Anker Solix F3800 Plus: Specs, Price, and How It Stacks Up
If you're shopping for a high-capacity portable power station, the naming alone can slow you down. The Anker Solix F3800 Plus shows up alongside the standard F3800 in search results, and the difference between the two is not obvious from the product names. This article breaks down the Anker Solix F3800 Plus specs, pricing, and expansion battery options in plain terms. It also compares the unit directly with the EcoFlow DELTA Pro 3 so you can see which setup fits your power needs.
What Is the Anker Solix F3800 Plus, and How Is It Different From the Standard F3800?
Most people searching for the F3800 don't even realize there's a "Plus" version until they're halfway through a product page. Fair enough. The two units share the same 3,840Wh LiFePO4 battery and the same 6,000W max AC output. Dimensions are nearly identical too. So why does the Plus cost more?
It comes down to how the unit handles solar. The Anker Solix F3800 Plus portable power station runs a dual 165V high-voltage solar configuration that pulls up to 3,200W. Compare that to the standard F3800's lower-voltage 60V MPPT setup, and you're looking at a real difference in how fast a large panel array can recharge the battery.
There's also a generator adapter port with a bypass function on the Plus that the base model doesn't have. If the power goes out for days, not hours, you can hook up a fuel generator to keep your essentials running while the Anker Solix F3800 Plus power station recharges in the background. FEMA's power outage preparedness guide actually recommends this kind of layered backup approach for households in storm-prone areas.
Here's where the two models split:
Spec | Anker Solix F3800 | Anker Solix F3800 Plus |
Capacity | 3,840Wh LiFePO4 | 3,840Wh LiFePO4 |
AC Output | 6,000W max | 6,000W max |
Solar Input | Up to 1,800W (60V MPPT) | Up to 3,200W (dual 165V) |
Generator Adapter Port | No | Yes (with bypass function) |
Weight | ~132 lbs | ~137 lbs |
That 5 lb difference? It's all charging hardware. Battery capacity is identical across both.
Anker Solix F3800 Plus Specs and Price
Now for the full picture. Here's everything published on the Anker Solix F3800 Plus specs:
Spec | Anker Solix F3800 Plus |
Capacity | 3,840Wh, LiFePO4 |
AC Output | 6,000W max, 120V/240V dual voltage |
Solar Input | Up to 3,200W (dual 165V) |
AC Charging Input | Up to 1,800W |
Generator/Home Panel Charging | Up to 6,000W |
Cycle Life | 3,000+ cycles to 80% |
Weight | 136.7 lbs |
Dimensions | 27.6 x 15.3 x 15.6 in |
Warranty | 5 years (10-year rated lifespan) |
Price | ~$2,799 (base unit) |
About that Anker Solix F3800 Plus price: $2,799 is what you'll typically see for the base unit, but don't treat that as gospel. Pricing on power stations this size bounces around with sales and bundles. One thing worth checking: the Residential Clean Energy Credit could knock a chunk off the final cost if your setup qualifies. ENERGY STAR's battery storage tax credit page has the full eligibility breakdown.
Also, that 6,000W generator charging input stands out. Most buyers won't need it for weekend camping, but if you're planning around multi-day outages, it's a big deal.
How Far the Expansion Battery Scales the System
3,840Wh on its own runs a decent number of appliances. But if you're thinking about whole-home backup or living off-grid, the real question is how far you can push the system with add-on batteries.
Each Anker Solix F3800 Plus expansion battery (the BP3800) adds another 3,840Wh. Stack up to six of them onto one F3800 Plus and you're looking at roughly 26.9kWh total. That's a lot of stored energy for a portable platform.
Here's the catch, though. Those expansion batteries can't run on their own. They only charge, discharge, and show up in the app when they're physically connected to the main unit. Some competing systems let each battery work independently, so this is worth thinking about if you want to split your storage across different locations.
How does that compare to EcoFlow's approach? The DELTA Pro 3 ecosystem tops out at 36kWh (48kWh max), charges faster from the wall, and each unit weighs 113.5 lbs instead of 137.
Anker Solix F3800 Plus vs EcoFlow DELTA Pro 3
With both systems' scaling paths laid out, here is how the two compare on the specs that matter most for a buying decision.
Spec | Anker Solix F3800 Plus | EcoFlow DELTA Pro 3 |
Capacity | 3,840Wh | 4,096Wh |
Continuous AC Output | 6,000W | 4,000W (6,000W with X-Boost) |
Solar Input | 3,200W | 2,600W |
AC Charging | 1,800W standard | 1,800W, 80% in ~50 min |
Weight | ~137 lbs | 113.5 lbs |
Max System Expansion | ~26.9kWh | Up to 36kWh (48kWh max) |
Price | ~$2,799 | ~$2,549 to $3,699 |
On raw Anker Solix F3800 Plus power and solar input, Anker wins. If you're running heavy appliances or want your panels to charge the battery as fast as possible, the numbers favor the F3800 Plus.
But the DELTA Pro 3 pulls ahead on expansion headroom and wall-charging speed, and it's noticeably easier to move around at 113.5 lbs. Both units use LiFePO4 chemistry, so cycle life and safety are comparable.
What do independent reviewers say? Most give the F3800 Plus the edge on raw output and Anker's customer support. The DELTA Pro 3 tends to score better on noise levels and long-term scalability. There's no clean winner across the board, which is exactly why it's worth matching specs to your actual household power needs rather than going off a single rating.
What Reviewers Say About the Anker Solix F3800 Plus
Across the Anker Solix F3800 Plus review sites we looked at, two things come up over and over: the solar input advantage and the generator-charging flexibility. Those are the features that separate the Plus from the standard F3800 and from most competitors at this price point.
Weight gets mentioned too. At close to 137 lbs, you're not casually carrying this between your truck and your campsite. It's a plant-it-and-leave-it kind of unit.
On the support side, Anker's customer service gets solid marks in most third-party comparisons. Individual experiences always vary, of course. The EPA's power resilience resources provide some helpful context for thinking about how any backup battery fits into your overall household preparedness plan.
Before committing, it's smart to compare Anker's warranty and support terms against what EcoFlow offers on the DELTA Pro 3. This roundup of solar generators for home backup is another good resource if you want to see how both stack up against the broader field.
The Anker Solix F3800 Plus separates itself from the base F3800 with a higher-voltage solar setup and generator-charging support, while keeping the same core battery and output specs. Against the EcoFlow DELTA Pro 3, it wins on raw output and solar wattage but trails on expansion ceiling, recharge speed, and weight. Pick the F3800 Plus if solar charging speed and peak output are your top priorities, or go with the DELTA Pro 3 if you want more room to grow the system and a lighter single unit.
What's the difference between the Anker Solix F3800 and F3800 Plus?
Both share the same 3,840Wh capacity and 6,000W output. The Plus version adds a dual 165V high-voltage solar configuration rated up to 3,200W and a generator adapter port with bypass function. Weight is slightly higher on the Plus at about 137 lbs versus 132 lbs on the standard model.
How much does the Anker Solix F3800 Plus cost?
The Anker Solix F3800 Plus price sits around $2,799 for the base unit right now. That number moves with promotions, so always check current listings before buying.
How much does the F3800 Plus expansion battery add to total capacity?
Each Anker Solix F3800 Plus expansion battery (BP3800) adds 3,840Wh. Connect all six and you hit roughly 26.9kWh total.
How does the Anker Solix F3800 Plus compare to the EcoFlow DELTA Pro 3?
The F3800 Plus puts out more continuous power (6,000W vs 4,000W) and accepts more solar (3,200W vs 2,600W). The DELTA Pro 3 holds more capacity per unit (4,096Wh), scales higher (up to 36kWh), recharges faster from the wall, and weighs about 23 lbs less.
Is the Anker Solix F3800 Plus good for solar charging?
Very. A 3,200W dual 165V input is one of the highest solar ratings you'll find on any portable power station right now. If you've got a big panel array or plan to build one, it's well suited. This guide to solar-powered portable power stations goes deeper on how input wattage shapes real-world charge times.
