household?
The DELTA Pro suits buyers who prioritize portability and price. The DELTA Pro 3 is the closest match to the Anker F3800 in power and speed, generally at a lower cost. The DELTA Pro Ultra is built for true whole-home backup that grows past what a single unit can cover. The EIA's data on residential electricity use can help you estimate how much capacity your household actually requires.
The Anker Solix F3800 is a 3,840Wh, 6,000W portable power station priced around $3,799 to $3,999, with strong continuous output and built-in EV charging balanced against its 132-lb weight; EcoFlow's DELTA Pro, DELTA Pro 3, and DELTA Pro Ultra each cover that same general range at different price, output, and expansion points, so the best choice comes down to matching the comparison to your actual use case rather than headline capacity alone: the DELTA Pro for price and portability, the DELTA Pro 3 for the closest power-and-speed match, and the DELTA Pro Ultra for true whole-home scaling.
What are the full specs of the Anker Solix F3800?
The Anker Solix F3800 specs include a 3,840Wh LFP battery, 6,000W continuous AC output with 120V/240V dual voltage, 9,000W surge output, up to 2,400W solar input, built-in NEMA 14-50 EV charging port, and a 5-year warranty. The unit weighs 132.3 lbs and expands up to 53.8kWh with additional batteries.
How much does the Anker Solix F3800 cost?
You'll usually find the Anker Solix F3800 priced between $3,799 and $3,999 from the major retailers. Solar panel or expansion battery kits are pricier. Anker doesn't always have a fixed list price on its own website, so the best way to see current pricing is to check retailer listings.
Is the Anker Solix F3800 good for whole-home backup?
Alone, the F3800 has a 6,000W output and 3,840Wh capacity, which means it can power most essentials during an outage. You may need expansion batteries for full whole-home coverage for extended periods of time. Its maximum capacity of 53.8kWh (with two units and twelve batteries) puts it in genuine whole-home territory when fully built out.
How does the Anker Solix F3800 compare to EcoFlow's DELTA Pro lineup?
The Anker Solix F3800 power station delivers more continuous output than the EcoFlow DELTA Pro and DELTA Pro 3 individually. However, the DELTA Pro 3 matches closely with overall performance at a generally lower price, and the DELTA Pro Ultra surpasses it in output, solar input, and expansion capacity (up to 90kWh).
Does the Anker Solix F3800 support EV charging?
Yup. The Anker Solix F3800 portable power station features a built-in NEMA 14-50 port that can output up to 6,000W for EV charging. This is an important difference to most power stations of this size, which usually need a separate adapter or accessory for charging EVs.
